[U-Boot] [RFC PATCH v2 11/12] mkimage: Fix variable length header support
Support for variable length images like AIS image was introduced in commit f0662105b674a3874227316abf8536bebc9b5995. A parameter "-s" was also introduced to prohibit copying of the image file automatically in the main program. However, this parameter was implemented incorrectly and the image file was copied nevertheless.
Signed-off-by: Christian Riesch christian.riesch@omicron.at Cc: Stefano Babic sbabic@denx.de Cc: Heiko Schocher hs@denx.de --- tools/mkimage.c | 97 ++++++++++++++++++++++++++++--------------------------- 1 files changed, 49 insertions(+), 48 deletions(-)
diff --git a/tools/mkimage.c b/tools/mkimage.c index 36e28ec..eeb1b10 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -383,65 +383,66 @@ NXTARG: ; exit (EXIT_FAILURE); }
- if (!params.skipcpy && - (params.type == IH_TYPE_MULTI || - params.type == IH_TYPE_SCRIPT)) { - char *file = params.datafile; - uint32_t size; - - for (;;) { - char *sep = NULL; - - if (file) { - if ((sep = strchr(file, ':')) != NULL) { - *sep = '\0'; + if (!params.skipcpy) { + if (params.type == IH_TYPE_MULTI || + params.type == IH_TYPE_SCRIPT) { + char *file = params.datafile; + uint32_t size; + + for (;;) { + char *sep = NULL; + + if (file) { + if ((sep = strchr(file, ':')) != NULL) { + *sep = '\0'; + } + + if (stat (file, &sbuf) < 0) { + fprintf (stderr, "%s: Can't stat %s: %s\n", + params.cmdname, file, strerror(errno)); + exit (EXIT_FAILURE); + } + size = cpu_to_uimage (sbuf.st_size); + } else { + size = 0; }
- if (stat (file, &sbuf) < 0) { - fprintf (stderr, "%s: Can't stat %s: %s\n", - params.cmdname, file, strerror(errno)); + if (write(ifd, (char *)&size, sizeof(size)) != sizeof(size)) { + fprintf (stderr, "%s: Write error on %s: %s\n", + params.cmdname, params.imagefile, + strerror(errno)); exit (EXIT_FAILURE); } - size = cpu_to_uimage (sbuf.st_size); - } else { - size = 0; - }
- if (write(ifd, (char *)&size, sizeof(size)) != sizeof(size)) { - fprintf (stderr, "%s: Write error on %s: %s\n", - params.cmdname, params.imagefile, - strerror(errno)); - exit (EXIT_FAILURE); - } + if (!file) { + break; + }
- if (!file) { - break; + if (sep) { + *sep = ':'; + file = sep + 1; + } else { + file = NULL; + } }
- if (sep) { - *sep = ':'; - file = sep + 1; - } else { - file = NULL; - } - } + file = params.datafile;
- file = params.datafile; - - for (;;) { - char *sep = strchr(file, ':'); - if (sep) { - *sep = '\0'; - copy_file (ifd, file, 1); - *sep++ = ':'; - file = sep; - } else { - copy_file (ifd, file, 0); - break; + for (;;) { + char *sep = strchr(file, ':'); + if (sep) { + *sep = '\0'; + copy_file (ifd, file, 1); + *sep++ = ':'; + file = sep; + } else { + copy_file (ifd, file, 0); + break; + } } + } else { + copy_file (ifd, params.datafile, 0); } - } else { - copy_file (ifd, params.datafile, 0); }
/* We're a bit of paranoid */
Christian Riesch
