[U-Boot] ubi part failing on NAND
The "ubi part" command is failing for me on my PowerPC 85xx board. I am not trying to do anything special, just create the partitions and volumes so that I can try writing an ubi.img. It spits out enough information that it looks like it did work but it prints out an error nonetheless.
And of course there is the long standing issue of the reported MTD number not making any sense. But previous posts have discounted this as an issue.
Here is the snippet of the error:
UBI error: ubi_init: cannot attach mtd2 UBI: mtd2 is detached from ubi0 UBI error: ubi_init: UBI error: cannot initialize UBI, error -17 UBI init error -17
Here is a cleaned up version of the session log:
=> mtdparts
device nor0 <f8000000.nor>, # parts = 8 #: name size offset mask_flags 0: config 0x00020000 0x00000000 0 1: kernel 0x00260000 0x00020000 0 2: fdt 0x00020000 0x00280000 0 3: tinyfs 0x00600000 0x002a0000 0 4: rootfs 0x076a0000 0x008a0000 0 5: u-boot-env-r 0x00020000 0x07f40000 1 6: u-boot-env 0x00020000 0x07f60000 1 7: u-boot 0x00080000 0x07f80000 1
device nand0 <f4000000.nand>, # parts = 2 #: name size offset mask_flags 0: fs1 0x20000000 0x00000000 0 1: fs2 0x20000000 0x20000000 0
=> nand erase 0x0 0x40000000
NAND erase: device 0 whole chip Skipping bad block at 0x01200000 Skipping bad block at 0x0e880000 Skipping bad block at 0x1cd80000 Skipping bad block at 0x2b300000 Skipping bad block at 0x323c0000 Skipping bad block at 0x364c0000 Skipping bad block at 0x37cc0000 Erasing at 0x3ffc0000 -- 100% complete. OK
=> ubi part fs1 Creating 1 MTD partitions on "nand0": 0x000000000000-0x000020000000 : "mtd=0" UBI: attaching mtd2 to ubi0 UBI: physical eraseblock size: 262144 bytes (256 KiB) UBI: logical eraseblock size: 253952 bytes UBI: smallest flash I/O unit: 4096 UBI: VID header offset: 4096 (aligned 4096) UBI: data offset: 8192 UBI: empty MTD device detected UBI: create volume table (copy #1) UBI: create volume table (copy #2) UBI: attached mtd2 to ubi0 UBI: MTD device name: "mtd=0" UBI: MTD device size: 512 MiB UBI: number of good PEBs: 2045 UBI: number of bad PEBs: 3 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 0 UBI: available PEBs: 2021 UBI: total number of reserved PEBs: 24 UBI: number of PEBs reserved for bad PEB handling: 20 UBI: max/mean erase counter: 0/0 UBI error: ubi_init: cannot attach mtd2 UBI: mtd2 is detached from ubi0 UBI error: ubi_init: UBI error: cannot initialize UBI, error -17 UBI init error -17 exit not allowed from main input shell.
My last sync with the denx git was when 2.6.31 was released. Here is my version: => ver
U-Boot 2009.08-00213-gfdf80f7 (Dec 17 2009 - 12:57:07)
Jeff Angielski The PTR Group www.theptrgroup.com
Jeff,
Patches to fix/change this are welcome. :)
-17 == EEXIST. Looking at the code (build.c) shows that ubi_attach_mtd_dev() is returning this error code in case the MTD device is already attached. Even though the UBI implementation should handle this without any problems. I have to admit that I'm a bit out of ideas what's going wrong in your case. I just checked again and UBI works fine for me with the latest version:
=> mtdparts
device nand0 <nand>, # parts = 3 #: name size offset mask_flags 0: bootloader 0x00100000 0x00000000 0 1: rootfs 0x01000000 0x00100000 0 2: ubifs 0x02f00000 0x01100000 0
active partition: nand0,0 - (bootloader) 0x00100000 @ 0x00000000
defaults: mtdids : nand0=nand mtdparts: mtdparts=nand:1m(bootloader),16m(rootfs),-(ubifs) => nand erase 1100000 2f00000
NAND erase: device 0 offset 0x1100000, size 0x2f00000 Erasing at 0x3ffc000 -- 100% complete. OK => ubi part ubifs Creating 1 MTD partitions on "nand0": 0x000001100000-0x000004000000 : "mtd=2" UBI: attaching mtd1 to ubi0 UBI: physical eraseblock size: 16384 bytes (16 KiB) UBI: logical eraseblock size: 15872 bytes UBI: smallest flash I/O unit: 512 UBI: sub-page size: 256 UBI: VID header offset: 256 (aligned 256) UBI: data offset: 512 UBI: empty MTD device detected UBI: create volume table (copy #1) UBI: create volume table (copy #2) UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=2" UBI: MTD device size: 47 MiB UBI: number of good PEBs: 3008 UBI: number of bad PEBs: 0 UBI: max. allowed volumes: 92 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 0 UBI: available PEBs: 2974 UBI: total number of reserved PEBs: 34 UBI: number of PEBs reserved for bad PEB handling: 30 UBI: max/mean erase counter: 0/0 => mtdparts
