[PATCH v1] mailbox: add i.MX MU driver
Add i.MX MU based mailbox driver.
Signed-off-by: Viorel Suman viorel.suman@nxp.com Signed-off-by: Peng Fan peng.fan@nxp.com Signed-off-by: Alice Guo alice.guo@nxp.com Reviewed-by: Ye Li ye.li@nxp.com --- drivers/mailbox/Kconfig | 7 + drivers/mailbox/Makefile | 1 + drivers/mailbox/imx-mailbox.c | 417 ++++++++++++++++++++++++++++++++++ 3 files changed, 425 insertions(+) create mode 100644 drivers/mailbox/imx-mailbox.c
diff --git a/drivers/mailbox/Kconfig b/drivers/mailbox/Kconfig index 67d5ac1a74..4d9f004eba 100644 --- a/drivers/mailbox/Kconfig +++ b/drivers/mailbox/Kconfig @@ -21,6 +21,13 @@ config APPLE_MBOX such as the System Management Controller (SMC) and NVMe and this driver is required to get that functionality up and running.
+config IMX_MU_MBOX + bool "Enable i.MX MU MBOX support" + depends on DM_MAILBOX + help + Enable support for i.MX Messaging Unit for communication with other + processors on the SoC using mailbox interface + config SANDBOX_MBOX bool "Enable the sandbox mailbox test driver" depends on DM_MAILBOX && SANDBOX diff --git a/drivers/mailbox/Makefile b/drivers/mailbox/Makefile index 59e8d0de93..96a6adb709 100644 --- a/drivers/mailbox/Makefile +++ b/drivers/mailbox/Makefile @@ -5,6 +5,7 @@
obj-$(CONFIG_$(SPL_)DM_MAILBOX) += mailbox-uclass.o obj-$(CONFIG_APPLE_MBOX) += apple-mbox.o +obj-$(CONFIG_IMX_MU_MBOX) += imx-mailbox.o obj-$(CONFIG_SANDBOX_MBOX) += sandbox-mbox.o obj-$(CONFIG_SANDBOX_MBOX) += sandbox-mbox-test.o obj-$(CONFIG_STM32_IPCC) += stm32-ipcc.o diff --git a/drivers/mailbox/imx-mailbox.c b/drivers/mailbox/imx-mailbox.c new file mode 100644 index 0000000000..584950b20d --- /dev/null +++ b/drivers/mailbox/imx-mailbox.c @@ -0,0 +1,417 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2017-2023 NXP + */ + +#include <asm/io.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <mailbox-uclass.h> +#include <linux/bitfield.h> +#include <linux/bug.h> +#include <linux/iopoll.h> +#include <linux/compat.h> + +/* This driver only exposes the status bits to keep with the + * polling methodology of u-boot. + */ +DECLARE_GLOBAL_DATA_PTR; + +#define IMX_MU_CHANS 24 + +#define IMX_MU_V2_PAR_OFF 0x4 +#define IMX_MU_V2_TR_MASK GENMASK(7, 0) +#define IMX_MU_V2_RR_MASK GENMASK(15, 8) + +enum imx_mu_chan_type { + IMX_MU_TYPE_TX = 0, /* Tx */ + IMX_MU_TYPE_RX = 1, /* Rx */ + IMX_MU_TYPE_TXDB = 2, /* Tx doorbell */ + IMX_MU_TYPE_RXDB = 3, /* Rx doorbell */ + IMX_MU_TYPE_RST = 4, /* Reset */ + IMX_MU_TYPE_TXDB_V2 = 5, /* Tx doorbell with S/W ACK */ +}; + +enum imx_mu_xcr { + IMX_MU_CR, + IMX_MU_GIER, + IMX_MU_GCR, + IMX_MU_TCR, + IMX_MU_RCR, + IMX_MU_xCR_MAX, +}; + +enum imx_mu_xsr { + IMX_MU_SR, + IMX_MU_GSR, + IMX_MU_TSR, + IMX_MU_RSR, + IMX_MU_xSR_MAX, +}; + +struct imx_mu_con_priv { + unsigned int idx; + enum imx_mu_chan_type type; + struct mbox_chan *chan; +}; + +enum imx_mu_type { + IMX_MU_V1, + IMX_MU_V2 = BIT(1), + IMX_MU_V2_S4 = BIT(15), + IMX_MU_V2_IRQ = BIT(16), +}; + +struct imx_mu { + void __iomem *base; + const struct imx_mu_dcfg *dcfg; + u32 num_tr; + u32 num_rr; + /* use pointers to channel as a way to reserve channels */ + struct mbox_chan *channels[IMX_MU_CHANS]; + struct imx_mu_con_priv con_priv[IMX_MU_CHANS]; +}; + +struct imx_mu_dcfg { + int (*tx)(struct imx_mu *plat, struct imx_mu_con_priv *cp, const void *data); + int (*rx)(struct imx_mu *plat, struct imx_mu_con_priv *cp); + int (*rxdb)(struct imx_mu *plat, struct imx_mu_con_priv *cp); + int (*init)(struct imx_mu *plat); + int (*of_xlate)(struct mbox_chan *chan, struct ofnode_phandle_args *args); + enum imx_mu_type type; + u32 xTR; /* Transmit Register0 */ + u32 xRR; /* Receive Register0 */ + u32 xSR[IMX_MU_xSR_MAX]; /* Status Registers */ + u32 xCR[IMX_MU_xCR_MAX]; /* Control Registers */ +}; + +#define IMX_MU_xSR_GIPn(type, x) (type & IMX_MU_V2 ? BIT(x) : BIT(28 + (3 - (x)))) +#define IMX_MU_xSR_RFn(type, x) (type & IMX_MU_V2 ? BIT(x) : BIT(24 + (3 - (x)))) +#define IMX_MU_xSR_TEn(type, x) (type & IMX_MU_V2 ? BIT(x) : BIT(20 + (3 - (x)))) + +/* General Purpose Interrupt Enable */ +#define IMX_MU_xCR_GIEn(type, x) (type & IMX_MU_V2 ? BIT(x) : BIT(28 + (3 - (x)))) +/* Receive Interrupt Enable */ +#define IMX_MU_xCR_RIEn(type, x) (type & IMX_MU_V2 ? BIT(x) : BIT(24 + (3 - (x)))) +/* Transmit Interrupt Enable */ +#define IMX_MU_xCR_TIEn(type, x) (type & IMX_MU_V2 ? BIT(x) : BIT(20 + (3 - (x)))) +/* General Purpose Interrupt Request */ +#define IMX_MU_xCR_GIRn(type, x) (type & IMX_MU_V2 ? BIT(x) : BIT(16 + (3 - (x)))) +/* MU reset */ +#define IMX_MU_xCR_RST(type) (type & IMX_MU_V2 ? BIT(0) : BIT(5)) +#define IMX_MU_xSR_RST(type) (type & IMX_MU_V2 ? BIT(0) : BIT(7)) + +static void imx_mu_write(struct imx_mu *plat, u32 val, u32 offs) +{ + iowrite32(val, plat->base + offs); +} + +static u32 imx_mu_read(struct imx_mu *plat, u32 offs) +{ + return ioread32(plat->base + offs); +} + +static u32 imx_mu_xcr_rmw(struct imx_mu *plat, enum imx_mu_xcr type, u32 set, u32 clr) +{ + u32 val; + + val = imx_mu_read(plat, plat->dcfg->xCR[type]); + val &= ~clr; + val |= set; + imx_mu_write(plat, val, plat->dcfg->xCR[type]); + + return val; +} + +/* check that the channel is open or owned by caller */ +static int imx_mu_check_channel(struct mbox_chan *chan) +{ + struct imx_mu *plat = dev_get_plat(chan->dev); + + if (plat->channels[chan->id] != NULL) { + /* if reserved check that caller owns */ + if (plat->channels[chan->id] == chan) + return 1; /* caller owns the channel */ + + return -EACCES; + } + + return 0; /* channel empty */ +} + +static int imx_mu_chan_request(struct mbox_chan *chan) +{ + struct imx_mu *plat = dev_get_plat(chan->dev); + struct imx_mu_con_priv *cp; + enum imx_mu_chan_type type; + int idx; + + type = chan->id / 4; + idx = chan->id % 4; + + if (imx_mu_check_channel(chan) < 0) /* check if channel already in use */ + return -EPERM; + + plat->channels[chan->id] = chan; + chan->con_priv = kcalloc(1, sizeof(struct imx_mu_con_priv), 0); + if (!chan->con_priv) + return -ENOMEM; + cp = chan->con_priv; + cp->idx = idx; + cp->type = type; + cp->chan = chan; + + switch (type) { + case IMX_MU_TYPE_RX: + imx_mu_xcr_rmw(plat, IMX_MU_RCR, IMX_MU_xCR_RIEn(plat->dcfg->type, idx), 0); + break; + case IMX_MU_TYPE_TXDB_V2: + case IMX_MU_TYPE_TXDB: + case