[U-Boot] [PATCH v11] Add support for Network Space v2 and parents
This patch add support for the Network Space v2 board and parents, based on the Marvell Kirkwood 6281 SoC. This include Network Space (Max) v2 and Internet Space v2.
Additional information is available at: http://lacie-nas.org/doku.php?id=network_space_v2
Signed-off-by: Simon Guinot sguinot@lacie.com --- Changes for v2: - add entries to MAINTAINERS file - move boards from root Makefile to boards.cfg - move MACH_TYPE definition into netspace_v2.h - remove CONFIG_SYS_HZ redefinition - turn PHY initialization message into debug()
Changes for v3: none
Changes for v4: - enhance commit message: add SoC information
Changes for v5: none
Changes for v6: - enable device tree support - clean some "#define" in netspace_v2.h - enhance commit message: provide description URL and mention SoC family - rebase against u-boot-{arm,marvell}/master branches
Changes for v7: - rebase against u-boot-marvell/master branch
Changes for v8: - update commit title (add netspace_v2 parents information). - move GPIO button definition into header file. - update CONFIG_IDENT_STRING with boards alias. - handle wrong board definition. - by default, use DHCP to get IP address.
Changes for v9: - rebase against u-boot-marvell/master branch
Changes for v10: - rebase against u-boot-marvell/master branch
Changes for v11: - rebase against u-boot-marvell/next branch - set email encoding to ISO-8859-1
MAINTAINERS | 6 + board/LaCie/netspace_v2/Makefile | 49 ++++++++++ board/LaCie/netspace_v2/kwbimage.cfg | 162 +++++++++++++++++++++++++++++++++ board/LaCie/netspace_v2/netspace_v2.c | 142 +++++++++++++++++++++++++++++ board/LaCie/netspace_v2/netspace_v2.h | 42 +++++++++ boards.cfg | 3 + include/configs/netspace_v2.h | 162 +++++++++++++++++++++++++++++++++ 7 files changed, 566 insertions(+), 0 deletions(-) create mode 100644 board/LaCie/netspace_v2/Makefile create mode 100644 board/LaCie/netspace_v2/kwbimage.cfg create mode 100644 board/LaCie/netspace_v2/netspace_v2.c create mode 100644 board/LaCie/netspace_v2/netspace_v2.h create mode 100644 include/configs/netspace_v2.h
diff --git a/MAINTAINERS b/MAINTAINERS index 653c928..0de32d3 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -647,6 +647,12 @@ Sedji Gaouaousedji.gaouaou@atmel.com at91sam9g10ek ARM926EJS (AT91SAM9G10 SoC) at91sam9m10g45ek ARM926EJS (AT91SAM9G45 SoC)
+Simon Guinot simon.guinot@sequanux.org + + inetspace_v2 ARM926EJS (Kirkwood SoC) + netspace_v2 ARM926EJS (Kirkwood SoC) + netspace_max_v2 ARM926EJS (Kirkwood SoC) + Marius Gröger mag@sysgo.de
impa7 ARM720T (EP7211) diff --git a/board/LaCie/netspace_v2/Makefile b/board/LaCie/netspace_v2/Makefile new file mode 100644 index 0000000..a245f2c --- /dev/null +++ b/board/LaCie/netspace_v2/Makefile @@ -0,0 +1,49 @@ +# +# Copyright (C) 2011 Simon Guinot sguinot@lacie.com +# +# Based on Kirkwood support: +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := netspace_v2.