[PATCH] mmc: rockchip_sdhci: enable strobe line for HS400
The default configuration of rk3399 EMMC PHY does not enable the strobe line, and EMMC controller will got data transmission error at HS400 mode.
Signed-off-by: Yifeng Zhao yifeng.zhao@rock-chips.com ---
drivers/mmc/rockchip_sdhci.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c index 1ac00587d4..278473899c 100644 --- a/drivers/mmc/rockchip_sdhci.c +++ b/drivers/mmc/rockchip_sdhci.c @@ -143,6 +143,9 @@ static void rk3399_emmc_phy_power_on(struct rockchip_emmc_phy *phy, u32 clock) writel(RK_CLRSETBITS(3 << 12, freqsel << 12), &phy->emmcphy_con[0]); writel(RK_CLRSETBITS(1 << 1, 1 << 1), &phy->emmcphy_con[6]);
+ /* REN Enable on STRB Line for HS400 */ + writel(RK_CLRSETBITS(0, 1 << 9), &phy->emmcphy_con[2]); + read_poll_timeout(readl, &phy->emmcphy_status, dllrdy, PHYCTRL_DLL_LOCK_WO_TMOUT(dllrdy), 1, 5000); }
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- /* REN Enable on STRB Line for HS400 */
- writel(RK_CLRSETBITS(0, 1 << 9), &phy->emmcphy_con[2]);
- read_poll_timeout(readl, &phy->emmcphy_status, dllrdy, PHYCTRL_DLL_LOCK_WO_TMOUT(dllrdy), 1, 5000); }
Just wonder about doesn't it affect to other mode?
Best Regards, Jaehoon Chung
Hi Jaehoon
The strobe line will only be used in hs400 mode and will not affect other modes.
Best Regards, Yifeng Zhao
Hi Yifeng,
On 10/18/21 10:08 AM, 赵仪峰 wrote:
Hi Jaehoon
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Jaehoon Chung
Kever Yang
Yifeng Zhao
赵仪峰
