[PATCH v2 1/3] mmc: Convert hs400_tuning flag from u8 to bool
This hs400_tuning is a flag, make it bool. No functional change. This will be useful in the following patch, which adds another more generic flag, where the compiler can better use the space now reserved for the u8 to store more flags in it.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Hai Pham hai.pham.ud@renesas.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Peng Fan peng.fan@nxp.com Cc: Sean Anderson seanga2@gmail.com Cc: Tom Rini trini@konsulko.com Cc: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- V2: Use bool var:1; --- drivers/mmc/mmc.c | 4 ++-- include/mmc.h | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 83f9ae8bb7d..07d87c993a6 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -2027,9 +2027,9 @@ static int mmc_select_hs400(struct mmc *mmc) mmc_set_clock(mmc, mmc->tran_speed, false);
/* execute tuning if needed */ - mmc->hs400_tuning = 1; + mmc->hs400_tuning = true; err = mmc_execute_tuning(mmc, MMC_CMD_SEND_TUNING_BLOCK_HS200); - mmc->hs400_tuning = 0; + mmc->hs400_tuning = false; if (err) { debug("tuning failed\n"); return err; diff --git a/include/mmc.h b/include/mmc.h index 2b9a6aa8ee0..afca123b386 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -736,7 +736,7 @@ struct mmc { * accessing the boot partitions */ u32 quirks; - u8 hs400_tuning; + bool hs400_tuning:1;
enum bus_mode user_speed_mode; /* input speed mode from user */ };
Set generic mmc->tuning flag when performing tuning to indicate this condition to drivers. Drivers may use this to bypass various checks during tuning.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Hai Pham hai.pham.ud@renesas.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Peng Fan peng.fan@nxp.com Cc: Sean Anderson seanga2@gmail.com Cc: Tom Rini trini@konsulko.com Cc: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- V2: Use bool var:1; --- drivers/mmc/mmc-uclass.c | 8 +++++++- include/mmc.h | 1 + 2 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc-uclass.c b/drivers/mmc/mmc-uclass.c index 328456831dd..304bd5eaee2 100644 --- a/drivers/mmc/mmc-uclass.c +++ b/drivers/mmc/mmc-uclass.c @@ -124,7 +124,13 @@ static int dm_mmc_execute_tuning(struct udevice *dev, uint opcode)
int mmc_execute_tuning(struct mmc *mmc, uint opcode) { - return dm_mmc_execute_tuning(mmc->dev, opcode); + int ret; + + mmc->tuning = true; + ret = dm_mmc_execute_tuning(mmc->dev, opcode); + mmc->tuning = false; + + return ret; } #endif
diff --git a/include/mmc.h b/include/mmc.h index afca123b386..5c1be5c5b1e 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -736,6 +736,7 @@ struct mmc { * accessing the boot partitions */ u32 quirks; + bool tuning:1; bool hs400_tuning:1;
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
V2: Use bool var:1;
- int ret;
- mmc->tuning = true;
- ret = dm_mmc_execute_tuning(mmc->dev, opcode);
- mmc->tuning = false;
- return ret;
} #endif
Do not access SCC when sending commands during tuning operation as that will disrupt the tuning operation. The tuning operation is adjusting the SCC settings itself in execute_tuning callback.
When renesas_sdhi_execute_tuning() is called by the MMC core code, a loop which consists of renesas_sdhi_prepare_tuning(), mmc_send_tuning() and renesas_sdhi_compare_scc_data() iterates over each SCC tuning tap.
The renesas_sdhi_prepare_tuning() configures the SCC tuning tap number into hardware, mmc_send_tuning() triggers transfer of tuning block which depends on the bus mode for which the bus is currently being tuned, this information is supplied by the MMC core code, and finally renesas_sdhi_compare_scc_data() tests the received tuning block for validity.
Because renesas_sdhi_prepare_tuning() configures the SCC tuning tap into the hardware to fit the tuning operation, mmc_send_tuning() which triggers command transfer using renesas_sdhi_send_cmd() must not manipulate with the SCC in any way. Currently renesas_sdhi_send_cmd() does unconditionally call renesas_sdhi_check_scc_error(), which may adjust the SCC tuning tap position by writing RENESAS_SDHI_SCC_TAPSET, which would overwrite the required tuning configuration set by renesas_sdhi_prepare_tuning() and disrupt the tuning operation.
Fix this by skipping the renesas_sdhi_check_scc_error() call in case the MMC subsystem is in tuning state. This way, the SCC settings are left unmodified by command transfer during tuning operation.
Reviewed-by: Paul Barker paul.barker.ct@bp.renesas.com Tested-by: Paul Barker paul.barker.ct@bp.renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Hai Pham hai.pham.ud@renesas.com Cc: Jaehoon Chung jh80.chung@samsung.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Peng Fan peng.fan@nxp.com Cc: Sean Anderson seanga2@gmail.com Cc: Tom Rini trini@konsulko.com Cc: Yoshihiro Shimoda yoshihiro.shimoda.uh@renesas.com --- V2: Add RB/TB from Paul --- drivers/mmc/renesas-sdhi.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index 29a742f404e..c4d0733b621 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -798,9 +798,12 @@ static int renesas_sdhi_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, #if CONFIG_IS_ENABLED(MMC_UHS_SUPPORT) || \ CONFIG_IS_ENABLED(MMC_HS200_SUPPORT) || \ CONFIG_IS_ENABLED(MMC_HS400_SUPPORT) + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); struct tmio_sd_priv *priv = dev_get_priv(dev); + struct mmc *mmc = upriv->mmc;
- renesas_sdhi_check_scc_error(dev); + if (!mmc->tuning) + renesas_sdhi_check_scc_error(dev);
if (cmd->cmdidx == MMC_CMD_SEND_STATUS) renesas_sdhi_adjust_hs400_mode_enable(priv);
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); struct tmio_sd_priv *priv = dev_get_priv(dev);
- struct mmc *mmc = upriv->mmc;
if (!mmc->tuning)
V2: Use bool var:1;
- mmc->hs400_tuning = true; err = mmc_execute_tuning(mmc, MMC_CMD_SEND_TUNING_BLOCK_HS200);
- mmc->hs400_tuning = false; if (err) { debug("tuning failed\n"); return err;
- u8 hs400_tuning;
Jaehoon Chung
