[U-Boot] [PATCH 1/2] net: tsec: Fix NULL access in case init_phy() fails
If the PHY is not recognized don't access phydev (NULL) and return 0 to signal failure.
Signed-off-by: Claudiu Manoil claudiu.manoil@freescale.com --- drivers/net/tsec.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index e9138f0..65fb2b0 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -590,6 +590,8 @@ static int init_phy(struct eth_device *dev) tsec_configure_serdes(priv);
phydev = phy_connect(priv->bus, priv->phyaddr, dev, priv->interface); + if (!phydev) + return 0;
phydev->supported &= supported; phydev->advertising = phydev->supported;
fsl_enet.h defines the mapping of the usual MII management registers, which are included in the MDIO register block common to Freescale ethernet controllers. So it shouldn't depend on the CPU architecture but it should be actually part of the arch independent fsl_mdio.h.
To remove the arch dependency, merge the content of asm/fsl_enet.h into fsl_mdio.h. Some files (like fm_eth.h) were simply including fsl_enet.h only for phy.h. These were updated to include phy.h instead.
Signed-off-by: Claudiu Manoil claudiu.manoil@freescale.com --- arch/powerpc/include/asm/fsl_enet.h | 24 ------------------------ board/freescale/mpc8360emds/mpc8360emds.c | 2 +- board/freescale/mpc837xemds/mpc837xemds.c | 1 - drivers/net/fm/dtsec.c | 1 - drivers/net/fm/fm.h | 2 +- drivers/net/fm/init.c | 1 + drivers/net/fm/memac.c | 1 - drivers/net/fm/tgec.c | 1 - drivers/net/fsl_mdio.c | 1 - drivers/qe/uec.h | 1 - include/fm_eth.h | 2 +- include/fsl_mdio.h | 13 ++++++++++++- include/tsec.h | 2 +- 13 files changed, 17 insertions(+), 35 deletions(-) delete mode 100644 arch/powerpc/include/asm/fsl_enet.h
diff --git a/arch/powerpc/include/asm/fsl_enet.h b/arch/powerpc/include/asm/fsl_enet.h deleted file mode 100644 index 96146b6..0000000 --- a/arch/powerpc/include/asm/fsl_enet.h +++ /dev/null @@ -1,24 +0,0 @@ -/* - * Copyright 2010 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __ASM_PPC_FSL_ENET_H -#define __ASM_PPC_FSL_ENET_H - -#include <phy.h> - -struct tsec_mii_mng { - u32 miimcfg; /* MII management configuration reg */ - u32 miimcom; /* MII management command reg */ - u32 miimadd; /* MII management address reg */ - u32 miimcon; /* MII management control reg */ - u32 miimstat; /* MII management status reg */ - u32 miimind; /* MII management indication reg */ - u32 ifstat; /* Interface Status Register */ -} __attribute__ ((packed)); - -int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc); - -#endif /* __ASM_PPC_FSL_ENET_H */ diff --git a/board/freescale/mpc8360emds/mpc8360emds.c b/board/freescale/mpc8360emds/mpc8360emds.c index ac96163..5ff9dff 100644 --- a/board/freescale/mpc8360emds/mpc8360emds.c +++ b/board/freescale/mpc8360emds/mpc8360emds.c @@ -11,13 +11,13 @@ #include <i2c.h> #include <miiphy.h> #include <phy.h> +#include <fsl_mdio.h> #if defined(CONFIG_PCI) #include <pci.h> #endif #include <spd_sdram.h> #include <asm/mmu.h> #include <asm/io.h> -#include <asm/fsl_enet.h> #include <asm/mmu.h> #if defined(CONFIG_OF_LIBFDT) #include <libfdt.h> diff --git a/board/freescale/mpc837xemds/mpc837xemds.c b/board/freescale/mpc837xemds/mpc837xemds.c index 0a3c972..c749e55 100644 --- a/board/freescale/mpc837xemds/mpc837xemds.c +++ b/board/freescale/mpc837xemds/mpc837xemds.c @@ -10,7 +10,6 @@ #include <i2c.h> #include <asm/io.h> #include <asm/fsl_mpc83xx_serdes.h> -#include <asm/fsl_enet.h> #include <spd_sdram.h> #include <tsec.h> #include <libfdt.h> diff --git a/drivers/net/fm/dtsec.c b/drivers/net/fm/dtsec.c index 78bbd43..8d3dc0e 100644 --- a/drivers/net/fm/dtsec.c +++ b/drivers/net/fm/dtsec.c @@ -7,7 +7,6 @@ #include <common.h> #include <asm/types.h> #include <asm/io.h> -#include <asm/fsl_enet.h> #include <asm/fsl_dtsec.h> #include <fsl_mdio.h> #include <phy.h> diff --git a/drivers/net/fm/fm.h b/drivers/net/fm/fm.h index 43de114..c8eba4f 100644 --- a/drivers/net/fm/fm.h +++ b/drivers/net/fm/fm.h @@ -8,8 +8,8 @@ #define __FM_H__
