[U-Boot] [PATCH v2 0/5] [3/3] Initial support Texas Instrument's AM654 Platform
Continue from PART 2/3...
This series adds arm64 support for AM654 EVM. Patch 2/6 describes the boot flow in detail. I would recommend to go through the patch in order to understand the entire boot flow.
Right now only arm64 support is added. r5 support will be posted later once loading of system firmware is ported to generic filesystem loader.
Changes since v1: - Merged adding readme patch[2/6] to board support patch[1/6] - Updated more info on the boot flow.
Andreas Dannenberg (1): include: am654_evm: Establish initial environment for SD card boot
Lokesh Vutla (4): board: ti: am654: a53: Add initial support for am654 arm64: dts: k3: Add Support for AM654 SoC arm64: dts: k3: Add u-boot specific nodes configs: am65x_evm_a53: Add initial support
arch/arm/dts/Makefile | 2 + arch/arm/dts/k3-am65-main.dtsi | 31 +++ arch/arm/dts/k3-am65.dtsi | 87 ++++++++ arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 203 +++++++++++++++++++ arch/arm/dts/k3-am654-base-board.dts | 36 ++++ arch/arm/dts/k3-am654.dtsi | 115 +++++++++++ arch/arm/mach-k3/Kconfig | 1 + board/ti/am65x/Kconfig | 28 +++ board/ti/am65x/MAINTAINERS | 6 + board/ti/am65x/Makefile | 8 + board/ti/am65x/README | 141 +++++++++++++ board/ti/am65x/evm.c | 68 +++++++ configs/am65x_evm_a53_defconfig | 71 +++++++ include/configs/am65x_evm.h | 69 +++++++ include/dt-bindings/pinctrl/k3-am65.h | 49 +++++ 15 files changed, 915 insertions(+) create mode 100644 arch/arm/dts/k3-am65-main.dtsi create mode 100644 arch/arm/dts/k3-am65.dtsi create mode 100644 arch/arm/dts/k3-am654-base-board-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am654-base-board.dts create mode 100644 arch/arm/dts/k3-am654.dtsi create mode 100644 board/ti/am65x/Kconfig create mode 100644 board/ti/am65x/MAINTAINERS create mode 100644 board/ti/am65x/Makefile create mode 100644 board/ti/am65x/README create mode 100644 board/ti/am65x/evm.c create mode 100644 configs/am65x_evm_a53_defconfig create mode 100644 include/configs/am65x_evm.h create mode 100644 include/dt-bindings/pinctrl/k3-am65.h
Add initial support for AM654 based EVM running on A53. Enable 4GB of DDR available on the EVM so that kernel DTB file can be updated accordingly.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com [Andreas: Added 4GB ddr support] Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/mach-k3/Kconfig | 1 + board/ti/am65x/Kconfig | 28 +++++++ board/ti/am65x/MAINTAINERS | 5 ++ board/ti/am65x/Makefile | 8 ++ board/ti/am65x/README | 141 ++++++++++++++++++++++++++++++++++++ board/ti/am65x/evm.c | 56 ++++++++++++++ include/configs/am65x_evm.h | 34 +++++++++ 7 files changed, 273 insertions(+) create mode 100644 board/ti/am65x/Kconfig create mode 100644 board/ti/am65x/MAINTAINERS create mode 100644 board/ti/am65x/Makefile create mode 100644 board/ti/am65x/README create mode 100644 board/ti/am65x/evm.c create mode 100644 include/configs/am65x_evm.h
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index 1380013fe7..2df6197af7 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -47,4 +47,5 @@ config SYS_K3_BOOT_PARAM_TABLE_INDEX Address at which ROM stores the value which determines if SPL is booted up by primary boot media or secondary boot media.
