Miscellaneous fixes made when developing the lwIP series [1]. They are posted separately since they make sense on their own. Subsequent versions of the lwIP series will contain a squashed version of this one.
[1] http://patchwork.ozlabs.org/project/uboot/list/?series=420712&state=%2A&...
Changes in v4:
- "net: fm: call dtsec_init_phy() only when it is defined" Use '#if CONFIG_IS_ENABLED()' not 'if IS_ENABLED()' which would still cause an error. - Drop "Makefile: detect HOST_ARCH properly when CROSS_COMPILE is multi-word". The first use case mentioned in the patch description (cross-compiling sandbox) is not valid, and the second one (buildman) is actually addressed in another patch ("buildman/toolchain.py: do not set CROSS_COMPILE for sandbox"). - Rebased onto next
Changes in v3:
- Apply R-b tags from Peter R. - Rework "buildman/toolchain.py: set CROSS_COMPILE only if self.cross is set". Subject changed to "buildman/toolchain.py: do not set CROSS_COMPILE for sandbox", GetEnvArgs function fixed as well, and test cases added. (Simon G.)
Changes in v2:
- Rebased onto master - "flash: prefix error codes with FL_" Update drivers/mtd/altera_qspi.c too. This was mentioned by Simon G. in my lwIP v9 thread [1]. Tom R./Ilias A./Peter R.: I kept your R-b tags, please shout if it's not OK. - "net: fm: call dtsec_init_phy() only when it is defined" Address Simon G.'s comments: update condition (parentheses, CONFIG_BITBANGMII, if instead of #if). Peter R: I dropped your R-b since the code changed significantly. - New patches: "common: update: UPDATE_COMMON implies CMD_TFTPBOOT" "cmd: pxe: CMD_PXE implies CMD_TFTPBOOT" "buildman/toolchain.py: set CROSS_COMPILE only if self.cross is set"
[1] https://lists.denx.de/pipermail/u-boot/2024-August/563497.html
Jerome Forissier (15): buildman/toolchain.py: do not set CROSS_COMPILE for sandbox flash: prefix error codes with FL_ at91: rename mem_init() to at91_mem_init() arm: omap2: add missing #include <netdev.h> net: fm: call dtsec_init_phy() only when it is defined net: wget: removed unused function wget_success() net: phy: ncsi: depend on NET net: ftgmac100: depend on NET net: wget: allow EFI boot net: fec_mxc_init(): do not ignore return status of fec_open() test/py: net_boot: fix comment test/py: test_efi_loader: add missing dependency on cmd_tftpboot test/py: test_efi_loader: add HTTP (wget) test for the EFI loader common: update: UPDATE_COMMON implies CMD_TFTPBOOT cmd: pxe: CMD_PXE implies CMD_TFTPBOOT
arch/arm/mach-at91/include/mach/at91_common.h | 2 +- arch/arm/mach-at91/spl_at91.c | 2 +- arch/arm/mach-at91/spl_atmel.c | 2 +- arch/arm/mach-omap2/omap3/emac.c | 1 + .../atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 2 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 2 +- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 2 +- .../atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 2 +- .../sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 2 +- board/atmel/sama5d2_icp/sama5d2_icp.c | 2 +- .../atmel/sama5d2_xplained/sama5d2_xplained.c | 2 +- .../atmel/sama5d3_xplained/sama5d3_xplained.c | 2 +- board/atmel/sama5d3xek/sama5d3xek.c | 2 +- .../atmel/sama5d4_xplained/sama5d4_xplained.c | 2 +- board/atmel/sama5d4ek/sama5d4ek.c | 2 +- board/cobra5272/flash.c | 26 ++++---- .../conclusive/kstr-sama5d27/kstr-sama5d27.c | 2 +- board/freescale/m5253demo/flash.c | 6 +- board/gardena/smart-gateway-at91sam/spl.c | 2 +- board/siemens/corvus/board.c | 2 +- board/siemens/smartweb/smartweb.c | 2 +- board/siemens/taurus/taurus.c | 2 +- cmd/Kconfig | 1 + common/Kconfig | 1 + common/flash.c | 44 ++++++------- drivers/mtd/altera_qspi.c | 4 +- drivers/mtd/cfi_flash.c | 36 +++++------ drivers/net/Kconfig | 1 + drivers/net/fec_mxc.c | 3 +- drivers/net/fm/eth.c | 6 +- drivers/net/phy/Kconfig | 1 + include/flash.h | 20 +++--- net/wget.c | 11 ++-- test/py/tests/test_efi_loader.py | 62 ++++++++++++++----- test/py/tests/test_net_boot.py | 2 +- tools/buildman/test.py | 46 ++++++++++++++ tools/buildman/toolchain.py | 6 +- 37 files changed, 200 insertions(+), 115 deletions(-)
When building for sandbox, self.cross is empty.
In MakeEnvironment(), CROSS_COMPILE is defined to be self.cross (with or without a full path), optionally prefixed by the toolchain wrapper defined in ~/.buildman. This is fine when self.cross is not empty, but it doesn't make sense when it is: - Either there is no wrapper and we end up with an empty CROSS_COMPILE which is the same as not defining it (the host compiler will be used), - Or there is a wrapper and CROSS_COMPILE will contain only the wrapper which obviously is not a valid compiler, hence an error.
Test case:
$ sudo apt install ccache $ grep -q toolchain-wrapper ~/.buildman || \ printf "[toolchain-wrapper]\nwrapper = ccache\n" >>~/.buildman $ make mrproper $ ./tools/buildman/buildman sandbox_noinst $ ./tools/buildman/buildman sandbox_noinst Building current source for 1 boards (1 thread, 24 jobs per thread) sandbox: + sandbox_noinst +arch/sandbox/lib/reloc_sandbox_efi.c:10:15: error: operator '==' has no left operand + 10 | #if HOST_ARCH == HOST_ARCH_X86_64 + | ^~ [...]
The GetEnvArgs function is modified too, since the VAR_CROSS_COMPILE case has the same issue.
