[U-Boot] [PATCH 00/10] sunxi: Remove SYS_EXTRA_OPTIONS
Hello everyone,
This patchset removes the SYS_EXTRA_OPTIONS from all sunxi defconfigs. The values in this variable are converted to Kconfig or simply removed.
Based on u-boot sunxi repository: git://git.denx.de/u-boot-sunxi.git from last commit: 002d907da51fdf10a03d389852645675529c78e6
Patch 1: Convert SUNXI_GMAC config to Kconfig and remove it from all defconfig. Patch 2: Remove AXP209_POWER configuration as this config is already converted in Kconfig (drivers/power). It is automatically chosen when the SoC is sun4i, sun5i or sun7i. Patch 3 and 4: Remove CMD_BMP and CMD_ZIP configs from SYS_EXTRA_OPTIONS. Patch 5: Remove SYS_EXTRA_OPTIONS from mk802_defconfig as it contains only USB_EHCI which is already converted to Kconfig. Patch 6, 7: Convert SUNXI_EMAC and CONFIG_RGMII to Kconfig and remove it from all SYS_EXTRA_OPTIONS entries. Patch 8 and 9: Convert CONFIG_SATAPWR and CONFIG_MACPWR to Kconfig. It becomes a string instead of the gpio number so the function sunxi_name_to_gpio is used to do the conversion from string to int. Patch 10: Convert console index (CONS_INDEX) to Kconfig. The default value is 1 except for sun5i which is 2 and sun8i which is 5.
Thank you in advance! Best regards,
Mylène Josserand (10): sunxi: Convert SUNXI_GMAC to Kconfig sunxi: icnova-a20-swac_defconfig: Remove AXP209_POWER from SYS_EXTRA_OPTIONS sunxi: icnova-a20-swac_defconfig: Remove CMD_BMP from SYS_EXTRA_OPTIONS sunxi: icnova-a20-swac_defconfig: Remove CMD_UNZIP and SYS_EXTRA_OPTIONS sunxi: mk802_defconfig: Remove SYS_EXTRA_OPTIONS sunxi: Convert SUNXI_EMAC to Kconfig sunxi: Convert CONFIG_RGMII to Kconfig sunxi: Convert CONFIG_SATAPWR to Kconfig sunxi: Convert CONFIG_MACPWR to Kconfig sunxi: Convert CONS_INDEX to Kconfig
board/sunxi/Kconfig | 36 ++++++++++++++++++++++++++++++ board/sunxi/board.c | 12 +++++----- configs/A10-OLinuXino-Lime_defconfig | 3 ++- configs/A10s-OLinuXino-M_defconfig | 2 +- configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 4 +++- configs/A20-OLinuXino-Lime_defconfig | 3 ++- configs/A20-OLinuXino_MICRO_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 4 +++- configs/Ampe_A76_defconfig | 1 - configs/Bananapi_defconfig | 4 +++- configs/Bananapro_defconfig | 4 +++- configs/CHIP_defconfig | 1 - configs/CSQ_CS908_defconfig | 2 +- configs/Colombus_defconfig | 3 ++- configs/Cubieboard2_defconfig | 3 ++- configs/Cubieboard_defconfig | 3 ++- configs/Cubietruck_defconfig | 4 +++- configs/Empire_electronix_d709_defconfig | 1 - configs/Empire_electronix_m712_defconfig | 1 - configs/Hummingbird_A31_defconfig | 3 ++- configs/Itead_Ibox_A20_defconfig | 3 ++- configs/Lamobo_R1_defconfig | 5 ++++- configs/Linksprite_pcDuino3_Nano_defconfig | 4 +++- configs/Linksprite_pcDuino3_defconfig | 3 ++- configs/Linksprite_pcDuino_defconfig | 2 +- configs/Marsboard_A10_defconfig | 2 +- configs/Mele_A1000G_quad_defconfig | 2 +- configs/Mele_A1000_defconfig | 3 ++- configs/Mele_I7_defconfig | 2 +- configs/Mele_M3_defconfig | 2 +- configs/Mele_M5_defconfig | 2 +- configs/Mele_M9_defconfig | 2 +- configs/Orangepi_defconfig | 4 +++- configs/Orangepi_mini_defconfig | 4 +++- configs/Sinlinx_SinA31s_defconfig | 2 +- configs/Sinovoip_BPI_M2_defconfig | 3 ++- configs/Sinovoip_BPI_M3_defconfig | 2 +- configs/Wits_Pro_A20_DKT_defconfig | 3 ++- configs/ba10_tv_box_defconfig | 2 +- configs/difrnce_dit4350_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/i12-tvbox_defconfig | 3 ++- configs/iNet_D978_rev2_defconfig | 1 - configs/icnova-a20-swac_defconfig | 2 +- configs/inet86dz_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/jesurun_q5_defconfig | 3 ++- configs/mixtile_loftq_defconfig | 4 +++- configs/mk802_defconfig | 1 - configs/orangepi_plus2e_defconfig | 2 +- configs/orangepi_plus_defconfig | 3 ++- configs/polaroid_mid2407pxe03_defconfig | 1 - configs/polaroid_mid2809pxe04_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - drivers/net/Kconfig | 6 +++++ 61 files changed, 124 insertions(+), 63 deletions(-)
