[U-Boot] Please pull u-boot-ti/master, v2
Hey,
The following changes since commit d627eefcd5e72db00889718ca9ee1dcb4d026fc9:
Merge remote-tracking branch 'u-boot-pxa/master' into 'u-boot-arm/master' (2013-12-18 22:19:02 +0100)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to 2931fa4db349c97f882ffda42e901208654b5ca9:
ARM: AM43xx: Add Maintainer (2013-12-18 21:14:45 -0500)
Changes in v2: - Dropped Dan's patch as he's right and it depends on another series we aren't quite ready for. - Reworked Lokesh's ioregs related patch to cover cm_t335 now as well.
---------------------------------------------------------------- Lokesh Vutla (12): ARM: AM43xx: Update the base addresses of modules ARM: AM43xx: Adapt to ti_armv7_common.h config file ARM: AM43xx: Add L2 Support ARM: AM43xx: Add extra ENV settings ARM: AM43xx: Select clk source for Timer2 ARM: AM43xx: Update Current Booting devices list ARM: AM43xx: mux: Update mux data ARM: AM43xx: clocks: Update DPLL details ARM: AM33xx+: Update ioregs to pass different values ARM: AM43xx: EPOS_EVM: Add support for LPDDR2 ARM: AM43xx: GP_EVM: Add support for DDR3 ARM: AM43xx: Add Maintainer
Sekhar Nori (2): ARM: AM43XX: board: add support for reading onboard EEPROM ARM: AM43XX: Add CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG support
Stefan Roese (1): arm: omap3: Fix beagleboard SPL boot hangup (GPIO clocks not enabled)
arch/arm/cpu/armv7/am33xx/clock.c | 12 +- arch/arm/cpu/armv7/am33xx/clock_am33xx.c | 15 + arch/arm/cpu/armv7/am33xx/clock_am43xx.c | 12 +- arch/arm/cpu/armv7/am33xx/ddr.c | 146 +++++++- arch/arm/cpu/armv7/am33xx/emif4.c | 25 +- arch/arm/cpu/armv7/omap-common/emif-common.c | 14 - arch/arm/include/asm/arch-am33xx/clock.h | 7 +- arch/arm/include/asm/arch-am33xx/clocks_am33xx.h | 3 + arch/arm/include/asm/arch-am33xx/cpu.h | 24 +- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 41 ++- arch/arm/include/asm/arch-am33xx/gpio.h | 12 + arch/arm/include/asm/arch-am33xx/hardware.h | 7 - arch/arm/include/asm/arch-am33xx/hardware_am33xx.h | 2 + arch/arm/include/asm/arch-am33xx/hardware_am43xx.h | 16 + arch/arm/include/asm/arch-am33xx/mux_am43xx.h | 45 +++ arch/arm/include/asm/arch-am33xx/omap.h | 4 +- arch/arm/include/asm/arch-am33xx/spl.h | 13 +- arch/arm/include/asm/emif.h | 26 ++ board/compulab/cm_t335/spl.c | 10 +- board/isee/igep0033/board.c | 10 +- board/phytec/pcm051/board.c | 20 +- board/siemens/dxr2/board.c | 12 +- board/siemens/pxm2/board.c | 10 +- board/siemens/rut/board.c | 10 +- board/ti/am335x/board.c | 40 ++- board/ti/am43xx/board.c | 355 +++++++++++++++++++- board/ti/am43xx/board.h | 36 ++ board/ti/am43xx/mux.c | 35 +- board/ti/ti814x/evm.c | 4 +- board/ti/ti816x/evm.c | 12 +- boards.cfg | 2 +- include/configs/am43xx_evm.h | 204 +++++------ include/configs/omap3_beagle.h | 3 + 33 files changed, 1005 insertions(+), 182 deletions(-)
Thanks!
Hi Tom,
On Thu, 19 Dec 2013 12:04:19 -0500, Tom Rini trini@ti.com wrote:
Hey,
Changes in v2:
Thanks!
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
