[U-Boot] U-Boot on the POGO-E02
I'm trying to get the latest U-Boot on a Pogoplug (Pink) POGO-E02. I've gotten so far as to get something to compile and thought I'd check here to see if I'm on the right track.
The pink Pogoplug is a sheevaplug but with 256M of RAM instead of 1G. All it needs is a different kwbimage.cfg file, it's not really a whole new board, so I've taken pains not to just duplicate the sheevaplug board but instead to create a new target with a different kwbimage. (Is the trick with CONFIG_SYS_KWD_CONFIG the right approach?)
The appended patch is to the latest U-Boot release, 2012-04. I'll see about sending a patch with git as described in the FAQ if I get something working.
This patch is not to apply, but I'm having a problem because the patch wraps. boards.cfg contains long lines, and some of the original source has long lines as well. What to do?
Thanks for the help.
Karl kop@meme.com Free Software: "You don't pay back, you pay forward." -- Robert A. Heinlein
-----------<snip>------------------ diff '--exclude=*~' -ruN u-boot-2012.04.orig/board/Marvell/sheevaplug/ kwbimage-pogoplug_e02.cfg u-boot-2012.04-pogo//board/Marvell/ sheevaplug/kwbimage-pogoplug_e02.cfg --- u-boot-2012.04.orig/board/Marvell/sheevaplug/kwbimage- pogoplug_e02.cfg 1969-12-31 18:00:00.000000000 -0600 +++ u-boot-2012.04-pogo//board/Marvell/sheevaplug/kwbimage- pogoplug_e02.cfg 2012-07-26 21:18:10.000000000 -0500 @@ -0,0 +1,166 @@ +# +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# Modified for the POGO-E02 by: Karl O. Pinc kop@meme.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# +# This is the kwbimage.cfg file for the Pogoplug (Pink) POGO-E02. +# It is the same as the sheevaplug image (Sheevaplug Development kit +# board) except that the sheevaplug has 1G of ram and this has only +# 256M. +# +# Refer doc/README.kwbimage for more details about how-to configure +# and create kirkwood boot image +# + +# Boot Media configurations +BOOT_FROM nand +NAND_ECC_MODE default +NAND_PAGE_SIZE 0x0800 + +# SOC registers configuration using bootrom header extension +# Maximum KWBIMAGE_MAX_CONFIG configurations allowed + +# Configure RGMII-0 interface pad voltage to 1.8V +DATA 0xFFD100e0 0x1b1b1b9b + +#Dram initalization for SINGLE x16 CL=5 @ 400MHz +DATA 0xFFD01400 0x43000c30 # DDR Configuration register +# bit13-0: 0xc30 (3120 DDR2 clks refresh rate) +# bit23-14: zero +# bit24: 1= enable exit self refresh mode on DDR access +# bit25: 1 required +# bit29-26: zero +# bit31-30: 01 + +DATA 0xFFD01404 0x37543000 # DDR Controller Control Low +# bit 4: 0=addr/cmd in smame cycle +# bit 5: 0=clk is driven during self refresh, we don't care for APX +# bit 6: 0=use recommended falling edge of clk for addr/cmd +# bit14: 0=input buffer always powered up +# bit18: 1=cpu lock transaction enabled +# bit23-20: 5=recommended value for CL=5 and STARTBURST_DEL disabled bit31=0 +# bit27-24: 7= CL+2, STARTBURST sample stages, for freqs 400MHz, unbuffered DIMM +# bit30-28: 3 required +# bit31: 0=no additional STARTBURST delay + +DATA 0xFFD01408 0x22125451 # DDR Timing (Low) (active cycles value +1) +# bit3-0: TRAS lsbs +# bit7-4: TRCD +# bit11- 8: TRP +# bit15-12: TWR +# bit19-16: TWTR +# bit20: TRAS msb +# bit23-21: 0x0 +# bit27-24: TRRD +# bit31-28: TRTP + +DATA 0xFFD0140C 0x00000a33 # DDR Timing (High) +# bit6-0: TRFC +# bit8-7: TR2R +# bit10-9: TR2W +# bit12-11: TW2W +# bit31-13: zero required + +DATA 0xFFD01410 0x0000000d # DDR Address Control +# bit1-0: 10, Cs0width=x2 +# bit3-2: 11, Cs0size=1Gb +# bit5-4: 00, Cs1width=nonexistant +# bit7-6: 00, Cs1size =nonexistant +# bit9-8: 00, Cs2width=nonexistent +# bit11-10: 00, Cs2size =nonexistent +# bit13-12: 00, Cs3width=nonexistent +# bit15-14: 00, Cs3size =nonexistent +# bit16: 0, Cs0AddrSel +# bit17: 0, Cs1AddrSel +# bit18: 0, Cs2AddrSel +# bit19: 0, Cs3AddrSel +# bit31-20: 0 required + +DATA 0xFFD01414 0x00000000 # DDR Open Pages Control +# bit0: 0, OpenPage enabled +# bit31-1: 