[U-Boot] [PATCH] spl: Introduce SPL_DM_GPIO Kconfig define
This define indicates if DM_GPIO shall be supported in SPL. This allows proper operation of DM converted GPIO drivers in SPL, which use #if !CONFIG_IS_ENABLED(DM_GPIO) to also support not yet DM/DTS converted boards.
Signed-off-by: Lukasz Majewski lukma@denx.de ---
common/spl/Kconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 5b7667ea16..7c3391cabe 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -458,6 +458,12 @@ config SPL_DMA_SUPPORT the CPU moving the data. Enable this option to build the drivers in drivers/dma as part of an SPL build.
+config SPL_DM_GPIO + bool "Support Driver Model GPIO drivers" + depends on SPL_GPIO_SUPPORT + help + Enable support for Driver Model based GPIO drivers in SPL. + config SPL_DRIVERS_MISC_SUPPORT bool "Support misc drivers" help
Lukasz Majewski