+source "board/ti/am65x/Kconfig" endif diff --git a/board/ti/am65x/Kconfig b/board/ti/am65x/Kconfig new file mode 100644 index 0000000000..591600483e --- /dev/null +++ b/board/ti/am65x/Kconfig @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ +# Lokesh Vutla lokeshvutla@ti.com + +choice + prompt "K3 AM65 based boards" + optional + +config TARGET_AM654_A53_EVM + bool "TI K3 based AM654 EVM running on A53" + select ARM64 + select SOC_K3_AM6 + +endchoice + +if TARGET_AM654_A53_EVM + +config SYS_BOARD + default "am65x" + +config SYS_VENDOR + default "ti" + +config SYS_CONFIG_NAME + default "am65x_evm" + +endif diff --git a/board/ti/am65x/MAINTAINERS b/board/ti/am65x/MAINTAINERS new file mode 100644 index 0000000000..c5921b4a28 --- /dev/null +++ b/board/ti/am65x/MAINTAINERS @@ -0,0 +1,5 @@ +AM65x BOARD +M: Lokesh Vutla lokeshvutla@ti.com +S: Maintained +F: board/ti/am65x/ +F: include/configs/am65x_evm.h diff --git a/board/ti/am65x/Makefile b/board/ti/am65x/Makefile new file mode 100644 index 0000000000..94dddfcc4a --- /dev/null +++ b/board/ti/am65x/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ +# Lokesh Vutla lokeshvutla@ti.com +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := evm.o diff --git a/board/ti/am65x/README b/board/ti/am65x/README new file mode 100644 index 0000000000..e7f4ff6578 --- /dev/null +++ b/board/ti/am65x/README @@ -0,0 +1,141 @@ +Introduction: +------------- +The AM65x family of SoCs is the first device family from K3 Multicore +SoC architecture, targeted for broad market and industrial control with +aim to meet the complex processing needs of modern embedded products. + +The device is built over three domains, each containing specific processing +cores, voltage domains and peripherals: +1. Wake-up (WKUP) domain: + - Device Management and Security Controller (DMSC) +2. Microcontroller (MCU) domain: + - Dual Core ARM Cortex-R5F processor +3. MAIN domain: + - Quad core 64-bit ARM Cortex-A53 + +More info can be found in TRM: http://www.ti.com/lit/pdf/spruid7 + +Boot Flow: +---------- +On AM65x family devices, ROM supports boot only via MCU(R5). This means that +bootloader has to run on R5 core. In order to meet this constraint, and for +the following reasons the boot flow is designed as mentioned: +1. Need to move away from R5 asap, so that we want to start *any* +firmware on the r5 cores like.... autosar can be loaded to receive CAN +response and other safety operations to be started. This operation is +very time critical and is applicable for all automotive use cases. +2. U-Boot on A53 should start other remotecores for various +applications. This should happen before running Linux. +3. In production boot flow, we might not like to use full u-boot, +instead use Flacon boot flow to reduce boot time. + ++------------------------------------------------------------------------+ +| DMSC | R5 | A53 | ++------------------------------------------------------------------------+ +| +--------+ | | | +| | Reset | | | | +| +--------+ | | | +| : | | | +| +--------+ | +-----------+ | | +| | *rom* |----------|-->| Reset rls | | | +| +--------+ | +-----------+ | | +| | | | : | | +| | rom | | : | | +| |services| | : | | +| | | | +-------------+ | | +| | | | | *R5 rom* | | | +| | | | +-------------+ | | +| | |<---------|---|Load and auth| | | +| | | | | tiboot3.bin | | | +| | | | +-------------+ | | +| | | | : | | +| | | | : | | +| | | | : | | +| | | | +-------------+ | | +| | Start | | | *R5 SPL* | | | +| | System | | +-------------+ | | +| |Firmware|<---------|---|Load and auth| | | +| +--------+ | | sysfw bin | | | +| : | +-------------+ | | +| +---------+ | | DDR | | | +| | *SYSFW* | | | config | | | +| +---------+ | +-------------+ | | +| | |<--------|---| Load | | | +| | | | | tispl.bin | | | +| | | | +-------------+ | | +| | |<--------|---| Start A53 | | | +| | | | | and Reset | | | +| | | | +-------------+ | | +| | | | | +-----------+ | +| | |---------|-----------------------|---->| Reset rls | | +| | | | | +-----------+ | +| | DMSC | | | : | +| |Services | | | +-----------+ | +| | |<--------|-----------------------|---->|*ATF/OPTEE*| | +| | | | | +-----------+ | +| | | | | : | +| | | | | +-----------+ | +| | |<--------|-----------------------|---->| *A53 SPL* | | +| | | | | +-----------+ | +| | | | | | Load | | +| | | | | | u-boot.img| | +| | | | | +-----------+ | +| | | | | : | +| | | | | +-----------+ | +| | |<--------|-----------------------|---->| *u-boot* | | +| | | | | +-----------+ | +| | | | | | prompt | | +| | | | | +-----------+ | +| +---------+ | | | +| | | | ++------------------------------------------------------------------------+ + +- Here DMSC acts as master and provides all the critical services. R5/A53 +requests DMSC to get these services done as shown in the above diagram. + +Sources: +-------- +1. SYSFW: + System Firmware repo is closed source and the binaries are delivered + to users with NDA. Please contact TI to get the System Firmware + Binary named ti-sci-firmware-am6x.bin that runs on AM65x SoC. + +2. ATF: + Tree: https://github.com/ARM-software/arm-trusted-firmware.git + Branch: master + +3. OPTEE: + Tree: https://github.com/OP-TEE/optee_os.git + Branch: master + +4. U-Boot: + Tree: http://git.denx.de/u-boot.git + Branch: master + +Build procedure: +---------------- +1. SYSFW: + ROM expects a signed binary that contains the X509 certificate. So +the binary ti-sci-firmware-am6x.bin cannot be uses as-is and needs to be signed. +Contact TI on the procedure to sign the system firmware binary. + +2. ATF: +$ make CROSS_COMPILE=aarch64-linux-gnu- ARCH=aarch64 PLAT=k3 TARGET_BOARD=generic SPD=opteed + +3. OPTEE: +$ make PLATFORM=k3-am65x CFG_ARM64_core=y + +4. U-Boot: + +4.1. R5: + TBD. + +4.2. A53: +$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- am65x_evm_a53_defconfig O=/tmp/a53 +$ make ARCH=arm CROSS_COMPILE=aarch64-linux-gnu- ATF=<path to ATF dir>/build/k3/generic/release/bl31.bin TEE=<path to OPTEE OS dir>/out/arm-plat-k3/core/tee-pager.bin O=/tmp/a53 + +Target Images +-------------- +Copy the below images to an SD card and boot: +- tiboot3.bin from step 4.1 +- tispl.bin, u-boot.img from 4.2 diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c new file mode 100644 index 0000000000..cb54d97551 --- /dev/null +++ b/board/ti/am65x/evm.c @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Board specific initialization for AM654 EVM + * + * Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ + * Lokesh Vutla lokeshvutla@ti.com + * + */ + +#include <common.h> +#include <asm/io.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ +#ifdef CONFIG_PHYS_64BIT + gd->ram_size = 0x100000000; +#else + gd->ram_size = 0x80000000; +#endif + + return 0; +} + +ulong board_get_usable_ram_top(ulong total_size) +{ +#ifdef CONFIG_PHYS_64BIT + /* Limit RAM used by U-Boot to the DDR low region */ + if (gd->ram_top > 0x100000000) + return 0x100000000; +#endif + + return gd->ram_top; +} + +int dram_init_banksize(void) +{ + /* Bank 0 declares the memory available in the DDR low region */ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = 0x80000000; + +#ifdef CONFIG_PHYS_64BIT + /* Bank 1 declares the memory available in the DDR high region */ + gd->bd->bi_dram[1].start = CONFIG_SYS_SDRAM_BASE1; + gd->bd->bi_dram[1].size = 0x80000000; +#endif + + return 0; +} diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h new file mode 100644 index 0000000000..90dd9f3721 --- /dev/null +++ b/include/configs/am65x_evm.h @@ -0,0 +1,34 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration header file for K3 AM654 EVM + * + * Copyright (C) 2017-2018 Texas Instruments Incorporated - http://www.ti.com/ + * Lokesh Vutla lokeshvutla@ti.com + */ + +#ifndef __CONFIG_AM654_EVM_H +#define __CONFIG_AM654_EVM_H + +#include <linux/sizes.h> +#include <config_distro_bootcmd.h> + +#define CONFIG_ENV_SIZE (128 << 10) + +/* DDR Configuration */ +#define CONFIG_SYS_SDRAM_BASE1 0x880000000 + +/* SPL Loader Configuration */ +#ifdef CONFIG_TARGET_AM654_A53_EVM +#define CONFIG_SPL_TEXT_BASE 0x80080000 +#endif + +#define CONFIG_SKIP_LOWLEVEL_INIT + +#define CONFIG_SPL_MAX_SIZE CONFIG_SYS_K3_MAX_DOWNLODABLE_IMAGE_SIZE +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + \ + CONFIG_SYS_K3_NON_SECURE_MSRAM_SIZE - 4) + +/* Now for the remaining common defines */ +#include <configs/ti_armv7_common.h> + +#endif /* __CONFIG_AM654_EVM_H */
Create a basic U-Boot environment that allows the automatic loading of a Linux Kernel located at /boot/Image and an associated device tree blob located at /boot/k3-am654-base-board.dtb from the secondary partition of an ext4-formatted SD card on the AM654x EVM. Furthermore the boot.scr and uEnv.txt detection and loading schemes are supported in a manner already known from other TI platforms.
