[PATCH] board: st: common: update test on misc_read result in command stboard
Update management of misc_read/misc_write, which now returns length of data after the commit 8729b1ae2cbd ("misc: Update read() and write() methods to return bytes xfered"): raise a error when the result is not the expected length.
Fixes: 658fde8a36ff ("board: stm32mp1: stboard: lock the OTP after programming") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
board/st/common/cmd_stboard.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/st/common/cmd_stboard.c b/board/st/common/cmd_stboard.c index 2fba383168..c1ecd643b0 100644 --- a/board/st/common/cmd_stboard.c +++ b/board/st/common/cmd_stboard.c @@ -91,14 +91,14 @@ static int do_stboard(struct cmd_tbl *cmdtp, int flag, int argc, ret = misc_read(dev, STM32_BSEC_OTP(BSEC_OTP_BOARD), &otp, sizeof(otp));
- if (ret < 0) { + if (ret != sizeof(otp)) { puts("OTP read error"); return CMD_RET_FAILURE; }
ret = misc_read(dev, STM32_BSEC_LOCK(BSEC_OTP_BOARD), &lock, sizeof(lock)); - if (ret < 0) { + if (ret != sizeof(lock)) { puts("LOCK read error"); return CMD_RET_FAILURE; } @@ -172,7 +172,7 @@ static int do_stboard(struct cmd_tbl *cmdtp, int flag, int argc, ret = misc_write(dev, STM32_BSEC_OTP(BSEC_OTP_BOARD), &otp, sizeof(otp));
- if (ret < 0) { + if (ret != sizeof(otp)) { puts("BOARD programming error\n"); return CMD_RET_FAILURE; } @@ -181,7 +181,7 @@ static int do_stboard(struct cmd_tbl *cmdtp, int flag, int argc, otp = 1; ret = misc_write(dev, STM32_BSEC_LOCK(BSEC_OTP_BOARD), &otp, sizeof(otp)); - if (ret < 0) { + if (ret != sizeof(otp)) { puts("BOARD lock error\n"); return CMD_RET_FAILURE; }
Hi Patrick
- if (ret < 0) {
- if (ret < 0) {
- if (ret != sizeof(lock)) { puts("LOCK read error"); return CMD_RET_FAILURE; }
- if (ret < 0) {
- if (ret != sizeof(otp)) { puts("BOARD programming error\n"); return CMD_RET_FAILURE; }
- if (ret < 0) {
- if (ret != sizeof(otp)) { puts("BOARD lock error\n"); return CMD_RET_FAILURE; }
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com
Thanks Patrice
Hi Patrick
On 2/23/22 08:43, Patrice CHOTARD wrote:
Hi Patrick
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
- if (ret < 0) {
Thanks Patrice _______________________________________________ Uboot-stm32 mailing list Uboot-stm32@st-md-mailman.stormreply.com https://st-md-mailman.stormreply.com/mailman/listinfo/uboot-stm32
Applied to u-boot-stm32
Thanks Patrice
Patrice CHOTARD
Patrick Delaunay