In tools/buildman/test.py, testGetEnvArgs is extended and testMakeEnvironment is added. They check the 'arm' and 'sandbox' toolchains, with and without a wrapper.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- tools/buildman/test.py | 46 +++++++++++++++++++++++++++++++++++++ tools/buildman/toolchain.py | 6 +++-- 2 files changed, 50 insertions(+), 2 deletions(-)
diff --git a/tools/buildman/test.py b/tools/buildman/test.py index 5eed013d51c..46aa2a17916 100644 --- a/tools/buildman/test.py +++ b/tools/buildman/test.py @@ -36,6 +36,16 @@ main: /usr/sbin x86: i386 x86_64 '''
+settings_data_wrapper = ''' +# Buildman settings file + +[toolchain] +main: /usr/sbin + +[toolchain-wrapper] +wrapper = ccache +''' + migration = '''===================== WARNING ====================== This board does not use CONFIG_DM. CONFIG_DM will be compulsory starting with the v2020.01 release. @@ -606,6 +616,9 @@ class TestBuild(unittest.TestCase): tc.GetEnvArgs(toolchain.VAR_ARCH)) self.assertEqual('', tc.GetEnvArgs(toolchain.VAR_MAKE_ARGS))
+ tc = self.toolchains.Select('sandbox') + self.assertEqual('', tc.GetEnvArgs(toolchain.VAR_CROSS_COMPILE)) + self.toolchains.Add('/path/to/x86_64-linux-gcc', test=False) tc = self.toolchains.Select('x86') self.assertEqual('/path/to', @@ -614,6 +627,39 @@ class TestBuild(unittest.TestCase): self.assertEqual('HOSTCC=clang CC=clang', tc.GetEnvArgs(toolchain.VAR_MAKE_ARGS))
+ # Test config with ccache wrapper + bsettings.setup(None) + bsettings.add_file(settings_data_wrapper) + + tc = self.toolchains.Select('arm') + self.assertEqual('ccache arm-linux-', + tc.GetEnvArgs(toolchain.VAR_CROSS_COMPILE)) + + tc = self.toolchains.Select('sandbox') + self.assertEqual('', tc.GetEnvArgs(toolchain.VAR_CROSS_COMPILE)) + + def testMakeEnvironment(self): + """Test the MakeEnvironment function""" + tc = self.toolchains.Select('arm') + env = tc.MakeEnvironment(False) + self.assertEqual(env[b'CROSS_COMPILE'], b'arm-linux-') + + tc = self.toolchains.Select('sandbox') + env = tc.MakeEnvironment(False) + self.assertTrue(b'CROSS_COMPILE' not in env) + + # Test config with ccache wrapper + bsettings.setup(None) + bsettings.add_file(settings_data_wrapper) + + tc = self.toolchains.Select('arm') + env = tc.MakeEnvironment(False) + self.assertEqual(env[b'CROSS_COMPILE'], b'ccache arm-linux-') + + tc = self.toolchains.Select('sandbox') + env = tc.MakeEnvironment(False) + self.assertTrue(b'CROSS_COMPILE' not in env) + def testPrepareOutputSpace(self): def _Touch(fname): tools.write_file(os.path.join(base_dir, fname), b'') diff --git a/tools/buildman/toolchain.py b/tools/buildman/toolchain.py index 6ca79c2c0f9..a7d7883b851 100644 --- a/tools/buildman/toolchain.py +++ b/tools/buildman/toolchain.py @@ -159,6 +159,8 @@ class Toolchain: if which == VAR_CROSS_COMPILE: wrapper = self.GetWrapper() base = '' if self.arch == 'sandbox' else self.path + if (base == '' and self.cross == ''): + return '' return wrapper + os.path.join(base, self.cross) elif which == VAR_PATH: return self.path @@ -208,10 +210,10 @@ class Toolchain: if self.override_toolchain: # We'll use MakeArgs() to provide this pass - elif full_path: + elif full_path and self.cross: env[b'CROSS_COMPILE'] = tools.to_bytes( wrapper + os.path.join(self.path, self.cross)) - else: + elif self.cross: env[b'CROSS_COMPILE'] = tools.to_bytes(wrapper + self.cross)
# Detect a Python virtualenv and avoid defeating it
Hi Jerome,
On Wed, 11 Sept 2024 at 03:58, Jerome Forissier jerome.forissier@linaro.org wrote:
Test case:
- 10 | #if HOST_ARCH == HOST_ARCH_X86_64
I did not expect to still get that same error now, but OK.
Prefix the flash status codes (ERR_*) with FL_ in order to avoid clashes with third-party libraries. Case in point: including the lwIP library header file <lwip/err.h> which defines err_enum_t as an enum with values being ERR_*.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com --- board/cobra5272/flash.c | 26 +++++++++--------- board/freescale/m5253demo/flash.c | 6 ++--- common/flash.c | 44 +++++++++++++++---------------- drivers/mtd/altera_qspi.c | 4 +-- drivers/mtd/cfi_flash.c | 36 ++++++++++++------------- include/flash.h | 20 +++++++------- 6 files changed, 68 insertions(+), 68 deletions(-)
diff --git a/board/cobra5272/flash.c b/board/cobra5272/flash.c index 616842e62f4..d324aa6ac11 100644 --- a/board/cobra5272/flash.c +++ b/board/cobra5272/flash.c @@ -135,22 +135,22 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) { ulong result; int iflag, cflag, prot, sect; - int rc = ERR_OK; + int rc = FL_ERR_OK; int chip1; ulong start;
/* first look for protection bits */
if (info->flash_id == FLASH_UNKNOWN) - return ERR_UNKNOWN_FLASH_TYPE; + return FL_ERR_UNKNOWN_FLASH_TYPE;
if ((s_first < 0) || (s_first > s_last)) { - return ERR_INVAL; + return FL_ERR_INVAL; }
if ((info->flash_id & FLASH_VENDMASK) != (AMD_MANUFACT & FLASH_VENDMASK)) { - return ERR_UNKNOWN_FLASH_VENDOR; + return FL_ERR_UNKNOWN_FLASH_VENDOR; }
prot = 0; @@ -160,7 +160,7 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) } } if (prot) - return ERR_PROTECTED; + return FL_ERR_PROTECTED;
/* * Disable interrupts which might cause a timeout @@ -217,11 +217,11 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) MEM_FLASH_ADDR1 = CMD_READ_ARRAY;
if (chip1 == ERR) { - rc = ERR_PROG_ERROR; + rc = FL_ERR_PROG_ERROR; goto outahere; } if (chip1 == TMO) { - rc = ERR_TIMEOUT; + rc = FL_ERR_TIMEOUT; goto outahere; }
