[PATCH v2 0/3] arm: mvebu: helios-4: add config fragment for spi booting et al
This patch-set introduces a new config fragment for spi booting on kobol helios-4.
Additionally add minor update for default defconfig to enable setexpr command, and fix u-boot command access to i2c0 bus.
Signed-off-by: Josua Mayer josua@solid-run.com --- Changes in v2: - replaced new defconfig with config fragment in board directory (suggested by Tom Rini trini@konsulko.com) - Link to v1: https://lore.kernel.org/r/20240113-helios4-spi-v1-0-2a5663a10e6a@solid-run.c...
--- Josua Mayer (3): arm: dts: armada-38x-solidrun-microsom: configure i2c0 bus arm: mvebu: helios4_defconfig: enable setexpr command board: helios-4: add config fragment for spi booting
arch/arm/dts/armada-38x-solidrun-microsom.dtsi | 5 +++++ board/kobol/helios4/spiboot.config | 4 ++++ configs/helios4_defconfig | 1 - 3 files changed, 9 insertions(+), 1 deletion(-) --- base-commit: 050a9b981d6a835133521b599be3ae189ce70f41 change-id: 20240113-helios4-spi-144085c0bbc7
Sincerely,
SolidRun Armada-388 SoM has an i2c bus supporting on-som eeprom, and peripherals on a carrier. armada-38x.dtsi disables this bus by default, it should be enabled by som or carrier dts.
Linux has moved i2c0 from helios-4 board dts to som dtsi, including status, pinctrl and clock speed. Copy these settings from mainline.
This fixes accessing i2c bus from u-boot commandline.
Signed-off-by: Josua Mayer josua@solid-run.com --- arch/arm/dts/armada-38x-solidrun-microsom.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/armada-38x-solidrun-microsom.dtsi b/arch/arm/dts/armada-38x-solidrun-microsom.dtsi index f6ae784bed..1540162e03 100644 --- a/arch/arm/dts/armada-38x-solidrun-microsom.dtsi +++ b/arch/arm/dts/armada-38x-solidrun-microsom.dtsi @@ -99,6 +99,11 @@ };
&i2c0 { + clock-frequency = <400000>; + pinctrl-0 = <&i2c0_pins>; + pinctrl-names = "default"; + status = "okay"; + eeprom@53 { compatible = "atmel,24c02"; reg = <0x53>;
Applied to u-boot-marvell/master
Thanks, Stefan
&i2c0 {
- clock-frequency = <400000>;
- pinctrl-0 = <&i2c0_pins>;
- pinctrl-names = "default";
- status = "okay";
- eeprom@53 { compatible = "atmel,24c02"; reg = <0x53>;
Viele Grüße, Stefan Roese
Update the helios4 defconfig to enable the 'setexpr' command, which is a default and useful for various complex boot-scripts.
Signed-off-by: Josua Mayer josua@solid-run.com --- configs/helios4_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index 04194004f0..73f0638344 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y
I am curious about your use cases for this. as ideally all systems use the generic distro boot paths and it is not needed for them.
Dennis
-- 2.35.3
Hi Dennis,
Use-case is with separate boot and rootfs partitions to calculate next partition number as argument for further commands:
setexpr openwrt_rootpart ${distro_bootpart} + 1 part uuid ${devtype} ${devnum}:${openwrt_rootpart} uuid setenv bootargs ${bootargs} root=PARTUUID=${uuid} rootfstype=auto rootwait
- Josua Mayer
Am 12.02.24 um 21:40 schrieb Dennis Gilmore:
Dennis
Update the helios4 defconfig to enable the 'setexpr' command, which is a default and useful for various complex boot-scripts. Signed-off-by: Josua Mayer <josua@solid-run.com> --- configs/helios4_defconfig | 1 - 1 file changed, 1 deletion(-) diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index 04194004f0..73f0638344 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -44,7 +44,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TFTPPUT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y -- 2.35.3
-- Dennis Gilmore Senior Manager Systems Enablement OpenShift Development
Thanks, Stefan
Add a config fragment with required differences for booting from spi flash instead of sd-card (default).
Settings for environment location are based on vendor u-boot: https://github.com/kobol-io/u-boot/blob/helios4/include/configs/helios4.h#L5...
The fragment can be applied on top of helios4_defconfig by make: make helios4_defconfig spiboot.config
Signed-off-by: Josua Mayer josua@solid-run.com --- board/kobol/helios4/spiboot.config | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/kobol/helios4/spiboot.config b/board/kobol/helios4/spiboot.config new file mode 100644 index 0000000000..5ffb7d2e3b --- /dev/null +++ b/board/kobol/helios4/spiboot.config @@ -0,0 +1,4 @@ +CONFIG_MVEBU_SPL_BOOT_DEVICE_SPI=y +# CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC is not set +CONFIG_ENV_OFFSET=0x100000 +CONFIG_ENV_SECT_SIZE=0x10000
Can you please follow-up by adding doc/board/kobol/ content (and adding to the index and making sure make htmldocs is happy) ? Thanks!
Thanks, Stefan
Dennis Gilmore
Josua Mayer
Stefan Roese
