[U-Boot] [PATCH 1/2] tools: env: Fix format warnings in debug
Format warnings (-Wformat) were shown in printf() calls after defining DEBUG macro.
Update format string and explicitly cast variables to suppress all warnings.
Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com --- tools/env/fw_env.c | 17 ++++++++++------- 1 file changed, 10 insertions(+), 7 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 06cf63d..b4b542a 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -649,8 +649,8 @@ static int flash_bad_block (int fd, uint8_t mtd_type, loff_t *blockstart)
if (badblock) { #ifdef DEBUG - fprintf (stderr, "Bad block at 0x%llx, " - "skipping\n", *blockstart); + fprintf (stderr, "Bad block at 0x%llx, skipping\n", + (unsigned long long) *blockstart); #endif return badblock; } @@ -737,7 +737,8 @@ static int flash_read_buf (int dev, int fd, void *buf, size_t count, } #ifdef DEBUG fprintf(stderr, "Read 0x%x bytes at 0x%llx on %s\n", - rc, blockstart + block_seek, DEVNAME(dev)); + rc, (unsigned long long) blockstart + block_seek, + DEVNAME(dev)); #endif processed += readlen; readlen = min (blocklen, count - processed); @@ -835,8 +836,9 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count, if (block_seek + count != write_total) { if (block_seek != 0) fprintf(stderr, " and "); - fprintf(stderr, "0x%lx - 0x%x", - block_seek + count, write_total - 1); + fprintf(stderr, "0x%lx - 0x%lx", + (unsigned long) block_seek + count, + (unsigned long) write_total - 1); } fprintf(stderr, "\n"); #endif @@ -899,8 +901,9 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count, }
#ifdef DEBUG - fprintf(stderr, "Write 0x%x bytes at 0x%llx\n", erasesize, - blockstart); + fprintf(stderr, "Write 0x%llx bytes at 0x%llx\n", + (unsigned long long) erasesize, + (unsigned long long) blockstart); #endif if (write (fd, data + processed, erasesize) != erasesize) { fprintf (stderr, "Write error on %s: %s\n",
Up to now we were able to read/write environment data from/to UBI volumes only indirectly by gluebi driver. This driver creates NAND MTD on top of UBI volumes, which is quite a workaroung for this use case.
Add support for direct read/write UBI volumes in order to not use obsolete gluebi driver.
Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com --- tools/env/fw_env.c | 249 +++++++++++++++++++++++++++++++++++++++++++++++- tools/env/fw_env.config | 8 ++ 2 files changed, 256 insertions(+), 1 deletion(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index b4b542a..0e977e3 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -24,6 +24,7 @@ #include <sys/ioctl.h> #include <sys/stat.h> #include <unistd.h> +#include <dirent.h>
#ifdef MTD_OLD # include <stdint.h> @@ -33,6 +34,8 @@ # include <mtd/mtd-user.h> #endif
+#include <mtd/ubi-user.h> + #include "fw_env.h"
struct common_args common_args; @@ -54,6 +57,7 @@ struct envdev_s { ulong erase_size; /* device erase size */ ulong env_sectors; /* number of environment sectors */ uint8_t mtd_type; /* type of the MTD device */ + int is_ubi; /* set if we use UBI volume */ };
static struct envdev_s envdevices[2] = @@ -72,6 +76,7 @@ static int dev_current; #define DEVESIZE(i) envdevices[(i)].erase_size #define ENVSECTORS(i) envdevices[(i)].env_sectors #define DEVTYPE(i) envdevices[(i)].mtd_type +#define IS_UBI(i) envdevices[(i)].is_ubi
#define CUR_ENVSIZE ENVSIZE(dev_current)
@@ -117,6 +122,229 @@ static unsigned char obsolete_flag = 0; #define DEFAULT_ENV_INSTANCE_STATIC #include <env_default.h>
