[U-Boot] [u-boot] [PATCH][1/2] mx27: Add necessary defines and helper functions to support I2C in i.MX27.
Add proper register definitions, macros and clock functions required for I2C driver to be developed.
Signed-off-by: Javier Martin javier.martin@vista-silicon.com -- diff --git a/cpu/arm926ejs/mx27/generic.c b/cpu/arm926ejs/mx27/generic.c index 808371f..540ef0c 100644 --- a/cpu/arm926ejs/mx27/generic.c +++ b/cpu/arm926ejs/mx27/generic.c @@ -22,11 +22,21 @@ #include <div64.h> #include <netdev.h> #include <asm/io.h> +#include <asm/arch/asm-offsets.h> #include <asm/arch/imx-regs.h> #ifdef CONFIG_MXC_MMC #include <asm/arch/mxcmmc.h> #endif
+int imx_get_revision(void) +{ + ulong val; + + val = readl(SYSCTRL_CID); + + return (int)(val >> 28); +} + /* * get the system pll clock in Hz * @@ -152,6 +162,19 @@ ulong imx_get_perclk4(void) return imx_decode_perclk(((readl(&pll->pcdr1) >> 24) & 0x3f) + 1); }
+ulong imx_get_ipgclk(void) +{ + ulong rate, ipg_pdf; + + if (imx_get_revision() >= CHIP_REV_2_0) + return imx_get_ahbclk(); + else + ipg_pdf = (readl(CSCR) >> 8) & 1; + + rate = imx_get_ahbclk(); + return rate / (ipg_pdf + 1); +} + #if defined(CONFIG_DISPLAY_CPUINFO) int print_cpuinfo (void) { diff --git a/include/asm-arm/arch-mx27/asm-offsets.h b/include/asm-arm/arch-mx27/asm-offsets.h index 497afe5..cdecef6 100644 --- a/include/asm-arm/arch-mx27/asm-offsets.h +++ b/include/asm-arm/arch-mx27/asm-offsets.h @@ -14,3 +14,5 @@ #define ESDCTL1_ROF 0x08 #define ESDCFG1_ROF 0x0C #define ESDMISC_ROF 0x10 +#define SYSCTRL_CID 0x10027800 +#define CHIP_REV_2_0 0x01 diff --git a/include/asm-arm/arch-mx27/imx-regs.h b/include/asm-arm/arch-mx27/imx-regs.h index d36a6da..2b89b4e 100644 --- a/include/asm-arm/arch-mx27/imx-regs.h +++ b/include/asm-arm/arch-mx27/imx-regs.h @@ -206,6 +206,10 @@ struct iim_regs { }; #endif
+#define __REG(x) (*((volatile u32 *)(x))) +#define __REG16(x) (*((volatile u16 *)(x))) +#define __REG8(x) (*((volatile u8 *)(x))) + #define IMX_IO_BASE 0x10000000
#define IMX_AIPI1_BASE (0x00000 + IMX_IO_BASE) -- Javier Martin Vista Silicon S.L. CDTUC - FASE C - Oficina S-345 Avda de los Castros s/n 39005- Santander. Cantabria. Spain +34 942 25 32 60 www.vista-silicon.com
Hello Javier,
Why you need this? Couldn;t you use io accessor from asm/io.h?
bye, Heiko
2009/11/2 Heiko Schocher hs@denx.de:
Hello Javier,
Hi Heiko, thank you for the comments. I think that would make the driver dirty since there would also be needed the use of an ifdef to separate i.MX31 reg accesses, which are accessed through __REG() macros, from i.MX27 ones which should be accessed by io accessors from io.h. If you do not have any complaint about that I will use functions from asm/io.h.
Hello javier,
Hello Javier,
No, that is suboptimal, I thought more in the direction to cleanup the driver ;-)
I see no reason, why the i.mx31 shouldn;t be able to use also the io accessors from asm/io.h ... Tom, any suggestions?
bye Heiko
Heiko Schocher
Javier Martin
javier Martin
