Re: Kirkwood: Fix tv sec/usec normalization in kwboot
On 27.04.21 21:57, Dagan Martinez wrote:
From 328c559acf6872bf0cbafe7fbb881748d5c753fb Mon Sep 17 00:00:00 2001 From: Property404 dmartinez@starry.com Date: Tue, 27 Apr 2021 15:48:31 -0400 Subject: [PATCH] Kirkwood: Fix tv sec/usec normalization in kwboot
`kwboot.c` had an issue where it failed to normalize the `tv` struct in the case where the `tv_usec` field was 1000000, ie one second.
This caused issues on Fedora Linux 34, where `select` would return `EINVAL`, preventing kwboot from communicating with the board.
Signed-off-by: Property404 dmartinez@starry.com
tools/kwboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/kwboot.c b/tools/kwboot.c index 4be094c9c8..5d5d501d36 100644 --- a/tools/kwboot.c +++ b/tools/kwboot.c @@ -167,7 +167,7 @@ kwboot_tty_recv(int fd, void *buf, size_t len, int timeo)
tv.tv_sec = 0; tv.tv_usec = timeo * 1000;
- if (tv.tv_usec > 1000000) {
- if (tv.tv_usec >= 1000000) { tv.tv_sec += tv.tv_usec / 1000000; tv.tv_usec %= 1000000; }
BTW: I'm not 100% sure, but my understanding is that it is preferred (or even required) to provide a "real name" in the tags. So it might be that "Property404" is not enough here.
Thanks, Stefan
From a45340719110b8a8b5292f6353fda7509be81417 Mon Sep 17 00:00:00 2001
Signed-off-by: Dagan Martinez dmartinez@starry.com --- tools/kwboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
tv.tv_sec = 0; tv.tv_usec = timeo * 1000; - if (tv.tv_usec > 1000000) { + if (tv.tv_usec >= 1000000) { tv.tv_sec += tv.tv_usec / 1000000; tv.tv_usec %= 1000000; }
On 28.04.21 13:24, Dagan Martinez wrote:
From a45340719110b8a8b5292f6353fda7509be81417 Mon Sep 17 00:00:00 2001 From: Property404 dmartinez@starry.com Date: Tue, 27 Apr 2021 15:48:31 -0400 Subject: [PATCH] Kirkwood: Fix tv sec/usec normalization in kwboot
Thanks for re-submitting. I do have some more change requests - sorry for being a bit strict here.
First, please change the subject to not reply on a message but also mention the patch version in the subject (v2). And also please add the patch history below the commit text. See here for more details on submitting patch versions:
http://www.denx.de/wiki/view/U-Boot/Patches#Sending_updated_patch_versions
And also please change your "From:" line, so that it does not mention "Property404" any more.
BTW: "git send-email" is very helpful for sending patches.
Thanks, Stefan
From c200095d4136a071dd9526a48be642ce58fae8c9 Mon Sep 17 00:00:00 2001
From: Dagan Martinez dmartinez@starry.com Date: Tue, 27 Apr 2021 15:48:31 -0400 Subject: [PATCH v2] Kirkwood: Fix tv sec/usec normalization in kwboot
Signed-off-by: Dagan Martinez dmartinez@starry.com --- Changes for v2: - Use real author name in patch
On 29.04.21 14:03, Dagan Martinez wrote:
From c200095d4136a071dd9526a48be642ce58fae8c9 Mon Sep 17 00:00:00 2001 From: Dagan Martinez dmartinez@starry.com Date: Tue, 27 Apr 2021 15:48:31 -0400 Subject: [PATCH v2] Kirkwood: Fix tv sec/usec normalization in kwboot
Thanks. Still this patch does not apply. How did you generate and send it? It's somehow mangled. I suggest to use git send-email.
And another issue: The subject of this original mail still has "Re: " in it. Please don't reply in some mail client but either use git send-email or write a completely new message. Some mail clients tend to clutter the whitespace etc.
Thanks, Stefan
Viele Grüße, Stefan
Dagan Martinez
Stefan Roese
