[PATCH v2 00/10] ClearFog Base static variant support
This patch series adds support for ClearFog Base static configuration, as well as updating and fixing the ClearFog support for MMC and SPI booting.
V2 changes: - updated against, and dependent on, https://patchwork.ozlabs.org/cover/1200324
Joel Johnson (10): arm: mvebu: fix SerDes table alignment arm: mvebu: solidrun: remove hardcoded DTS MAC address arm: mvebu: clearfog: initial ClearFog Base variant arm: mvebu: clearfog: Use Pro DT by default arm: mvebu: clearfog: Add SATA mode flags arm: mvebu: clearfog: Add option for 2.5 Gbps SFP arm: mvebu: clearfog: add SPI offsets arm: mvebu: enable working default boot support arm: mvebu: clearfog: move ENV params to Kconfig arm: mvebu: clearfog: reduce MMC boot assumptions
.../arm/dts/armada-38x-solidrun-microsom.dtsi | 1 - arch/arm/mach-mvebu/Kconfig | 13 ++++ .../serdes/a38x/high_speed_env_spec.c | 6 +- board/solidrun/clearfog/Kconfig | 62 +++++++++++++++++++ board/solidrun/clearfog/clearfog.c | 26 +++++++- configs/clearfog_defconfig | 5 -- include/configs/clearfog.h | 1 - 7 files changed, 103 insertions(+), 11 deletions(-) create mode 100644 board/solidrun/clearfog/Kconfig
Tested on Solidrun ClearFog Base. Table alignment was: | Lane # | Speed | Type | -------------------------------- | 0 | 3 | SATA0 | | 1 | 0 | SGMII1 | | 2 | 3 | SATA1 | | 3 | 5 | USB3 HOST1 | | 4 | 5 | USB3 HOST0 | | 5 | 4 | SGMII2 | --------------------------------
After the change, it's correctly aligned as: | Lane # | Speed | Type | -------------------------------- | 0 | 3 | SATA0 | | 1 | 0 | SGMII1 | | 2 | 5 | PCIe1 | | 3 | 5 | USB3 HOST1 | | 4 | 5 | PCIe2 | | 5 | 0 | SGMII2 | --------------------------------
Signed-off-by: Joel Johnson mrjoel@lixil.net
v2 changes - none
--- arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c b/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c index 33e70569bc..66409a50c0 100644 --- a/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c +++ b/arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c @@ -1366,16 +1366,16 @@ static void print_topology_details(const struct serdes_map *serdes_map,
DEBUG_INIT_S("board SerDes lanes topology details:\n");
- DEBUG_INIT_S(" | Lane # | Speed | Type |\n"); + DEBUG_INIT_S(" | Lane # | Speed | Type |\n"); DEBUG_INIT_S(" --------------------------------\n"); for (lane_num = 0; lane_num < count; lane_num++) { if (serdes_map[lane_num].serdes_type == DEFAULT_SERDES) continue; DEBUG_INIT_S(" | "); DEBUG_INIT_D(hws_get_physical_serdes_num(lane_num), 1); - DEBUG_INIT_S(" | "); + DEBUG_INIT_S(" | "); DEBUG_INIT_D(serdes_map[lane_num].serdes_speed, 2); - DEBUG_INIT_S(" | "); + DEBUG_INIT_S(" | "); DEBUG_INIT_S((char *) serdes_type_to_string[serdes_map[lane_num]. serdes_type]);
Using a consistent hardcoded MAC address from the DTS file causes issues when using multiple devices on the same network segment. Instead rely on environment configuration or random generation.
v2 changes: - none
--- arch/arm/dts/armada-38x-solidrun-microsom.dtsi | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/dts/armada-38x-solidrun-microsom.dtsi b/arch/arm/dts/armada-38x-solidrun-microsom.dtsi index a322a28c21..9bbeafc53b 100644 --- a/arch/arm/dts/armada-38x-solidrun-microsom.dtsi +++ b/arch/arm/dts/armada-38x-solidrun-microsom.dtsi @@ -39,7 +39,6 @@
ð0 { /* ethernet@70000 */ - mac-address = [00 50 43 02 02 01]; pinctrl-0 = <&ge0_rgmii_pins>; pinctrl-names = "default"; phy = <&phy_dedicated>;
Add a unique entry for ClearFog Base variant, reflected in the board name and adjusted SerDes topology.
