[U-Boot] [PATCH] beagleboard: enable HUB power on all variants of the BeagleBoard
From: Christian Spielberger c.spielberger@bct-electronic.com
Signed-off-by: Joel A Fernandes joelagnel@ti.com Cc: "Eric Bénard" eric@eukrea.com Cc: "Christian Spielberger" c.spielberger@bct-electronic.com --- Pushing this patch myself as no one else did.
Previous discussions: http://article.gmane.org/gmane.comp.boot-loaders.u-boot/105663/ http://article.gmane.org/gmane.comp.boot-loaders.u-boot/101540/
board/ti/beagle/beagle.c | 10 +++++++++- 1 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 13fe39b..9d65e9e 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -332,7 +332,15 @@ int misc_init_r(void) setenv(expansion_config.env_var, expansion_config.env_setting);
twl4030_power_init(); - twl4030_led_init(TWL4030_LED_LEDEN_LEDAON | TWL4030_LED_LEDEN_LEDBON); + switch (get_board_revision()) { + case REVISION_XM_C: + case REVISION_C4: + twl4030_led_init(TWL4030_LED_LEDEN_LEDAON | TWL4030_LED_LEDEN_LEDBON); + break; + default: + twl4030_led_init(TWL4030_LED_LEDEN_LEDBON); + break; + }
/* Set GPIO states before they are made outputs */ writel(GPIO23 | GPIO10 | GPIO8 | GPIO2 | GPIO1,
Signed-off-by: Joel A Fernandes joelagnel@ti.com Cc: "Eric Bأ�nard" eric@eukrea.com Cc: "Christian Spielberger" c.spielberger@bct-electronic.com
- switch (get_board_revision()) {
- case REVISION_XM_C:
- case REVISION_C4:
break;
- default:
break;
Am I just too sleepy or the Subject doesn't correlate with what the patch does ...
My understanding of Subject is that it enables power on HUB ... USB HUB ? But the patch enables some LEDs ?
I might be wrong.
CHeers
- case REVISION_C4:
- break;
- default:
- twl4030_led_init(TWL4030_LED_LEDEN_LEDBON);
- break;
Please excuse if this is a duplicate, but I'm configuring a new mail tool and I don't think my other message got sent.
It is XM_A and XM_B that are odd-balls, so the correct code should be something like:
+ switch (get_board_revision()) { + case REVISION_XM_A: + case REVISION_XM_B: + twl4030_led_init(TWL4030_LED_LEDEN_LEDBON); /* LEDA signal set low */ + break; + default: + twl4030_led_init(TWL4030_LED_LEDEN_LEDAON | TWL4030_LED_LEDEN_LEDBON); + break;
The LED drivers on the power management device (TWL4030-compatible) are used to enable the hub power.
I might be wrong.
CHeers
case REVISION_XM_C:
case REVISION_C4:
default:
break;
case REVISION_XM_A:
case REVISION_XM_B:
signal set low */
break;
default:
break;
Oh uh ... ok, now I understand. Please add a comment explaining it.
Also, change the subject se it's clear you're operating with USB HUB here.
Thanks!
I might be wrong.
CHeers
Jason Kridner
Joel A Fernandes
