[U-Boot-Users] usb.c patch
Hello,
Please find a little patch which corrects a buffer overflow in usb.c
Best regards
CHANGELOG: Patch by Laurent MOHIN, 05 Feb 2004 - common/usb.c: buffer overflow correction
--- work/u-boot-1.0.0/common/usb.c Thu Sep 18 11:21:35 2003 +++ work-lm/u-boot-1.0.0/common/usb.c Thu Feb 5 17:07:38 2004 @@ -46,6 +46,7 @@ #include <405gp_pci.h> #endif
+#define BUFFER_MAX_SIZE 512
#undef USB_DEBUG
@@ -386,7 +387,12 @@ return -1; } tmp=swap_16(config->wTotalLength); - + + if (tmp > BUFFER_MAX_SIZE) { + USB_PRINTF("usb_get_configuration_no: failed to get descriptor - length too long %d\n",tmp); + return -1; + } + result = usb_get_descriptor(dev, USB_DT_CONFIG, cfgno, buffer, tmp); USB_PRINTF("get_conf_no %d Result %d, wLength %d\n",cfgno,result,tmp); return result; @@ -516,8 +522,8 @@ */ int usb_string(struct usb_device *dev, int index, char *buf, size_t size) { - - unsigned char mybuf[256]; + + unsigned char mybuf[BUFFER_MAX_SIZE]; unsigned char *tbuf; int err; unsigned int u, idx; @@ -550,9 +556,15 @@ if (err < 0) return err; u=tbuf[0]; USB_PRINTF("Strn Len %d, index %d\n",u,index); + + if (u > BUFFER_MAX_SIZE) { + USB_PRINTF("usb_string : failed to get string - length too long %d\n",u); + return -1; + } + err = usb_get_string(dev, dev->string_langid, index, tbuf, u); @@ -619,8 +631,8 @@ { int addr, err; int tmp; - unsigned char tmpbuf[256]; - + unsigned char tmpbuf[BUFFER_MAX_SIZE]; + dev->descriptor.bMaxPacketSize0 = 8; /* Start off at 8 bytes */ dev->maxpacketsize = 0; /* Default to 8 byte max packet size */ dev->epmaxpacketin [0] = 8; @@ -895,7 +907,7 @@
int usb_hub_configure(struct usb_device *dev) { - unsigned char buffer[256], *bitmap; + unsigned char buffer[BUFFER_MAX_SIZE], *bitmap; struct usb_hub_descriptor *descriptor; struct usb_hub_status *hubsts; int i; @@ -912,7 +924,13 @@ return -1; } descriptor = (struct usb_hub_descriptor *)buffer; - if (usb_get_hub_descriptor(dev, buffer, descriptor->bLength) < 0) { + + if (descriptor->bLength > BUFFER_MAX_SIZE) { + USB_HUB_PRINTF("usb_hub_configure: failed to get hub descriptor - length too long %d\n",descriptor->bLength); + return -1; + } + + if (usb_get_hub_descriptor(dev, buffer, descriptor->bLength) < 0) { USB_HUB_PRINTF("usb_hub_configure: failed to get hub descriptor 2nd giving up %lX\n",dev->status); return -1; } @@ -968,7 +986,13 @@ for (i = 0; i < dev->maxchild; i++) USB_HUB_PRINTF("port %d is%s removable\n", i + 1, hub->desc.DeviceRemovable[(i + 1)/8] & (1 << ((i + 1)%8)) ? " not" : ""); - if (usb_get_hub_status(dev, buffer) < 0) { + + if (sizeof(struct usb_hub_status) > BUFFER_MAX_SIZE) { + USB_HUB_PRINTF("usb_hub_configure: failed to get Status - length too long %d\n",descriptor->bLength); + return -1; + } + + if (usb_get_hub_status(dev, buffer) < 0) { USB_HUB_PRINTF("usb_hub_configure: failed to get Status %lX\n",dev->status); return -1; }
In message OF56887FBC.3A841413-ONC1256E31.005A0EAE-C1256E31.005AF086@se.wavetek.com you wrote:
I would like to add this, but your patch is broken because your mailer added some line wraps.
Please resubmit. Make sure to follow the instructions of the README, especially sections "Coding Standards" (Indentation!!) and "Submitting Patches".
Laurent Mohin
