[U-Boot] [PATCH v2 0/9] Add new OPTEE bootm support to u-boot
v2: - Added CONFIG_OPTEE_TZDRAM_BASE instead of #ifndef OPTEE_TZDRAM_BASE as an error. - Tom Rini
- Added Tested-by: Peng Fan peng.fan@nxp.com - as indicated
- Added better explanation text to patch 6/9 "tools: mkimage: add optee image type"
- Fixed some checkpatch warnings in optee.c
v1: This series adds a new OPTEE bootable image type to u-boot, which is directly bootable with the bootm command.
There is already a TEE image type but, in this case the TEE firmware is loaded into RAM, jumped into and then back out of. This image type is a directly bootable image as described here : http://mrvan.github.io/optee-imx6ul
Instead of reusing the Linux bootable image type instead a new image type is defined, which allows us to perform additional image verification, prior to handing off control via bootm.
OPTEE images get linked to a specific address at compile time and must be loaded to this address too. This series extends out mkimage with a new image type that allows the OPTEE binary link location to be validated against CONFIG_OPTEE_TZDRAM_BASE and CONFIG_OPTEE_TZDRAM_SIZE respectively prior to proceeding through the bootm phase.
Once applied you can generate a bootable OPTEE image like this
mkimage -A arm -T optee -C none -d ./out/arm-plat-imx/core/tee.bin uTee.optee
That image can then be booted directly by bootm. bootm will verify the header contents of the OPTEE binary against the DRAM area carved out in u-boot. If the defined DRAM area does not match the link address specified we refuse to boot.
Kever - I'd like to suggest that your OPTEE SPL image takes a different image type IH_TYPE_OPTEE_SPL ? to indicate the different behavior your image type has versus a directly bootable bootm image.
Bryan O'Donoghue (9): optee: Add lib entries for sharing OPTEE code across ports optee: Add CONFIG_OPTEE_TZDRAM_SIZE optee: Add CONFIG_OPTEE_TZDRAM_BASE optee: Add optee_image_get_entry_point() optee: Add optee_image_get_load_addr() tools: mkimage: add optee image type optee: Add optee_verify_bootm_image() optee: Improve error printout bootm: optee: Add mechanism to validate an OPTEE image before boot
common/bootm.c | 11 ++++++++- common/image.c | 1 + include/image.h | 1 + include/tee/optee.h | 41 ++++++++++++++++++++++++++++++++ lib/Kconfig | 1 + lib/Makefile | 1 + lib/optee/Kconfig | 24 +++++++++++++++++++ lib/optee/Makefile | 7 ++++++ lib/optee/optee.c | 66 +++++++++++++++++++++++++++++++++++++++++++++++++++ tools/default_image.c | 25 ++++++++++++++----- 10 files changed, 171 insertions(+), 7 deletions(-) create mode 100644 lib/optee/Kconfig create mode 100644 lib/optee/Makefile create mode 100644 lib/optee/optee.c
This patch adds code to lib to enable sharing of useful OPTEE code between board-ports and architectures. The code on lib/optee/optee.c comes from the TI omap2 port. Eventually the OMAP2 code will be patched to include the shared code. The intention here is to add more useful OPTEE specific code as more functionality gets added.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Harinarayan Bhatta harinarayan@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Tom Rini trini@konsulko.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Peng Fan peng.fan@nxp.com Tested-by: Peng Fan peng.fan@nxp.com --- include/tee/optee.h | 16 ++++++++++++++++ lib/Kconfig | 1 + lib/Makefile | 1 + lib/optee/Kconfig | 8 ++++++++ lib/optee/Makefile | 7 +++++++ lib/optee/optee.c | 37 +++++++++++++++++++++++++++++++++++++ 6 files changed, 70 insertions(+) create mode 100644 lib/optee/Kconfig create mode 100644 lib/optee/Makefile create mode 100644 lib/optee/optee.c