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/LaCie/netspace_v2/kwbimage.cfg b/board/LaCie/netspace_v2/kwbimage.cfg new file mode 100644 index 0000000..361feeb --- /dev/null +++ b/board/LaCie/netspace_v2/kwbimage.cfg @@ -0,0 +1,162 @@ +# +# Copyright (C) 2011 Simon Guinot sguinot@lacie.com +# +# Based on Kirkwood support: +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# Refer docs/README.kwimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM spi # Boot from SPI flash + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +# Configure RGMII-0 interface pad voltage to 1.8V +DATA 0xFFD100e0 0x1B1B1B9B + +#Dram initalization for SINGLE x16 CL=5 @ 400MHz +DATA 0xFFD01400 0x43000618 # DDR Configuration register +# bit13-0: 0xa00 (2560 DDR2 clks refresh rate) +# bit23-14: zero +# bit24: 1= enable exit self refresh mode on DDR access +# bit25: 1 required +# bit29-26: zero +# bit31-30: 01 + +DATA 0xFFD01404 0x35143000 # DDR Controller Control Low +# bit 4: 0=addr/cmd in smame cycle +# bit 5: 0=clk is driven during self refresh, we don't care for APX +# bit 6: 0=use recommended falling edge of clk for addr/cmd +# bit14: 0=input buffer always powered up +# bit18: 1=cpu lock transaction enabled +# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 +# bit27-24: 8= CL+3, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM +# bit30-28: 3 required +# bit31: 0=no additional STARTBURST delay + +DATA 0xFFD01408 0x11012228 # DDR Timing (Low) (active cycles value +1) +# bit7-4: TRCD +# bit11- 8: TRP +# bit15-12: TWR +# bit19-16: TWTR +# bit20: TRAS msb +# bit23-21: 0x0 +# bit27-24: TRRD +# bit31-28: TRTP + +DATA 0xFFD0140C 0x00000A19 # DDR Timing (High) +# bit6-0: TRFC +# bit8-7: TR2R +# bit10-9: TR2W +# bit12-11: TW2W +# bit31-13: zero required + +DATA 0xFFD01410 0x0000CCCC # DDR Address Control +# bit1-0: 01, Cs0width=x16 +# bit3-2: 11, Cs0size=1Gb +# bit5-4: 00, Cs2width=nonexistent +# bit7-6: 00, Cs1size =nonexistent +# bit9-8: 00, Cs2width=nonexistent +# bit11-10: 00, Cs2size =nonexistent +# bit13-12: 00, Cs3width=nonexistent +# bit15-14: 00, Cs3size =nonexistent +# bit16: 0, Cs0AddrSel +# bit17: 0, Cs1AddrSel +# bit18: 0, Cs2AddrSel +# bit19: 0, Cs3AddrSel +# bit31-20: 0 required + +DATA 0xFFD01414 0x00000000 # DDR Open Pages Control +# bit0: 0, OpenPage enabled +# bit31-1: 0 required + +DATA 0xFFD01418 0x00000000 # DDR Operation +# bit3-0: 0x0, DDR cmd +# bit31-4: 0 required + +DATA 0xFFD0141C 0x00000632 # DDR Mode +# bit2-0: 2, BurstLen=2 required +# bit3: 0, BurstType=0 required +# bit6-4: 4, CL=5 +# bit7: 0, TestMode=0 normal +# bit8: 0, DLL reset=0 normal +# bit11-9: 6, auto-precharge write recovery ???????????? +# bit12: 0, PD must be zero +# bit31-13: 0 required + +DATA 0xFFD01420 0x00000004 # DDR Extended Mode +# bit0: 0, DDR DLL enabled +# bit1: 1, DDR drive strenght reduced +# bit2: 1, DDR ODT control lsd enabled +# bit5-3: 000, required +# bit6: 1, DDR ODT control msb, enabled +# bit9-7: 000, required +# bit10: 0, differential DQS enabled +# bit11: 0, required +# bit12: 0, DDR output buffer enabled +# bit31-13: 0 required + +DATA 0xFFD01424 0x0000F07F # DDR Controller Control High +# bit2-0: 111, required +# bit3 : 1 , MBUS Burst Chop disabled +# bit6-4: 111, required +# bit7 : 1 , D2P Latency enabled +# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz +# bit9 : 0 , no half clock cycle addition to dataout +# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals +# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh +# bit15-12: 1111 required +# bit31-16: 0 required + +DATA 0xFFD01428 0x00085520 # DDR2 ODT Read Timing (default values) +DATA 0xFFD0147C 0x00008552 # DDR2 ODT Write Timing (default values) + +DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 +DATA 0xFFD01504 0x0FFFFFF1 # CS[0]n Size +# bit0: 1, Window enabled +# bit1: 0, Write Protect