IMX_MU_TYPE_RXDB: + imx_mu_xcr_rmw(plat, IMX_MU_GIER, IMX_MU_xCR_GIEn(plat->dcfg->type, idx), 0); + break; + default: + break; + } + + return 0; +} + +static int imx_mu_chan_free(struct mbox_chan *chan) +{ + struct imx_mu *plat = dev_get_plat(chan->dev); + struct imx_mu_con_priv *cp = chan->con_priv; + + if (imx_mu_check_channel(chan) <= 0) /* check that the channel is also not empty */ + return -EINVAL; + + /* if you own channel and channel is NOT empty */ + plat->channels[chan->id] = NULL; + switch (cp->type) { + case IMX_MU_TYPE_TX: + imx_mu_xcr_rmw(plat, IMX_MU_TCR, 0, IMX_MU_xCR_TIEn(plat->dcfg->type, cp->idx)); + break; + case IMX_MU_TYPE_RX: + imx_mu_xcr_rmw(plat, IMX_MU_RCR, 0, IMX_MU_xCR_RIEn(plat->dcfg->type, cp->idx)); + break; + case IMX_MU_TYPE_TXDB_V2: + case IMX_MU_TYPE_TXDB: + case IMX_MU_TYPE_RXDB: + imx_mu_xcr_rmw(plat, IMX_MU_GIER, 0, IMX_MU_xCR_GIEn(plat->dcfg->type, cp->idx)); + break; + default: + break; + } + + kfree(cp); + + return 0; +} + +static int imx_mu_send(struct mbox_chan *chan, const void *data) +{ + struct imx_mu *plat = dev_get_plat(chan->dev); + struct imx_mu_con_priv *cp = chan->con_priv; + + if (imx_mu_check_channel(chan) < 1) /* return if channel isn't owned */ + return -EPERM; + + return plat->dcfg->tx(plat, cp, data); +} + +static int imx_mu_recv(struct mbox_chan *chan, void *data) +{ + struct imx_mu *plat = dev_get_plat(chan->dev); + struct imx_mu_con_priv *cp = chan->con_priv; + u32 ctrl, val; + + if (imx_mu_check_channel(chan) < 1) /* return if channel isn't owned */ + return -EPERM; + + switch (cp->type) { + case IMX_MU_TYPE_TXDB_V2: + case IMX_MU_TYPE_RXDB: + /* check if GSR[GIRn] bit is set */ + if (readx_poll_timeout(ioread32, plat->base + plat->dcfg->xSR[IMX_MU_GSR], + val, val & BIT(cp->idx), 1000000) < 0) + return -EBUSY; + + ctrl = imx_mu_read(plat, plat->dcfg->xCR[IMX_MU_GIER]); + val = imx_mu_read(plat, plat->dcfg->xSR[IMX_MU_GSR]); + val &= IMX_MU_xSR_GIPn(plat->dcfg->type, cp->idx) & + (ctrl & IMX_MU_xCR_GIEn(plat->dcfg->type, cp->idx)); + break; + default: + dev_warn(chan->dev, "Unhandled channel type %d\n", cp->type); + return -EOPNOTSUPP; + }; + + if (val == IMX_MU_xSR_GIPn(plat->dcfg->type, cp->idx)) + plat->dcfg->rxdb(plat, cp); + + return 0; +} + +static int imx_mu_of_to_plat(struct udevice *dev) +{ + struct imx_mu *plat = dev_get_plat(dev); + fdt_addr_t addr; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) + return -ENODEV; + + plat->base = (struct mu_type *)addr; + + return 0; +} + +static int imx_mu_init_generic(struct imx_mu *plat) +{ + unsigned int i; + unsigned int val; + + if (plat->num_rr > 4 || plat->num_tr > 4) { + WARN_ONCE(true, "%s not support TR/RR larger than 4\n", __func__); + return -EOPNOTSUPP; + } + + /* Set default MU configuration */ + for (i = 0; i < IMX_MU_xCR_MAX; i++) + imx_mu_write(plat, 0, plat->dcfg->xCR[i]); + + /* Clear any pending GIP */ + val = imx_mu_read(plat, plat->dcfg->xSR[IMX_MU_GSR]); + imx_mu_write(plat, val, plat->dcfg->xSR[IMX_MU_GSR]); + + /* Clear any pending RSR */ + for (i = 0; i < plat->num_rr; i++) + imx_mu_read(plat, plat->dcfg->xRR + i * 4); + + return 0; +} + +static