[PATCH] zynqmp: Remove usb init initialization for Kria
USB hub initialization is done by driver introduced by commit 09f557e106ef ("usb: onboard-hub: Add i2c initialization for usb5744 hub") that's why there is no need to do initialization via variables.
Reported-by: Love Kumar love.kumar@amd.com Signed-off-by: Michal Simek michal.simek@amd.com ---
board/xilinx/zynqmp/zynqmp_kria.env | 14 ++++---------- 1 file changed, 4 insertions(+), 10 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp_kria.env b/board/xilinx/zynqmp/zynqmp_kria.env index ff3a0924de7d..b0c2ac6f2e86 100644 --- a/board/xilinx/zynqmp/zynqmp_kria.env +++ b/board/xilinx/zynqmp/zynqmp_kria.env @@ -62,14 +62,8 @@ bootmenu_0=eMMC Boot=run som_mmc_boot bootmenu_1=SD Boot=run som_cc_boot bootmenu_delay=5
-usb_hub_init=mw 1000 0056 && sleep 1 && i2c write 1000 2d aa 2 -s - -# usb hub init -kv260_setup=i2c dev 1 && run usb_hub_init -# usb hub init -kr260_setup=i2c dev 1 && run usb_hub_init; i2c dev 2 && run usb_hub_init; -# usb hub init with enabling PM nodes for ... -kd240_setup=i2c dev 1 && run usb_hub_init;zynqmp pmufw node 33; zynqmp pmufw node 47 +# Enabling PM nodes for uart0 and can0 +kd240_setup=zynqmp pmufw node 33; zynqmp pmufw node 47
tpm_setup=tpm autostart; tpm_reset=echo "!!! For TPM reset a full power cycle or pressing the POR_B button is required !!!"; @@ -79,7 +73,7 @@ tpm_kd240=if test ${card1_rev} = A; then run tpm_reset; fi board_setup=\ rtc dev 0; \ zynqmp mmio_write 0xFFCA0010 0xfff 0; \ -if test ${card1_name} = SCK-KV-G; then run kv260_setup; run tpm_kv260; fi;\ -if test ${card1_name} = SCK-KR-G; then run kr260_setup; run tpm_reset; fi;\ +if test ${card1_name} = SCK-KV-G; then run tpm_kv260; fi;\ +if test ${card1_name} = SCK-KR-G; then run tpm_reset; fi;\ if test ${card1_name} = SCK-KD-G; then run kd240_setup; run tpm_kd240; fi;\ run tpm_setup
tpm_setup=tpm autostart; tpm_reset=echo "!!! For TPM reset a full power cycle or pressing the POR_B button is required !!!"; @@ -79,7 +73,7 @@ tpm_kd240=if test ${card1_rev} = A; then run tpm_reset; fi board_setup=\ rtc dev 0; \ zynqmp mmio_write 0xFFCA0010 0xfff 0; \ -if test ${card1_name} = SCK-KV-G; then run kv260_setup; run tpm_kv260; fi;\ -if test ${card1_name} = SCK-KR-G; then run kr260_setup; run tpm_reset; fi;\ +if test ${card1_name} = SCK-KV-G; then run tpm_kv260; fi;\ +if test ${card1_name} = SCK-KR-G; then run tpm_reset; fi;\ if test ${card1_name} = SCK-KD-G; then run kd240_setup; run tpm_kd240; fi;\ run tpm_setup -- 2.43.0
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Applied. M
Ilias Apalodimas
Michal Simek