0 required + +DATA 0xFFD01418 0x00000000 # DDR Operation +# bit3-0: 0x0, DDR cmd +# bit31-4: 0 required + +DATA 0xFFD0141C 0x00000C52 # DDR Mode +# bit2-0: 2, BurstLen=2 required +# bit3: 0, BurstType=0 required +# bit6-4: 4, CL=5 +# bit7: 0, TestMode=0 normal +# bit8: 0, DLL reset=0 normal +# bit11-9: 6, auto-precharge write recovery ???????????? +# bit12: 0, PD must be zero +# bit31-13: 0 required + +DATA 0xFFD01420 0x00000040 # DDR Extended Mode +# bit0: 0, DDR DLL enabled +# bit1: 0, DDR drive strenght normal +# bit2: 0, DDR ODT control lsd (disabled) +# bit5-3: 000, required +# bit6: 1, DDR ODT control msb, (disabled) +# bit9-7: 000, required +# bit10: 0, differential DQS enabled +# bit11: 0, required +# bit12: 0, DDR output buffer enabled +# bit31-13: 0 required + +DATA 0xFFD01424 0x0000F17F # DDR Controller Control High +# bit2-0: 111, required +# bit3 : 1 , MBUS Burst Chop disabled +# bit6-4: 111, required +# bit7 : 0 +# bit8 : 1 , add writepath sample stage, must be 1 for DDR freq >= 300MHz +# bit9 : 0 , no half clock cycle addition to dataout +# bit10 : 0 , 1/4 clock cycle skew enabled for addr/ctl signals +# bit11 : 0 , 1/4 clock cycle skew disabled for write mesh +# bit15-12: 1111 required +# bit31-16: 0 required + +DATA 0xFFD01428 0x00085520 # DDR2 ODT Read Timing (default values) +DATA 0xFFD0147C 0x00008552 # DDR2 ODT Write Timing (default values) + +DATA 0xFFD01500 0x00000000 # CS[0]n Base address to 0x0 +DATA 0xFFD01504 0x07FFFFF1 # CS[0]n Size +# bit0: 1, Window enabled +# bit1: 0, Write Protect disabled +# bit3-2: 00, CS0 hit selected +# bit23-4: ones, required +# bit31-24: 0x07, Size (i.e. 2^3x16MB=128MB) + +DATA 0xFFD0150C 0x00000000 # CS[1]n Size, window disabled +DATA 0xFFD01514 0x00000000 # CS[2]n Size, window disabled +DATA 0xFFD0151C 0x00000000 # CS[3]n Size, window disabled + +DATA 0xFFD01494 0x00030000 # DDR ODT Control (Low) +DATA 0xFFD01498 0x00000000 # DDR ODT Control (High) +# bit1-0: 00, ODT0 controlled by ODT Control (low) register above +# bit3-2: 01, ODT1 active NEVER! +# bit31-4: zero, required + +DATA 0xFFD0149C 0x0000E803 # CPU ODT Control +DATA 0xFFD01480 0x00000001 # DDR Initialization Control +#bit0=1, enable DDR init upon this register write + +# End of Header extension +DATA 0x0 0x0 diff '--exclude=*~' -ruN u-boot-2012.04.orig/boards.cfg u-boot-2012.04- pogo//boards.cfg --- u-boot-2012.04.orig/boards.cfg 2012-04-21 11:55:26.000000000 -0500 +++ u-boot-2012.04-pogo//boards.cfg 2012-07-26 21:23:47.000000000
-0500 @@ -151,6 +151,7 @@ openrd_base arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_BASE openrd_client arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_CLIENT openrd_ultimate arm arm926ejs openrd Marvell kirkwood openrd:BOARD_IS_OPENRD_ULTIMATE +pogoplug_e02 arm arm926ejs sheevaplug Marvell kirkwood sheevaplug:BOARD_IS_POGOPLUG_E02 rd6281a arm arm926ejs - Marvell kirkwood sheevaplug arm arm926ejs - Marvell kirkwood dockstar arm arm926ejs - Seagate kirkwood diff '--exclude=*~' -ruN u-boot-2012.04.orig/doc/README.pogoplug_e02 u- boot-2012.04-pogo//doc/README.pogoplug_e02 --- u-boot-2012.04.orig/doc/README.pogoplug_e02 1969-12-31 18:00:00.000000000 -0600 +++ u-boot-2012.04-pogo//doc/README.pogoplug_e02 2012-07-26 21:50:41.000000000 -0500 @@ -0,0 +1,47 @@ +The Pogoplug (Pink) Model POGO-E02 is a consumer product based on the +Marvell Sheevaplug Developers kit, the sheevaplug board. It differs +from the Sheevaplug in that where the Sheevaplug has 1G of RAM, the +Pogoplug POGO-E02 has only 256M of RAM. The Sheevaplug is also a nice +small white brick, whereas the POGO-E02 is a pink and white plastic +monstrosity. The POGO-E02 has no external serial connector and must +be opened by popping the case to get to the 3.3v serial connector. + +Note that there are other Pogoplug models. This will work only +with the POGO-E02. + +Description of the 3.3v serial connector: + +When 'gap' in the keyed connector is "up". Pins, left to right are: + +3.3v +TXD +RXD +GND + +The neighboring connector is a standard 10 pin JTAG. + +The serial port may be used to talk to the existing U-Boot command +interface to obtain the configuration environment and load a new +U-Boot. (A 3.3v RS232 to USB serial converter is useful here, and +quite cheap. $2.37, if you're willing to wait for shipping from +Singapore.) Of course this means you're trusting the factory U-Boot +code. If you're paranoid use the JTAG interface. + +Code for the factory installed U-Boot is at: + +http://download.pogoplug.com/opensource/pogoplug-u- boot-1.1.4.pp2.0.tar.bz2 + +The interesting bits are: + +dramregs_pp128_A.txt A file which has the 512 byte U-Boot header + describing how to setup the board. This was + prepened to the u-boot.img file with + tools/doimage program. + +The change to Das U-Boot is to add a pogoplug_e02 the sheevaplug +target to support this alternate header. The header is in +"board/Marvell/sheevaplug/kwbimage-pogoplug_e02.cfg". + +See also: doc/README.kwbimage + +26 July, 2012 Karl O. Pinc kop@meme.com diff '--exclude=*~' -ruN u-boot-2012.04.orig/include/configs/ sheevaplug.h u-boot-2012.04-pogo//include/configs/sheevaplug.h --- u-boot-2012.04.orig/include/configs/sheevaplug.h 2012-04-21 11:55:26.000000000 -0500 +++ u-boot-2012.04-pogo//include/configs/sheevaplug.h 2012-07-26 23:34:14.000000000 -0500 @@ -28,7 +28,11 @@ /* * Version number information */ +#ifdef CONFIG_BOARD_IS_POGOPLUG_E02 /* Pogoplug (Pink) POGO-E02 */ +#define CONFIG_IDENT_STRING "\nPogoplug-POGO-E02" +#else /* Default: Marvell Sheevaplug */ #define CONFIG_IDENT_STRING "\nMarvell-Sheevaplug" +#endif /* CONFIG_BOARD_IS_POGOPLUG_E02 */
/* * High Level Configuration Options (easy to change) @@ -50,6 +54,17 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_PING #define CONFIG_CMD_USB + +/* + * Kirkwood Data file used to initialize board. + * (Default, the Sheevaplug Development Kit board, is kwbimage.cfg.) + * Must be defined before mv-common.h. + */ +#ifdef CONFIG_BOARD_IS_POGOPLUG_E02 /* Pogoplug (Pink) POGO-E02 */ +/* Different RAM configuration for the POGO-E02. */ +#define CONFIG_SYS_KWD_CONFIG $(SRCTREE)/$(CONFIG_BOARDDIR)/kwbimage- pogoplug_e02.cfg +#endif /* CONFIG_BOARD_IS_POGOPLUG_E02 */ + /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff '--exclude=*~' -ruN u-boot-2012.04.orig/MAINTAINERS u- boot-2012.04-pogo//MAINTAINERS --- u-boot-2012.04.orig/MAINTAINERS 2012-04-21 11:55:26.000000000
-0500 +++ u-boot-2012.04-pogo//MAINTAINERS 2012-07-26 01:16:09.000000000 -0500 @@ -769,6 +769,10 @@ davinci_dm365evm ARM926EJS davinci_dm6467evm ARM926EJS
+Karl O. Pinc kop@meme.com + + pogoplug_e02 ARM926EJS (Kirkwood SoC) + Helmut Raiger helmut.raiger@hale.at
tt01 i.MX31
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot- bounces@lists.denx.de] On Behalf Of Karl O. Pinc Sent: 27 July 2012 10:27 To: U-Boot@lists.denx.de Subject: [U-Boot] U-Boot on the POGO-E02
Yes
You may send this patch as RFC for review.
Regards... Prafulla . . .
+# End of Header extension +DATA 0x0 0x0 diff '--exclude=*~' -ruN u-boot-2012.04.orig/boards.cfg u-boot- 2012.04- pogo//boards.cfg --- u-boot-2012.04.orig/boards.cfg 2012-04-21 11:55:26.000000000 -0500 +++ u-boot-2012.04-pogo//boards.cfg 2012-07-26 21:23:47.000000000
- Version number information
- High Level Configuration Options (easy to change)
- Kirkwood Data file used to initialize board.
- (Default, the Sheevaplug Development Kit board, is kwbimage.cfg.)
- Must be defined before mv-common.h.
- mv-common.h should be defined after CMD configs since it used them
- to enable certain macros
tt01 i.MX31
Is there anything special, besides using git, that I need to do to send a patch as RFC for review?
And I think I should wait to see if it works on the device, right?
Dear Karl,
use "git format-patch" to create the patch, and "git send-email" to submit it. This will prevent such problems. And make sure to add your Signed-off-by: line.
Thanks.
Karl O. Pinc
Prafulla Wadaskar