int imx_mu_generic_of_xlate(struct mbox_chan *chan, struct ofnode_phandle_args *args) +{ + enum imx_mu_chan_type type; + int idx, cid; + + if (args->args_count != 2) { + dev_err(chan->dev, "Invalid argument count %d\n", args->args_count); + return -EINVAL; + } + + type = args->args[0]; /* channel type */ + idx = args->args[1]; /* index */ + + cid = type * 4 + idx; + if (cid >= IMX_MU_CHANS) { + dev_err(chan->dev, "Not supported channel number: %d. (type: %d, idx: %d)\n", + cid, type, idx); + return -EINVAL; + } + + chan->id = cid; + + return 0; +} + +static int imx_mu_generic_tx(struct imx_mu *plat, struct imx_mu_con_priv *cp, + const void *data) +{ + switch (cp->type) { + case IMX_MU_TYPE_TXDB_V2: + imx_mu_xcr_rmw(plat, IMX_MU_GCR, IMX_MU_xCR_GIRn(plat->dcfg->type, cp->idx), 0); + break; + default: + dev_warn(cp->chan->dev, "Send data on wrong channel type: %d\n", cp->type); + return -EINVAL; + } + + return 0; +} + +static int imx_mu_generic_rxdb(struct imx_mu *plat, struct imx_mu_con_priv *cp) +{ + imx_mu_write(plat, IMX_MU_xSR_GIPn(plat->dcfg->type, cp->idx), + plat->dcfg->xSR[IMX_MU_GSR]); + + return 0; +} + +static const struct imx_mu_dcfg imx_mu_cfg_imx95 = { + .tx = imx_mu_generic_tx, + .rxdb = imx_mu_generic_rxdb, + .init = imx_mu_init_generic, + .of_xlate = imx_mu_generic_of_xlate, + .type = IMX_MU_V2, + .xTR = 0x200, + .xRR = 0x280, + .xSR = {0xC, 0x118, 0x124, 0x12C}, + .xCR = {0x8, 0x110, 0x114, 0x120, 0x128}, +}; + +static const struct udevice_id ids[] = { + { .compatible = "fsl,imx95-mu", .data = (ulong)&imx_mu_cfg_imx95 }, + { } +}; + +int imx_mu_of_xlate(struct mbox_chan *chan, struct ofnode_phandle_args *args) +{ + struct imx_mu *plat = dev_get_plat(chan->dev); + + return plat->dcfg->of_xlate(chan, args); +} + +struct mbox_ops imx_mu_ops = { + .of_xlate = imx_mu_of_xlate, + .request = imx_mu_chan_request, + .rfree = imx_mu_chan_free, + .send = imx_mu_send, + .recv = imx_mu_recv, +}; + +static void imx_mu_get_tr_rr(struct imx_mu *plat) +{ + u32 val; + + if (plat->dcfg->type & IMX_MU_V2) { + val = imx_mu_read(plat, IMX_MU_V2_PAR_OFF); + plat->num_tr = FIELD_GET(IMX_MU_V2_TR_MASK, val); + plat->num_rr = FIELD_GET(IMX_MU_V2_RR_MASK, val); + } else { + plat->num_tr = 4; + plat->num_rr = 4; + } +} + +static int imx_mu_probe(struct udevice *dev) +{ + struct imx_mu *plat = dev_get_plat(dev); + int ret; + + debug("%s(dev=%p)\n", __func__, dev); + + plat->dcfg = (void *)dev_get_driver_data(dev); + + imx_mu_get_tr_rr(plat); + + ret = plat->dcfg->init(plat); + if (ret) { + dev_err(dev, "Failed to init MU\n"); + return ret; + } + + return 0; +} + +U_BOOT_DRIVER(imx_mu) = { + .name = "imx-mu", + .id = UCLASS_MAILBOX, + .of_match = ids, + .of_to_plat = imx_mu_of_to_plat, + .plat_auto = sizeof(struct imx_mu), + .probe = imx_mu_probe, + .ops = &imx_mu_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Please improve the commit message. The help text in Kconfig is clearer.
Who is going to be a user of this driver?
From reading the compatible string, I assume this is preparatory work
for the i.MX95 support.
If this is the case, please also state in the commit log.
Fabio Estevam
