[U-Boot] [PATCH v4 0/7]
From: Dalon Westergreen dalon.westergreen@intel.com
These patches update the boot and os partition numbers in the default uboot environment for a number of socfpga boards. Per request, common environment configurations have been moved to a shared header.
Changes in v4: - Removed extraneous define in socfpga_common.h and only use CONFIG_EXTRA_ENV_SETTINGS for common uboot environment Changes in v3: - Corrected error in common default environment
Dalon Westergreen (7): arm: socfpga: add env settings to common header arm: socfpga: update de0 nano default environment arm: socfpga: update cyclone5 socdk default environment arm: socfpga: update arria5 socdk default environment arm: socfpga: Update DE1 environment arm: socfpga: Update SoCKit environment arm: socfpga: Update sr1500 environment
configs/socfpga_arria5_defconfig | 1 + configs/socfpga_cyclone5_defconfig | 1 + configs/socfpga_de0_nano_soc_defconfig | 3 +-- configs/socfpga_de1_soc_defconfig | 1 + configs/socfpga_sockit_defconfig | 1 + configs/socfpga_sr1500_defconfig | 1 + include/configs/socfpga_arria5_socdk.h | 25 ------------------------- include/configs/socfpga_common.h | 27 +++++++++++++++++++++++++++ include/configs/socfpga_cyclone5_socdk.h | 25 ------------------------- include/configs/socfpga_de0_nano_soc.h | 19 +------------------ include/configs/socfpga_de1_soc.h | 19 +------------------ include/configs/socfpga_sockit.h | 27 +-------------------------- include/configs/socfpga_sr1500.h | 25 ------------------------- 13 files changed, 36 insertions(+), 139 deletions(-)
Move repeated environment settings for socfpga boards to a common header.
The default values for the boot partition and the OS filesystem partition have changed and as as result the default uboot environment for socfpga boards needs updating.
Move to using CONFIG_DEFAULT_DEVICE_TREE for setting the default linux devicetree used during linux boot.
Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com --- include/configs/socfpga_common.h | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 6285266..bdd6e2f 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -336,5 +336,32 @@ unsigned int cm_get_qspi_controller_clk_hz(void); * Stack setup */ #define CONFIG_SPL_STACK CONFIG_SYS_INIT_SP_ADDR + +/* Extra Environment */ +#ifndef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "verify=n\0" \ + "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ + "bootimage=" CONFIG_BOOTFILE "\0" \ + "fdt_addr=100\0" \ + "fdtimage=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ + "bootm ${loadaddr} - ${fdt_addr}\0" \ + "mmcroot=/dev/mmcblk0p3\0" \ + "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ + " root=${mmcroot} rw rootwait;" \ + "bootz ${loadaddr} - ${fdt_addr}\0" \ + "mmcload=mmc rescan;" \ + "load mmc 0:2 ${loadaddr} ${bootimage};" \ + "load mmc 0:2 ${fdt_addr} ${fdtimage}\0" \ + "qspiload=sf probe && mtdparts default && run ubiload\0" \ + "qspiboot=setenv bootargs " CONFIG_BOOTARGS \ + " ubi.mtd=1,64 root=ubi0:rootfs rw rootfstype=ubifs;"\ + "bootz ${loadaddr} - ${fdt_addr}\0" \ + "ubiload=ubi part UBI && ubifsmount ubi0 && " \ + "ubifsload ${loadaddr} /boot/${bootimage} && " \ + "ubifsload ${fdt_addr} /boot/${fdtimage}\0" + +#endif
#endif /* __CONFIG_SOCFPGA_COMMON_H__ */
- Stack setup
- "verify=n\0" \
- "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \
- "bootimage=" CONFIG_BOOTFILE "\0" \
- "fdt_addr=100\0" \
- "fdtimage=" CONFIG_DEFAULT_FDT_FILE "\0" \
- "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \
- "mmcroot=/dev/mmcblk0p3\0" \
Should this be mmcblk0p2?
Dinh
- "verify=n\0" \
that was the point of the patches, p1 is now the a2 partition, so the fat and root partition shifted up by 1.
Dinh
- Stack setup
- "verify=n\0" \
Ok, sorry about that.
Dinh
Remove the default environment as it is now in a common header.
Add the CONFIG_DEFAULT_DEVICE_TREE to the board's defconfig to set the linux devicetree name.
Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com --- configs/socfpga_de0_nano_soc_defconfig | 3 +-- include/configs/socfpga_de0_nano_soc.h | 19 +------------------ 2 files changed, 2 insertions(+), 20 deletions(-)
diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index af41e1e..4837809 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_TERASIC_DE0_NANO=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" +CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_de0_sockit.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y @@ -20,7 +21,6 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_GREPENV=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_I2C=y CONFIG_CMD_USB=y @@ -35,7 +35,6 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_UBI=y CONFIG_SPL_DM=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index 6b9546e..97216ea 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -18,7 +18,7 @@ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB */
/* Booting Linux */ -#define CONFIG_BOOTFILE "fitImage" +#define CONFIG_BOOTFILE "zImage" #define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) #define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" #define CONFIG_LOADADDR 0x01000000 @@ -32,23 +32,6 @@
#define CONFIG_ENV_IS_IN_MMC
-/* Extra Environment */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "bootimage=zImage\0" \ - "fdt_addr=100\0" \ - "fdtimage=socfpga.dtb\0" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "mmcroot=/dev/mmcblk0p2\0" \ - "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${mmcroot} rw rootwait;" \ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "mmcload=mmc rescan;" \ - "load mmc 0:1 ${loadaddr} ${bootimage};" \ - "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ - /* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
This should be socfpga_cyclone5_de0_nano_soc.dtb
Dinh
No, just checked the dts in the kernel source. it is socfpga_cyclone5_de0_sockit.dts. I can change this to what you like, but my intent had been to match names in the kernel source where possible.
thanks.
Dinh
This is U-Boot: check under U-Boot's arch/arm/dts/
socfpga_cyclone5_sockit.dtb is for the sockit socfpga_cyclone5_de0_nano_soc.dtb is for the DE0 Nano board.
commit 55c7a765f63ab10b9a3b8cbd38bf1483901a7b36 Author: Dinh Nguyen dinguyen@opensource.altera.com Date: Tue Sep 1 17:41:52 2015 -0500
arm: socfpga: Add support for the Terasic DE-0 Atlas board
Add support for the Terasic DE0-Nano/Atlas-SoC Kit, which is CycloneV based board. The board can boot from SD/MMC. Ethernet is also supported.
Dinh
Oh you're right...I got confused. You're matching the DTS in the kernel. Sorry about that...
Dinh
Ah, i see. I was under the impression CONFIG_DEFAULT_FDT_FILE was only being used for the uboot env and CONFIG_DEFAULT_DEVICE_TREE was for the dts being used by uboot. I am using CONFIG_DEFAULT_FDT_FILE to set the uboot env fdtimage variable. Is that not the case?
Dinh _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
No, you're right! I got confused..see follow up message.
Dinh
Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com --- configs/socfpga_cyclone5_defconfig | 1 + include/configs/socfpga_cyclone5_socdk.h | 25 ------------------------- 2 files changed, 1 insertion(+), 25 deletions(-)
diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index 8b050b9..cba1e9c 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_CYCLONE5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" +CONFIG_DEFAULT_FDT_FILE="socfpga_cyclone5_socdk.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index 7ced6a6..96b2b87 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -36,31 +36,6 @@
-/* Extra Environment */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "verify=n\0" \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "bootimage=zImage\0" \ - "fdt_addr=100\0" \ - "fdtimage=socfpga.dtb\0" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "mmcroot=/dev/mmcblk0p2\0" \ - "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${mmcroot} rw rootwait;" \ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "mmcload=mmc rescan;" \ - "load mmc 0:1 ${loadaddr} ${bootimage};" \ - "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ - "qspiload=sf probe && mtdparts default && run ubiload\0" \ - "qspiboot=setenv bootargs " CONFIG_BOOTARGS \ - " ubi.mtd=1,64 root=ubi0:rootfs rw rootfstype=ubifs;"\ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "ubiload=ubi part UBI && ubifsmount ubi0 && " \ - "ubifsload ${loadaddr} /boot/${bootimage} && " \ - "ubifsload ${fdt_addr} /boot/${fdtimage}\0" - /* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com --- configs/socfpga_arria5_defconfig | 1 + include/configs/socfpga_arria5_socdk.h | 25 ------------------------- 2 files changed, 1 insertion(+), 25 deletions(-)
diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 43c51fe..6a473a9 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_ARRIA5_SOCDK=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" +CONFIG_DEFAULT_FDT_FILE="socfpga_arria5_socdk.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index 3b0b416..481a032 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -36,31 +36,6 @@
Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com --- configs/socfpga_de1_soc_defconfig | 1 + include/configs/socfpga_de1_soc.h | 19 +------------------ 2 files changed, 2 insertions(+), 18 deletions(-)
diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index 032deef..19ff608 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_SOCFPGA_TERASIC_DE1_SOC=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de1_soc" +CONFIG_DEFAULT_FDT_FILE="socfpga.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_de1_soc.h b/include/configs/socfpga_de1_soc.h index deec647..3142bd1 100644 --- a/include/configs/socfpga_de1_soc.h +++ b/include/configs/socfpga_de1_soc.h @@ -18,7 +18,7 @@ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB */
-/* Extra Environment */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ - "bootm ${loadaddr} - ${fdtaddr}\0" \ - "bootimage=zImage\0" \ - "fdtaddr=100\0" \ - "fdtimage=socfpga.dtb\0" \ - "bootm ${loadaddr} - ${fdtaddr}\0" \ - "mmcroot=/dev/mmcblk0p2\0" \ - "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${mmcroot} rw rootwait;" \ - "bootz ${loadaddr} - ${fdtaddr}\0" \ - "mmcload=mmc rescan;" \ - "load mmc 0:1 ${loadaddr} ${bootimage};" \ - "load mmc 0:1 ${fdtaddr} ${fdtimage}\0" \ - /* The rest of the configuration is shared */ #include <configs/socfpga_common.h>
Why not socfpga_cyclone5_de1_soc.dtb ?