diff --git a/include/tee/optee.h b/include/tee/optee.h index 9ab0d08..8943afb 100644 --- a/include/tee/optee.h +++ b/include/tee/optee.h @@ -10,6 +10,8 @@ #ifndef _OPTEE_H #define _OPTEE_H
+#include <linux/errno.h> + #define OPTEE_MAGIC 0x4554504f #define OPTEE_VERSION 1 #define OPTEE_ARCH_ARM32 0 @@ -27,4 +29,18 @@ struct optee_header { uint32_t paged_size; };
+#if defined(CONFIG_OPTEE) +int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start, + unsigned long tzdram_len, unsigned long image_len); +#else +static inline int optee_verify_image(struct optee_header *hdr, + unsigned long tzdram_start, + unsigned long tzdram_len, + unsigned long image_len) +{ + return -EPERM; +} + +#endif + #endif /* _OPTEE_H */ diff --git a/lib/Kconfig b/lib/Kconfig index 00ac650..2077f9c 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -288,5 +288,6 @@ endmenu
source lib/efi/Kconfig source lib/efi_loader/Kconfig +source lib/optee/Kconfig
endmenu diff --git a/lib/Makefile b/lib/Makefile index 8cd779f..46813b6 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -17,6 +17,7 @@ obj-$(CONFIG_FIT) += libfdt/ obj-$(CONFIG_OF_LIVE) += of_live.o obj-$(CONFIG_CMD_DHRYSTONE) += dhry/ obj-$(CONFIG_ARCH_AT91) += at91/ +obj-$(CONFIG_OPTEE) += optee/
obj-$(CONFIG_AES) += aes.o obj-y += charset.o diff --git a/lib/optee/Kconfig b/lib/optee/Kconfig new file mode 100644 index 0000000..2e406fe --- /dev/null +++ b/lib/optee/Kconfig @@ -0,0 +1,8 @@ +config OPTEE + bool "Support OPTEE images" + help + U-Boot can be configured to boot OPTEE images. + Selecting this option will enable shared OPTEE library code and + enable an OPTEE specific bootm command that will perform additional + OPTEE specific checks before booting an OPTEE image created with + mkimage. diff --git a/lib/optee/Makefile b/lib/optee/Makefile new file mode 100644 index 0000000..03e832f --- /dev/null +++ b/lib/optee/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2017 Linaro +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_OPTEE) += optee.o diff --git a/lib/optee/optee.c b/lib/optee/optee.c new file mode 100644 index 0000000..64ceacd --- /dev/null +++ b/lib/optee/optee.c @@ -0,0 +1,37 @@ +/* + * Copyright (C) 2017 Linaro + * Bryan O'Donoghue bryan.odonoghue@linaro.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <tee/optee.h> + +#define optee_hdr_err_msg "OPTEE verification error tzdram 0x%08lx-0x%08lx " \ + "header lo=0x%08x hi=0x%08x size=0x%08x\n" + +int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start, + unsigned long tzdram_len, unsigned long image_len) +{ + unsigned long tzdram_end = tzdram_start + tzdram_len; + uint32_t tee_file_size; + + tee_file_size = hdr->init_size + hdr->paged_size + + sizeof(struct optee_header); + + if (hdr->magic != OPTEE_MAGIC || + hdr->version != OPTEE_VERSION || + hdr->init_load_addr_hi > tzdram_end || + hdr->init_load_addr_lo < tzdram_start || + tee_file_size > tzdram_len || + tee_file_size != image_len || + (hdr->init_load_addr_lo + tee_file_size) > tzdram_end) { + printf(optee_hdr_err_msg, tzdram_start, tzdram_end, + hdr->init_load_addr_lo, hdr->init_load_addr_hi, + tee_file_size); + return -EINVAL; + } + + return 0; +}
OPTEE is currently linked to a specific area of memory called the TrustZone DRAM. This patch adds a CONFIG entry for the default size of TrustZone DRAM that a board-port can over-ride. The region that U-Boot sets aside for the OPTEE run-time should be verified before attempting to hand off to the OPTEE run-time. Each board-port should carefully ensure that the TZDRAM size specified in the OPTEE build and the TZDRAM size specified in U-Boot match-up.
