[U-Boot] [PATCH v3 0/2] Add GPIO driver for BCM2835 SoC
Also, add the driver to the raspberrypi default config
Cc: Stephen Warren swarren@wwwdotorg.org Cc: Albert Aribaud albert.u.boot@aribaud.net
Vikram Narayanan (2): gpio: bcm2835: Add GPIO driver rbpi: Add BCM2835 GPIO driver for raspberry pi
Changes from v2: Incorporate further comments from Stephen Warren Changes from v1: Incorporate comments from Stephen Warren
arch/arm/include/asm/arch-bcm2835/gpio.h | 71 ++++++++++++++++++++++++ drivers/gpio/Makefile | 1 + drivers/gpio/bcm2835_gpio.c | 88 ++++++++++++++++++++++++++++++ include/configs/rpi_b.h | 3 +- 4 files changed, 162 insertions(+), 1 deletions(-) create mode 100644 arch/arm/include/asm/arch-bcm2835/gpio.h create mode 100644 drivers/gpio/bcm2835_gpio.c
Driver for BCM2835 SoC. This gives the basic functionality of setting/clearing the output.
Signed-off-by: Vikram Narayanan vikram186@gmail.com --- arch/arm/include/asm/arch-bcm2835/gpio.h | 71 ++++++++++++++++++++++++ drivers/gpio/Makefile | 1 + drivers/gpio/bcm2835_gpio.c | 88 ++++++++++++++++++++++++++++++ 3 files changed, 160 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-bcm2835/gpio.h create mode 100644 drivers/gpio/bcm2835_gpio.c
diff --git a/arch/arm/include/asm/arch-bcm2835/gpio.h b/arch/arm/include/asm/arch-bcm2835/gpio.h new file mode 100644 index 0000000..515456a --- /dev/null +++ b/arch/arm/include/asm/arch-bcm2835/gpio.h @@ -0,0 +1,71 @@ +/* + * Copyright (C) 2012 Vikram Narayananan + * vikram186@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _BCM2835_GPIO_H_ +#define _BCM2835_GPIO_H_ + +#define BCM2835_GPIO_BASE 0x7E200000 +#define BCM2835_GPIO_COUNT 53 + +#define BCM2835_GPIO_FSEL_MASK 0x7 +#define BCM2835_GPIO_INPUT 0x0 +#define BCM2835_GPIO_OUTPUT 0x1 +#define BCM2835_GPIO_ALT0 0x2 +#define BCM2835_GPIO_ALT1 0x3 +#define BCM2835_GPIO_ALT2 0x4 +#define BCM2835_GPIO_ALT3 0x5 +#define BCM2835_GPIO_ALT4 0x6 +#define BCM2835_GPIO_ALT5 0x7 + +#define BCM2835_GPIO_COMMON_BANK(gpio) ((gpio < 32) ? 0 : 1) +#define BCM2835_GPIO_COMMON_SHIFT(gpio) (gpio & 0x1f) + +#define BCM2835_GPIO_FSEL_BANK(gpio) (gpio / 10) +#define BCM2835_GPIO_FSEL_SHIFT(gpio) ((gpio % 10) * 3) + +struct bcm_gpio_regs { + u32 gpfsel[6]; + u32 reserved1; + u32 gpset[2]; + u32 reserved2; + u32 gpclr[2]; + u32 reserved3; + u32 gplev[2]; + u32 reserved4; + u32 gpeds[2]; + u32 reserved5; + u32 gpren[2]; + u32 reserved6; + u32 gpfen[2]; + u32 reserved7; + u32 gphen[2]; + u32 reserved8; + u32 gplen[2]; + u32 reserved9; + u32 gparen[2]; + u32 reserved10; + u32 gppud; + u32 gppudclk[2]; +}; + +#endif /* _BCM2835_GPIO_H_ */ diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 32a2474..8d2f2b2 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -40,6 +40,7 @@ COBJS-$(CONFIG_TEGRA_GPIO) += tegra_gpio.o COBJS-$(CONFIG_DA8XX_GPIO) += da8xx_gpio.o COBJS-$(CONFIG_ALTERA_PIO) += altera_pio.o COBJS-$(CONFIG_MPC83XX_GPIO) += mpc83xx_gpio.o +COBJS-$(CONFIG_BCM2835_GPIO) += bcm2835_gpio.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/gpio/bcm2835_gpio.c b/drivers/gpio/bcm2835_gpio.c new file mode 100644 index 0000000..eb02efa --- /dev/null +++ b/drivers/gpio/bcm2835_gpio.c @@ -0,0 +1,88 @@ +/* + * Copyright (C) 2012 Vikram Narayananan + * vikram186@gmail.