[U-Boot-Users] U-boot on Avila GW2355 platform : UART not working
Has anybody done the u-boot porting on Avila platforms. I have GW2355, which is based on IXP425 CPU.
I have used the existing IXDP425 support from the u-boot, and could get the console messages till the prompt. But the problem is I could not write anything in the console. I could see that the serial_getc() is looping around to get a character in the UART receive buffer. Since the "data ready bit" is not set, the loop is like a forever type.
Any idea on this matter ?.
Thanks in advance.
Regards, Mahesh.
Mahesh,
I am not aware of the GW2355 and if it was a custom design since Gateworks does do custom boards. For their current "retail" offerings I had posted a patch a few months ago:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/30313/match=avila
Hope it helps.
-Ranjit
Thanks in advance.
Regards, Mahesh.
This SF.net email is sponsored by: Microsoft Defy all challenges. Microsoft(R) Visual Studio 2008. http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
On 13:13 Fri 18 Jan , Ranjit Deshpande wrote:
Mahesh,
Hi Ranjit,
Could you resend your patch rebase on the current tree?
and create a board specific file for Avila not a hack in ixdp425 board.
Best Regards, J.
Mahesh,
Hope it helps.
-Ranjit
Hi Ranjit,
Best Regards, J.
Jean-Christophe,
1. Do you want the patch against the Xscale custodian tree or the mainline ? 2. Do you want me to create a separate directory under board/ ?
Thanks, -Ranjit
On 1/19/08 12:59 AM, "Jean-Christophe PLAGNIOL-VILLARD" plagnioj@jcrosoft.com wrote:
Mahesh,
Hope it helps.
-Ranjit
Hi Ranjit,
Could you resend your patch rebase on the current tree? and create a board specific file for Avila not a hack in ixdp425 board.
Best Regards, J.
On 08:23 Sat 19 Jan , Ranjit Deshpande wrote:
Jean-Christophe,
- Do you want the patch against the Xscale custodian tree or the mainline ?
ixp custodian tree, please
- Do you want me to create a separate directory under board/ ?
yes
Best Regards, J.
Mahesh Kumar
Ranjit Deshpande