v2 changes: - reworked based on Baruch's run-time TLV EEPROM detection series
--- arch/arm/mach-mvebu/Kconfig | 2 ++ board/solidrun/clearfog/Kconfig | 18 ++++++++++++++++++ board/solidrun/clearfog/clearfog.c | 12 ++++++++++++ 3 files changed, 32 insertions(+) create mode 100644 board/solidrun/clearfog/Kconfig
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index bc5eaa5a76..161dee937f 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -280,4 +280,6 @@ config SECURED_MODE_CSK_INDEX default 0 depends on SECURED_MODE_IMAGE
+source "board/solidrun/clearfog/Kconfig" + endif diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig new file mode 100644 index 0000000000..cee8f3bac1 --- /dev/null +++ b/board/solidrun/clearfog/Kconfig @@ -0,0 +1,18 @@ +menu "ClearFog configuration" + depends on TARGET_CLEARFOG + +config TARGET_CLEARFOG_BASE + bool "Use ClearFog Base static configuration" + help + Use the ClearFog Base as the static configuration instead of the + default which uses the ClearFog Pro. + + Runtime board detection is always attempted and used if available. The + static configuration is used as a fallback in cases where runtime + detection is not available. + + Only newer revisions of the ClearFog product line support runtime + detection via additional EEPROM hardware. This option enables selecting + the Base variant for older hardware revisions. + +endmenu diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index f407f744bf..b66f9f61cf 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -44,7 +44,11 @@ static struct serdes_map board_serdes_map[] = { {SGMII1, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, {PEX1, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, {USB3_HOST1, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#if defined (CONFIG_TARGET_CLEARFOG_BASE) + {USB3_HOST0, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#else {PEX2, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, +#endif {SGMII2, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, };
@@ -262,7 +266,11 @@ int board_init(void)
int checkboard(void) { +#if defined (CONFIG_TARGET_CLEARFOG_BASE) + char *board = "ClearFog Base"; +#else char *board = "ClearFog"; +#endif
read_tlv_data(); if (strlen(tlv_product_name[0]) > 0) @@ -292,6 +300,10 @@ int board_late_init(void) env_set("fdtfile", "armada-385-clearfog-gtr-s4.dtb"); else if (sr_product_is("Clearfog GTR L8")) env_set("fdtfile", "armada-385-clearfog-gtr-l8.dtb"); +#if defined (CONFIG_TARGET_CLEARFOG_BASE) + else + env_set("fdtfile", "armada-388-clearfog-base.dtb"); +#endif
return 0; }
Switch to explicitly using the Pro variant DT, which has been available since Linux 4.11. Also unify the location of DT selection in board_late_init instead of split between detection and static configuration paths.
v2 changes - newly added in V2 series based on run-time rebasing
Signed-off-by: Joel Johnson mrjoel@lixil.net --- board/solidrun/clearfog/clearfog.c | 6 ++++-- include/configs/clearfog.h | 1 - 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index b66f9f61cf..a3c5780730 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -269,7 +269,7 @@ int checkboard(void) #if defined (CONFIG_TARGET_CLEARFOG_BASE) char *board = "ClearFog Base"; #else - char *board = "ClearFog"; + char *board = "ClearFog Pro"; #endif
read_tlv_data(); @@ -300,9 +300,11 @@ int board_late_init(void) env_set("fdtfile", "armada-385-clearfog-gtr-s4.dtb"); else if (sr_product_is("Clearfog GTR L8")) env_set("fdtfile", "armada-385-clearfog-gtr-l8.dtb"); -#if defined (CONFIG_TARGET_CLEARFOG_BASE) else +#if defined (CONFIG_TARGET_CLEARFOG_BASE) env_set("fdtfile", "armada-388-clearfog-base.dtb"); +#else + env_set("fdtfile", "armada-388-clearfog-pro.dtb"); #endif
return 0; diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index 633187d86f..6ca0474461 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -134,7 +134,6 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ RELOCATION_LIMITS_ENV_SETTINGS \ LOAD_ADDRESS_ENV_SETTINGS \ - "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "console=ttyS0,115200\0" \ BOOTENV
The mPCIe slots on ClearFog Pro and ClearFog Base may be alternately configured for SATA usage.
v2 changes: - fixed help indentation
--- board/solidrun/clearfog/Kconfig | 17 +++++++++++++++++ board/solidrun/clearfog/clearfog.c | 6 ++++++ 2 files changed, 23 insertions(+)
diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig index cee8f3bac1..a82f9867fe 100644 --- a/board/solidrun/clearfog/Kconfig +++ b/board/solidrun/clearfog/Kconfig @@ -15,4 +15,21 @@ config TARGET_CLEARFOG_BASE detection via additional EEPROM hardware. This option enables selecting the Base variant for older hardware revisions.