Dinh
There was no mainlined linux dts for this board so i just left it as it was.
Dinh
Ok.
Dinh
Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com --- configs/socfpga_sockit_defconfig | 1 + include/configs/socfpga_sockit.h | 27 +-------------------------- 2 files changed, 2 insertions(+), 26 deletions(-)
diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index d0c2bda..130c4e2 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_TERASIC_SOCKIT=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" +CONFIG_DEFAULT_FDT_FILE="socfpga.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index 3fceb31..c51cc72 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -18,7 +18,7 @@ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SoCDK */
/* Booting Linux */ -#define CONFIG_BOOTFILE "fitImage" +#define CONFIG_BOOTFILE "zImage" #define CONFIG_BOOTARGS "console=ttyS0," __stringify(CONFIG_BAUDRATE) #define CONFIG_BOOTCOMMAND "run mmcload; run mmcboot" #define CONFIG_LOADADDR 0x01000000 @@ -32,31 +32,6 @@
Should this be "socfpga_cyclone5_sockit.dtb" ?
Dinh
I can certainly do that, but as before i just left the default b/c there is no mainlined dts in linux. That said, i think you are correct, i will update all the socfpga.dtb's to reflect the board name.
Dinh
I think there is mainline DTS file for the sockit, (socfpga_cyclone5_sockit.dts), or am I confused again?
Dinh
Yeah, that's sockit .
missed that. thanks. i am updating all of the socfpga.dtbs in any case. i figure once (or if) their dts's are upstreamed these files wont need changing.
Signed-off-by: Dalon Westergreen dalon.westergreen@intel.com Acked-by: Stefan Roese --- configs/socfpga_sr1500_defconfig | 1 + include/configs/socfpga_sr1500.h | 25 ------------------------- 2 files changed, 1 insertion(+), 25 deletions(-)
diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 6fd7bc0..b0b08da 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TARGET_SOCFPGA_SR1500=y CONFIG_SPL_STACK_R_ADDR=0x00800000 CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" +CONFIG_DEFAULT_FDT_FILE="socfpga.dtb" CONFIG_FIT=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index 0407f03..3c63e80 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -32,31 +32,6 @@ #define CONFIG_PHY_MARVELL #define PHY_ANEG_TIMEOUT 8000
-#define CONFIG_EXTRA_ENV_SETTINGS \ - "verify=n\0" \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "ramboot=setenv bootargs " CONFIG_BOOTARGS ";" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "bootimage=zImage\0" \ - "fdt_addr=100\0" \ - "fdtimage=socfpga.dtb\0" \ - "fsloadcmd=ext2load\0" \ - "bootm ${loadaddr} - ${fdt_addr}\0" \ - "mmcroot=/dev/mmcblk0p2\0" \ - "mmcboot=setenv bootargs " CONFIG_BOOTARGS \ - " root=${mmcroot} rw rootwait;" \ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "mmcload=mmc rescan;" \ - "load mmc 0:1 ${loadaddr} ${bootimage};" \ - "load mmc 0:1 ${fdt_addr} ${fdtimage}\0" \ - "qspiload=sf probe && mtdparts default && run ubiload\0" \ - "qspiboot=setenv bootargs " CONFIG_BOOTARGS \ - " ubi.mtd=1,64 root=ubi0:rootfs rw rootfstype=ubifs;"\ - "bootz ${loadaddr} - ${fdt_addr}\0" \ - "ubiload=ubi part UBI && ubifsmount ubi0 && " \ - "ubifsload ${loadaddr} /boot/${bootimage} && " \ - "ubifsload ${fdt_addr} /boot/${fdtimage}\0" - /* Environment */ #define CONFIG_ENV_IS_IN_SPI_FLASH
Changes in v4:
Changes in v3:
Whole series Acked-by: Marek Vasut marex@denx.de
Dinh, any comments ?
Changes in v4:
Changes in v3:
I thought you had a comment on why this series changes the default bootfile from a fitImage to zImage. Was that comment addressed?
Dinh
Yes, my comment was that none of the boards were currently using fitimages.
Dinh
Changes in v4:
Changes in v3:
Yes, it seems the default altera SD card images use zImage + separate DTB. I constantly regret bringing bootz into U-Boot tbh, but such are the mistakes of youth ...
Changes in v4:
Changes in v3:
So I think my only valid comment is for patch "[6/7] arm: socfpga: Update SoCKit environment"
There is mainline kernel support for this board:
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/arch/ar...
Dinh
Dalon Westergreen
Dinh Nguyen
Westergreen, Dalon