Note that this is intended to be a starting point to enable initial board use and will most certainly get extended and refactored as different boot media become available.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Andreas Dannenberg dannenberg@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- include/configs/am65x_evm.h | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/include/configs/am65x_evm.h b/include/configs/am65x_evm.h index 90dd9f3721..65015df131 100644 --- a/include/configs/am65x_evm.h +++ b/include/configs/am65x_evm.h @@ -11,6 +11,7 @@
#include <linux/sizes.h> #include <config_distro_bootcmd.h> +#include <environment/ti/mmc.h>
@@ -28,6 +29,40 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SPL_TEXT_BASE + \ CONFIG_SYS_K3_NON_SECURE_MSRAM_SIZE - 4)
+/* U-Boot general configuration */ +#define EXTRA_ENV_AM65X_BOARD_SETTINGS \ + "findfdt=" \ + "if test $board_name = am65x; then " \ + "setenv name_fdt k3-am654-base-board.dtb; " \ + "else if test $name_fdt = undefined; then " \ + "echo WARNING: Could not determine device tree to use;"\ + "fi; fi; " \ + "setenv fdtfile ${name_fdt}\0" \ + "loadaddr=0x80080000\0" \ + "fdtaddr=0x82000000\0" \ + "name_kern=Image\0" \ + "console=ttyS2,115200n8\0" \ + "args_all=setenv optargs earlycon=ns16550a,mmio32,0x02800000\0" \ + "run_kern=booti ${loadaddr} ${rd_spec} ${fdtaddr}\0" + +/* U-Boot MMC-specific configuration */ +#define EXTRA_ENV_AM65X_BOARD_SETTINGS_MMC \ + "boot=mmc\0" \ + "mmcdev=1\0" \ + "bootpart=1:2\0" \ + "bootdir=/boot\0" \ + "rd_spec=-\0" \ + "init_mmc=run args_all args_mmc\0" \ + "get_fdt_mmc=load mmc ${bootpart} ${fdtaddr} ${bootdir}/${name_fdt}\0" \ + "get_kern_mmc=load mmc ${bootpart} ${loadaddr} " \ + "${bootdir}/${name_kern}\0" + +/* Incorporate settings into the U-Boot environment */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + DEFAULT_MMC_TI_ARGS \ + EXTRA_ENV_AM65X_BOARD_SETTINGS \ + EXTRA_ENV_AM65X_BOARD_SETTINGS_MMC + /* Now for the remaining common defines */ #include <configs/ti_armv7_common.h>
Add initial DT support for AM654 EVM that runs on A53.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/Makefile | 2 + arch/arm/dts/k3-am65-main.dtsi | 31 ++++++++ arch/arm/dts/k3-am65.dtsi | 87 ++++++++++++++++++++ arch/arm/dts/k3-am654-base-board.dts | 36 +++++++++ arch/arm/dts/k3-am654.dtsi | 115 +++++++++++++++++++++++++++ board/ti/am65x/evm.c | 12 +++ 6 files changed, 283 insertions(+) create mode 100644 arch/arm/dts/k3-am65-main.dtsi create mode 100644 arch/arm/dts/k3-am65.dtsi create mode 100644 arch/arm/dts/k3-am654-base-board.dts create mode 100644 arch/arm/dts/k3-am654.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ebfa227262..150e1d4090 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -549,6 +549,8 @@ dtb-$(CONFIG_TARGET_STM32MP1) += \ stm32mp157c-ed1.dtb \ stm32mp157c-ev1.dtb
+dtb-$(CONFIG_SOC_K3_AM6) += k3-am654-base-board.dtb + targets += $(dtb-y)
# Add any required device tree compiler flags here diff --git a/arch/arm/dts/k3-am65-main.dtsi b/arch/arm/dts/k3-am65-main.dtsi new file mode 100644 index 0000000000..2409344df4 --- /dev/null +++ b/arch/arm/dts/k3-am65-main.dtsi @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for AM6 SoC Family Main Domain peripherals + * + * Copyright (C) 2016-2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +&cbass_main { + gic500: interrupt-controller@1800000 { + compatible = "arm,gic-v3"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + #interrupt-cells = <3>; + interrupt-controller; + reg = <0x01800000 0x10000>, /* GICD */ + <0x01880000 0x90000>; /* GICR */ + /* + * vcpumntirq: + * virtual CPU interface maintenance interrupt + */ + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + + gic_its: gic-its@18200000 { + compatible = "arm,gic-v3-its"; + reg = <0x01820000 0x10000>; + msi-controller; + #msi-cells = <1>; + }; + }; +}; diff --git a/arch/arm/dts/k3-am65.dtsi b/arch/arm/dts/k3-am65.dtsi new file mode 100644 index 0000000000..cede1fa098 --- /dev/null +++ b/arch/arm/dts/k3-am65.dtsi @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for AM6 SoC Family + * + * Copyright (C) 2016-2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + model = "Texas Instruments K3 AM654 SoC"; + compatible = "ti,am654"; + interrupt-parent = <&gic500>; + #address-cells = <2>; + #size-cells = <2>; + + chosen { }; + + firmware { + optee { + compatible = "linaro,optee-tz"; + method = "smc"; + }; + + psci: psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + }; + + a53_timer0: timer-cl0-cpu0 { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */ + <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */ + <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */ + <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */ + }; + + pmu: pmu { + compatible = "arm,armv8-pmuv3"; + /* Recommendation from GIC500 TRM Table A.3 */ + interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>; + }; + + cbass_main: interconnect@100000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00100000 0x00 0x00100000 0x00020000>, /* ctrl mmr */ + <0x00600000 0x00 0x00600000 0x00001100>, /* GPIO */ + <0x00900000 0x00 0x00900000 0x00012000>, /* serdes */ + <0x01000000 0x00 0x01000000 0x0af02400>, /* Most peripherals */ + <0x30800000 0x00 0x30800000 0x0bc00000>, /* MAIN NAVSS */ + /* MCUSS Range */ + <0x28380000 0x00 0x28380000 0x03880000>, + <0x40200000 0x00 0x40200000 0x00900100>, + <0x42040000 0x00 0x42040000 0x03ac2400>, + <0x45100000 0x00 0x45100000 0x00c24000>, + <0x46000000 0x00 0x46000000 0x00200000>, + <0x47000000 0x00 0x47000000 0x00068400>; + + cbass_mcu: interconnect@28380000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x28380000 0x28380000 0x03880000>, /* MCU NAVSS*/ + <0x40200000 0x40200000 0x00900100>, /* First peripheral window */ + <0x42040000 0x42040000 0x03ac2400>, /* WKUP */ + <0x45100000 0x45100000 0x00c24000>, /* MMRs, remaining NAVSS */ + <0x46000000 0x46000000 0x00200000>, /* CPSW */ + <0x47000000 0x47000000 0x00068400>; /* OSPI space 1 */ + + cbass_wakeup: interconnect@42040000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + /* WKUP Basic peripherals */ + ranges = <0x42040000 0x42040000 0x03ac2400>; + }; + }; + }; +}; + +/* Now include the peripherals for each bus segments */ +#include "k3-am65-main.dtsi" diff --git a/arch/arm/dts/k3-am654-base-board.dts b/arch/arm/dts/k3-am654-base-board.dts new file mode 100644 index 0000000000..af6956fdc1 --- /dev/null +++ b/arch/arm/dts/k3-am654-base-board.dts @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2016-2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-am654.dtsi" + +/ { + compatible = "ti,am654-evm", "ti,am654"; + model = "Texas Instruments AM654 Base Board"; + + chosen { + stdout-path = "serial2:115200n8"; + bootargs = "earlycon=ns16550a,mmio32,0x02800000"; + }; + + memory@80000000 { + device_type = "memory"; + /* 4G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>, + <0x00000008 0x80000000 0x00000000 0x80000000>; + }; + + reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + secure_ddr: secure_ddr@9e800000 { + reg = <0 0x9e800000 0 0x01800000>; /* for OP-TEE */ + alignment = <0x1000>; + no-map; + }; + }; +}; diff --git a/arch/arm/dts/k3-am654.dtsi b/arch/arm/dts/k3-am654.dtsi new file mode 100644 index 0000000000..2affa6f661 --- /dev/null +++ b/arch/arm/dts/k3-am654.dtsi @@ -0,0 +1,115 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree Source for AM6 SoC family in Quad core configuration + * + * Copyright (C) 