+config CLEARFOG_CON3_SATA + bool "Use CON3 slot in SATA mode" + help + Use the CON3 port with SATA protocol instead of the default PCIe. + The ClearFog port allows usage of either mSATA or miniPCIe + modules, but the desired protocol must be configured at build + time since it affects the SerDes topology layout. + +config CLEARFOG_CON2_SATA + bool "Use CON2 slot in SATA mode" + depends on !TARGET_CLEARFOG_BASE + help + Use the CON2 port with SATA protocol instead of the default PCIe. + The ClearFog port allows usage of either mSATA or miniPCIe + modules, but the desired protocol must be configured at build + time since it affects the SerDes topology layout. + endmenu diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index a3c5780730..291a9279b6 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -42,10 +42,16 @@ static void read_tlv_data(void); static struct serdes_map board_serdes_map[] = { {SATA0, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0}, {SGMII1, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#if defined (CONFIG_CLEARFOG_CON3_SATA) + {SATA1, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#else {PEX1, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, +#endif {USB3_HOST1, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, #if defined (CONFIG_TARGET_CLEARFOG_BASE) {USB3_HOST0, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#elif defined(CONFIG_CLEARFOG_CON2_SATA) + {SATA2, SERDES_SPEED_3_GBPS, SERDES_DEFAULT_MODE, 0, 0}, #else {PEX2, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, #endif
--- board/solidrun/clearfog/Kconfig | 7 +++++++ board/solidrun/clearfog/clearfog.c | 4 ++++ 2 files changed, 11 insertions(+)
diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig index a82f9867fe..6231407589 100644 --- a/board/solidrun/clearfog/Kconfig +++ b/board/solidrun/clearfog/Kconfig @@ -32,4 +32,11 @@ config CLEARFOG_CON2_SATA modules, but the desired protocol must be configured at build time since it affects the SerDes topology layout.
+config CLEARFOG_SFP_25GB + bool "Enable 2.5 Gbps mode for SFP" + help + Set the SFP module connection to support 2.5 Gbps transfer speed for the + SGMII connection (requires a supporting SFP). By default, transfer speed + of 1.25 Gbps is used, suitable for a more common 1 Gbps SFP module. + endmenu diff --git a/board/solidrun/clearfog/clearfog.c b/board/solidrun/clearfog/clearfog.c index 291a9279b6..c9ef620f78 100644 --- a/board/solidrun/clearfog/clearfog.c +++ b/board/solidrun/clearfog/clearfog.c @@ -55,7 +55,11 @@ static struct serdes_map board_serdes_map[] = { #else {PEX2, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, #endif +#if defined (CONFIG_CLEARFOG_SFP_25GB) + {SGMII2, SERDES_SPEED_3_125_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#else {SGMII2, SERDES_SPEED_1_25_GBPS, SERDES_DEFAULT_MODE, 0, 0}, +#endif };
int hws_board_topology_load(struct serdes_map **serdes_map_array, u8 *count)
Add reasonable default SPI offsets and ENV size when configured to boot from SPI flash.
v2 changes: - none
There was some reasonable concern raised about duplicating config entries within a board specific config file rather than making board specific configurations within defconfig. This seems to offer a more board localized mechanism to provide platform defaults for core values. As mentioned in the review, this usage seems to match the Kconfig documented intended usage. As noted at https://www.kernel.org/doc/html/latest/kbuild/kconfig-language.html: "Default values are not limited to the menu entry where they are defined. This means the default can be defined somewhere else or be overridden by an earlier definition."
Given that there is some dependency variability with these values I prefer keeping them as Kconfig values, but defer to maintainers. Notably, for the ENV values in this and a later commit, I'm using a pattern already in used several other board configs.
--- board/solidrun/clearfog/Kconfig | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig index 6231407589..f563c3c4fc 100644 --- a/board/solidrun/clearfog/Kconfig +++ b/board/solidrun/clearfog/Kconfig @@ -39,4 +39,16 @@ config CLEARFOG_SFP_25GB SGMII connection (requires a supporting SFP). By default, transfer speed of 1.25 Gbps is used, suitable for a more common 1 Gbps SFP module.
+config ENV_SECT_SIZE + hex "Environment Sector-Size" + # Use SPI flash erase block size of 4 KiB + default 0x1000 if MVEBU_SPL_BOOT_DEVICE_SPI + # Use optimistic 64 KiB erase block, will vary between actual media + default 0x10000 if MVEBU_SPL_BOOT_DEVICE_MMC + +config SYS_SPI_U_BOOT_OFFS + hex "address of u-boot payload in SPI flash" + default 0x20000 + depends on MVEBU_SPL_BOOT_DEVICE_SPI + endmenu
With the move to driver model usage, ensure that the required driver support for SPI and MMC booting is available in SPL.
