[U-Boot] [PATCH] warp7: Adjust CONFIG_MMCROOT for booting a mainline kernel
When booting a mainline kernel on warp7 we have: - mmc0: Wifi SDIO chip - mmc1: eMMC
, so point CONFIG_MMCROOT to use mmcblk1 instead.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- include/configs/warp7.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/warp7.h b/include/configs/warp7.h index e59b16c..eaea4e6 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -113,7 +113,7 @@
#define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 0 -#define CONFIG_MMCROOT "/dev/mmcblk2p2" +#define CONFIG_MMCROOT "/dev/mmcblk1p2"
/* USB Configs */ #define CONFIG_USB_STORAGE
- mmc1: eMMC
As far as I know, the sold WaRP7 boards are shipped with the NXP kernel so if this patch is applied, the U-Boot won't work out of box for most of users.
From me, this is a NACK.
Hi Otavio,
On Thu, Aug 25, 2016 at 5:13 PM, Otavio Salvador otavio.salvador@ossystems.com.br wrote:
- mmc1: eMMC
Currently U-Boot mainline does not boot NXP kernel, so I am not breaking anything here.
To better handle NXP kernel I can add a 'warp7_secure_defconfig' and then do like this to handle the mmcroot:
--- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -113,7 +113,11 @@
#define CONFIG_SYS_MMC_ENV_DEV 0 #define CONFIG_SYS_MMC_ENV_PART 0 -#define CONFIG_MMCROOT "/dev/mmcblk2p2" +#ifdef CONFIG_ARMV7_BOOT_SEC_DEFAULT +#define CONFIG_MMCROOT "/dev/mmcblk2p2" /* NXP kernel */ +#else +#define CONFIG_MMCROOT "/dev/mmcblk1p2" /* Mainline kernel */ +#endif
- mmc1: eMMC
Well ...
warp7: Select secure boot
In order to boot NXP 4.1.15 we need to boot in secure mode.
So enable the variable CONFIG_ARMV7_BOOT_SEC_DEFAULT by default.
Signed-off-by: Breno Lima breno.lima@nxp.com
From Breno, sent to the mailing list, does fix this and so it does work.
Someone using mainline kernel is expected to know how to set mmcroot variable or so. I would not include this patch at all.
On Thu, Aug 25, 2016 at 5:56 PM, Otavio Salvador otavio.salvador@ossystems.com.br wrote:
Well ...
No, this is only available in u-boot-fslc.
This would be a bad customer experience. Much better when things work out of the box.
Mangling the mmcroot depending of secure boot is hidden things from user, in my point of view.
I am not the i.MX or WaRP7 maintainer so it is not my call but if I were to decide I prefer default to be kept working with NXP kernel. To accept this change, I would prefer if NXP kernel was changed in a way it uses same mmcroot as will be used in mainline so if user upgrades it, he/she has a consistent behaviour.
Hi Otavio,
On Thu, Aug 25, 2016 at 6:06 PM, Otavio Salvador otavio.salvador@ossystems.com.br wrote:
Yes, I agree.
It seems like a more elegant solution is to use UUID to specify the rootfs location.
Will prepare a v2.
Thanks
Fabio Estevam
Fabio Estevam
Otavio Salvador
