Re: [PATCH v4 1/7] dt-bindings: clock: Add StarFive JH7110 PLL clock generator
On Tue, May 23, 2023 at 01:10:06PM +0200, Torsten Duwe wrote:
On Tue, 23 May 2023 09:28:39 +0100 Conor Dooley conor.dooley@microchip.com wrote:
On Tue, May 23, 2023 at 10:56:43AM +0800, Xingyu Wu wrote:
On 2023/5/19 22:16, Conor Dooley wrote:
On Fri, May 19, 2023 at 03:57:33PM +0200, Torsten Duwe wrote:
On Fri, May 12, 2023 at 10:20:30AM +0800, Xingyu Wu wrote: [...]
+/* PLL clocks */ +#define JH7110_CLK_PLL0_OUT 0 +#define JH7110_CLK_PLL1_OUT 1 +#define JH7110_CLK_PLL2_OUT 2
In U-Boot commit 58c9c60b Yanhong Wang added:
+#define JH7110_SYSCLK_PLL0_OUT 190 +#define JH7110_SYSCLK_PLL1_OUT 191 +#define JH7110_SYSCLK_PLL2_OUT 192
+#define JH7110_SYSCLK_END 193
Ohh, that's not good.. If you pass the U-Boot dtb to Linux it won't understand the numbering. The headers are part of the dt-binding :/
In fact, the clock index >= 190 makes linux hang on boot, waiting with EPROBE_DEFER for every device's clock, because the sysclk driver errors out with EINVAL (jh7110_sysclk_get()).
Yup, that's about what I expected to happen.
Because PLL driver is separated from SYSCRG drivers in Linux, the numbering starts from 0. But in Uboot, the PLL driver is included in the SYSCRG driver, and the number follows the SYSCRG.
Unfortunately, how you choose to construct your drivers has nothing to do with this. These defines/numbers appear in the dts and are part of the DT ABI. The same dts is supposed to work for Linux & U-Boot.
The JH7110 has 6 blocks of 64k iomem in that functional area: {SYS,STG,AON} x {CRG,SYSCON}. None of these has 190 clocks. The good news: the current DTS, as proposed here and in U-Boot master, provides nodes for all 6 entities. The bad news is that the clock assignments to those nodes and their numbering is messed up.
AFAICT PLL{0,1,2} _are_ generated in SYS_SYSCON and thus U-Boot gets it wrong, in addition to the erroneous DTS.
The numbers are kinda hocus-pocus anyway, they are just made up since the clock numbering usually isn't something with a nice TRM to go and reference (unlike interrupts which usually are documented in that way). It is very helpful to make them aligned some register/bit positions or, but that is not required. IOW U-Boot is not wrong per se to use 190 instead of 0, but it is wrong to have different numbers in both places.
It sounds like you're saying that (and I have not looked) the U-Boot dts actually has structural difference w.r.t. what provides which clock? If so, that'll need to be fixed independently of the numbering problem.
Otherwise Xingyu & Yanhong should coordinate on which is the "correct" way of doing things & do it in both places.
Thanks, Conor.
> +/* PLL clocks */ > +#define JH7110_CLK_PLL0_OUT 0 > +#define JH7110_CLK_PLL1_OUT 1 > +#define JH7110_CLK_PLL2_OUT 2
Oh, unfortunately, the 7110 can not support to mix the uboot dtb and linux dtb up. If boot the Linux and should use the linux dtb instead of the uboot dtb. Because all clock ids and reset ids in Linux and Uboot are different include PLL, and some modules can work in Linux but not in uboot. I suggest to boot Linux with its own linux dtb.
Best regards, Xingyu Wu
On Fri, May 19, 2023 at 03:57:33PM +0200, Torsten Duwe wrote: > On Fri, May 12, 2023 at 10:20:30AM +0800, Xingyu Wu wrote: > [...]
> > +/* PLL clocks */ > > +#define JH7110_CLK_PLL0_OUT 0 > > +#define JH7110_CLK_PLL1_OUT 1 > > +#define JH7110_CLK_PLL2_OUT 2 > > In U-Boot commit 58c9c60b Yanhong Wang added: > > + > +#define JH7110_SYSCLK_PLL0_OUT 190 > +#define JH7110_SYSCLK_PLL1_OUT 191 > +#define JH7110_SYSCLK_PLL2_OUT 192 > + > +#define JH7110_SYSCLK_END 193
What does "cannot support" mean? It's normal and desirable for the same dtb to be usable for both. The Linux kernel's dt-bindings are used for multiple projects, not just Linux - it'd be silly for U-Boot, FreeBSD etc etc to go off and each have their open set of (incompatible) bindings.