@@ -252,7 +252,7 @@ static int write_word(flash_info_t *info, ulong dest, ulong data) { volatile u16 *addr = (volatile u16 *) dest; ulong result; - int rc = ERR_OK; + int rc = FL_ERR_OK; int cflag, iflag; int chip1; ulong start; @@ -262,7 +262,7 @@ static int write_word(flash_info_t *info, ulong dest, ulong data) */ result = *addr; if ((result & data) != data) - return ERR_NOT_ERASED; + return FL_ERR_NOT_ERASED;
/* * Disable interrupts which might cause a timeout @@ -302,7 +302,7 @@ static int write_word(flash_info_t *info, ulong dest, ulong data) *addr = CMD_READ_ARRAY;
if (chip1 == ERR || *addr != data) - rc = ERR_PROG_ERROR; + rc = FL_ERR_PROG_ERROR;
if (iflag) enable_interrupts(); @@ -320,13 +320,13 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt)
if (addr & 1) { printf ("unaligned destination not supported\n"); - return ERR_ALIGN; + return FL_ERR_ALIGN; }
#if 0 if (cnt & 1) { printf ("odd transfer sizes not supported\n"); - return ERR_ALIGN; + return FL_ERR_ALIGN; } #endif
@@ -364,5 +364,5 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) cnt -= 1; }
- return ERR_OK; + return FL_ERR_OK; } diff --git a/board/freescale/m5253demo/flash.c b/board/freescale/m5253demo/flash.c index 334518a4bc9..ab5d2ebff64 100644 --- a/board/freescale/m5253demo/flash.c +++ b/board/freescale/m5253demo/flash.c @@ -72,7 +72,7 @@ int flash_get_offsets(ulong base, flash_info_t * info) } }
void flash_print_info(flash_info_t * info) @@ -369,9 +369,9 @@ int write_buff(flash_info_t * info, uchar * src, ulong addr, ulong cnt) }
if (cnt == 0) - return ERR_OK; + return FL_ERR_OK;
/*----------------------------------------------------------------------- diff --git a/common/flash.c b/common/flash.c index 24ddc8bee72..a64e51a9b5a 100644 --- a/common/flash.c +++ b/common/flash.c @@ -110,13 +110,13 @@ addr2info(ulong addr) * Make sure all target addresses are within Flash bounds, * and no protected sectors are hit. * Returns: - * ERR_OK 0 - OK - * ERR_TIMEOUT 1 - write timeout - * ERR_NOT_ERASED 2 - Flash not erased - * ERR_PROTECTED 4 - target range includes protected sectors - * ERR_INVAL 8 - target address not in Flash memory - * ERR_ALIGN 16 - target address not aligned on boundary - * (only some targets require alignment) + * FL_ERR_OK 0 - OK + * FL_ERR_TIMEOUT 1 - write timeout + * FL_ERR_NOT_ERASED 2 - Flash not erased + * FL_ERR_PROTECTED 4 - target range includes protected sectors + * FL_ERR_INVAL 8 - target address not in Flash memory + * FL_ERR_ALIGN 16 - target address not aligned on boundary + * (only some targets require alignment) */ int flash_write(char *src, ulong addr, ulong cnt) @@ -131,11 +131,11 @@ flash_write(char *src, ulong addr, ulong cnt) __maybe_unused ulong cnt_orig = cnt;
if (cnt == 0) { - return (ERR_OK); + return (FL_ERR_OK); }
if (!info_first || !info_last) { - return (ERR_INVAL); + return (FL_ERR_INVAL); }
for (info = info_first; info <= info_last; ++info) { @@ -146,7 +146,7 @@ flash_write(char *src, ulong addr, ulong cnt)
if ((end >= info->start[i]) && (addr < e_addr) && (info->protect[i] != 0) ) { - return (ERR_PROTECTED); + return (FL_ERR_PROTECTED); } } } @@ -169,11 +169,11 @@ flash_write(char *src, ulong addr, ulong cnt) #if defined(CONFIG_FLASH_VERIFY) if (memcmp(src_orig, addr_orig, cnt_orig)) { printf("\nVerify failed!\n"); - return ERR_PROG_ERROR; + return FL_ERR_PROG_ERROR; } #endif /* CONFIG_SYS_FLASH_VERIFY_AFTER_WRITE */
/*----------------------------------------------------------------------- @@ -182,33 +182,33 @@ flash_write(char *src, ulong addr, ulong cnt) void flash_perror(int err) { switch (err) { - case ERR_OK: + case FL_ERR_OK: break; - case ERR_TIMEOUT: + case FL_ERR_TIMEOUT: puts ("Timeout writing to Flash\n"); break; - case ERR_NOT_ERASED: + case FL_ERR_NOT_ERASED: puts ("Flash not Erased\n"); break; - case ERR_PROTECTED: + case FL_ERR_PROTECTED: puts ("Can't write to protected Flash sectors\n"); break; - case ERR_INVAL: + case FL_ERR_INVAL: puts ("Outside available Flash\n"); break; - case ERR_ALIGN: + case FL_ERR_ALIGN: puts ("Start and/or end address not on sector boundary\n"); break; - case ERR_UNKNOWN_FLASH_VENDOR: + case FL_ERR_UNKNOWN_FLASH_VENDOR: puts ("Unknown Vendor of Flash\n"); break; - case ERR_UNKNOWN_FLASH_TYPE: + case FL_ERR_UNKNOWN_FLASH_TYPE: puts ("Unknown Type of Flash\n"); break; - case ERR_PROG_ERROR: + case FL_ERR_PROG_ERROR: puts ("General Flash Programming Error\n"); break; - case ERR_ABORTED: + case FL_ERR_ABORTED: puts("Flash Programming Aborted\n"); break; default: diff --git a/drivers/mtd/altera_qspi.c b/drivers/mtd/altera_qspi.c index c26615821c8..e5c8df750b7 100644 --- a/drivers/mtd/altera_qspi.c +++ b/drivers/mtd/altera_qspi.c @@ -96,7 +96,7 @@ int flash_erase(flash_info_t *info, int s_first, int s_last) ret = mtd_erase(mtd, &instr); flash_set_verbose(0); if (ret) - return ERR_PROTECTED; + return FL_ERR_PROTECTED;
puts(" done\n"); return 0; @@ -114,7 +114,7 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt)
ret = mtd_write(mtd, to, cnt, &retlen, src); if (ret) - return ERR_PROTECTED; + return FL_ERR_PROTECTED;