2016-2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include "k3-am65.dtsi" + +/ { + cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu-map { + cluster0: cluster0 { + core0 { + cpu = <&cpu0>; + }; + + core1 { + cpu = <&cpu1>; + }; + }; + + cluster1: cluster1 { + core0 { + cpu = <&cpu2>; + }; + + core1 { + cpu = <&cpu3>; + }; + }; + }; + + cpu0: cpu@0 { + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x000>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0x8000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_0>; + }; + + cpu1: cpu@1 { + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x001>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0x8000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_0>; + }; + + cpu2: cpu@100 { + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x100>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0x8000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_1>; + }; + + cpu3: cpu@101 { + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x101>; + device_type = "cpu"; + enable-method = "psci"; + i-cache-size = <0x8000>; + i-cache-line-size = <64>; + i-cache-sets = <256>; + d-cache-size = <0x8000>; + d-cache-line-size = <64>; + d-cache-sets = <128>; + next-level-cache = <&L2_1>; + }; + }; + + L2_0: l2-cache0 { + compatible = "cache"; + cache-level = <2>; + cache-size = <0x80000>; + cache-line-size = <64>; + cache-sets = <512>; + next-level-cache = <&msmc_l3>; + }; + + L2_1: l2-cache1 { + compatible = "cache"; + cache-level = <2>; + cache-size = <0x80000>; + cache-line-size = <64>; + cache-sets = <512>; + next-level-cache = <&msmc_l3>; + }; + + msmc_l3: l3-cache0 { + compatible = "cache"; + cache-level = <3>; + }; +}; diff --git a/board/ti/am65x/evm.c b/board/ti/am65x/evm.c index cb54d97551..784b2b0191 100644 --- a/board/ti/am65x/evm.c +++ b/board/ti/am65x/evm.c @@ -54,3 +54,15 @@ int dram_init_banksize(void)
return 0; } + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ +#ifdef CONFIG_TARGET_AM654_A53_EVM + if (!strcmp(name, "k3-am654-base-board")) + return 0; +#endif + + return -1; +} +#endif
Add the minimum dt nodes required to boot. These nodes will get deleted as kernel gets these nodes added in the main dts files.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/k3-am654-base-board-u-boot.dtsi | 203 +++++++++++++++++++ include/dt-bindings/pinctrl/k3-am65.h | 49 +++++ 2 files changed, 252 insertions(+) create mode 100644 arch/arm/dts/k3-am654-base-board-u-boot.dtsi create mode 100644 include/dt-bindings/pinctrl/k3-am65.h
diff --git a/arch/arm/dts/k3-am654-base-board-u-boot.dtsi b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi new file mode 100644 index 0000000000..d4ecb3be10 --- /dev/null +++ b/arch/arm/dts/k3-am654-base-board-u-boot.dtsi @@ -0,0 +1,203 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include <dt-bindings/pinctrl/k3-am65.h> + +/ { + chosen { + stdout-path = "serial2:115200n8"; + }; + + aliases { + serial2 = &main_uart0; + }; +}; + +&cbass_main{ + u-boot,dm-spl; + secure_proxy: secure_proxy@32c00000 { + compatible = "ti,am654-secure-proxy"; + #mbox-cells = <1>; + reg-names = "target_data", "rt", "scfg"; + reg = <0x32c00000 0x100000>, + <0x32400000 0x100000>, + <0x32800000 0x100000>; + interrupt-names = "rx_011"; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + }; + + dmsc: dmsc { + compatible = "ti,k2g-sci"; + ti,host-id = <12>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + /* + * In case of rare platforms that does not use am6 as + * system master, use /delete-property/ + */ + ti,system-reboot-controller; + mbox-names = "rx", "tx"; + + mboxes= <&secure_proxy 11>, + <&secure_proxy 13>; + + k3_pds: power-controller { + compatible = "ti,sci-pm-domain"; + #power-domain-cells = <1>; + }; + + k3_clks: clocks { + compatible = "ti,k2g-sci-clk"; + #clock-cells = <2>; + }; + + k3_reset: reset-controller { + compatible = "ti,sci-reset"; + #reset-cells = <2>; + }; + + k3_sysreset: sysreset-controller { + compatible = "ti,sci-sysreset"; + }; + }; + + main_pmx0: pinmux@11c000 { + compatible = "pinctrl-single"; + reg = <0x11c000 0x2e4>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + main_pmx1: pinmux@11c2e8 { + compatible = "pinctrl-single"; + reg = <0x11c2e8 0x24>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <32>; + pinctrl-single,function-mask = <0xffffffff>; + }; + + main_uart0: serial@2800000 { + compatible = "ti,am654-uart", "ti,omap4-uart", "ns16550a"; + reg = <0x02800000 0x100>; + reg-shift = <2>; + reg-io-width = <4>; + interrupts = <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + current-speed = <115200>; + status = "disabled"; + u-boot,dm-pre-reloc; + }; + + sdhci0: sdhci@04F80000 { + compatible = "arasan,sdhci-5.1"; + reg = <0x4F80000 0x1000>, + <0x4F90000 0x400>; + clocks = <&k3_clks 47 1>; + power-domains = <&k3_pds 47>; + max-frequency = <25000000>; + }; + + sdhci1: sdhci@04FA0000 { + compatible = "arasan,sdhci-5.1"; + reg = <0x4FA0000 0x1000>, + <0x4FB0000 0x400>; + clocks = <&k3_clks 48 1>; + power-domains = <&k3_pds 48>; + max-frequency = <25000000>; + }; + +}; + +&secure_proxy { + u-boot,dm-spl; +}; + +&dmsc { + u-boot,dm-spl; +}; + +&k3_pds { + u-boot,dm-spl; +}; + +&k3_clks { + u-boot,dm-spl; +}; + +&k3_reset { + u-boot,dm-spl; +}; + +&main_pmx0 { + u-boot,dm-spl; + main_uart0_pins_default: main_uart0_pins_default { + pinctrl-single,pins = < + AM65X_IOPAD(0x01e4, PIN_INPUT | MUX_MODE0) /* (AF11) UART0_RXD */ + AM65X_IOPAD(0x01e8, PIN_OUTPUT | MUX_MODE0) /* (AE11) UART0_TXD */ + AM65X_IOPAD(0x01ec, PIN_INPUT | MUX_MODE0) /* (AG11) UART0_CTSn */ + AM65X_IOPAD(0x01f0, PIN_OUTPUT | MUX_MODE0) /* (AD11) UART0_RTSn */ + >; + }; + + main_mmc0_pins_default: main_mmc0_pins_default { + pinctrl-single,pins = < + AM65X_IOPAD(0x01a8, PIN_INPUT_PULLDOWN | MUX_MODE0) /* (B25) MMC0_CLK */ + AM65X_IOPAD(0x01aC, PIN_INPUT_PULLUP | MUX_MODE0) /* (B27) MMC0_CMD */ + AM65X_IOPAD(0x01a4, PIN_INPUT_PULLUP | MUX_MODE0) /* (A26) MMC0_DAT0 */ + AM65X_IOPAD(0x01a0, PIN_INPUT_PULLUP | MUX_MODE0) /* (E25) MMC0_DAT1 */ + AM65X_IOPAD(0x019c, PIN_INPUT_PULLUP | MUX_MODE0) /* (C26) MMC0_DAT2 */ + AM65X_IOPAD(0x0198, PIN_INPUT_PULLUP | MUX_MODE0) /* (A25) MMC0_DAT3 */ + AM65X_IOPAD(0x0194, PIN_INPUT_PULLUP | MUX_MODE0) /* (E24) MMC0_DAT4 */ + AM65X_IOPAD(0x0190, PIN_INPUT_PULLUP | MUX_MODE0) /* (A24) MMC0_DAT5 */ + AM65X_IOPAD(0x018c, PIN_INPUT_PULLUP | MUX_MODE0) /* (B26) MMC0_DAT6 */ + AM65X_IOPAD(0x0188, PIN_INPUT_PULLUP | MUX_MODE0) /* (D25) MMC0_DAT7 */ + AM65X_IOPAD(0x01b0, PIN_INPUT | MUX_MODE0) /* (C25) MMC0_DS */ + >; + }; + + main_mmc1_pins_default: main_mmc1_pins_default { + pinctrl-single,pins = < + AM65X_IOPAD(0x02d4, PIN_INPUT_PULLDOWN | MUX_MODE0) /* (C27) MMC1_CLK */ + AM65X_IOPAD(0x02d8, PIN_INPUT_PULLUP | MUX_MODE0) /* (C28) MMC1_CMD */ + AM65X_IOPAD(0x02d0, PIN_INPUT_PULLUP | MUX_MODE0) /* (D28) MMC1_DAT0 */ + AM65X_IOPAD(0x02cc, PIN_INPUT_PULLUP | MUX_MODE0) /* (E27) MMC1_DAT1 */ + AM65X_IOPAD(0x02c8, PIN_INPUT_PULLUP | MUX_MODE0) /* (D26) MMC1_DAT2 */ + AM65X_IOPAD(0x02c4, PIN_INPUT_PULLUP | MUX_MODE0) /* (D27) MMC1_DAT3 */ + AM65X_IOPAD(0x02dc, PIN_INPUT_PULLUP | MUX_MODE0) /* (B24) MMC1_SDCD */ + AM65X_IOPAD(0x02e0, PIN_INPUT | MUX_MODE0) /* (C24) MMC1_SDWP */ + >; + }; + +}; + +&main_pmx1 { + u-boot,dm-spl; +}; + +&main_uart0 { + u-boot,dm-spl; + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; + status = "okay"; +}; + +&sdhci0 { + u-boot,dm-spl; + status = "okay"; + non-removable; + bus-width = <8>; + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc0_pins_default>; +}; + +&sdhci1 { + u-boot,dm-spl; + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc1_pins_default>; + sdhci-caps-mask = <0x7 0x0>; +}; diff --git a/include/dt-bindings/pinctrl/k3-am65.h b/include/dt-bindings/pinctrl/k3-am65.h new file mode 100644 index 0000000000..c86c9fd4ce --- /dev/null +++ b/include/dt-bindings/pinctrl/k3-am65.h @@ -0,0 +1,49 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * This header provides constants for TI K3-AM65 pinctrl bindings. + * + * Copyright (C) 2018 Texas Instruments + */ +#ifndef _DT_BINDINGS_PINCTRL_TI_K3_AM65_H +#define _DT_BINDINGS_PINCTRL_TI_K3_AM65_H + +/* K3 mux mode options for each pin. See TRM for options */ +#define MUX_MODE0 0 +#define MUX_MODE1 1 +#define MUX_MODE2 2 +#define MUX_MODE3 3 +#define MUX_MODE4 4 +#define MUX_MODE5 5 +#define MUX_MODE6 6 +#define MUX_MODE7 7 +#define MUX_MODE15 15 + +#define PULL_DISABLE (1 << 16) +#define PULL_UP (1 << 17) +#define INPUT_EN (1 << 18) +#define SLEWCTRL_200MHZ 0 +#define SLEWCTRL_150MHZ (1 << 19) +#define SLEWCTRL_100MHZ (2 << 19) +#define SLEWCTRL_50MHZ (3 << 19) +#define TX_DIS (1 << 21) +#define ISO_OVR (1 << 22) +#define ISO_BYPASS (1 << 23) +#define DS_EN (1 << 24) +#define DS_INPUT (1 << 25) +#define DS_FORCE_OUT_HIGH (1 << 26) +#define DS_PULL_UP_DOWN_EN 0 +#define DS_PULL_UP_DOWN_DIS (1 << 27) +#define DS_PULL_UP_SEL (1 << 28) +#define WAKEUP_ENABLE (1 << 29) + +#define PIN_OUTPUT (PULL_DISABLE) +#define PIN_OUTPUT_PULLUP (PULL_UP) +#define PIN_OUTPUT_PULLDOWN 0 +#define PIN_INPUT (INPUT_EN | PULL_DISABLE) +#define PIN_INPUT_PULLUP (INPUT_EN | PULL_UP) +#define PIN_INPUT_PULLDOWN (INPUT_EN) + +#define AM65X_IOPAD(pa, val) (((pa) & 0x1fff)) (val) +#define AM65X_WKUP_IOPAD(pa, val) (((pa) & 0x1fff)) (val) + +#endif
Add initial defconfig support for AM65x that runs on A53.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am65x/MAINTAINERS | 1 + configs/am65x_evm_a53_defconfig | 71 +++++++++++++++++++++++++++++++++ 2 files changed, 72 insertions(+) create mode 100644 configs/am65x_evm_a53_defconfig
diff --git a/board/ti/am65x/MAINTAINERS b/board/ti/am65x/MAINTAINERS index c5921b4a28..ca1ce58f72 100644 --- a/board/ti/am65x/MAINTAINERS +++ b/board/ti/am65x/MAINTAINERS @@ -3,3 +3,4 @@ M: Lokesh Vutla lokeshvutla@ti.com S: Maintained F: board/ti/am65x/ F: include/configs/am65x_evm.h +F: configs/am65x_evm_a53_defconfig diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig new file mode 100644 index 0000000000..a17cf7cb50 --- /dev/null +++ b/configs/am65x_evm_a53_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SOC_K3_AM6=y +CONFIG_TARGET_AM654_A53_EVM=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_DRIVERS_MISC_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_NR_DRAM_BANKS=2 +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_LOAD_FIT=y +CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run run_kern" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_REMOTEPROC=y +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_REMOTEPROC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am654-base-board" +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_INTERFACE="mmc" +CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" +CONFIG_DM=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_TI_SCI=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_MISC=y +CONFIG_DM_MMC=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_K3_ARASAN=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_GENERIC is not set +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_K3=y +CONFIG_DM_RESET=y +CONFIG_RESET_TI_SCI=y +CONFIG_DM_SERIAL=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_TI_SCI=y
Lokesh Vutla