What do you mean by "modules"? It is fine for either Linux or U-Boot to not have drivers for particular peripherals - for example, there might be no driver for your camera related bits in U-Boot, or for controlling DRAM in Linux.
The description of the hardware should not change though, as the hardware has not.
I suggest to make sure that you can use the same dtb for both.
Thanks, Conor.
On Wed, 24 May 2023 11:19:48 +0100 Conor Dooley conor.dooley@microchip.com wrote:
On 2023/5/19 22:16, Conor Dooley wrote: > On Fri, May 19, 2023 at 03:57:33PM +0200, Torsten Duwe > wrote: >> On Fri, May 12, 2023 at 10:20:30AM +0800, Xingyu Wu wrote:
Exactly. As I wrote (quote below), the PLLx frequencies are controlled by the I/O block SYS_SYSCON (starting there at offset 0x18), according to the public datasheets. All(?) other clocks are derived from those in the *_CRG units. That *is* the hardware to be described, in *the* (one and only!) DT. U-Boot, and any OS, are free to reorganise their driver framework around that, but the hardware description is quite clear.
U-Boot reuses the Common Clock Framework from Linux, and I'm not sure whether the clock IDs need to be unique in order for the appropriate clock to be found. But that would be the only restriction, if it applies. Even then, each driver could register a clock with its own, arbitrarily chosen base offset with the CCF, so each CRG unit could still have its own clocks enumerated starting with 0 in the DTB.
IMHO "desirable" is too weak.
This is a fragile band-aid, to be used only as a last resort. It creates more problems than it solves. Your DTB will then match your kernel, but whether it describes the actual hardware is a game of chance. Doesn't the VisionFive2 have an RPi connector... ?
One of the IMO few valid use cases of adding a DTB to the kernel at boot is OpenWRT, when you build an OS Image for a particular piece of hardware you have at hand.
Interestingly enough, U-Boot already has the PLL driver in a separate file. I have a half-baked patch here that moves the sys_syscon DT matching into that file...
Torsten
On Tue, May 23, 2023 at 10:56:43AM +0800, Xingyu Wu wrote: > On 2023/5/19 22:16, Conor Dooley wrote: > > On Fri, May 19, 2023 at 03:57:33PM +0200, Torsten Duwe > > wrote: > >> On Fri, May 12, 2023 at 10:20:30AM +0800, Xingyu Wu wrote:
> Because PLL driver is separated from SYSCRG drivers in > Linux, the numbering starts from 0. But in Uboot, the PLL > driver is included in the SYSCRG driver, and the number > follows the SYSCRG.
The dt-binding that is in this series specifies that the pll clock controller is a child of the syscon: https://lore.kernel.org/linux-riscv/20230512022036.97987-1-xingyu.wu@starfiv...
That seems correct to me & U-Boot's devicetree is not compliant.
Unique within the clock controller, otherwise it is impossible to tell the difference between <&cctrl 1> and <&cctrl 1> apart! (The same follows even with increased #clock-cells, something must be unique). That's besides the point of this particular issue though.
Yeah, agreed. I just don't like being prescriptive about what happens in projects that I do not maintain things for I guess.
If you have patches that fix the devicetree & drivers in U-Boot, please post them. I don't really care at all which set of arbitrary numbers are chosen (as long as there is one and one only) but it looks like U-Boot's devicetree has an incorrect description of the clock controllers.
Thanks, Conor.
> On Tue, May 23, 2023 at 10:56:43AM +0800, Xingyu Wu wrote: > > On 2023/5/19 22:16, Conor Dooley wrote: > > > On Fri, May 19, 2023 at 03:57:33PM +0200, Torsten Duwe > > > wrote: > > >> On Fri, May 12, 2023 at 10:20:30AM +0800, Xingyu Wu wrote:
> > Because PLL driver is separated from SYSCRG drivers in > > Linux, the numbering starts from 0. But in Uboot, the PLL > > driver is included in the SYSCRG driver, and the number > > follows the SYSCRG. > > Unfortunately, how you choose to construct your drivers has > nothing to do with this.
> These defines/numbers appear in the dts and are part of the DT > ABI. The same dts is supposed to work for Linux & U-Boot.
Thank you for your suggestions. I will discuss with my partners how to solve this problem.
Hi Conor and Torsten, After our internal discussions, it was decided to make the change on Uboot. The clock id in Uboot are changed to be same with Linux and the PLL clocks become the child node of SYSCON. And we will send this patch on Uboot soon.
Best Regards, Xingyu Wu
Conor Dooley
Torsten Duwe
Xingyu Wu
