[U-Boot] [PATCH] powerpc/t2080: DDR controller erratum A-009942
This erratum is already implemented for other ARM based QorIQ platforms with the Gen4 DDR controller. Port the fix to the Gen3 controller and enable it for T2080 and T2081.
Reviewed-by: Chris Packham chris.packham@alliedtelesis.co.nz Signed-off-by: Hamish Martin hamish.martin@alliedtelesis.co.nz Cc: York Sun york.sun@nxp.com --- arch/powerpc/cpu/mpc85xx/cmd_errata.c | 3 +++ arch/powerpc/include/asm/config_mpc85xx.h | 1 + drivers/ddr/fsl/mpc85xx_ddr_gen3.c | 17 +++++++++++++++++ 3 files changed, 21 insertions(+)
diff --git a/arch/powerpc/cpu/mpc85xx/cmd_errata.c b/arch/powerpc/cpu/mpc85xx/cmd_errata.c index 3b06ae42e4bc..94b6dcca96b6 100644 --- a/arch/powerpc/cpu/mpc85xx/cmd_errata.c +++ b/arch/powerpc/cpu/mpc85xx/cmd_errata.c @@ -329,6 +329,9 @@ static int do_errata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #ifdef CONFIG_SYS_FSL_ERRATUM_A009663 puts("Work-around for Erratum A009663 enabled\n"); #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A009942 + puts("Work-around for Erratum A009942 enabled\n"); +#endif
return 0; } diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 6d845e859f4a..9e1cd80e16e0 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -910,6 +910,7 @@ defined(CONFIG_PPC_T1014) || defined(CONFIG_PPC_T1013) #define CONFIG_SYS_FSL_ERRATUM_A006593 #define CONFIG_SYS_FSL_ERRATUM_A007186 #define CONFIG_SYS_FSL_ERRATUM_A006379 +#define CONFIG_SYS_FSL_ERRATUM_A009942 #define ESDHCI_QUIRK_BROKEN_TIMEOUT_VALUE #define CONFIG_SYS_FSL_SFP_VER_3_0
diff --git a/drivers/ddr/fsl/mpc85xx_ddr_gen3.c b/drivers/ddr/fsl/mpc85xx_ddr_gen3.c index 653b7f0c770c..a88884377f80 100644 --- a/drivers/ddr/fsl/mpc85xx_ddr_gen3.c +++ b/drivers/ddr/fsl/mpc85xx_ddr_gen3.c @@ -39,6 +39,10 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, #ifdef CONFIG_SYS_FSL_ERRATUM_DDR_A003 u32 save1, save2; #endif +#ifdef CONFIG_SYS_FSL_ERRATUM_A009942 + ulong ddr_freq; + u32 tmp; +#endif
switch (ctrl_num) { case 0: @@ -183,6 +187,19 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, out_be32(&ddr->debug[21], 0x24000000); #endif /* CONFIG_SYS_FSL_ERRATUM_DDR_A003474 */
+#ifdef CONFIG_SYS_FSL_ERRATUM_A009942 + ddr_freq = get_ddr_freq(ctrl_num) / 1000000; + tmp = in_be32(&ddr->debug[28]); + if (ddr_freq <= 1333) + out_be32(&ddr->debug[28], tmp | 0x0080006a); + else if (ddr_freq <= 1600) + out_be32(&ddr->debug[28], tmp | 0x0070006f); + else if (ddr_freq <= 1867) + out_be32(&ddr->debug[28], tmp | 0x00700076); + else if (ddr_freq <= 2133) + out_be32(&ddr->debug[28], tmp | 0x0060007b); +#endif + /* * For RDIMMs, JEDEC spec requires clocks to be stable before reset is * deasserted. Clocks start when any chip select is enabled and clock
- puts("Work-around for Erratum A009942 enabled\n");
Thanks for fixing it. Please also enable this workaround for T1024, T2080, T1040, B4420, B4860, T4240 (and change the subject accordingly).
York
A second thought, NXP is updating this erratum workaround. A new patch will be sent out. Thanks for bring it up.
York
York
Just to clarify, should I abandon this patch because you (or someone else from NXP) will provide a better, more comprehensive fix?
Thanks, Hamish M.
York
Don't abandon it before a new patch is sent.
I got a notice from our hardware team that this workaround needs a little change. While our DDR maintainer is on that, he may be able to add the workaround to DDR3 controller as well.
York
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of york sun Sent: Thursday, October 27, 2016 3:57 AM To: Hamish Martin Hamish.Martin@alliedtelesis.co.nz; u- boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] powerpc/t2080: DDR controller erratum A-009942 I got a notice from our hardware team that this workaround needs a little change. While our DDR maintainer is on that, he may be able to add the workaround to DDR3 controller as well.
York
The new patches cover all DDR3/DDR4 parts. http://patchwork.ozlabs.org/patch/689803 http://patchwork.ozlabs.org/patch/689802
-Shengzhou
York
Hamish,
New implementation of erratum workaround for A009942 is in place, see commit 473f1fc2 and 90101386. This patch is no longer needed.
Thanks.
York
Hamish Martin
Hamish Martin
Shengzhou Liu
york sun