Further patches will use TZDRAM size with other defines and variables to carry out a degree of automated verification in U-Boot prior to trying to boot an OPTEE image.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Harinarayan Bhatta harinarayan@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Tom Rini trini@konsulko.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Peng Fan peng.fan@nxp.com Tested-by: Peng Fan peng.fan@nxp.com --- lib/optee/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/lib/optee/Kconfig b/lib/optee/Kconfig index 2e406fe..41c0ab7 100644 --- a/lib/optee/Kconfig +++ b/lib/optee/Kconfig @@ -6,3 +6,11 @@ config OPTEE enable an OPTEE specific bootm command that will perform additional OPTEE specific checks before booting an OPTEE image created with mkimage. + +config OPTEE_TZDRAM_SIZE + hex "Amount of Trust-Zone RAM for the OPTEE image" + depends on OPTEE + default 0x3000000 + help + The size of pre-allocated Trust Zone DRAM to allocate for the OPTEE + runtime.
OPTEE is currently linked to a specific area of memory called the TrustZone DRAM. This patch adds a CONFIG entry for the default address of TrustZone DRAM that a board-port can over-ride. The region that U-Boot sets aside for the OPTEE run-time should be verified before attempting to hand off to the OPTEE run-time. Each board-port should carefully ensure that the TZDRAM address specified in the OPTEE build and the TZDRAM address specified in U-Boot match-up.
Further patches will use TZDRAM address with other defines and variables to carry out a degree of automated verification in U-Boot prior to trying to boot an OPTEE image.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Harinarayan Bhatta harinarayan@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Tom Rini trini@konsulko.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Peng Fan peng.fan@nxp.com --- lib/optee/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/lib/optee/Kconfig b/lib/optee/Kconfig index 41c0ab7..a3b7332 100644 --- a/lib/optee/Kconfig +++ b/lib/optee/Kconfig @@ -14,3 +14,11 @@ config OPTEE_TZDRAM_SIZE help The size of pre-allocated Trust Zone DRAM to allocate for the OPTEE runtime. + +config OPTEE_TZDRAM_BASE + hex "Base address of Trust-Zone RAM for the OPTEE image" + depends on OPTEE + default 0x9d000000 + help + The base address of pre-allocated Trust Zone DRAM for + the OPTEE runtime.
Add a helper function for extracting the least significant 32 bits from the OPTEE entry point address, which will be good enough to load OPTEE binaries up to (2^32)-1 bytes.
We may need to extend this out later on but for now (2^32)-1 should be fine.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Harinarayan Bhatta harinarayan@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Tom Rini trini@konsulko.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Peng Fan peng.fan@nxp.com Tested-by: Peng Fan peng.fan@nxp.com --- include/tee/optee.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/tee/optee.h b/include/tee/optee.h index 8943afb..eb328d3 100644 --- a/include/tee/optee.h +++ b/include/tee/optee.h @@ -29,6 +29,13 @@ struct optee_header { uint32_t paged_size; };
+static inline uint32_t optee_image_get_entry_point(const image_header_t *hdr) +{ + struct optee_header *optee_hdr = (struct optee_header *)(hdr + 1); + + return optee_hdr->init_load_addr_lo; +} + #if defined(CONFIG_OPTEE) int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start, unsigned long tzdram_len, unsigned long image_len);
This patch adds optee_image_get_load_addr() a helper function used to calculate the load-address of an OPTEE image based on the lower entry-point address given in the OPTEE header.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Harinarayan Bhatta harinarayan@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Tom Rini trini@konsulko.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Peng Fan peng.fan@nxp.com Tested-by: Peng Fan peng.fan@nxp.com --- include/tee/optee.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/tee/optee.h b/include/tee/optee.h index eb328d3..e782cb0 100644 --- a/include/tee/optee.h +++ b/include/tee/optee.h @@ -36,6 +36,11 @@ static inline uint32_t optee_image_get_entry_point(const image_header_t *hdr) return optee_hdr->init_load_addr_lo; }
+static inline uint32_t optee_image_get_load_addr(const image_header_t *hdr) +{ + return optee_image_get_entry_point(hdr) - sizeof(struct optee_header); +} + #if defined(CONFIG_OPTEE) int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start, unsigned long tzdram_len, unsigned long image_len);
This patch adds support for bootable OPTEE images to mkimage. Currently there is a (Trusted Execution Environment) TEE image type, the TEE image type is installed to a memory location with u-boot continuing to own the boot process whereas the OPTEE image type defined here is a bootable image, which typically wants to live at a defined location in memory. Defining a new image type allows us to pull out the load address and entry point defined in the OPTEE header and having a separate image type lays the foundation for a subsequent patch to validate the OPTEE memory defined in a board-port matches the link location specified in the OPTEE bootable image.