#include <common.h> +#include <phy.h> #include <fm_eth.h> -#include <asm/fsl_enet.h> #include <asm/fsl_fman.h>
/* Port ID */ diff --git a/drivers/net/fm/init.c b/drivers/net/fm/init.c index cd787f4..7371dbf 100644 --- a/drivers/net/fm/init.c +++ b/drivers/net/fm/init.c @@ -6,6 +6,7 @@ #include <common.h> #include <asm/io.h> #include <asm/fsl_serdes.h> +#include <fsl_mdio.h>
#include "fm.h"
diff --git a/drivers/net/fm/memac.c b/drivers/net/fm/memac.c index 592a67f..9499290 100644 --- a/drivers/net/fm/memac.c +++ b/drivers/net/fm/memac.c @@ -12,7 +12,6 @@ #include <phy.h> #include <asm/types.h> #include <asm/io.h> -#include <asm/fsl_enet.h> #include <asm/fsl_memac.h>
#include "fm.h" diff --git a/drivers/net/fm/tgec.c b/drivers/net/fm/tgec.c index f450f80..5017123 100644 --- a/drivers/net/fm/tgec.c +++ b/drivers/net/fm/tgec.c @@ -12,7 +12,6 @@ #include <phy.h> #include <asm/types.h> #include <asm/io.h> -#include <asm/fsl_enet.h> #include <asm/fsl_tgec.h>
#include "fm.h" diff --git a/drivers/net/fsl_mdio.c b/drivers/net/fsl_mdio.c index 1d88e65..8d09f5d 100644 --- a/drivers/net/fsl_mdio.c +++ b/drivers/net/fsl_mdio.c @@ -11,7 +11,6 @@ #include <fsl_mdio.h> #include <asm/io.h> #include <asm/errno.h> -#include <asm/fsl_enet.h>
void tsec_local_mdio_write(struct tsec_mii_mng __iomem *phyregs, int port_addr, int dev_addr, int regnum, int value) diff --git a/drivers/qe/uec.h b/drivers/qe/uec.h index 48a1634..6b559f7 100644 --- a/drivers/qe/uec.h +++ b/drivers/qe/uec.h @@ -13,7 +13,6 @@ #include "qe.h" #include "uccf.h" #include <phy.h> -#include <asm/fsl_enet.h>
#define MAX_TX_THREADS 8 #define MAX_RX_THREADS 8 diff --git a/include/fm_eth.h b/include/fm_eth.h index 98edfcf..e46a684 100644 --- a/include/fm_eth.h +++ b/include/fm_eth.h @@ -8,8 +8,8 @@ #define __FM_ETH_H__
#include <common.h> +#include <phy.h> #include <asm/types.h> -#include <asm/fsl_enet.h>
enum fm_port { FM1_DTSEC1, diff --git a/include/fsl_mdio.h b/include/fsl_mdio.h index b58713d..a531edf 100644 --- a/include/fsl_mdio.h +++ b/include/fsl_mdio.h @@ -10,7 +10,18 @@
#include <net.h> #include <miiphy.h> -#include <asm/fsl_enet.h> + +struct tsec_mii_mng { + u32 miimcfg; /* MII management configuration reg */ + u32 miimcom; /* MII management command reg */ + u32 miimadd; /* MII management address reg */ + u32 miimcon; /* MII management control reg */ + u32 miimstat; /* MII management status reg */ + u32 miimind; /* MII management indication reg */ + u32 ifstat; /* Interface Status Register */ +} __packed; + +int fdt_fixup_phy_connection(void *blob, int offset, phy_interface_t phyc);
/* PHY register offsets */ #define PHY_EXT_PAGE_ACCESS 0x1f diff --git a/include/tsec.h b/include/tsec.h index 1046426..2054715 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -20,7 +20,7 @@ #include <net.h> #include <config.h> #include <phy.h> -#include <asm/fsl_enet.h> +#include <fsl_mdio.h>
#define TSEC_SIZE 0x01000 #define TSEC_MDIO_OFFSET 0x01000
On Tue, Dec 10, 2013 at 7:21 AM, Claudiu Manoil < claudiu.manoil@freescale.com> wrote:
Applied, Thanks! -Joe
Claudiu Manoil
Joe Hershberger