return 0; } diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index a7826e81c17..e50502824ac 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -593,11 +593,11 @@ static int flash_status_check(flash_info_t *info, flash_sect_t sector, flash_read_long(info, sector, 0)); flash_write_cmd(info, sector, 0, info->cmd_reset); udelay(1); - return ERR_TIMEOUT; + return FL_ERR_TIMEOUT; } udelay(1); /* also triggers watchdog */ } - return ERR_OK; + return FL_ERR_OK; }
/*----------------------------------------------------------------------- @@ -616,9 +616,9 @@ static int flash_full_status_check(flash_info_t *info, flash_sect_t sector, case CFI_CMDSET_INTEL_PROG_REGIONS: case CFI_CMDSET_INTEL_EXTENDED: case CFI_CMDSET_INTEL_STANDARD: - if (retcode == ERR_OK && + if (retcode == FL_ERR_OK && !flash_isset(info, sector, 0, FLASH_STATUS_DONE)) { - retcode = ERR_INVAL; + retcode = FL_ERR_INVAL; printf("Flash %s error at address %lx\n", prompt, info->start[sector]); if (flash_isset(info, sector, 0, FLASH_STATUS_ECLBS | @@ -627,14 +627,14 @@ static int flash_full_status_check(flash_info_t *info, flash_sect_t sector, } else if (flash_isset(info, sector, 0, FLASH_STATUS_ECLBS)) { puts("Block Erase Error.\n"); - retcode = ERR_NOT_ERASED; + retcode = FL_ERR_NOT_ERASED; } else if (flash_isset(info, sector, 0, FLASH_STATUS_PSLBS)) { puts("Locking Error\n"); } if (flash_isset(info, sector, 0, FLASH_STATUS_DPS)) { puts("Block locked.\n"); - retcode = ERR_PROTECTED; + retcode = FL_ERR_PROTECTED; } if (flash_isset(info, sector, 0, FLASH_STATUS_VPENS)) puts("Vpp Low Error.\n"); @@ -702,12 +702,12 @@ static int flash_status_poll(flash_info_t *info, void *src, void *dst, if (get_timer(start) > tout) { printf("Flash %s timeout at address %lx data %lx\n", prompt, (ulong)dst, (ulong)flash_read8(dst)); - return ERR_TIMEOUT; + return FL_ERR_TIMEOUT; } udelay(1); /* also triggers watchdog */ } #endif /* CONFIG_SYS_CFI_FLASH_STATUS_POLL */ - return ERR_OK; + return FL_ERR_OK; }
/*----------------------------------------------------------------------- @@ -810,7 +810,7 @@ static int flash_write_cfiword(flash_info_t *info, ulong dest, cfiword_t cword) break; } if (!flag) - return ERR_NOT_ERASED; + return FL_ERR_NOT_ERASED;
/* Disable interrupts which might cause a timeout here */ flag = disable_interrupts(); @@ -899,7 +899,7 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, shift = 3; break; default: - retcode = ERR_INVAL; + retcode = FL_ERR_INVAL; goto out_unmap; }
@@ -930,7 +930,7 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, } } if (!flag) { - retcode = ERR_NOT_ERASED; + retcode = FL_ERR_NOT_ERASED; goto out_unmap; }
@@ -950,7 +950,7 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, retcode = flash_status_check(info, sector, info->buffer_write_tout, "write to buffer"); - if (retcode == ERR_OK) { + if (retcode == FL_ERR_OK) { /* reduce the number of loops by the width of * the port */ @@ -975,7 +975,7 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, src += 8, dst += 8; break; default: - retcode = ERR_INVAL; + retcode = FL_ERR_INVAL; goto out_unmap; } } @@ -1025,7 +1025,7 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp, } break; default: - retcode = ERR_INVAL; + retcode = FL_ERR_INVAL; goto out_unmap; }
@@ -1043,7 +1043,7 @@ static int flash_write_cfibuffer(flash_info_t *info, ulong dest, uchar *cp,
default: debug("Unknown Command Set\n"); - retcode = ERR_INVAL; + retcode = FL_ERR_INVAL; break; }
@@ -1389,7 +1389,7 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) if (i > cnt) i = cnt; rc = flash_write_cfibuffer(info, wp, src, i); - if (rc != ERR_OK) + if (rc != FL_ERR_OK) return rc; i -= i & (info->portwidth - 1); wp += i; @@ -1398,7 +1398,7 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) FLASH_SHOW_PROGRESS(scale, dots, digit, i); /* Only check every once in a while */ if ((cnt & 0xFFFF) < buffered_size && ctrlc()) - return ERR_ABORTED; + return FL_ERR_ABORTED; } #else while (cnt >= info->portwidth) { @@ -1413,7 +1413,7 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) FLASH_SHOW_PROGRESS(scale, dots, digit, info->portwidth); /* Only check every once in a while */ if ((cnt & 0xFFFF) < info->portwidth && ctrlc()) - return ERR_ABORTED; + return FL_ERR_ABORTED; } #endif /* CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
diff --git a/include/flash.h b/include/flash.h index 60babe8a805..32bc65e7b60 100644 --- a/include/flash.h +++ b/include/flash.h @@ -127,16 +127,16 @@ void flash_perror(int err); /*----------------------------------------------------------------------- * return codes from flash_write(): */ -#define ERR_OK 0 -#define ERR_TIMEOUT 1 -#define ERR_NOT_ERASED 2 -#define ERR_PROTECTED 4 -#define ERR_INVAL 8 -#define ERR_ALIGN 16 -#define ERR_UNKNOWN_FLASH_VENDOR 32 -#define ERR_UNKNOWN_FLASH_TYPE 64 -#define ERR_PROG_ERROR 128 -#define ERR_ABORTED 256 +#define FL_ERR_OK 0 +#define FL_ERR_TIMEOUT 1 +#define FL_ERR_NOT_ERASED 2 +#define FL_ERR_PROTECTED 4 +#define FL_ERR_INVAL 8 +#define FL_ERR_ALIGN 16 +#define FL_ERR_UNKNOWN_FLASH_VENDOR 32 +#define FL_ERR_UNKNOWN_FLASH_TYPE 64 +#define FL_ERR_PROG_ERROR 128 +#define FL_ERR_ABORTED 256
/*----------------------------------------------------------------------- * Protection Flags for flash_protect():
The AT91-based platforms have a mem_init() function declared in arch/arm/mach-at91/include/mach/at91_common.h and implemented in various places. In preparation of the introduction of the lwIP networking library which also has a global mem_init() function, rename the AT91 one to at91_mem_init().