Move the SUNXI_GMAC config option to Kconfig and remove it from SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- board/sunxi/Kconfig | 5 +++++ configs/A20-OLinuXino-Lime2_defconfig | 3 ++- configs/A20-OLinuXino-Lime_defconfig | 3 ++- configs/A20-OLinuXino_MICRO_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 3 ++- configs/Bananapi_defconfig | 3 ++- configs/Bananapro_defconfig | 3 ++- configs/CSQ_CS908_defconfig | 2 +- configs/Colombus_defconfig | 3 ++- configs/Cubieboard2_defconfig | 3 ++- configs/Cubietruck_defconfig | 3 ++- configs/Hummingbird_A31_defconfig | 3 ++- configs/Itead_Ibox_A20_defconfig | 3 ++- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 3 ++- configs/Linksprite_pcDuino3_defconfig | 3 ++- configs/Mele_A1000G_quad_defconfig | 2 +- configs/Mele_I7_defconfig | 2 +- configs/Mele_M3_defconfig | 2 +- configs/Mele_M5_defconfig | 2 +- configs/Mele_M9_defconfig | 2 +- configs/Orangepi_defconfig | 3 ++- configs/Orangepi_mini_defconfig | 3 ++- configs/Sinlinx_SinA31s_defconfig | 2 +- configs/Sinovoip_BPI_M2_defconfig | 3 ++- configs/Wits_Pro_A20_DKT_defconfig | 3 ++- configs/i12-tvbox_defconfig | 3 ++- configs/icnova-a20-swac_defconfig | 3 ++- configs/mixtile_loftq_defconfig | 3 ++- 29 files changed, 54 insertions(+), 28 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 00011331b9..ff11b98ddb 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -683,6 +683,11 @@ config VIDEO_LCD_TL059WV5C0
endchoice
+config SUNXI_GMAC + bool "Enable GMAC Ethernet support" + default n + ---help--- + Enable the support for the GMAC Ethernet controller
config GMAC_TX_DELAY int "GMAC Transmit Clock Delay Chain" diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 8fd7c64e77..47a876082a 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -6,10 +6,11 @@ CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 26e6ace103..e84f1c760a 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -4,10 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index d629eb1b36..b08708a9b9 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -7,10 +7,11 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_VIDEO_VGA=y +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index b5d52dba24..dd7b1ac3e9 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -9,10 +9,11 @@ CONFIG_MMC3_PINS="PH" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 0f2ef1b7ed..c6a9e88351 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -4,11 +4,12 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index e3bb4b20d5..596eb2dd7a 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -6,11 +6,12 @@ CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="PH0" CONFIG_USB2_VBUS_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 448ce951a0..b3a292f9fe 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -4,9 +4,9 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index d8272c5dcf..f9919558d4 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -14,9 +14,10 @@ CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_I2C_SDA="PA23" CONFIG_VIDEO_LCD_PANEL_I2C_SCL="PA24" CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index dfeb66c9fb..bedef4933b 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -4,10 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 10f3237cd5..7d0adc061a 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -8,11 +8,12 @@ CONFIG_USB0_VBUS_PIN="PH17" CONFIG_USB0_VBUS_DET="PH22" CONFIG_USB0_ID_DET="PH19" CONFIG_VIDEO_VGA=y +CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPH(12)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index dc4133d081..189d680320 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -6,9 +6,10 @@ CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index baca3e84cc..51cd318992 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -4,10 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 6fe79e2a6e..bdb13ca2d9 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -4,11 +4,12 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH10" +CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 622d35c70b..8cb57b83ba 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -5,11 +5,12 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=122 CONFIG_USB1_VBUS_PIN="PH11" +CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 9d2dfa5a7c..b73e85ce1b 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -4,10 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=122 +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index 4097e5bbe0..7325b1d222 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -5,9 +5,9 @@ CONFIG_DRAM_ZQ=120 CONFIG_INITIAL_USB_SCAN_DELAY=2000 CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index eb3c74c55d..a6d9e4ae39 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -4,9 +4,9 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=120 CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 037e768c64..c0df3958aa 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -7,9 +7,9 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index e64e45257b..c65bc1a6cf 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -6,10 +6,10 @@ CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=122 CONFIG_MMC0_CD_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index c4e599351f..59605286a4 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -4,9 +4,9 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=120 CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index ccece01029..edda06803c 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -7,11 +7,12 @@ CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index febdcd07ad..8e77107ac2 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -9,11 +9,12 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 9ac89121bc..f1c4e627d9 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -8,9 +8,9 @@ CONFIG_MMC3_PINS="PC" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 267aaf8ad1..95f3ff145b 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -4,9 +4,10 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 0735055622..b7bd7a1bcd 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -9,10 +9,11 @@ CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 8012c078fb..601c37d9ce 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -4,9 +4,10 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,MACPWR=SUNXI_GPH(21)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 78cc3bb972..85c4806a87 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -11,9 +11,10 @@ CONFIG_USB1_VBUS_PIN="PG10" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH22" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP,CMD_UNZIP" +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,CMD_BMP,CMD_UNZIP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 8ca8467a4e..11772b949d 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -5,9 +5,10 @@ CONFIG_DRAM_ZQ=251 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPA(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
endchoice
+config SUNXI_GMAC
This would be better in drivers/net. And it would be great if you could also rename it in the process for SUN7I_GMAC, to be able to distinguish the various generations of ethernet controller we had.
Looks good otherwise Thanks!
Remove the AXP209_POWER option from SYS_EXTRA_OPTIONS. As this configuration already exists on Kconfig, we just need to remove it from defconfig.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- configs/icnova-a20-swac_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 85c4806a87..84ca843f1f 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -14,7 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,CMD_BMP,CMD_UNZIP" +CONFIG_SYS_EXTRA_OPTIONS="CMD_BMP,CMD_UNZIP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com Thanks! Maxime
This configuration is not necessary in a defconfig file so it is removed from the SYS_EXTRA_OPTIONS.
diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 84ca843f1f..ccd4429d35 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -14,7 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CMD_BMP,CMD_UNZIP" +CONFIG_SYS_EXTRA_OPTIONS="CMD_UNZIP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
Thanks! Maxime
Remove this command as it is not necessary in defconfig file. As there is no more command/option in SYS_EXTRA_OPTIONS, it can be removed from this defconfig file.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- configs/icnova-a20-swac_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index ccd4429d35..0bc2fbecfd 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -14,7 +14,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CMD_UNZIP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
Thanks! Maxime
The USB_EHCI configuration is already set in this defconfig using kconfig's config. This configuration in SYS_EXTRA_OPTIONS must be removed and so the SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- configs/mk802_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 47bbf62274..2f63320fb9 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -4,7 +4,6 @@ CONFIG_MACH_SUN4I=y CONFIG_USB2_VBUS_PIN="PH12" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
Convert the SUNXI_EMAC config to Kconfig. Remove it from SYS_EXTRA_OPTIONS from many sunxi defconfig.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- configs/A10-OLinuXino-Lime_defconfig | 3 ++- configs/A10s-OLinuXino-M_defconfig | 2 +- configs/Cubieboard_defconfig | 3 ++- configs/Linksprite_pcDuino_defconfig | 2 +- configs/Marsboard_A10_defconfig | 2 +- configs/Mele_A1000_defconfig | 3 ++- configs/ba10_tv_box_defconfig | 2 +- configs/jesurun_q5_defconfig | 3 ++- drivers/net/Kconfig | 6 ++++++ 9 files changed, 18 insertions(+), 8 deletions(-)
diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 50436a7a52..74f6fc2d76 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -9,11 +9,12 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUNXI_EMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index e2bebf827c..3f766244ee 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -9,10 +9,10 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=1 CONFIG_USB1_VBUS_PIN="PB10" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUNXI_EMAC=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 64aebed2f1..2c16b0fc72 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -7,9 +7,10 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUNXI_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index ab094a6553..93a99af917 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -6,9 +6,9 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUNXI_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 0d381ff1b8..a1ddae76e0 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -4,10 +4,10 @@ CONFIG_MACH_SUN4I=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUNXI_EMAC=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 820d5ed98e..1ff4364cd5 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -7,9 +7,10 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(15)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUNXI_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index c60766ce3c..7570cf3457 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -9,10 +9,10 @@ CONFIG_USB2_VBUS_PIN="PH12" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-ba10-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUNXI_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 6e4e6ca235..988a15f348 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -7,10 +7,11 @@ CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(19)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(19)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUNXI_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 929b9e273e..b58e78c744 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -175,6 +175,12 @@ config RTL8169 This driver supports Realtek 8169 series gigabit ethernet family of PCI/PCIe chipsets/adapters.
+config SUNXI_EMAC + bool "Allwinner Ethernet MAC support" + depends on DM_ETH + help + This driver supports the general Allwinner Ethernet MAC. + config SUN8I_EMAC bool "Allwinner Sun8i Ethernet MAC support" depends on DM_ETH
On Thu, Feb 23, 2017 at 04:44:15PM +0100, Mylène Josserand wrote:
+config SUNXI_EMAC
depends on DM_ETH
help
This would be great to rename it as well to SUN4I_EMAC to avoid introducing confusion with SUN8I_EMAC
Thanks! Maxime
On Fri, Feb 24, 2017 at 12:16 AM, Maxime Ripard maxime.ripard@free-electrons.com wrote:
+config SUNXI_EMAC
depends on DM_ETH
help
Tom has sent similar patch before, [1]
[1] http://patchwork.ozlabs.org/patch/730006/
thanks!
Convert CONFIG_RGMII to Kconfig. Thanks to that, it is possible to update defconfig files of SYS_EXTRA_OPTIONS accordingly and remove it when it is possible.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- board/sunxi/Kconfig | 7 +++++++ configs/A20-OLinuXino-Lime2_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 3 ++- configs/Bananapi_defconfig | 3 ++- configs/Bananapro_defconfig | 3 ++- configs/Colombus_defconfig | 2 +- configs/Cubietruck_defconfig | 3 ++- configs/Hummingbird_A31_defconfig | 2 +- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 3 ++- configs/Orangepi_defconfig | 3 ++- configs/Orangepi_mini_defconfig | 3 ++- configs/Sinovoip_BPI_M2_defconfig | 2 +- configs/Wits_Pro_A20_DKT_defconfig | 2 +- configs/mixtile_loftq_defconfig | 3 ++- 15 files changed, 31 insertions(+), 14 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index ff11b98ddb..a51066f7c6 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -385,6 +385,13 @@ config INITIAL_USB_SCAN_DELAY option to a non 0 value to add an extra delay before the first usb bus scan.