disabled +# bit3-2: 00, CS0 hit selected +# bit23-4: ones, required +# bit31-24: 0x07, Size (i.e. 128MB) + +DATA 0xFFD0150C 0x00000000 # CS[1]n Size, window disabled +DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled +DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled + +DATA 0xFFD01494 0x00010000 # DDR ODT Control (Low) +# bit3-0: 1, ODT0Rd, MODT[0] asserted during read from DRAM CS0 +# bit19-16:1, ODT0Wr, MODT[0] asserted during write to DRAM CS0 + +DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) +# bit1-0: 00, ODT0 controlled by ODT Control (low) register above +# bit3-2: 01, ODT1 active NEVER! +# bit31-4: zero, required + +DATA 0xFFD0149C 0x0000E40F # CPU ODT Control +# bit3-0: 1, ODT0Rd, Internal ODT asserted during read from DRAM bank0 +# bit7-4: 1, ODT0Wr, Internal ODT asserted during write to DRAM bank0 +# bit11-10:1, DQ_ODTSel. ODT select turned on + +DATA 0xFFD01480 0x00000001 # DDR Initialization Control +#bit0=1, enable DDR init upon this register write + +# End of Header extension +DATA 0x0 0x0 diff --git a/board/LaCie/netspace_v2/netspace_v2.c b/board/LaCie/netspace_v2/netspace_v2.c new file mode 100644 index 0000000..3bb83f3 --- /dev/null +++ b/board/LaCie/netspace_v2/netspace_v2.c @@ -0,0 +1,142 @@ +/* + * Copyright (C) 2011 Simon Guinot sguinot@lacie.com + * + * Based on Kirkwood support: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <common.h> +#include <miiphy.h> +#include <netdev.h> +#include <command.h> +#include <asm/arch/kirkwood.h> +#include <asm/arch/mpp.h> +#include <asm/arch/gpio.h> +#include "netspace_v2.h" + +DECLARE_GLOBAL_DATA_PTR; + +int board_early_init_f(void) +{ + /* Gpio configuration */ + kw_config_gpio(NETSPACE_V2_OE_VAL_LOW, NETSPACE_V2_OE_VAL_HIGH, + NETSPACE_V2_OE_LOW, NETSPACE_V2_OE_HIGH); + + /* Multi-Purpose Pins Functionality configuration */ + u32 kwmpp_config[] = { + MPP0_SPI_SCn, + MPP1_SPI_MOSI, + MPP2_SPI_SCK, + MPP3_SPI_MISO, + MPP4_NF_IO6, + MPP5_NF_IO7, + MPP6_SYSRST_OUTn, + MPP7_GPO, /* Fan speed (bit 1) */ + MPP8_TW_SDA, + MPP9_TW_SCK, + MPP10_UART0_TXD, + MPP11_UART0_RXD, + MPP12_GPO, /* Red led */ + MPP14_GPIO, /* USB fuse */ + MPP16_GPIO, /* SATA 0 power */ + MPP17_GPIO, /* SATA 1 power */ + MPP18_NF_IO0, + MPP19_NF_IO1, + MPP20_SATA1_ACTn, + MPP21_SATA0_ACTn, + MPP22_GPIO, /* Fan speed (bit 0) */ + MPP23_GPIO, /* Fan power */ + MPP24_GPIO, /* USB mode select */ + MPP25_GPIO, /* Fan rotation fail */ + MPP26_GPIO, /* USB vbus-in detection */ + MPP28_GPIO, /* USB enable vbus-out */ + MPP29_GPIO, /* Blue led (slow register) */ + MPP30_GPIO, /* Blue led (command register) */ + MPP31_GPIO, /* Board power off */ + MPP32_GPIO, /* Button (0 = Released, 1 = Pushed) */ + MPP33_GPIO, /* Fan speed (bit 2) */ + 0 + }; + kirkwood_mpp_conf(kwmpp_config); + + return 0; +} + +int board_init(void) +{ + /* Machine number */ + gd->bd->bi_arch_number = CONFIG_MACH_TYPE; + + /* Boot parameters address */ + gd->bd->bi_boot_params = kw_sdram_bar(0) + 0x100; + + return 0; +} + +void mv_phy_88e1116_init(char *name) +{ + u16 reg; + u16 devadr; + + if (miiphy_set_current_dev(name)) + return; + + /* command to read PHY dev address */ + if (miiphy_read(name, 0xEE, 0xEE, (u16 *) &devadr)) { + printf("Err..