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Heiko Schocher hs@denx.de --- arch/arm/mach-at91/include/mach/at91_common.h | 2 +- arch/arm/mach-at91/spl_at91.c | 2 +- arch/arm/mach-at91/spl_atmel.c | 2 +- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 2 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 2 +- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 2 +- board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c | 2 +- board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c | 2 +- board/atmel/sama5d2_icp/sama5d2_icp.c | 2 +- board/atmel/sama5d2_xplained/sama5d2_xplained.c | 2 +- board/atmel/sama5d3_xplained/sama5d3_xplained.c | 2 +- board/atmel/sama5d3xek/sama5d3xek.c | 2 +- board/atmel/sama5d4_xplained/sama5d4_xplained.c | 2 +- board/atmel/sama5d4ek/sama5d4ek.c | 2 +- board/conclusive/kstr-sama5d27/kstr-sama5d27.c | 2 +- board/gardena/smart-gateway-at91sam/spl.c | 2 +- board/siemens/corvus/board.c | 2 +- board/siemens/smartweb/smartweb.c | 2 +- board/siemens/taurus/taurus.c | 2 +- 19 files changed, 19 insertions(+), 19 deletions(-)
diff --git a/arch/arm/mach-at91/include/mach/at91_common.h b/arch/arm/mach-at91/include/mach/at91_common.h index 683e539b1b3..8fec346c1e4 100644 --- a/arch/arm/mach-at91/include/mach/at91_common.h +++ b/arch/arm/mach-at91/include/mach/at91_common.h @@ -28,7 +28,7 @@ void at91_pllb_init(u32 pllar); void at91_mck_init(u32 mckr); void at91_mck_init_down(u32 mckr); void at91_pmc_init(void); -void mem_init(void); +void at91_mem_init(void); void at91_phy_reset(void); void at91_sdram_hw_init(void); void at91_mck_init(u32 mckr); diff --git a/arch/arm/mach-at91/spl_at91.c b/arch/arm/mach-at91/spl_at91.c index cde1700a283..0d1233cd109 100644 --- a/arch/arm/mach-at91/spl_at91.c +++ b/arch/arm/mach-at91/spl_at91.c @@ -142,7 +142,7 @@ void board_init_f(ulong dummy) preloader_console_init(); #endif
- mem_init(); + at91_mem_init();
at91_spl_board_init(); } diff --git a/arch/arm/mach-at91/spl_atmel.c b/arch/arm/mach-at91/spl_atmel.c index 62a7df8a195..7bfbadf0483 100644 --- a/arch/arm/mach-at91/spl_atmel.c +++ b/arch/arm/mach-at91/spl_atmel.c @@ -134,7 +134,7 @@ void board_init_f(ulong dummy)
board_early_init_f();
ret = spl_init(); if (ret) { diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 3bd94d0889d..af486e977e5 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -125,7 +125,7 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); }
-void mem_init(void) +void at91_mem_init(void) { struct atmel_mpddrc_config ddr2;
diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index afc0c0520e1..6f9abcbb127 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -167,7 +167,7 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); }
-void mem_init(void) +void at91_mem_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index e5688c6cf13..f52b9a97731 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -181,7 +181,7 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); }
-void mem_init(void) +void at91_mem_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; diff --git a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c index 36995a927cf..cb3cd7ac9ae 100644 --- a/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c +++ b/board/atmel/sama5d27_som1_ek/sama5d27_som1_ek.c @@ -146,7 +146,7 @@ static void ddrc_conf(struct atmel_mpddrc_config *ddrc) (8 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET)); }
-void mem_init(void) +void at91_mem_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct atmel_mpddr *mpddrc = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; diff --git a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c index c775d593e58..15cbd0daa6f 100644 --- a/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c +++ b/board/atmel/sama5d27_wlsom1_ek/sama5d27_wlsom1_ek.c @@ -208,7 +208,7 @@ static void ddrc_conf(struct atmel_mpddrc_config *ddrc) ddrc->cal_mr4 |= ATMEL_MPDDRC_CAL_MR4_MR4R(0xFFFE); }
-void mem_init(void) +void at91_mem_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct atmel_mpddr *mpddrc = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; diff --git a/board/atmel/sama5d2_icp/sama5d2_icp.c b/board/atmel/sama5d2_icp/sama5d2_icp.c index 986da01639f..6f0d578abf7 100644 --- a/board/atmel/sama5d2_icp/sama5d2_icp.c +++ b/board/atmel/sama5d2_icp/sama5d2_icp.c @@ -180,7 +180,7 @@ static void ddrc_conf(struct atmel_mpddrc_config *ddrc) (7 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET)); }
-void mem_init(void) +void at91_mem_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct atmel_mpddr *mpddrc = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; diff --git a/board/atmel/sama5d2_xplained/sama5d2_xplained.c b/board/atmel/sama5d2_xplained/sama5d2_xplained.c index c8a8eb49826..d104736fa7c 100644 --- a/board/atmel/sama5d2_xplained/sama5d2_xplained.c +++ b/board/atmel/sama5d2_xplained/sama5d2_xplained.c @@ -146,7 +146,7 @@ static void ddrc_conf(struct atmel_mpddrc_config *ddrc) 7 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET); }
-void mem_init(void) +void at91_mem_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct atmel_mpddr *mpddrc = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; diff --git a/board/atmel/sama5d3_xplained/sama5d3_xplained.c b/board/atmel/sama5d3_xplained/sama5d3_xplained.c index 54cc3c4d900..f98322fb540 100644 --- a/board/atmel/sama5d3_xplained/sama5d3_xplained.c +++ b/board/atmel/sama5d3_xplained/sama5d3_xplained.c @@ -175,7 +175,7 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) 8 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); }
diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index f2e1242fcb0..28079a81517 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -241,7 +241,7 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) 8 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); }
diff --git a/board/atmel/sama5d4_xplained/sama5d4_xplained.c b/board/atmel/sama5d4_xplained/sama5d4_xplained.c index 09ca16ca88c..f9112fc5321 100644 --- a/board/atmel/sama5d4_xplained/sama5d4_xplained.c +++ b/board/atmel/sama5d4_xplained/sama5d4_xplained.c @@ -184,7 +184,7 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) 8 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); }
diff --git a/board/atmel/sama5d4ek/sama5d4ek.c b/board/atmel/sama5d4ek/sama5d4ek.c index 1f8b85f0614..0bdc6adbdc8 100644 --- a/board/atmel/sama5d4ek/sama5d4ek.c +++ b/board/atmel/sama5d4ek/sama5d4ek.c @@ -169,7 +169,7 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) 8 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); }
-void mem_init(void) +void at91_mem_init(void) { struct atmel_mpddrc_config ddr2; const struct atmel_mpddr *mpddr = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; diff --git a/board/conclusive/kstr-sama5d27/kstr-sama5d27.c b/board/conclusive/kstr-sama5d27/kstr-sama5d27.c index 64282ae9dc7..37750137ad9 100644 --- a/board/conclusive/kstr-sama5d27/kstr-sama5d27.c +++ b/board/conclusive/kstr-sama5d27/kstr-sama5d27.c @@ -182,7 +182,7 @@ static void ddrc_conf(struct atmel_mpddrc_config *ddrc) (8 << ATMEL_MPDDRC_TPR2_TFAW_OFFSET)); }
-void mem_init(void) +void at91_mem_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct atmel_mpddr *mpddrc = (struct atmel_mpddr *)ATMEL_BASE_MPDDRC; diff --git a/board/gardena/smart-gateway-at91sam/spl.c b/board/gardena/smart-gateway-at91sam/spl.c index fb3ec48f9c5..db9ba881884 100644 --- a/board/gardena/smart-gateway-at91sam/spl.c +++ b/board/gardena/smart-gateway-at91sam/spl.c @@ -110,7 +110,7 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); }
-void mem_init(void) +void at91_mem_init(void) { struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; diff --git a/board/siemens/corvus/board.c b/board/siemens/corvus/board.c index 7d73d1f2b36..cd27fc1cc37 100644 --- a/board/siemens/corvus/board.c +++ b/board/siemens/corvus/board.c @@ -187,7 +187,7 @@ static void ddr2_conf(struct atmel_mpddrc_config *ddr2) 2 << ATMEL_MPDDRC_TPR2_TXARD_OFFSET); }
diff --git a/board/siemens/smartweb/smartweb.c b/board/siemens/smartweb/smartweb.c index 946fbc3f229..e9e4bc348cb 100644 --- a/board/siemens/smartweb/smartweb.c +++ b/board/siemens/smartweb/smartweb.c @@ -238,7 +238,7 @@ void at91_spl_board_init(void) | AT91_SDRAMC_TRP_VAL(2) | AT91_SDRAMC_TRCD_VAL(2) \ | AT91_SDRAMC_TRAS_VAL(5) | AT91_SDRAMC_TXSR_VAL(8))
-void mem_init(void) +void at91_mem_init(void) { struct at91_matrix *ma = (struct at91_matrix *)ATMEL_BASE_MATRIX; struct at91_port *port = (struct at91_port *)ATMEL_BASE_PIOC; diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index bda12a97708..3764ab48ab3 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -177,7 +177,7 @@ void sdramc_configure(unsigned int mask) sdramc_initialize(ATMEL_BASE_CS1, &setting); }
-void mem_init(void) +void at91_mem_init(void) { unsigned int ram_size = 0;
On 9/11/24 3:28 PM, Jerome Forissier wrote:
EXTERNAL EMAIL: Do not click links or open attachments unless you know the content is safe
Looks good to me as well:
Reviewed-by: Hari Prasath Gujulan Elango hari.prasathge@microchip.com
Regards, Hari
mem_init();
at91_mem_init(); at91_spl_board_init();
mem_init();
at91_mem_init(); ret = spl_init(); if (ret) {
-- 2.40.1
emac.c implements cpu_eth_init() so it needs to pull the corresponding header file.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- arch/arm/mach-omap2/omap3/emac.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-omap2/omap3/emac.c b/arch/arm/mach-omap2/omap3/emac.c index 7348e92cabd..1e30a06361d 100644 --- a/arch/arm/mach-omap2/omap3/emac.c +++ b/arch/arm/mach-omap2/omap3/emac.c @@ -9,6 +9,7 @@ #include <net.h> #include <asm/io.h> #include <asm/arch/am35x_def.h> +#include <netdev.h>
/* * Initializes on-chip ethernet controllers.
dtsec_init_phy() is defined only with MII so add the proper conditional in the caller code.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org --- drivers/net/fm/eth.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/net/fm/eth.c b/drivers/net/fm/eth.c index 19f3f0fef07..63fe4b2d33c 100644 --- a/drivers/net/fm/eth.c +++ b/drivers/net/fm/eth.c @@ -26,7 +26,8 @@
#include "fm.h"
-#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) && !defined(BITBANGMII) +#if ((defined(CONFIG_MII) || defined(CONFIG_CMD_MII)) && \ + !defined(CONFIG_BITBANGMII))
#define TBIANA_SETTINGS (TBIANA_ASYMMETRIC_PAUSE | TBIANA_SYMMETRIC_PAUSE | \ TBIANA_FULL_DUPLEX) @@ -701,8 +702,11 @@ static int init_phy(struct fm_eth *fm_eth) supported |= SUPPORTED_2500baseX_Full; #endif
+#if (CONFIG_IS_ENABLED(MII) || CONFIG_IS_ENABLED(CMD_MII)) && \ + !CONFIG_IS_ENABLED(BITBANGMII) if (fm_eth->type == FM_ETH_1G_E) dtsec_init_phy(fm_eth); +#endif
#ifdef CONFIG_PHYLIB #ifdef CONFIG_DM_MDIO
Hi Jerome,
On Wed, 11 Sept 2024 at 03:59, Jerome Forissier jerome.forissier@linaro.org wrote:
#include "fm.h"
Ugly! I wonder if we need a special Kconfig for this function?