example usage:
making a separate image type means you don't need to specify things like entry point and load address as you would if you were defining the OPTEE image as a linux image.
mkimage -A arm -O linux -C none -a 0x9c0fffe4 -e 0x9c100000 -d ./out/arm-plat-imx/core/tee.bin uTee
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Harinarayan Bhatta harinarayan@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Tom Rini trini@konsulko.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Peng Fan peng.fan@nxp.com Tested-by: Peng Fan peng.fan@nxp.com --- common/image.c | 1 + include/image.h | 1 + tools/default_image.c | 25 +++++++++++++++++++------ 3 files changed, 21 insertions(+), 6 deletions(-)
diff --git a/common/image.c b/common/image.c index e9609cd..14e738b 100644 --- a/common/image.c +++ b/common/image.c @@ -161,6 +161,7 @@ static const table_entry_t uimage_type[] = { { IH_TYPE_TEE, "tee", "Trusted Execution Environment Image",}, { IH_TYPE_FIRMWARE_IVT, "firmware_ivt", "Firmware with HABv4 IVT" }, { IH_TYPE_PMMC, "pmmc", "TI Power Management Micro-Controller Firmware",}, + { IH_TYPE_OPTEE, "optee", "OPTEE Boot Image",}, { -1, "", "", }, };
diff --git a/include/image.h b/include/image.h index a128a62..9175624 100644 --- a/include/image.h +++ b/include/image.h @@ -271,6 +271,7 @@ enum { IH_TYPE_TEE, /* Trusted Execution Environment OS Image */ IH_TYPE_FIRMWARE_IVT, /* Firmware Image with HABv4 IVT */ IH_TYPE_PMMC, /* TI Power Management Micro-Controller Firmware */ + IH_TYPE_OPTEE, /* OPTEE Boot Image */
IH_TYPE_COUNT, /* Number of image types */ }; diff --git a/tools/default_image.c b/tools/default_image.c index 4e5568e..5653933 100644 --- a/tools/default_image.c +++ b/tools/default_image.c @@ -18,6 +18,7 @@ #include "mkimage.h"
#include <image.h> +#include <tee/optee.h> #include <u-boot/crc.h>
static image_header_t header; @@ -25,7 +26,8 @@ static image_header_t header; static int image_check_image_types(uint8_t type) { if (((type > IH_TYPE_INVALID) && (type < IH_TYPE_FLATDT)) || - (type == IH_TYPE_KERNEL_NOLOAD) || (type == IH_TYPE_FIRMWARE_IVT)) + (type == IH_TYPE_KERNEL_NOLOAD) || (type == IH_TYPE_FIRMWARE_IVT) || + (type == IH_TYPE_OPTEE)) return EXIT_SUCCESS; else return EXIT_FAILURE; @@ -90,6 +92,8 @@ static void image_set_header(void *ptr, struct stat *sbuf, int ifd, uint32_t checksum; time_t time; uint32_t imagesize; + uint32_t ep; + uint32_t addr;
image_header_t * hdr = (image_header_t *)ptr;
@@ -99,18 +103,27 @@ static void image_set_header(void *ptr, struct stat *sbuf, int ifd, sbuf->st_size - sizeof(image_header_t));
time = imagetool_get_source_date(params, sbuf->st_mtime); - if (params->type == IH_TYPE_FIRMWARE_IVT) + ep = params->ep; + addr = params->addr; + imagesize = sbuf->st_size - sizeof(image_header_t); + + switch (params->type) { + case IH_TYPE_FIRMWARE_IVT: /* Add size of CSF minus IVT */ imagesize = sbuf->st_size - sizeof(image_header_t) + 0x1FE0; - else - imagesize = sbuf->st_size - sizeof(image_header_t); + break; + case IH_TYPE_OPTEE: + addr = optee_image_get_load_addr(hdr); + ep = optee_image_get_entry_point(hdr); + break; + }
/* Build new header */ image_set_magic(hdr, IH_MAGIC); image_set_time(hdr, time); image_set_size(hdr, imagesize); - image_set_load(hdr, params->addr); - image_set_ep(hdr, params->ep); + image_set_load(hdr, addr); + image_set_ep(hdr, ep); image_set_dcrc(hdr, checksum); image_set_os(hdr, params->os); image_set_arch(hdr, params->arch);
example usage:
I'm still not getting the reasoning for this all, you can have the load address checks and relocation stuff inside your loadable handler:
U_BOOT_FIT_LOADABLE_HANDLER(IH_TYPE_TEE, board_tee_image_process);
Then define 'board_tee_image_process' to do whatever you want to your image.
