[U-Boot] [PATCH] zynq: Use full tftpboot command instead of shortcut tftp
The reason is enabling tftpput command where tftp shorcut stops to work for tftpboot.
include/configs/zynq-common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 36b9508..f03c653 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -149,7 +149,7 @@ "fatload mmc 0 ${load_addr} ${fit_image} && " \ "bootm ${load_addr}\0" \ "jtagboot=echo TFTPing FIT to RAM... && " \ - "tftp ${load_addr} ${fit_image} && " \ + "tftpboot ${load_addr} ${fit_image} && " \ "bootm ${load_addr}\0" #define CONFIG_BOOTCOMMAND "run $modeboot" #define CONFIG_BOOTDELAY 3 /* -1 to Disable autoboot */ -- 1.8.2.3
Hi Michal,
On Wed, 5 Feb 2014 07:56:07 +0100, Michal Simek michal.simek@xilinx.com wrote:
Do you think you could extend this patch to all config files where the 'tftp' shortcut exists? This would prevent future issues on targets other than Zynq and hopefully it is only a matter of grepping / sed'ing through include/configs/*.h.
Amicalement,
Hi Albert,
On 02/10/2014 10:11 AM, Albert ARIBAUD wrote:
Hi Michal,
Based on my experience it is better to use full commands in variables but on the other hand I have met with the case when adding these 4 chars caused that max variable size has been exceed with error.
It means for short variables I can't see any problem with it and definitely will be better to use full command names instead of shortcut.
Thanks, Michal
Hi Michal,
On Mon, 10 Feb 2014 10:30:37 +0100, Michal Simek monstr@monstr.eu wrote:
Hi Albert,
Hi Michal,
Extending to "short variables" only is fine with me -- I'm not asking you to re-engineer config header files, only to perform a cheap and useful search-and-replace.
Thanks, Michal
Amicalement,
Hi Albert,
On 02/10/2014 10:36 AM, Albert ARIBAUD wrote:
Hi Michal,
Hi Albert,
Hi Michal,
Let's wait for others what they think and separate this from this patch because there is one more patch depends on this which you can see in my pull request. I think we shouldn't limit this just to include/configs/*.h but also to all READMEs and comments.
Thanks, Michal
Hi Michal,
On Mon, 10 Feb 2014 10:45:16 +0100, Michal Simek monstr@monstr.eu wrote:
Hi Albert,
Hi Michal,
Hi Albert,
Hi Michal,
Ok, so a separate patch. Fine with me -- this answers my question re your PR.
Thanks, Michal
Amicalement,
Hi Michal,
"bootm ${load_addr}\0""tftpboot ${load_addr} ${fit_image} && " \
1.8.2.3
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Michal Simek
Michal Simek
