[U-Boot] [PATCH] Revert "arm: config: fix default console only to specify the device"
This reverts commit 232ed3ca534708527a9515c7c41bc3542949525c.
In exynos boards, ${console} is used to set bootargs but it sets without "console=", so CONFIG_DEFAULT_CONSOLE for these boards is designated with "console=" but it is removed. So revert the commit.
References for using ${console} in board/samsung/common/bootscripts/autoboot.cmd board/samsung/common/bootscripts/bootzimg.cmd
Signed-off-by: Seung-Woo Kim sw0312.kim@samsung.com --- include/configs/odroid.h | 4 ++-- include/configs/odroid_xu3.h | 4 ++-- include/configs/s5p_goni.h | 4 ++-- include/configs/s5pc210_universal.h | 4 ++-- include/configs/trats.h | 4 ++-- include/configs/trats2.h | 4 ++-- 6 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/include/configs/odroid.h b/include/configs/odroid.h index ad77242e38..c3520bb15f 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -40,7 +40,7 @@ /* Console configuration */
#define CONFIG_BOOTCOMMAND "run distro_bootcmd ; run autoboot" -#define CONFIG_DEFAULT_CONSOLE "ttySAC1,115200n8" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - GENERATED_GBL_DATA_SIZE) @@ -157,7 +157,7 @@ "elif test -e mmc 0 uImage; then; " \ "run boot_uimg;" \ "fi;\0" \ - "console=" CONFIG_DEFAULT_CONSOLE "\0" \ + "console=" CONFIG_DEFAULT_CONSOLE \ "mmcbootdev=0\0" \ "mmcbootpart=1\0" \ "mmcrootdev=0\0" \ diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index f683ee46e3..3b9a945e7c 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -30,7 +30,7 @@
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000)
-#define CONFIG_DEFAULT_CONSOLE "ttySAC2,115200n8" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0"
/* USB */ #define CONFIG_USB_EHCI_EXYNOS @@ -99,7 +99,7 @@ MEM_LAYOUT_ENV_SETTINGS \ BOOTENV \ "rootfstype=ext4\0" \ - "console=" CONFIG_DEFAULT_CONSOLE "\0"\ + "console=" CONFIG_DEFAULT_CONSOLE \ "fdtfile=exynos5422-odroidxu3.dtb\0" \ "boardname=odroidxu3\0" \ "mmcbootdev=0\0" \ diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 87ddc20a52..ff634d91dd 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -87,7 +87,7 @@
#define CONFIG_BOOTCOMMAND "run mmcboot"
#define CONFIG_RAMDISK_BOOT "root=/dev/ram0 rw rootfstype=ext4" \ " ${console} ${meminfo}" @@ -134,7 +134,7 @@ "bootchart=set opts init=/sbin/bootchartd; run bootcmd\0" \ "verify=n\0" \ "rootfstype=ext4\0" \ - "console=" CONFIG_DEFAULT_CONSOLE "\0"\ + "console=" CONFIG_DEFAULT_CONSOLE \ "meminfo=mem=80M mem=256M@0x40000000 mem=128M@0x50000000\0" \ "loaduimage=ext4load mmc ${mmcdev}:${mmcbootpart} 0x30007FC0 uImage\0" \ "mmcdev=0\0" \ diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 999bdd1676..832032da18 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -27,7 +27,7 @@ /* Console configuration */
#define CONFIG_BOOTCOMMAND "run mmcboot" -#define CONFIG_DEFAULT_CONSOLE "ttySAC1,115200n8" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - GENERATED_GBL_DATA_SIZE) @@ -108,7 +108,7 @@ "mmcoops=mmc read 0 0x40000000 0x40 8; md 0x40000000 0x400\0" \ "verify=n\0" \ "rootfstype=ext4\0" \ - "console=" CONFIG_DEFAULT_CONSOLE "\0" \ + "console=" CONFIG_DEFAULT_CONSOLE \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT \ "mbrparts=" MBRPARTS_DEFAULT \ "meminfo=crashkernel=32M@0x50000000\0" \ diff --git a/include/configs/trats.h b/include/configs/trats.h index 223fce49a7..af8e8ce3b6 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -36,7 +36,7 @@ #define CONFIG_MACH_TYPE MACH_TYPE_TRATS
#define CONFIG_BOOTCOMMAND "run autoboot" -#define CONFIG_DEFAULT_CONSOLE "ttySAC2,115200n8" +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0"
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - GENERATED_GBL_DATA_SIZE) @@ -120,7 +120,7 @@ "mmcoops=mmc read 0 0x40000000 0x40 8; md 0x40000000 0x400\0" \ "verify=n\0" \ "rootfstype=ext4\0" \ - "console=" CONFIG_DEFAULT_CONSOLE "\0" \ + "console=" CONFIG_DEFAULT_CONSOLE \ "meminfo=crashkernel=32M@0x50000000\0" \ "nfsroot=/nfsroot/arm\0" \ "bootblock=" CONFIG_BOOTBLOCK "\0" \ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index f1e4cbad30..9c6b2bbc8d 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -34,7 +34,7 @@ /* Console configuration */