- { IH_TYPE_OPTEE, "optee", "OPTEE Boot Image",}, { -1, "", "", },
return EXIT_SUCCESS; else return EXIT_FAILURE;(type == IH_TYPE_OPTEE))
uint32_t ep;
uint32_t addr;
- ep = params->ep;
- addr = params->addr;
- switch (params->type) {
- case IH_TYPE_FIRMWARE_IVT: /* Add size of CSF minus IVT */ imagesize = sbuf->st_size - sizeof(image_header_t) + 0x1FE0;
- else
break;
case IH_TYPE_OPTEE:
break;
- image_set_load(hdr, addr);
- image_set_ep(hdr, ep); image_set_dcrc(hdr, checksum); image_set_os(hdr, params->os); image_set_arch(hdr, params->arch);
example usage:
uTee.optee
Hi Andrew,
As I understand it, that's a board-specific method, which wants to install a TEE (jump into a TEE and return to u-boot), whereas the aim with this patch-set is to chain-load and boot via TEE - OPTEE in this case.
I should make that clearer in the patch text description.
The example from Peng Fang
is then simplified down to this
and remove the requirement to pass load and entry point on the command line.
The boot-flow looks like this
BootROM -> u-boot {load kernel, dtb, optee} -> OPTEE -> Kernel
Whereas - as I understand it the flow on the TI examples you have is
BootROM -> u-boot {load kernel, dtb, TEE} -> TEE -> u-boot -> Kernel
Note: I do believe IH_TYPE_TEE is the right type to use for Kever's patch with the SPL - because again as I understand it - the model is
BootROM -> SPL -> Install TEE -> u-boot -> etc
--- bod
example usage:
uTee.optee
Hi Andrew,
This is not board-specific, this is the flow all ARM boards I know of use (except i.MX 6).
It is certainly possible to use the same flow on TI boards if we wanted, we just don't as in my mind OP-TEE logically should jump back to the non-secure side were it was called from so non-secure boot can continue. Not act as another boot loader stage.
Is there some technical reason I am missing as to why you want to use this alternate flow?
That would be great.
I haven't used mkimage in a while, but how is this any different than what we do with the kernel image? Why do we need to pull this info out of the header when we don't do the same for Linux?
line.
To me the save in this command (which should be handled automatically during the build process), doesn't justify the additional complexity in the boot flow.
This is correct, we also on some platforms load additional firmware, so returning to u-boot after each image is deployed is a must.
BootROM -> (u-boot u-boot u-boot u-boot) -> kernel | | | | | | v | v | v | TEE -> PMMC -> Something else, etc..
You seem to be locking yourself in with your flow, as now TEE *must* be the last item you load. What happens when you want to make secure calls into OP-TEE from U-Boot? You won't be able to move it back in the stages. (We are now doing this to handle some new Android secure-boot requirements, so it is not that far-fetched)
bod
The OPTEE port I'm working with is i.MX 7, which chain-loads in this same way.
The reason is the upstream OPTEE port we are working with already uses this bootflow.
So for a kernel you are typically making a uImage of a compressed kernel image and therefore you have to pass load-address and entry point.
mkimage -A arm -O linux -T kernel -C none -a 0x80008000 -e 0x80008000 -n "Linux kernel" -d arch/arm/boot/zImage uImage
For the bootable OPTEE image case I'm proposing
1. A distinct image type 2. Based on that image type we validate the OPTEE header MAGIC, version, etc 3. Based on the OPTEE header we can validate the location the OPTEE binary gets loaded to.