(%s) could not read PHY dev address\n", __func__); + return; + } + + /* + * Enable RGMII delay on Tx and Rx for CPU port + * Ref: sec 4.7.2 of chip datasheet + */ + miiphy_write(name, devadr, MV88E1116_PGADR_REG, 2); + miiphy_read(name, devadr, MV88E1116_MAC_CTRL_REG, ®); + reg |= (MV88E1116_RGMII_RXTM_CTRL | MV88E1116_RGMII_TXTM_CTRL); + miiphy_write(name, devadr, MV88E1116_MAC_CTRL_REG, reg); + miiphy_write(name, devadr, MV88E1116_PGADR_REG, 0); + + /* reset the phy */ + if (miiphy_read(name, devadr, MII_BMCR, ®) != 0) { + printf("Err..(%s) PHY status read failed\n", __func__); + return; + } + if (miiphy_write(name, devadr, MII_BMCR, reg | 0x8000) != 0) { + printf("Err..(%s) PHY reset failed\n", __func__); + return; + } + + debug("88E1116 Initialized on %s\n", name); +} + +/* Configure and initialize PHY */ +void reset_phy(void) +{ + mv_phy_88e1116_init("egiga0"); +} + +/* Return GPIO button status */ +static int +do_read_button(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return kw_gpio_get_value(NETSPACE_V2_GPIO_BUTTON); +} + +U_BOOT_CMD(button, 1, 1, do_read_button, + "Return GPIO button status 0=off 1=on", ""); diff --git a/board/LaCie/netspace_v2/netspace_v2.h b/board/LaCie/netspace_v2/netspace_v2.h new file mode 100644 index 0000000..3f3d51c --- /dev/null +++ b/board/LaCie/netspace_v2/netspace_v2.h @@ -0,0 +1,42 @@ +/* + * Copyright (C) 2011 Simon Guinot sguinot@lacie.com + * + * Based on Kirkwood support: + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef NETSPACE_V2_H +#define NETSPACE_V2_H + +/* GPIO configuration */ +#define NETSPACE_V2_OE_LOW 0x06004000 +#define NETSPACE_V2_OE_HIGH 0x00000031 +#define NETSPACE_V2_OE_VAL_LOW 0x10030000 +#define NETSPACE_V2_OE_VAL_HIGH 0x00000000 + +#define NETSPACE_V2_GPIO_BUTTON 32 + +/* PHY related */ +#define MV88E1116_LED_FCTRL_REG 10 +#define MV88E1116_CPRSP_CR3_REG 21 +#define MV88E1116_MAC_CTRL_REG 21 +#define MV88E1116_PGADR_REG 22 +#define MV88E1116_RGMII_TXTM_CTRL (1 << 4) +#define MV88E1116_RGMII_RXTM_CTRL (1 << 5) + +#endif /* NETSPACE_V2_H */ diff --git a/boards.cfg b/boards.cfg index 649f1af..dc3afcf 100644 --- a/boards.cfg +++ b/boards.cfg @@ -110,6 +110,9 @@ km_kirkwood arm arm926ejs km_arm keymile km_kirkwood_pci arm arm926ejs km_arm keymile kirkwood km_kirkwood mgcoge3un arm arm926ejs km_arm keymile kirkwood portl2 arm arm926ejs km_arm keymile kirkwood +inetspace_v2 arm arm926ejs netspace_v2 LaCie kirkwood netspace_v2:INETSPACE_V2 +netspace_v2 arm arm926ejs netspace_v2 LaCie kirkwood netspace_v2:NETSPACE_V2 +netspace_max_v2 arm arm926ejs netspace_v2 LaCie kirkwood netspace_v2:NETSPACE_MAX_V2 guruplug arm arm926ejs - Marvell kirkwood mv88f6281gtw_ge arm arm926ejs - Marvell kirkwood openrd_base arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_BASE diff --git a/include/configs/netspace_v2.h b/include/configs/netspace_v2.h new file mode 100644 index 0000000..82a1233 --- /dev/null +++ b/include/configs/netspace_v2.h @@ -0,0 +1,162 @@ +/* + * Copyright (C) 2011 Simon Guinot sguinot@lacie.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _CONFIG_NETSPACE_V2_H +#define _CONFIG_NETSPACE_V2_H + +/* + * Machine number definition + */ +#if defined(CONFIG_INETSPACE_V2) +#define CONFIG_MACH_TYPE MACH_TYPE_INETSPACE_V2 +#define CONFIG_IDENT_STRING " IS v2" +#elif defined(CONFIG_NETSPACE_V2) +#define CONFIG_MACH_TYPE MACH_TYPE_NETSPACE_V2 +#define CONFIG_IDENT_STRING " NS v2" +#elif defined(CONFIG_NETSPACE_MAX_V2) +#define CONFIG_MACH_TYPE MACH_TYPE_NETSPACE_MAX_V2 +#define CONFIG_IDENT_STRING " NS Max v2" +#else +#error "Unknown board" +#endif + +/* + * High Level Configuration Options (easy to change) + */ +#define CONFIG_FEROCEON_88FR131 /* CPU Core subversion */ +#define CONFIG_KIRKWOOD /* SOC Family Name */ +#define CONFIG_KW88F6281 /* SOC Name */ +#define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */ + +/* + * Commands configuration + */ +#define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ +#include <config_cmd_default.h> +#define CONFIG_CMD_ENV +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_SF +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_USB + +/* + * Core clock definition. + */ +#define CONFIG_SYS_TCLK 166000000 /* 166MHz */ + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#define CONFIG_NR_DRAM_BANKS 2 +#include "mv-common.h" + +/* Remove or override few declarations from mv-common.h */ +#undef CONFIG_RBTREE +#undef CONFIG_ENV_SPI_MAX_HZ +#undef CONFIG_SYS_IDE_MAXBUS +#undef CONFIG_SYS_IDE_MAXDEVICE +#undef CONFIG_SYS_PROMPT +#define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */ +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 +#define CONFIG_SYS_PROMPT "ns2> " + +/* + * Ethernet Driver configuration + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_MVGBE_PORTS {1, 0} /* enable port 0 only */ +#define CONFIG_NETCONSOLE +#endif + +/* + * SATA Driver configuration + */ +#ifdef CONFIG_MVSATA_IDE +#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET +/* Network Space Max v2 use 2 SATA ports */ +#ifdef CONFIG_NETSPACE_MAX_V2 +#define CONFIG_SYS_ATA_IDE1_OFFSET MV_SATA_PORT1_OFFSET +#endif +#endif + +/* + * Enable GPI0 support + */ +#define CONFIG_KIRKWOOD_GPIO + +/* + * File systems support + */ +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT + +/* + * Use the HUSH parser + */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* + * Console configuration + */ +#define CONFIG_CONSOLE_MUX +#define CONFIG_SYS_CONSOLE_IS_IN_ENV + +/* + * Enable device tree support + */ +#define CONFIG_OF_LIBFDT + +/* + * Environment variables configurations + */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SECT_SIZE 0x10000 /* 64KB */ +#define CONFIG_ENV_SIZE 0x1000 /* 4KB */ +#define CONFIG_ENV_ADDR 0x70000 +#define CONFIG_ENV_OFFSET 0x70000 /* env starts here */ + +/* + * Default environment variables + */ +#define CONFIG_BOOTARGS "console=ttyS0,115200" + +#define CONFIG_BOOTCOMMAND \ + "dhcp && run netconsole; " \ + "if run usbload || run diskload; then bootm; fi" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "stdin=serial\0" \ + "stdout=serial\0" \ + "stderr=serial\0" \ + "bootfile=uImage\0" \ + "loadaddr=0x800000\0" \ + "autoload=no\0" \ + "netconsole=" \ + "set stdin $stdin,nc; " \ + "set stdout $stdout,nc; " \ + "set stderr $stderr,nc;\0" \ + "diskload=ide reset && " \ + "ext2load ide 0:1 $loadaddr /boot/$bootfile\0" \ + "usbload=usb start && " \ + "fatload usb 0:1 $loadaddr /boot/$bootfile\0" + +#endif /* _CONFIG_NETSPACE_V2_H */
-----Original Message----- From: Simon Guinot [mailto:simon.guinot@sequanux.org] Sent: Friday, June 17, 2011 2:39 PM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Simon Guinot Subject: [PATCH v11] Add support for Network Space v2 and parents
Changes for v2:
Changes for v4:
Changes for v6:
Changes for v7:
Changes for v8:
Changes for v9:
Changes for v10:
Changes for v11:
Applied to u-boot-marvell.git next branch
Regards.. Prafulla . .
Prafulla Wadaskar
Simon Guinot