Tested on SolidRun ClearFog devices.
v2 changes: - change "select" for ENV_IS_IN_X to "imply" to allow disabling the default env location and configuring a different one if desired - remove SPL_DM_GPIO from defconfig, only include if needed for MMC booting --- arch/arm/mach-mvebu/Kconfig | 10 ++++++++++ configs/clearfog_defconfig | 1 - 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 161dee937f..32191e7157 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -235,9 +235,19 @@ choice
config MVEBU_SPL_BOOT_DEVICE_SPI bool "SPI NOR flash" + imply ENV_IS_IN_SPI_FLASH + select SPL_DM_SPI + select SPL_MTD_SUPPORT + select SPL_SPI_FLASH_SUPPORT + select SPL_SPI_LOAD + select SPL_SPI_SUPPORT
config MVEBU_SPL_BOOT_DEVICE_MMC bool "SDIO/MMC card" + imply ENV_IS_IN_MMC + # GPIO required for SD card presence detection line + select SPL_DM_GPIO + select SPL_DM_MMC select SPL_LIBDISK_SUPPORT
config MVEBU_SPL_BOOT_DEVICE_SATA diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index e932f9c195..24f0b557be 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -28,7 +28,6 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET=0x1 -CONFIG_SPL_DM_GPIO=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_CMD_SYS_EEPROM=y CONFIG_SPL_CMD_SYS_EEPROM=y
Migrate the values for ENV_SIZE and ENV_OFFSET into board specific Kconfig defaults so they're more accessible for configuration.
v2 changes: - none
Signed-off-by: Joel Johnson mrjoel@lixil.net --- board/solidrun/clearfog/Kconfig | 8 ++++++++ configs/clearfog_defconfig | 2 -- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/board/solidrun/clearfog/Kconfig b/board/solidrun/clearfog/Kconfig index f563c3c4fc..6b08ad4615 100644 --- a/board/solidrun/clearfog/Kconfig +++ b/board/solidrun/clearfog/Kconfig @@ -39,6 +39,14 @@ config CLEARFOG_SFP_25GB SGMII connection (requires a supporting SFP). By default, transfer speed of 1.25 Gbps is used, suitable for a more common 1 Gbps SFP module.
+config ENV_SIZE + hex "Environment Size" + default 0x10000 + +config ENV_OFFSET + hex "Environment offset" + default 0xF0000 + config ENV_SECT_SIZE hex "Environment Sector-Size" # Use SPI flash erase block size of 4 KiB diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 24f0b557be..c5a036804e 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -11,8 +11,6 @@ CONFIG_TARGET_CLEARFOG=y CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_ENV_SIZE=0x10000 -CONFIG_ENV_OFFSET=0xF0000 CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 CONFIG_SPL=y
Reduce those MMC booting assumptions from clearfog_defconfig which are already selected by dependent options via Kconfig.
v2 changes: - rebased on master to use Baruch's dynamic MMC/SD offset logic - update description, will revisit removal of CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC in separate future path if a more viable option is identified
--- arch/arm/mach-mvebu/Kconfig | 1 + configs/clearfog_defconfig | 2 -- 2 files changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 32191e7157..4b381a2936 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -249,6 +249,7 @@ config MVEBU_SPL_BOOT_DEVICE_MMC select SPL_DM_GPIO select SPL_DM_MMC select SPL_LIBDISK_SUPPORT + select SPL_MMC_SUPPORT
config MVEBU_SPL_BOOT_DEVICE_SATA bool "SATA" diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index c5a036804e..06423e1678 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -9,7 +9,6 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_CLEARFOG=y CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC=y -CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 @@ -42,7 +41,6 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DEFAULT_DEVICE_TREE="armada-388-clearfog" -CONFIG_ENV_IS_IN_MMC=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_AHCI_MVEBU=y
Hi Joel,
V2 changes:
Thanks for the update.
Next time please Cc at least me and Stefan on the entire series.
baruch
On 2020-01-19 01:38, Baruch Siach wrote:
Hi Joel,
V2 changes:
baruch
I certainly intended to, and based on the email headers it appears that I did...
Actually, I see what you're saying, not all of the patches in the series were delivered to you. I neglected to add (or notice during sending) the Series-cc line for patman. My apologizes - I've added it for my local branch on this series and I'll keep an eye out for that in the future.
Relatedly, I've been directing the series to Prafulla Wadaskar as noted in the custodians listing for marvell, but am getting email delivery failures. Any updated guidance or contact updates would be appreciated.
Joel
Hi Joel,
V2 changes:
baruch
Prafulla has been removed from the Marvell entry in MAINTAINERS in commit 1579faf52b9f4 (February 2019). I don't think you need to Cc him on Marvell SoC related patches.
baruch
On 2020-01-19 09:11, Baruch Siach wrote:
Hi Joel,
V2 changes:
baruch
baruch
Indeed, thanks. I had pulled his information from the Custodians wiki page at http://www.denx.de/wiki/U-Boot/Custodians, so perhaps something that Stefan or editor can update accordingly.
Joel
Hi Joel,
Hi Joel,
V2 changes:
baruch
baruch
Yes, thanks for the notification. We'll update this page accordingly soon.
Thanks, Stefan
Baruch Siach
Joel Johnson
Stefan Roese