+#define UBI_DEV_START "/dev/ubi" +#define UBI_SYSFS "/sys/class/ubi" +#define UBI_VOL_NAME_PATT "ubi%d_%d" + +static int is_ubi_devname(const char *devname) +{ + return !strncmp(devname, UBI_DEV_START, sizeof(UBI_DEV_START) - 1); +} + +static int ubi_check_volume_sysfs_name(const char *volume_sysfs_name, + const char *volname) +{ + char path[256]; + FILE *file; + char *name; + int ret; + + strcpy(path, UBI_SYSFS "/"); + strcat(path, volume_sysfs_name); + strcat(path, "/name"); + + file = fopen(path, "r"); + if (!file) + return -1; + + ret = fscanf(file, "%ms", &name); + fclose(file); + if (ret <= 0 || !name) { + fprintf(stderr, + "Failed to read from file %s, ret = %d, name = %s\n", + path, ret, name); + return -1; + } + + if (!strcmp(name, volname)) { + free(name); + return 0; + } + free(name); + + return -1; +} + +static int ubi_get_volnum_by_name(int devnum, const char *volname) +{ + DIR *sysfs_ubi; + struct dirent *dirent; + int ret; + int tmp_devnum; + int volnum; + + sysfs_ubi = opendir(UBI_SYSFS); + if (!sysfs_ubi) + return -1; + +#ifdef DEBUG + fprintf(stderr, "Looking for volume name "%s"\n", volname); +#endif + + while (1) { + dirent = readdir(sysfs_ubi); + if (!dirent) + return -1; + + ret = sscanf(dirent->d_name, UBI_VOL_NAME_PATT, + &tmp_devnum, &volnum); + if (ret == 2 && devnum == tmp_devnum) { + if (ubi_check_volume_sysfs_name(dirent->d_name, + volname) == 0) + return volnum; + } + } + + return -1; +} + +static int ubi_get_devnum_by_devname(const char *devname) +{ + int devnum; + int ret; + + ret = sscanf(devname + sizeof(UBI_DEV_START) - 1, "%d", &devnum); + if (ret != 1) + return -1; + + return devnum; +} + +static const char *ubi_get_volume_devname(const char *devname, + const char *volname) +{ + char *volume_devname; + int volnum; + int devnum; + int ret; + + devnum = ubi_get_devnum_by_devname(devname); + if (devnum < 0) + return NULL; + + volnum = ubi_get_volnum_by_name(devnum, volname); + if (volnum < 0) + return NULL; + + ret = asprintf(&volume_devname, "%s_%d", devname, volnum); + if (ret < 0) + return NULL; + +#ifdef DEBUG + fprintf(stderr, "Found ubi volume "%s:%s" -> %s\n", + devname, volname, volume_devname); +#endif + + return volume_devname; +} + +static void ubi_check_dev(unsigned int dev_id) +{ + char *devname = (char *) DEVNAME(dev_id); + char *pname; + const char *volname = NULL; + const char *volume_devname; + + if (!is_ubi_devname(DEVNAME(dev_id))) + return; + + IS_UBI(dev_id) = 1; + + for (pname = devname; *pname != '\0'; pname++) { + if (*pname == ':') { + *pname = '\0'; + volname = pname + 1; + break; + } + } + + if (volname) { + /* Let's find real volume device name */ + volume_devname = ubi_get_volume_devname(devname, + volname); + if (!volume_devname) { + fprintf(stderr, "Didn't found ubi volume "%s"\n", + volname); + return; + } + + free(devname); + DEVNAME(dev_id) = volume_devname; + } +} + +static int ubi_update_start(int fd, int64_t bytes) +{ + if (ioctl(fd, UBI_IOCVOLUP, &bytes)) + return -1; + return 0; +} + +static int ubi_read(int fd, void *buf, size_t count) +{ + ssize_t ret; + + while (count > 0) { + ret = read(fd, buf, count); + if (ret > 0) { + count -= ret; + buf += ret; + + continue; + } + + if (ret == 0) { + /* + * Happens in case of too short volume data size. If we + * return error status we will fail it will be treated + * as UBI device error. + * + * Leave catching this error to CRC check. + */ + fprintf(stderr, "Warning: end of data on ubi volume\n"); + return 0; + } else if (errno == EBADF) { + /* + * Happens in case of corrupted volume. The same as + * above, we cannot return error now, as we will still + * be able to successfully write environment later. + */ + fprintf(stderr, "Warning: corrupted volume?