[U-Boot] [PATCH] buildman: Fix problem with non-existent output directories
Now that we have buildman telling genboards.cfg to use an output directory we need to ensure that it exists.
Cc: Bin Meng bmeng.cn@gmail.com Cc: Simon Glass sjg@chromium.org Fixes: bc750bca1246 ("tools: buildman: Honor output directory when generating boards.cfg") Signed-off-by: Tom Rini trini@konsulko.com --- tools/buildman/control.py | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/tools/buildman/control.py b/tools/buildman/control.py index 9787b8674761..5988ada72b75 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -201,6 +201,8 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None,
# Work out what subset of the boards we are building if not boards: + if not os.path.exists(options.output_dir): + os.mkdir(options.output_dir) board_file = os.path.join(options.output_dir, 'boards.cfg') genboardscfg = os.path.join(options.git, 'tools/genboardscfg.py') status = subprocess.call([genboardscfg, '-o', board_file])
Use os.makedirs() ?
Regards, Bin
Use os.makedirs() ?
Ah, in case we need more than one directory made? OK, I'll do v2 shortly.
Cc: Bin Meng bmeng.cn@gmail.com Cc: Simon Glass sjg@chromium.org Fixes: bc750bca1246 ("tools: buildman: Honor output directory when generating boards.cfg") Signed-off-by: Tom Rini trini@konsulko.com --- Changes in v2: - Use os.makedirs() per Bin --- tools/buildman/control.py | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/tools/buildman/control.py b/tools/buildman/control.py index 216012d00168..c55a65d0c30b 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -201,6 +201,8 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None,
# Work out what subset of the boards we are building if not boards: + if not os.path.exists(options.output_dir): + os.makedirs(options.output_dir) board_file = os.path.join(options.output_dir, 'boards.cfg') genboardscfg = os.path.join(options.git, 'tools/genboardscfg.py') status = subprocess.call([genboardscfg, '-o', board_file])
Changes in v2:
Cc: Bin Meng bmeng.cn@gmail.com Cc: Simon Glass sjg@chromium.org Fixes: bc750bca1246 ("tools: buildman: Honor output directory when generating boards.cfg") Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
Bin Meng