2.40.1
wget_success() is used nowhere so remove it.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com --- net/wget.c | 7 ------- 1 file changed, 7 deletions(-)
diff --git a/net/wget.c b/net/wget.c index 4a168641c65..6ebf9bca0d8 100644 --- a/net/wget.c +++ b/net/wget.c @@ -196,13 +196,6 @@ void wget_fail(char *error_message, unsigned int tcp_seq_num, wget_send(action, tcp_seq_num, tcp_ack_num, 0); }
-void wget_success(u8 action, unsigned int tcp_seq_num, - unsigned int tcp_ack_num, int len, int packets) -{ - printf("Packets received %d, Transfer Successful\n", packets); - wget_send(action, tcp_seq_num, tcp_ack_num, len); -} - /* * Interfaces of U-BOOT */
PHY_NCSI enables drivers/net/phy/ncsi.c which calls net_loop() and net_set_timeout_handler(). That's the legacy NET stack (as opposed to NET_LWIP). Therefore add the dependency to Kconfig.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/net/phy/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/net/phy/Kconfig b/drivers/net/phy/Kconfig index 73064b2af68..a9efc509814 100644 --- a/drivers/net/phy/Kconfig +++ b/drivers/net/phy/Kconfig @@ -368,6 +368,7 @@ config PHY_FIXED
config PHY_NCSI bool "NC-SI based PHY" + depends on NET
endif #PHYLIB
FTGMAC100 enables drivers/net/ftgmac100.c which uses PHY_INTERFACE_MODE_NCSI, which is defined only when PHY_NCSI is enabled. Therefore FTGMAC100 depends on PHY_NCSI. However adding such a dependency causes a "recursive dependency detected!" message, so add a dependency on NET instead (PHY_NCSI depends on NET). All in all, either the stack is NET and FTGMAC100 can be enabled, or it is NET_LWIP (or NO_NET) and it cannot.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Simon Glass sjg@chromium.org --- drivers/net/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6ed325517c0..e7d0ddfe25a 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -468,6 +468,7 @@ config FTMAC100 config FTGMAC100 bool "Ftgmac100 Ethernet Support" select PHYLIB + depends on NET help This driver supports the Faraday's FTGMAC100 Gigabit SoC Ethernet controller that can be found on Aspeed SoCs (which
wget followed by bootefi currently fails as follows:
U-Boot> wget 200000 192.168.0.30:helloworld.efi Waiting for Ethernet connection... done. HTTP/1.0 200 OK Packets received 13, Transfer Successful Bytes transferred = 12720 (31b0 hex) U-Boot> bootefi 200000 No UEFI binary known at 200000 U-Boot>
Fix the problem by adding the missing efi_set_bootdev() call.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- net/wget.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/net/wget.c b/net/wget.c index 6ebf9bca0d8..c8cce554c5e 100644 --- a/net/wget.c +++ b/net/wget.c @@ -8,6 +8,7 @@ #include <command.h> #include <display_options.h> #include <env.h> +#include <efi_loader.h> #include <image.h> #include <lmb.h> #include <mapmem.h> @@ -425,6 +426,9 @@ static void wget_handler(uchar *pkt, u16 dport, case WGET_TRANSFERRED: printf("Packets received %d, Transfer Successful\n", packets); net_set_state(wget_loop_state); + efi_set_bootdev("Net", "", image_url, + map_sysmem(image_load_addr, 0), + net_boot_file_size); break; } }
The fec_mxc_init() function currently always returns 0. This does not allow the callers to detect when for instance the PHY initialization failed due to the port being unconnected. Fix that by returning the status of fec_open().
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Fabio Estevam festevam@gmail.com Reviewed-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- drivers/net/fec_mxc.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 0a0d92bc2cd..2dc1364beec 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -615,8 +615,7 @@ static int fecmxc_init(struct udevice *dev) if (fec->xcv_type != SEVENWIRE) miiphy_restart_aneg(dev); #endif - fec_open(dev); - return 0; + return fec_open(dev); }
If env__pxe_boot_test_skip is not present, it defaults to True not False. Therefore fix the comment.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- test/py/tests/test_net_boot.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/py/tests/test_net_boot.py b/test/py/tests/test_net_boot.py index 63309fe82e1..d7d74356928 100644 --- a/test/py/tests/test_net_boot.py +++ b/test/py/tests/test_net_boot.py @@ -75,7 +75,7 @@ env__net_pxe_bootable_file = { 'check_pattern': 'ERROR', }
-# False or omitted if a PXE boot test should be tested. +# False if a PXE boot test should be tested. # If PXE boot testing is not possible or desired, set this variable to True. # For example: If pxe configuration file is not proper to boot env__pxe_boot_test_skip = False
test_efi_helloworld_net() and test_efi_grub_net() depend on cmd_tftpboot so add the missing annotations.
Reported-by: Tom Rini trini@konsulko.com Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- test/py/tests/test_efi_loader.py | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/test/py/tests/test_efi_loader.py b/test/py/tests/test_efi_loader.py index 85473a9049b..7c1e0ffa594 100644 --- a/test/py/tests/test_efi_loader.py +++ b/test/py/tests/test_efi_loader.py @@ -149,6 +149,7 @@ def fetch_tftp_file(u_boot_console, env_conf):
@pytest.mark.buildconfigspec('of_control') @pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') +@pytest.mark.buildconfigspec('cmd_tftpboot') def test_efi_helloworld_net(u_boot_console): """Run the helloworld.efi binary via TFTP.
@@ -178,6 +179,7 @@ def test_efi_helloworld_builtin(u_boot_console):
@pytest.mark.buildconfigspec('of_control') @pytest.mark.buildconfigspec('cmd_bootefi') +@pytest.mark.buildconfigspec('cmd_tftpboot') def test_efi_grub_net(u_boot_console): """Run the grub.efi binary via TFTP.
