[PATCH] rockchip: ram: fix debug funcfion define when RAM_ROCKCHIP_DEBUG not set
The empty function define should not be in the header file, or else the build will error with function multi definition after CONFIG_RAM_ROCKCHIP_DEBUG is disabled.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/include/asm/arch-rockchip/sdram_common.h | 15 --------------- drivers/ram/rockchip/sdram_common.c | 13 +++++++++++++ 2 files changed, 13 insertions(+), 15 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 36d31156be..5efa6e9445 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -114,25 +114,10 @@ struct sdram_base_params { #define SYS_REG_ENC_CS1_COL(n, ch) (((n) - 9) << (0 + 2 * (ch))) #define SYS_REG_DEC_CS1_COL(n, ch) (9 + (((n) >> (0 + 2 * (ch))) & 0x3))
-#if !defined(CONFIG_RAM_ROCKCHIP_DEBUG) -inline void sdram_print_dram_type(unsigned char dramtype) -{ -} - -inline void sdram_print_ddr_info(struct sdram_cap_info *cap_info, - struct sdram_base_params *base) -{ -} - -inline void sdram_print_stride(unsigned int stride) -{ -} -#else void sdram_print_dram_type(unsigned char dramtype); void sdram_print_ddr_info(struct sdram_cap_info *cap_info, struct sdram_base_params *base); void sdram_print_stride(unsigned int stride); -#endif /* CONFIG_RAM_ROCKCHIP_DEBUG */
void sdram_org_config(struct sdram_cap_info *cap_info, struct sdram_base_params *base, diff --git a/drivers/ram/rockchip/sdram_common.c b/drivers/ram/rockchip/sdram_common.c index 6bc51572b2..b3e7421d08 100644 --- a/drivers/ram/rockchip/sdram_common.c +++ b/drivers/ram/rockchip/sdram_common.c @@ -117,6 +117,19 @@ void sdram_print_stride(unsigned int stride) printf("no stride\n"); } } +#else +inline void sdram_print_dram_type(unsigned char dramtype) +{ +} + +inline void sdram_print_ddr_info(struct sdram_cap_info *cap_info, + struct sdram_base_params *base) +{ +} + +inline void sdram_print_stride(unsigned int stride) +{ +} #endif
Hi Kever,
Any specific reason why? usually, it has in the header in most of the code in the tree.
Does it because of the v5.7-rc5 compiler sync patch.
[PATCH 07/10] compiler*.h: sync include/linux/compiler*.h with Linux 5.7-rc5
Jagan.
-- Jagan Teki, Amarula Solutions India Pvt. Ltd. Co-Founder & Embedded Linux Architect 405/E-Block, Sri Lakshmi Shubham Arcade, Chandanagar, Hyderabad - 500050, India M. (+91) 910 009 0959 [`as] http://www.amarulasolutions.com
Jagan Teki
Kever Yang