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR \ - GENERATED_GBL_DATA_SIZE) @@ -103,7 +103,7 @@ "boottrace=setenv opts initcall_debug; run bootcmd\0" \ "verify=n\0" \ "rootfstype=ext4\0" \ - "console=" CONFIG_DEFAULT_CONSOLE "\0" \ + "console=" CONFIG_DEFAULT_CONSOLE \ "kernelname=uImage\0" \ "loaduimage=ext4load mmc ${mmcdev}:${mmcbootpart} 0x40007FC0 " \ "${kernelname}\0" \
- "console=" CONFIG_DEFAULT_CONSOLE \ "mmcbootdev=0\0" \ "mmcbootpart=1\0" \ "mmcrootdev=0\0" \
- "console=" CONFIG_DEFAULT_CONSOLE \ "fdtfile=exynos5422-odroidxu3.dtb\0" \ "boardname=odroidxu3\0" \ "mmcbootdev=0\0" \
- "console=" CONFIG_DEFAULT_CONSOLE \ "meminfo=mem=80M mem=256M@0x40000000 mem=128M@0x50000000\0" \ "loaduimage=ext4load mmc ${mmcdev}:${mmcbootpart} 0x30007FC0 uImage\0" \ "mmcdev=0\0" \
- "console=" CONFIG_DEFAULT_CONSOLE \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT \ "mbrparts=" MBRPARTS_DEFAULT \ "meminfo=crashkernel=32M@0x50000000\0" \
- "console=" CONFIG_DEFAULT_CONSOLE \ "meminfo=crashkernel=32M@0x50000000\0" \ "nfsroot=/nfsroot/arm\0" \ "bootblock=" CONFIG_BOOTBLOCK "\0" \
- "console=" CONFIG_DEFAULT_CONSOLE \ "kernelname=uImage\0" \ "loaduimage=ext4load mmc ${mmcdev}:${mmcbootpart} 0x40007FC0 " \ "${kernelname}\0" \
I agree with that we did not consider about side effect of this patch. So, applied to u-boot-samsung.
@ Dongjin Kim, I'm sorry to revert your patch because you missed some boards and scripts. Please check and send new patch.
Thanks, Minkyu Kang.
Hi Seung-Woo,
-- 2.19.1
This revert commit breaks the booting of the Odroid U3 using latest u-boot on ArchLinux. I have just tried to install archlinux on sdcard and update the latest kernel after compiling the latest u-boot and upgrade. It fails to boot up at-least their is not console output on the serial port.
[0] https://www.spinics.net/lists/arm-kernel/msg713918.html
I shared the my input on above link. Can your verify this from your side.
Best Regards -Anand
Hello Anand,
-----Original Message----- From: Anand Moon [mailto:linux.amoon@gmail.com] Sent: Monday, March 25, 2019 3:45 PM To: Seung-Woo Kim Cc: U-Boot Mailing List; Lukasz Majewski Subject: Re: [U-Boot] [PATCH] Revert "arm: config: fix default console only to specify the device"
Hi Seung-Woo,
-- 2.19.1
In my case, it works fine for booting mainline kernel at least. Can you try after "env default -a; saveenv; reset;" command from u-boot prompt? When I cleared env, console in env is "console=console=ttySAC1,115200n8". Please refer below my system console log from odroud-u3.
U-Boot 2019.04-rc4-00051-ge7134b9714 (Mar 26 2019 - 13:00:45 +0900)
CPU: Exynos4412 @ 1 GHz Model: Odroid based on Exynos4412 Type: u3 DRAM: 2 GiB LDO20@VDDQ_EMMC_1.8V: set 1800000 uV; enabling LDO22@VDDQ_EMMC_2.8V: set 2800000 uV; enabling LDO21@TFLASH_2.8V: set 2800000 uV; enabling MMC: sdhci@12530000 - probe failed: -19
Loading Environment from MMC... OK Net: No ethernet found. Hit any key to stop autoboot: 0 Odroid # Odroid # Odroid # printenv arch=arm autoboot=if test -e mmc 0 boot.scr; then; run boot_script; elif test -e mmc 0 Image.itb; then; run boot_fit;elif test -e mmc 0 zImage; then; run boot_zimg;elif test -e mmc 0 uImage; then; run boot_uimg;fi; <...> console=console=ttySAC1,115200n8 <...> Environment size: 4657/16380 bytes Odroid # run autoboot 55205 bytes read in 4 ms (13.2 MiB/s) 8556752 bytes read in 299 ms (27.3 MiB/s) Kernel image @ 0x41000000 [ 0x000000 - 0x8290d0 ] ## Flattened Device Tree blob at 40800000 Booting using the fdt blob at 0x40800000 Loading Device Tree to 4ffef000, end 4ffff7a4 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0xa00
Best Regards, - Seung-Woo Kim
Best Regards -Anand
Hi Seung-Woo Kim,
On Tue, 26 Mar 2019 at 10:04, Seung-Woo Kim sw0312.kim@samsung.com wrote:
Hello Anand,
Hi Seung-Woo,
-- 2.19.1
Starting kernel ...
Best Regards,
- Seung-Woo Kim
Thanks for your testing. I will check this again at my end.
Best Regards -Anand
Anand Moon
Minkyu Kang
Seung-Woo Kim