\n"); + return 0; + } else if (errno == EINTR) { + continue; + } + + fprintf(stderr, "Cannot read %u bytes from ubi volume, %s\n", + (unsigned int) count, strerror(errno)); + return -1; + } + + return 0; +} + +static int ubi_write(int fd, const void *buf, size_t count) +{ + ssize_t ret; + + while (count > 0) { + ret = write(fd, buf, count); + if (ret <= 0) { + if (ret < 0 && errno == EINTR) + continue; + + fprintf(stderr, "Cannot write %u bytes to ubi volume\n", + (unsigned int) count); + return -1; + } + + count -= ret; + buf += ret; + } + + return 0; +} + static int flash_io (int mode); static char *envmatch (char * s1, char * s2); static int parse_config (void); @@ -997,6 +1225,12 @@ static int flash_write (int fd_current, int fd_target, int dev_target) DEVOFFSET (dev_target), DEVNAME (dev_target)); #endif
+ if (IS_UBI(dev_target)) { + if (ubi_update_start(fd_target, CUR_ENVSIZE) < 0) + return 0; + return ubi_write(fd_target, environment.image, CUR_ENVSIZE); + } + rc = flash_write_buf(dev_target, fd_target, environment.image, CUR_ENVSIZE, DEVOFFSET(dev_target), DEVTYPE(dev_target)); @@ -1024,6 +1258,12 @@ static int flash_read (int fd) struct stat st; int rc;
+ if (IS_UBI(dev_current)) { + DEVTYPE(dev_current) = MTD_ABSENT; + + return ubi_read(fd, environment.image, CUR_ENVSIZE); + } + rc = fstat(fd, &st); if (rc < 0) { fprintf(stderr, "Cannot stat the file %s\n", @@ -1236,7 +1476,8 @@ int fw_env_open(void) DEVTYPE(!dev_current) == MTD_UBIVOLUME) { environment.flag_scheme = FLAG_INCREMENTAL; } else if (DEVTYPE(dev_current) == MTD_ABSENT && - DEVTYPE(!dev_current) == MTD_ABSENT) { + DEVTYPE(!dev_current) == MTD_ABSENT && + IS_UBI(dev_current) == IS_UBI(!dev_current)) { environment.flag_scheme = FLAG_INCREMENTAL; } else { fprintf (stderr, "Incompatible flash types!\n"); @@ -1369,6 +1610,12 @@ static int parse_config () HaveRedundEnv = 1; #endif #endif + + /* Fills in IS_UBI(), converts DEVNAME() with ubi volume name */ + ubi_check_dev(0); + if (HaveRedundEnv) + ubi_check_dev(1); + if (stat (DEVNAME (0), &st)) { fprintf (stderr, "Cannot access MTD device %s: %s\n", diff --git a/tools/env/fw_env.config b/tools/env/fw_env.config index 6f216f9..db5498a 100644 --- a/tools/env/fw_env.config +++ b/tools/env/fw_env.config @@ -23,3 +23,11 @@
# VFAT example #/boot/uboot.env 0x0000 0x4000 + +# UBI volume +#/dev/ubi0_0 0x0 0x20000 +#/dev/ubi0_1 0x0 0x20000 + +# UBI volume by name +#/dev/ubi0:env 0x0 0x20000 +#/dev/ubi0:env-redund 0x0 0x20000
#include "fw_env.h"
- int is_ubi; /* set if we use UBI volume */
- return !strncmp(devname, UBI_DEV_START, sizeof(UBI_DEV_START) - 1);
- char path[256];
- FILE *file;
- char *name;
- int ret;
- strcpy(path, UBI_SYSFS "/");
- strcat(path, volume_sysfs_name);
- strcat(path, "/name");
- file = fopen(path, "r");
- if (!file)
return -1;
- ret = fscanf(file, "%ms", &name);
- fclose(file);
- if (ret <= 0 || !name) {
fprintf(stderr,
path, ret, name);
return -1;
- if (!strcmp(name, volname)) {
free(name);
- free(name);
- return -1;
- DIR *sysfs_ubi;
- struct dirent *dirent;
- int ret;
- int tmp_devnum;
- int volnum;
- sysfs_ubi = opendir(UBI_SYSFS);