defaults: mtdids : nand0=nand mtdparts: mtdparts=nand:1m(bootloader),16m(rootfs),-(ubifs) => nand erase 100000 1000000
NAND erase: device 0 offset 0x100000, size 0x1000000 Erasing at 0x10fc000 -- 100% complete. OK => ubi part rootfs UBI: mtd1 is detached from ubi0 Creating 1 MTD partitions on "nand0": 0x000000100000-0x000001100000 : "mtd=1" UBI: attaching mtd1 to ubi0 UBI: physical eraseblock size: 16384 bytes (16 KiB) UBI: logical eraseblock size: 15872 bytes UBI: smallest flash I/O unit: 512 UBI: sub-page size: 256 UBI: VID header offset: 256 (aligned 256) UBI: data offset: 512 UBI: empty MTD device detected UBI: create volume table (copy #1) UBI: create volume table (copy #2) UBI: attached mtd1 to ubi0 UBI: MTD device name: "mtd=1" UBI: MTD device size: 16 MiB UBI: number of good PEBs: 1024 UBI: number of bad PEBs: 0 UBI: max. allowed volumes: 92 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 0 UBI: available PEBs: 1010 UBI: total number of reserved PEBs: 14 UBI: number of PEBs reserved for bad PEB handling: 10 UBI: max/mean erase counter: 0/0 =>
Perhaps you should try the latest version as well. Could be that this is a bug already fixed now. Otherwise you need to debug this problem yourself, since I can't reproduce it here.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Jeff, what is the size of your allocateble memory. Had to increase it to 4MB to get it working.
On Fri, Dec 18, 2009 at 9:16 AM, Stefan Roese sr@denx.de wrote:
Jeff,
=> mtdparts
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
I've got 1MByte for my test on Kilauea. This should be enough. There is already a compile-time check in the UBI code:
#if (CONFIG_SYS_MALLOC_LEN < (512 << 10)) #error Malloc area too small for UBI, increase CONFIG_SYS_MALLOC_LEN to >= 512k #endif
Please let me know if this really is not enough. But for me, 1MB is working.
Cheers, Stefan
As per Hedwin's suggestion I increased my CONFIG_SYS_MALLOC_LEN to 4MB and the error disappeared. Thanks Hedwin! And now the UBI output matches my part (e.g. PEB size).
=> ubi part fs1 Creating 1 MTD partitions on "nand0": 0x000000000000-0x000020000000 : "mtd=0" UBI: attaching mtd2 to ubi0 UBI: physical eraseblock size: 262144 bytes (256 KiB) UBI: logical eraseblock size: 253952 bytes UBI: smallest flash I/O unit: 4096 UBI: VID header offset: 4096 (aligned 4096) UBI: data offset: 8192 UBI: empty MTD device detected UBI: create volume table (copy #1) UBI: create volume table (copy #2) UBI: attached mtd2 to ubi0 UBI: MTD device name: "mtd=0" UBI: MTD device size: 512 MiB UBI: number of good PEBs: 2045 UBI: number of bad PEBs: 3 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 0 UBI: available PEBs: 2021 UBI: total number of reserved PEBs: 24 UBI: number of PEBs reserved for bad PEB handling: 20 UBI: max/mean erase counter: 0/0 =>
A bit on the reason why this amount of memory is needed.
I had the same problem jeff mentions. After tracing where dlmalloc allocates its memory chunks I found out that it started allocating memory in code space. Overwritting code space eventually resultated in uboot crashing. Looking into dlmalloc I did not find any code that checks whether it allocates memory outside its boundary.
Since I use a 2009.01 release I need to verify this against the latest release.
There is also another problem with ubi. If you repeat the following statements more than once uboot also crashed.
nand erase /aPartition ubi part nand /aPartition ubi create aVolume
I did not check yet if this is also an allocation problem or something totally different.
Hedwin
-- Jeff Angielski The PTR Group www.theptrgroup.com
= 512k #endif
Hmmm. Must be because my test platform used a small page NAND device. I'll give it a try on a large page NAND soon. The code must be lacking a check for malloc failure.
Cheers, Stefan
#define CONFIG_SYS_MALLOC_LEN (1024 * 1024)
I'll try increasing it to see if that helps.
Jeff,
=> mtdparts
Cheers, Stefan
hedwin
Jeff Angielski
Stefan Roese