+config RGMII + bool "Enable RGMII" + default n + ---help--- + Enable the support of the Reduced Gigabit Media-Independent + Interface (RGMII). + config USB0_VBUS_PIN string "Vbus enable pin for usb0 (otg)" default "" diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 47a876082a..40468f1394 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -4,13 +4,14 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index dd7b1ac3e9..03f99809ef 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -7,13 +7,14 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH0" CONFIG_MMC3_PINS="PH" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index c6a9e88351..8751875d03 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -3,13 +3,14 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_RGMII=y CONFIG_VIDEO_COMPOSITE=y CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 596eb2dd7a..e70dbb8730 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH0" CONFIG_USB2_VBUS_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y @@ -11,7 +12,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index f9919558d4..6055a0d319 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=240 CONFIG_DRAM_ZQ=251 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="" CONFIG_I2C0_ENABLE=y CONFIG_AXP_GPIO=y @@ -17,7 +18,6 @@ CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 7d0adc061a..5575130aa5 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PH17" CONFIG_USB0_VBUS_DET="PH22" CONFIG_USB0_ID_DET="PH19" @@ -13,7 +14,7 @@ CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(12)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 189d680320..519357dd54 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=251 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_VIDEO_VGA_VIA_LCD=y @@ -9,7 +10,6 @@ CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index bdb13ca2d9..04cbd59b82 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -4,12 +4,13 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH10" +CONFIG_RGMII=y CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 8cb57b83ba..2d547099a9 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -4,13 +4,14 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=122 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH11" CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index edda06803c..195d451c57 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_VGA=y @@ -12,7 +13,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 8e77107ac2..80bffbbbca 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH10" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_COMPOSITE=y @@ -14,7 +15,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 95f3ff145b..3af699873a 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index b7bd7a1bcd..8d1e1ce3d3 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 +CONFIG_RGMII=y CONFIG_VIDEO_VGA=y CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:24,pclk_khz:65000,le:159,ri:160,up:22,lo:15,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH8" @@ -13,7 +14,6 @@ CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 11772b949d..a72dfaab35 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -3,12 +3,13 @@ CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=251 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPA(21)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPA(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
+config RGMII
- bool "Enable RGMII"
This should be in drivers/net too
- default n
And this is already the default.
Thanks! Maxime
Hello,
I'm not familiar with how Allwinner platforms are handled in U-Boot, but I have a question for the following patches:
[PATCH 07/10] sunxi: Convert CONFIG_RGMII to Kconfig [PATCH 08/10] sunxi: Convert CONFIG_SATAPWR to Kconfig [PATCH 09/10] sunxi: Convert CONFIG_MACPWR to Kconfig [PATCH 10/10] sunxi: Convert CONS_INDEX to Kconfig
To me, all these details are hardware specific details that are given in the Device Tree. For example, RGMII is given in:
&gmac { pinctrl-names = "default"; pinctrl-0 = <&gmac_pins_rgmii_a>; phy = <&phy1>; phy-mode = "rgmii"; status = "okay";
phy1: ethernet-phy@1 { reg = <1>; }; };
The SATA power GPIO is given by:
®_ahci_5v { pinctrl-0 = <&ahci_pwr_pin_olinuxinolime>; gpio = <&pio 2 3 GPIO_ACTIVE_HIGH>; status = "okay"; };
The MAC power GPIO is given by:
reg_gmac_3v3: gmac-3v3 { compatible = "regulator-fixed"; pinctrl-names = "default"; pinctrl-0 = <&gmac_power_pin_bananapi>; regulator-name = "gmac-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; startup-delay-us = <100000>; enable-active-high; gpio = <&pio 7 23 GPIO_ACTIVE_HIGH>; };
So it seems weird to encode it in the defconfig if the information is already available in the Device Tree.