- if (!sysfs_ubi)
return -1;
+#ifdef DEBUG
- fprintf(stderr, "Looking for volume name "%s"\n", volname);
- while (1) {
if (!dirent)
return -1;
volname) == 0)
return volnum;
- return -1;
- int devnum;
- int ret;
- ret = sscanf(devname + sizeof(UBI_DEV_START) - 1, "%d", &devnum);
- if (ret != 1)
return -1;
- return devnum;
- char *volume_devname;
- int volnum;
- int devnum;
- int ret;
- devnum = ubi_get_devnum_by_devname(devname);
- if (devnum < 0)
return NULL;
- volnum = ubi_get_volnum_by_name(devnum, volname);
- if (volnum < 0)
return NULL;
- ret = asprintf(&volume_devname, "%s_%d", devname, volnum);
- if (ret < 0)
return NULL;
+#ifdef DEBUG
- fprintf(stderr, "Found ubi volume "%s:%s" -> %s\n",
- return volume_devname;
- char *devname = (char *) DEVNAME(dev_id);
- char *pname;
- const char *volname = NULL;
- const char *volume_devname;
- if (!is_ubi_devname(DEVNAME(dev_id)))
return;
- IS_UBI(dev_id) = 1;
- for (pname = devname; *pname != '\0'; pname++) {
*pname = '\0';
break;
- if (volname) {
volname);
fprintf(stderr, "Didn't found ubi volume \"%s\"\n",
volname);
return;
free(devname);
- if (ioctl(fd, UBI_IOCVOLUP, &bytes))
return -1;
- ssize_t ret;
- while (count > 0) {
if (ret > 0) {
count -= ret;
buf += ret;
continue;
if (ret == 0) {
continue;
return -1;
- ssize_t ret;
if (ret <= 0) {
continue;
return -1;
count -= ret;
buf += ret;
- if (IS_UBI(dev_target)) {
- rc = flash_write_buf(dev_target, fd_target, environment.image, CUR_ENVSIZE, DEVOFFSET(dev_target), DEVTYPE(dev_target));
- if (IS_UBI(dev_current)) {
- rc = fstat(fd, &st); if (rc < 0) { fprintf(stderr, "Cannot stat the file %s\n",
} else { fprintf (stderr, "Incompatible flash types!\n");IS_UBI(dev_current) == IS_UBI(!dev_current)) { environment.flag_scheme = FLAG_INCREMENTAL;
- /* Fills in IS_UBI(), converts DEVNAME() with ubi volume name */
- ubi_check_dev(0);
- if (HaveRedundEnv)
ubi_check_dev(1);
- if (stat (DEVNAME (0), &st)) { fprintf (stderr, "Cannot access MTD device %s: %s\n",
Hello Marcin,
Sorry for the long delay
Am 06.05.2016 um 14:58 schrieb Marcin Niestroj:
I tried to apply your patch, but this fails, and I was unsure, if I could fix it correct... can you please send a new rebased version?
Thanks!
bye, Heiko
#include "fw_env.h"
- char path[256];
- FILE *file;
- char *name;
- int ret;
- if (!file)
return -1;
- fclose(file);
fprintf(stderr,
path, ret, name);
return -1;
free(name);
- free(name);
- return -1;
- DIR *sysfs_ubi;
- int ret;
- int tmp_devnum;
- int volnum;
- if (!sysfs_ubi)
return -1;
+#ifdef DEBUG
- while (1) {
if (!dirent)
return -1;
volname) == 0)
return volnum;
- return -1;
- int devnum;
- int ret;
- if (ret != 1)
return -1;
- return devnum;
- int volnum;
- int devnum;
- int ret;
- if (devnum < 0)
return NULL;
- if (volnum < 0)
return NULL;
- if (ret < 0)
return NULL;
+#ifdef DEBUG
- char *pname;
return;
*pname = '\0';
break;
- if (volname) {
volname);
volname);
return;
free(devname);
return -1;
- ssize_t ret;
if (ret > 0) {
count -= ret;
buf += ret;
continue;
if (ret == 0) {
continue;
return -1;
- ssize_t ret;
if (ret <= 0) {
continue;
return -1;
count -= ret;
buf += ret;
- static int flash_io (int mode); static char *envmatch (char * s1, char * s2); static int parse_config (void);
- ubi_check_dev(0);
ubi_check_dev(1);
ping
if (badblock) {
#ifdef DEBUG
DEVNAME(dev));
} fprintf(stderr, "\n");(unsigned long) write_total - 1);
#ifdef DEBUG
blockstart);
Heiko Schocher
Marcin Niestroj