Having a distinct image type makes it more robust.
line.
As above, it's about image generation, validation and load-address sanity checking.
I apologize for not making that clearer upfront - my bad, I'll attempt to flesh-out the patch descriptions to make the logic clearer.
--- bod
This patch adds optee_verify_bootm_image() which will be subsequently used to verify the parameters encoded in the OPTEE header match the memory allocated to the OPTEE region, OPTEE header magic and version prior to handing off control to the OPTEE image.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Harinarayan Bhatta harinarayan@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Tom Rini trini@konsulko.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Peng Fan peng.fan@nxp.com Tested-by: Peng Fan peng.fan@nxp.com --- include/tee/optee.h | 13 +++++++++++++ lib/optee/optee.c | 34 ++++++++++++++++++++++++++++++---- 2 files changed, 43 insertions(+), 4 deletions(-)
diff --git a/include/tee/optee.h b/include/tee/optee.h index e782cb0..4b9e94c 100644 --- a/include/tee/optee.h +++ b/include/tee/optee.h @@ -55,4 +55,17 @@ static inline int optee_verify_image(struct optee_header *hdr,
#endif
+#if defined(CONFIG_OPTEE) +int optee_verify_bootm_image(unsigned long image_addr, + unsigned long image_load_addr, + unsigned long image_len); +#else +static inline int optee_verify_bootm_image(unsigned long image_addr, + unsigned long image_load_addr, + unsigned long image_len) +{ + return -EPERM; +} +#endif + #endif /* _OPTEE_H */ diff --git a/lib/optee/optee.c b/lib/optee/optee.c index 64ceacd..e28627d 100644 --- a/lib/optee/optee.c +++ b/lib/optee/optee.c @@ -9,7 +9,8 @@ #include <tee/optee.h>
#define optee_hdr_err_msg "OPTEE verification error tzdram 0x%08lx-0x%08lx " \ - "header lo=0x%08x hi=0x%08x size=0x%08x\n" + "header 0x%08x-0x%08x size=0x%08lx arch=0x%08x" \ + "uimage params 0x%08lx-0x%08lx\n"
int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start, unsigned long tzdram_len, unsigned long image_len) @@ -27,11 +28,36 @@ int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start, tee_file_size > tzdram_len || tee_file_size != image_len || (hdr->init_load_addr_lo + tee_file_size) > tzdram_end) { - printf(optee_hdr_err_msg, tzdram_start, tzdram_end, - hdr->init_load_addr_lo, hdr->init_load_addr_hi, - tee_file_size); return -EINVAL; }
return 0; } + +int optee_verify_bootm_image(unsigned long image_addr, + unsigned long image_load_addr, + unsigned long image_len) +{ + struct optee_header *hdr = (struct optee_header *)image_addr; + unsigned long tzdram_start = CONFIG_OPTEE_TZDRAM_BASE; + unsigned long tzdram_len = CONFIG_OPTEE_TZDRAM_SIZE; + + int ret; + + ret = optee_verify_image(hdr, tzdram_start, tzdram_len, image_len); + if (ret) + goto error; + + if (image_load_addr + sizeof(*hdr) != hdr->init_load_addr_lo) { + ret = -EINVAL; + goto error; + } + + return ret; +error: + printf(optee_hdr_err_msg, tzdram_start, tzdram_start + tzdram_len, + hdr->init_load_addr_lo, hdr->init_load_addr_hi, image_len, + hdr->arch, image_load_addr, image_load_addr + image_len); + + return ret; +}
When encountering an error in OPTEE verification print out the address of the header and image.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Harinarayan Bhatta harinarayan@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Tom Rini trini@konsulko.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Peng Fan peng.fan@nxp.com Tested-by: Peng Fan peng.fan@nxp.com --- lib/optee/optee.c | 15 +++++++++------ 1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/lib/optee/optee.c b/lib/optee/optee.c index e28627d..78a15e8 100644 --- a/lib/optee/optee.c +++ b/lib/optee/optee.c @@ -8,9 +8,11 @@ #include <common.h> #include <tee/optee.h>