In addition, the option names are very generic: CONFIG_SATAPWR, CONFIG_MACPWR, even though they are completely sunxi specific. So if those options really need to exist, should be they named CONFIG_SUNXI_SATAPWR, CONFIG_SUNXI_MACPWR ?
Thanks,
Thomas
Hi Thomas,
On Mon, Feb 27, 2017 at 02:59:46PM +0100, Thomas Petazzoni wrote:
Hello,
You make some pretty good points, and I definitely agree with you on these changes.
However, there is also a plan to remove CONFIG_SYS_EXTRA_OPTIONS, and all the defconfig using it, in a very near future, hence why we did this serie.
We should definitely address the changes you pointed at, but I really don't want to hold back the changes Mylene did. But she is also very welcome to fix those issues later :)
Maxime
Convert the CONFIG_SATAPWR into kconfig. Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some defconfigs.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- board/sunxi/Kconfig | 8 ++++++++ board/sunxi/board.c | 7 ++++--- configs/A10-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino-Lime2_defconfig | 2 +- configs/A20-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino_MICRO_defconfig | 2 +- configs/A20-Olimex-SOM-EVB_defconfig | 2 +- configs/Cubieboard2_defconfig | 2 +- configs/Cubieboard_defconfig | 2 +- configs/Cubietruck_defconfig | 2 +- configs/Itead_Ibox_A20_defconfig | 2 +- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 2 +- configs/Linksprite_pcDuino3_defconfig | 2 +- configs/Sinovoip_BPI_M3_defconfig | 2 +- configs/orangepi_plus_defconfig | 3 ++- 16 files changed, 28 insertions(+), 17 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index a51066f7c6..0ba8e86f05 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -690,6 +690,14 @@ config VIDEO_LCD_TL059WV5C0
endchoice
+config SATAPWR + string "SATA power pin" + default "" + ---help--- + Set the pins used to power the SATA. This takes a string in the + format understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of + port H. + config SUNXI_GMAC bool "Enable GMAC Ethernet support" default n diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 53656383d5..131986bd17 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -80,7 +80,7 @@ DECLARE_GLOBAL_DATA_PTR; /* add board specific code here */ int board_init(void) { - __maybe_unused int id_pfr1, ret; + __maybe_unused int id_pfr1, ret, satapwr_pin;
gd->bd->bi_boot_params = (PHYS_SDRAM_0 + 0x100);
@@ -118,8 +118,9 @@ int board_init(void) return ret;
#ifdef CONFIG_SATAPWR - gpio_request(CONFIG_SATAPWR, "satapwr"); - gpio_direction_output(CONFIG_SATAPWR, 1); + satapwr_pin = sunxi_name_to_gpio(CONFIG_SATAPWR); + gpio_request(satapwr_pin, "satapwr"); + gpio_direction_output(satapwr_pin, 1); #endif #ifdef CONFIG_MACPWR gpio_request(CONFIG_MACPWR, "macpwr"); diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 74f6fc2d76..8404d0f3dd 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -6,10 +6,10 @@ CONFIG_DRAM_CLK=480 CONFIG_DRAM_EMR1=4 CONFIG_SYS_CLK_FREQ=912000000 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PC3" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 40468f1394..92d15f7a35 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -7,11 +7,11 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SATAPWR="PC3" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index e84f1c760a..aa14c7232b 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -4,11 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PC3" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index b08708a9b9..7f78a3f625 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -7,11 +7,11 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_VIDEO_VGA=y +CONFIG_SATAPWR="PC3" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 03f99809ef..4524959320 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -10,11 +10,11 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SATAPWR="PC3" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index bedef4933b..38040a5f31 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -4,11 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PB8" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 2c16b0fc72..e1cf5783fd 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -4,10 +4,10 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PB8" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 5575130aa5..2edebb8294 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -9,12 +9,12 @@ CONFIG_USB0_VBUS_PIN="PH17" CONFIG_USB0_VBUS_DET="PH22" CONFIG_USB0_ID_DET="PH19" CONFIG_VIDEO_VGA=y +CONFIG_SATAPWR="PH12" CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 51cd318992..857153883b 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -4,11 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PB8" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 04cbd59b82..3029dc0ee0 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -5,12 +5,13 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH10" CONFIG_RGMII=y +CONFIG_SATAPWR="PB3" CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 2d547099a9..7c26eddddc 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -6,12 +6,12 @@ CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=122 CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH11" +CONFIG_SATAPWR="PH2" CONFIG_SUNXI_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index b73e85ce1b..60d6a74db2 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -4,11 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=122 +CONFIG_SATAPWR="PH2" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index d15ac2000b..80b5a7a647 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -11,9 +11,9 @@ CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_USB0_ID_DET="PH11" CONFIG_USB1_VBUS_PIN="PD24" CONFIG_AXP_GPIO=y +CONFIG_SATAPWR="PD25" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinovoip-bpi-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPD(25)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index bf88fef3b8..9729580c96 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -7,9 +7,10 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PG13" +CONFIG_SATAPWR="PG11" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPG(11),MACPWR=SUNXI_GPD(6)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set
Convert the CONFIG_MACPWR to Kconfig and update all the sunxi defconfigs that used it in SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- board/sunxi/Kconfig | 7 +++++++ board/sunxi/board.c | 7 ++++--- configs/Bananapi_defconfig | 2 +- configs/Bananapro_defconfig | 2 +- configs/Lamobo_R1_defconfig | 2 +- configs/Mele_A1000_defconfig | 2 +- configs/Orangepi_defconfig | 2 +- configs/Orangepi_mini_defconfig | 2 +- configs/i12-tvbox_defconfig | 2 +- configs/jesurun_q5_defconfig | 2 +- configs/mixtile_loftq_defconfig | 2 +- configs/orangepi_plus2e_defconfig | 2 +- configs/orangepi_plus_defconfig | 2 +- 13 files changed, 22 insertions(+), 14 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 0ba8e86f05..492bf14ae1 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -318,6 +318,13 @@ config OLD_SUNXI_KERNEL_COMPAT Set this to enable various workarounds for old kernels, this results in sub-optimal settings for newer kernels, only enable if needed.
+config MACPWR + string "MAC power pin" + default "" + ---help--- + Set the pin used to power the MAC. This takes a string in the format + understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of port H. + config MMC depends on !UART0_PORT_F default y if ARCH_SUNXI diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 131986bd17..906a06d0d9 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -80,7 +80,7 @@ DECLARE_GLOBAL_DATA_PTR; /* add board specific code here */ int board_init(void) { - __maybe_unused int id_pfr1, ret, satapwr_pin; + __maybe_unused int id_pfr1, ret, satapwr_pin, macpwr_pin;
@@ -123,8 +123,9 @@ int board_init(void) gpio_direction_output(satapwr_pin, 1); #endif #ifdef CONFIG_MACPWR - gpio_request(CONFIG_MACPWR, "macpwr"); - gpio_direction_output(CONFIG_MACPWR, 1); + macpwr_pin = sunxi_name_to_gpio(CONFIG_MACPWR); + gpio_request(macpwr_pin, "macpwr"); + gpio_direction_output(macpwr_pin, 1); #endif
/* Uses dm gpio code so do this here and not in i2c_init_board() */ diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 8751875d03..311cfdc2df 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_RGMII=y CONFIG_VIDEO_COMPOSITE=y CONFIG_SUNXI_GMAC=y @@ -10,7 +11,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index e70dbb8730..26f920c86a 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH0" CONFIG_USB2_VBUS_PIN="PH1" @@ -12,7 +13,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 3029dc0ee0..c79b5c9d6d 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_MMC0_CD_PIN="PH10" CONFIG_RGMII=y CONFIG_SATAPWR="PB3" @@ -11,7 +12,6 @@ CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 1ff4364cd5..cde760051e 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y +CONFIG_MACPWR="PH15" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(15)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 195d451c57..44e2c0867d 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" @@ -13,7 +14,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 80bffbbbca..18556a7972 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_MMC0_CD_PIN="PH10" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 @@ -15,7 +16,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 601c37d9ce..80472bc400 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -3,11 +3,11 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 +CONFIG_MACPWR="PH21" CONFIG_VIDEO_COMPOSITE=y CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 988a15f348..c47617908c 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -3,11 +3,11 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=312 +CONFIG_MACPWR="PH19" CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(19)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index a72dfaab35..7c774d4f9c 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=251 +CONFIG_MACPWR="PA21" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH24" @@ -9,7 +10,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_SUNXI_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPA(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index df05d370e4..4f1336d211 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -5,10 +5,10 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus2e" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 9729580c96..b765459d07 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -5,12 +5,12 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PG13" CONFIG_SATAPWR="PG11" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set
Thanks! Maxime
Convert the CONS_INDEX configuration to Kconfig. Update sunxi's defconfigs to remove SYS_EXTRA_OPTIONS variable not needed anymore. Default value is 1 except for sun5i (equals 2) and sun8i (equals 5).
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- board/sunxi/Kconfig | 9 +++++++++ configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/CHIP_defconfig | 1 - configs/Empire_electronix_d709_defconfig | 1 - configs/Empire_electronix_m712_defconfig | 1 - configs/difrnce_dit4350_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/iNet_D978_rev2_defconfig | 1 - configs/inet86dz_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/polaroid_mid2407pxe03_defconfig | 1 - configs/polaroid_mid2809pxe04_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - 19 files changed, 9 insertions(+), 18 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 492bf14ae1..6a70ee26b3 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -157,6 +157,15 @@ config ARM_BOOT_HOOK_RMR This allows both the SPL and the U-Boot proper to be entered in either mode and switch to AArch64 if needed.
+config CONS_INDEX + int "UART used for console" + default 2 if MACH_SUN5I + default 5 if MACH_SUN8I + default 1 + ---help--- + Configures the console index for Allwinner SoC. 2 for SUN5I, 5 for SUN8I + and 1 otherwise. + config DRAM_TYPE int "sunxi dram type" depends on MACH_SUN8I_A83T diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index 361d90a701..1dbd671d01 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -12,7 +12,6 @@ CONFIG_VIDEO_LCD_POWER="PB10" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 3191098bf1..6aec11d594 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 5020724aa8..59a66c1b9d 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 65d0c9847a..080f4718b2 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -8,7 +8,6 @@ CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y CONFIG_USB0_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_DFU=y diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 831949a08b..756636d41e 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-d709" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index 4b51380fc0..22d43785be 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-m712" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index 6149c94ff4..a04b876266 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-difrnce-dit4350" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 02a8a78db5..ded42cd6c5 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index 913a7638f8..930a4e6011 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-gt90h-v4" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index d5e63095ab..8437c7b8c2 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-inet-d978-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index 4ed94dc1e3..28a8a4edf5 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-inet86dz" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index 7c306f8b59..b6502f1bc6 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 2ac6f4ccac..f88a0bedd0 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2407pxe03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index d9bcd4f554..c98d66235a 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2809pxe04" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 6b516db4b8..6d4889f9d9 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 971dcea1c8..c3eae9dd74 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index f99e347e43..8140d4fa1a 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index 182bd9acf3..7ba8fbb196 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
+config CONS_INDEX
- int "UART used for console"
- default 2 if MACH_SUN5I
- default 5 if MACH_SUN8I
- default 1
- ---help---
- Configures the console index for Allwinner SoC. 2 for SUN5I, 5 for SUN8I
- and 1 otherwise.
There's still a definition in sunxi-common.h that would be worth removing.
Thanks! Maxime
Jagan Teki
Maxime Ripard
Mylène Josserand
Thomas Petazzoni
