[U-Boot] [PATCH 2/8 v4] integratorap: make the compile work again
The integratorap/cp config for u-boot was outdated and would not even compile, so fix the obvious missing bits for it to start building. After this "make ap920t_config/make all" starts working again.
Signed-off-by: Linus Walleij linus.walleij@linaro.org --- board/armltd/integrator/lowlevel_init.S | 2 +- include/configs/integratorap.h | 6 ++++++ 2 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/board/armltd/integrator/lowlevel_init.S b/board/armltd/integrator/lowlevel_init.S index ab9589c..6f55bb5 100644 --- a/board/armltd/integrator/lowlevel_init.S +++ b/board/armltd/integrator/lowlevel_init.S @@ -199,7 +199,7 @@ cm_remap:
/* Now 0x00000000 is writeable, replace the vectors */ ldr r0, =_start /* r0 <- start of vectors */ - ldr r2, =_armboot_start /* r2 <- past vectors */ + ldr r2, =_TEXT_BASE /* r2 <- past vectors */ sub r1,r1,r1 /* destination 0x00000000 */
copy_vec: diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index 32ff193..8b41885 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -120,6 +120,12 @@ #define CONFIG_NR_DRAM_BANKS 1 /* we have 1 bank of DRAM */ #define PHYS_SDRAM_1 0x00000000 /* SDRAM Bank #1 */ #define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 +#define CONFIG_SYS_INIT_RAM_SIZE PHYS_SDRAM_1_SIZE +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_SDRAM_BASE + \ + CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET
#define CONFIG_SYS_FLASH_BASE 0x24000000
Linus Walleij