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/gpio.h> +#include <asm/io.h> + +inline int gpio_is_valid(unsigned gpio) +{ + return (gpio < BCM2835_GPIO_COUNT); +} + +int gpio_request(unsigned gpio, const char *label) +{ + return gpio_is_valid(gpio); +} + +int gpio_free(unsigned gpio) +{ + return 0; +} + +int gpio_direction_input(unsigned gpio) +{ + struct bcm_gpio_regs *reg = (struct bcm_gpio_regs *)BCM2835_GPIO_BASE; + unsigned val; + + val = readl(®->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]); + val &= ~(BCM2835_GPIO_FSEL_MASK << BCM2835_GPIO_FSEL_SHIFT(gpio)); + val |= (BCM2835_GPIO_INPUT << BCM2835_GPIO_FSEL_SHIFT(gpio)); + writel(val, reg->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]); + } + +int gpio_direction_output(unsigned gpio, int value) +{ + struct bcm_gpio_regs *reg = (struct bcm_gpio_regs *)BCM2835_GPIO_BASE; + unsigned val; + + if (value) + gpio_set_value(gpio, value); + + val = readl(®->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]); + val &= ~(BCM2835_GPIO_FSEL_MASK << BCM2835_GPIO_FSEL_SHIFT(gpio)); + val |= (BCM2835_GPIO_OUTPUT << BCM2835_GPIO_FSEL_SHIFT(gpio)); + writel(val, reg->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]); +} + +int gpio_get_value(unsigned gpio) +{ + struct bcm_gpio_regs *reg = (struct bcm_gpio_regs *)BCM2835_GPIO_BASE; + unsigned val; + + val = readl(®->gplev[BCM2835_GPIO_COMMON_BANK(gpio)]); + + return (val >> BCM2835_GPIO_COMMON_SHIFT(gpio)) & 0x1; +} + +int gpio_set_value(unsigned gpio, int value) +{ + struct bcm_gpio_regs *reg = (struct bcm_gpio_regs *)BCM2835_GPIO_BASE; + u32 *output_reg = value ? reg->gpset : reg->gpclr; + + writel(1 << BCM2835_GPIO_COMMON_SHIFT(gpio), + output_reg[BCM2835_GPIO_COMMON_BANK(gpio)]); + + return 0; +} +
Signed-off-by: Vikram Narayananvikram186@gmail.com
- Copyright (C) 2012 Vikram Narayananan
- *vikram186@gmail.com
- project.
- MA 02111-1307 USA
GPIO count should be 54 to make the gpio_is_valid work correctly when the gpio is 53. Will fix in v4.
Any other comments?
+#define BCM2835_GPIO_COMMON_BANK(gpio) ((gpio< 32) ? 0 : 1) +#define BCM2835_GPIO_COMMON_SHIFT(gpio) (gpio& 0x1f)
- u32 gpfsel[6];
- u32 reserved1;
- u32 gpset[2];
- u32 reserved2;
- u32 gpclr[2];
- u32 reserved3;
- u32 gplev[2];
- u32 reserved4;
- u32 gpeds[2];
- u32 reserved5;
- u32 gpren[2];
- u32 reserved6;
- u32 gpfen[2];
- u32 reserved7;
- u32 gphen[2];
- u32 reserved8;
- u32 gplen[2];
- u32 reserved9;
- u32 gparen[2];
- u32 reserved10;
- u32 gppud;
- u32 gppudclk[2];
- project.
- MA 02111-1307 USA
+#include<common.h> +#include<asm/gpio.h> +#include<asm/io.h>
- return (gpio< BCM2835_GPIO_COUNT);
- return gpio_is_valid(gpio);
- struct bcm_gpio_regs *reg = (struct bcm_gpio_regs *)BCM2835_GPIO_BASE;
- unsigned val;
- val = readl(®->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]);
- val&= ~(BCM2835_GPIO_FSEL_MASK<< BCM2835_GPIO_FSEL_SHIFT(gpio));
- val |= (BCM2835_GPIO_INPUT<< BCM2835_GPIO_FSEL_SHIFT(gpio));
- writel(val, reg->gpfsel[BCM2835_GPIO_FSEL_BANK(gpio)]);
- unsigned val;
- if (value)
- val |= (BCM2835_GPIO_OUTPUT<< BCM2835_GPIO_FSEL_SHIFT(gpio));
- unsigned val;
- val = readl(®->gplev[BCM2835_GPIO_COMMON_BANK(gpio)]);
- return (val>> BCM2835_GPIO_COMMON_SHIFT(gpio))& 0x1;
- u32 *output_reg = value ? reg->gpset : reg->gpclr;
- writel(1<< BCM2835_GPIO_COMMON_SHIFT(gpio),
Oh dear. I posted an updated version of your patches which fix a bunch of errors. I guess I'll wait and see if there are any other comments on other patches in that series, and re-post that series, or just that patch, with that fixed later.
P.S. There's no need to quote the entire patch just to comment on one line.
Add the driver to the default config
Signed-off-by: Vikram Narayanan vikram186@gmail.com --- include/configs/rpi_b.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index f547027..d4bbccc 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -43,7 +43,8 @@ #define CONFIG_SYS_NO_FLASH
/* Devices */ -/* None yet */ +/* GPIO */ +#define CONFIG_BCM2835_GPIO
/* Console UART */ #define CONFIG_PL011_SERIAL
Hmm. I tested this on real HW, and there are quite a few issues. I just re-posted my base Raspberry Pi series and rolled these two patches onto the end, including the fixes I found needed during actual compilation and testing.
Stephen Warren
Vikram Narayanan