-#define optee_hdr_err_msg "OPTEE verification error tzdram 0x%08lx-0x%08lx " \ - "header 0x%08x-0x%08x size=0x%08lx arch=0x%08x" \ - "uimage params 0x%08lx-0x%08lx\n" +#define optee_hdr_err_msg \ + "OPTEE verification error:" \ + "\n\thdr=%p image=0x%08lx magic=0x%08x tzdram 0x%08lx-0x%08lx " \ + "\n\theader lo=0x%08x hi=0x%08x size=0x%08lx arch=0x%08x" \ + "\n\tuimage params 0x%08lx-0x%08lx\n"
int optee_verify_image(struct optee_header *hdr, unsigned long tzdram_start, unsigned long tzdram_len, unsigned long image_len) @@ -55,9 +57,10 @@ int optee_verify_bootm_image(unsigned long image_addr,
return ret; error: - printf(optee_hdr_err_msg, tzdram_start, tzdram_start + tzdram_len, - hdr->init_load_addr_lo, hdr->init_load_addr_hi, image_len, - hdr->arch, image_load_addr, image_load_addr + image_len); + printf(optee_hdr_err_msg, hdr, image_addr, hdr->magic, tzdram_start, + tzdram_start + tzdram_len, hdr->init_load_addr_lo, + hdr->init_load_addr_hi, image_len, hdr->arch, image_load_addr, + image_load_addr + image_len);
return ret; }
- "OPTEE verification error:" \
- "\n\thdr=%p image=0x%08lx magic=0x%08x tzdram 0x%08lx-0x%08lx " \
- "\n\theader lo=0x%08x hi=0x%08x size=0x%08lx arch=0x%08x" \
- "\n\tuimage params 0x%08lx-0x%08lx\n"
return ret; error:
- printf(optee_hdr_err_msg, hdr, image_addr, hdr->magic, tzdram_start,
This all can be squashed up into the patches that introduce all this stuff.
return ret; }
Sure np.
This patch makes it possible to verify the contents and location of an OPTEE image in DRAM prior to handing off control to that image. If image verification fails we won't try to boot any further.
Signed-off-by: Bryan O'Donoghue bryan.odonoghue@linaro.org Cc: Harinarayan Bhatta harinarayan@ti.com Cc: Andrew F. Davis afd@ti.com Cc: Tom Rini trini@konsulko.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Peng Fan peng.fan@nxp.com Tested-by: Peng Fan peng.fan@nxp.com --- common/bootm.c | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/common/bootm.c b/common/bootm.c index adb1213..d528844 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -19,6 +19,7 @@ #include <lzma/LzmaTypes.h> #include <lzma/LzmaDec.h> #include <lzma/LzmaTools.h> +#include <tee/optee.h> #if defined(CONFIG_CMD_USB) #include <usb.h> #endif @@ -201,6 +202,12 @@ static int bootm_find_os(cmd_tbl_t *cmdtp, int flag, int argc, if (images.os.type == IH_TYPE_KERNEL_NOLOAD) { images.os.load = images.os.image_start; images.ep += images.os.load; + } else if (images.os.type == IH_TYPE_OPTEE) { + ret = optee_verify_bootm_image(images.os.image_start, + images.os.load, + images.os.image_len); + if (ret) + return ret; }
images.os.start = map_to_sysmem(os_hdr); @@ -275,7 +282,8 @@ static int bootm_find_other(cmd_tbl_t *cmdtp, int flag, int argc, { if (((images.os.type == IH_TYPE_KERNEL) || (images.os.type == IH_TYPE_KERNEL_NOLOAD) || - (images.os.type == IH_TYPE_MULTI)) && + (images.os.type == IH_TYPE_MULTI) || + (images.os.type == IH_TYPE_OPTEE)) && (images.os.os == IH_OS_LINUX || images.os.os == IH_OS_VXWORKS)) return bootm_find_images(flag, argc, argv); @@ -827,6 +835,7 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, switch (image_get_type(hdr)) { case IH_TYPE_KERNEL: case IH_TYPE_KERNEL_NOLOAD: + case IH_TYPE_OPTEE: *os_data = image_get_data(hdr); *os_len = image_get_data_size(hdr); break;
Andrew F. Davis
Bryan O'Donoghue