Add a test to test_efi_loader.py similar to the TFTP test but for HTTP with the wget command.
Suggested-by: Tom Rini trini@konsulko.com Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Tested-by: Tom Rini trini@konsulko.com Reviewed-by: Peter Robinson pbrobinson@gmail.com --- test/py/tests/test_efi_loader.py | 62 +++++++++++++++++++++++--------- 1 file changed, 46 insertions(+), 16 deletions(-)
diff --git a/test/py/tests/test_efi_loader.py b/test/py/tests/test_efi_loader.py index 7c1e0ffa594..5f3b448a066 100644 --- a/test/py/tests/test_efi_loader.py +++ b/test/py/tests/test_efi_loader.py @@ -45,11 +45,18 @@ env__efi_loader_helloworld_file = { 'crc32': 'c2244b26', # CRC32 check sum 'addr': 0x40400000, # load address } + +# False if the helloworld EFI over HTTP boot test should be performed. +# If HTTP boot testing is not possible or desired, set this variable to True or +# ommit it. +env__efi_helloworld_net_http_test_skip = True """
import pytest import u_boot_utils
+PROTO_TFTP, PROTO_HTTP = range(0, 2) + net_set_up = False
def test_efi_pre_commands(u_boot_console): @@ -110,10 +117,10 @@ def test_efi_setup_static(u_boot_console): global net_set_up net_set_up = True
-def fetch_tftp_file(u_boot_console, env_conf): - """Grab an env described file via TFTP and return its address +def fetch_file(u_boot_console, env_conf, proto): + """Grab an env described file via TFTP or HTTP and return its address
- A file as described by an env config <env_conf> is downloaded from the TFTP + A file as described by an env config <env_conf> is downloaded from the server. The address to that file is returned. """ if not net_set_up: @@ -128,7 +135,13 @@ def fetch_tftp_file(u_boot_console, env_conf): addr = u_boot_utils.find_ram_base(u_boot_console)
fn = f['fn'] - output = u_boot_console.run_command('tftpboot %x %s' % (addr, fn)) + if proto == PROTO_TFTP: + cmd = 'tftpboot' + elif proto == PROTO_HTTP: + cmd = 'wget' + else: + assert False + output = u_boot_console.run_command('%s %x %s' % (cmd, addr, fn)) expected_text = 'Bytes transferred = ' sz = f.get('size', None) if sz: @@ -147,17 +160,8 @@ def fetch_tftp_file(u_boot_console, env_conf):
return addr
-@pytest.mark.buildconfigspec('of_control') -@pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') -@pytest.mark.buildconfigspec('cmd_tftpboot') -def test_efi_helloworld_net(u_boot_console): - """Run the helloworld.efi binary via TFTP. - - The helloworld.efi file is downloaded from the TFTP server and is executed - using the fallback device tree at $fdtcontroladdr. - """ - - addr = fetch_tftp_file(u_boot_console, 'env__efi_loader_helloworld_file') +def do_test_efi_helloworld_net(u_boot_console, proto): + addr = fetch_file(u_boot_console, 'env__efi_loader_helloworld_file', proto)
output = u_boot_console.run_command('bootefi %x' % addr) expected_text = 'Hello, world' @@ -165,6 +169,32 @@ def test_efi_helloworld_net(u_boot_console): expected_text = '## Application failed' assert expected_text not in output
+@pytest.mark.buildconfigspec('of_control') +@pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') +@pytest.mark.buildconfigspec('cmd_tftpboot') +def test_efi_helloworld_net_tftp(u_boot_console): + """Run the helloworld.efi binary via TFTP. + + The helloworld.efi file is downloaded from the TFTP server and is executed + using the fallback device tree at $fdtcontroladdr. + """ + + do_test_efi_helloworld_net(u_boot_console, PROTO_TFTP); + +@pytest.mark.buildconfigspec('of_control') +@pytest.mark.buildconfigspec('cmd_bootefi_hello_compile') +@pytest.mark.buildconfigspec('cmd_wget') +def test_efi_helloworld_net_http(u_boot_console): + """Run the helloworld.efi binary via HTTP. + + The helloworld.efi file is downloaded from the HTTP server and is executed + using the fallback device tree at $fdtcontroladdr. + """ + if u_boot_console.config.env.get('env__efi_helloworld_net_http_test_skip', True): + pytest.skip('helloworld.efi HTTP test is not enabled!') + + do_test_efi_helloworld_net(u_boot_console, PROTO_HTTP); + @pytest.mark.buildconfigspec('cmd_bootefi_hello') def test_efi_helloworld_builtin(u_boot_console): """Run the builtin helloworld.efi binary. @@ -187,7 +217,7 @@ def test_efi_grub_net(u_boot_console): executed. """
- addr = fetch_tftp_file(u_boot_console, 'env__efi_loader_grub_file') + addr = fetch_file(u_boot_console, 'env__efi_loader_grub_file', PROTO_TFTP)
u_boot_console.run_command('bootefi %x' % addr, wait_for_prompt=False)
common/update.c (UPDATE_COMMON) depends on tftp_timeout_ms which is defined in cmd/tftp.c (CMD_TFTPBOOT). Therefore add the appropriate imply statement to Kconfig.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com --- common/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/common/Kconfig b/common/Kconfig index 83c81edac20..968d4fb66a8 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -934,6 +934,7 @@ menu "Update support" config UPDATE_COMMON bool select DFU_WRITE_ALT + imply CMD_TFTPBOOT
config UPDATE_TFTP bool "Auto-update using fitImage via TFTP"
cmd/pxe.c (CMD_PXE) calls do_get_tftp() (CMD_TFTPBOOT) therefore add an "imply" to cmd/Kconfig.
Signed-off-by: Jerome Forissier jerome.forissier@linaro.org Reviewed-by: Peter Robinson pbrobinson@gmail.com --- cmd/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 43f78a5aeb1..83c82818bf4 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2099,6 +2099,7 @@ config CMD_ETHSW config CMD_PXE bool "pxe" select PXE_UTILS + imply CMD_TFTPBOOT help Boot image via network using PXE protocol
Changes in v4:
Hari.PrasathGE@microchip.com
Jerome Forissier
