[U-Boot] [U-Boot, V2, PATCH 2/3] mips: add initial support for qca956x referenced board
Signed-off-by: Rosy Song rosysong@rosinson.com --- arch/mips/dts/Makefile | 1 + arch/mips/dts/ap152.dts | 48 ++ arch/mips/dts/qca956x.dtsi | 87 ++++ arch/mips/mach-ath79/Kconfig | 14 + arch/mips/mach-ath79/Makefile | 1 + .../mach-ath79/include/mach/ar71xx_regs.h | 73 +++ arch/mips/mach-ath79/include/mach/ath79.h | 3 + arch/mips/mach-ath79/qca956x/Makefile | 5 + arch/mips/mach-ath79/qca956x/clk.c | 419 ++++++++++++++++++ arch/mips/mach-ath79/qca956x/cpu.c | 9 + arch/mips/mach-ath79/qca956x/ddr.c | 308 +++++++++++++ .../mips/mach-ath79/qca956x/qca956x-ddr-tap.S | 193 ++++++++ arch/mips/mach-ath79/reset.c | 271 +++++++++++ board/qca/ap152/Kconfig | 15 + board/qca/ap152/MAINTAINERS | 6 + board/qca/ap152/Makefile | 3 + board/qca/ap152/ap152.c | 81 ++++ configs/ap152_defconfig | 49 ++ include/configs/ap152.h | 54 +++ 19 files changed, 1640 insertions(+) create mode 100644 arch/mips/dts/ap152.dts create mode 100644 arch/mips/dts/qca956x.dtsi create mode 100644 arch/mips/mach-ath79/qca956x/Makefile create mode 100644 arch/mips/mach-ath79/qca956x/clk.c create mode 100644 arch/mips/mach-ath79/qca956x/cpu.c create mode 100644 arch/mips/mach-ath79/qca956x/ddr.c create mode 100644 arch/mips/mach-ath79/qca956x/qca956x-ddr-tap.S create mode 100644 board/qca/ap152/Kconfig create mode 100644 board/qca/ap152/MAINTAINERS create mode 100644 board/qca/ap152/Makefile create mode 100644 board/qca/ap152/ap152.c create mode 100644 configs/ap152_defconfig create mode 100644 include/configs/ap152.h
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index b94b582837..621c35f0ef 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -2,6 +2,7 @@
dtb-$(CONFIG_TARGET_AP121) += ap121.dtb dtb-$(CONFIG_TARGET_AP143) += ap143.dtb +dtb-$(CONFIG_TARGET_AP152) += ap152.dtb dtb-$(CONFIG_TARGET_BOSTON) += img,boston.dtb dtb-$(CONFIG_TARGET_MALTA) += mti,malta.dtb dtb-$(CONFIG_TARGET_PIC32MZDASK) += pic32mzda_sk.dtb diff --git a/arch/mips/dts/ap152.dts b/arch/mips/dts/ap152.dts new file mode 100644 index 0000000000..1722290c73 --- /dev/null +++ b/arch/mips/dts/ap152.dts @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Rosy Song rosysong@rosinson.com + */ + +/dts-v1/; +#include "qca956x.dtsi" + +/ { + model = "AP152 Reference Board"; + compatible = "qca,ap152", "qca,qca956x"; + + aliases { + spi0 = &spi0; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&gmac0 { + phy-mode = "sgmii"; + status = "okay"; +}; + +&xtal { + clock-frequency = <25000000>; +}; + +&uart0 { + clock-frequency = <25000000>; + status = "okay"; +}; + +&spi0 { + spi-max-frequency = <25000000>; + status = "okay"; + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + memory-map = <0x9f000000 0x01000000>; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; diff --git a/arch/mips/dts/qca956x.dtsi b/arch/mips/dts/qca956x.dtsi new file mode 100644 index 0000000000..6cb360b3f8 --- /dev/null +++ b/arch/mips/dts/qca956x.dtsi @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Rosy Song rosysong@rosinson.com + */ + +#include "skeleton.dtsi" + +/ { + compatible = "qca,qca956x"; + + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "mips,mips74Kc"; + reg = <0>; + }; + }; + + clocks { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + xtal: xtal { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-output-names = "xtal"; + }; + }; + + ahb { + compatible = "simple-bus"; + ranges; + + #address-cells = <1>; + #size-cells = <1>; + + apb { + compatible = "simple-bus"; + ranges; + + #address-cells = <1>; + #size-cells = <1>; + + uart0: uart@18020000 { + compatible = "ns16550"; + reg = <0x18020000 0x20>; + reg-shift = <2>; + + status = "disabled"; + }; + + gmac0: eth@0x19000000 { + compatible = "qca,ag956x-mac"; + reg = <0x19000000 0x200>; + phy = <&phy0>; + phy-mode = "sgmii"; + + status = "disabled"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + phy0: ethernet-phy@0 { + reg = <0>; + }; + }; + }; + }; + + spi0: spi@1f000000 { + compatible = "qca,ar7100-spi"; + reg = <0x1f000000 0x10>; + + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + }; + }; +}; diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig index bc86f591df..bdb23b5765 100644 --- a/arch/mips/mach-ath79/Kconfig +++ b/arch/mips/mach-ath79/Kconfig @@ -33,6 +33,15 @@ config SOC_QCA953X help This supports QCA/Atheros qca953x family SOCs.
+config SOC_QCA956X + bool + select MIPS_TUNE_74KC + select SUPPORTS_BIG_ENDIAN + select SUPPORTS_CPU_MIPS32_R1 + select SUPPORTS_CPU_MIPS32_R2 + help + This supports QCA/Atheros qca956x family SOCs. + choice prompt "Board select"
@@ -44,6 +53,10 @@ config TARGET_AP143 bool "AP143 Reference Board" select SOC_QCA953X
+config TARGET_AP152 + bool "AP152 Reference Board" + select SOC_QCA956X + config BOARD_TPLINK_WDR4300 bool "TP-Link WDR4300 Board" select SOC_AR934X @@ -52,6 +65,7 @@ endchoice
source "board/qca/ap121/Kconfig" source "board/qca/ap143/Kconfig" +source "board/qca/ap152/Kconfig" source "board/tplink/wdr4300/Kconfig"
endmenu diff --git a/arch/mips/mach-ath79/Makefile b/arch/mips/mach-ath79/Makefile index 7aa40c65d3..fbd40c02be 100644 --- a/arch/mips/mach-ath79/Makefile +++ b/arch/mips/mach-ath79/Makefile @@ -7,3 +7,4 @@ obj-y += dram.o obj-$(CONFIG_SOC_AR933X) += ar933x/ obj-$(CONFIG_SOC_AR934X) += ar934x/ obj-$(CONFIG_SOC_QCA953X) += qca953x/ +obj-$(CONFIG_SOC_QCA956X) += qca956x/ diff --git a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h index 5d371bb582..7cd16b8d81 100644 --- a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h +++ b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h @@ -194,6 +194,9 @@ #define QCA956X_WMAC_BASE \ (AR71XX_APB_BASE + 0x00100000) #define QCA956X_WMAC_SIZE 0x20000 +#define QCA956X_RTC_BASE \ + (AR71XX_APB_BASE + 0x00107000) +#define QCA956X_RTC_SIZE 0x1000 #define QCA956X_EHCI0_BASE 0x1b000000 #define QCA956X_EHCI1_BASE 0x1b400000 #define QCA956X_EHCI_SIZE 0x200 @@ -201,6 +204,10 @@ (AR71XX_APB_BASE + 0x00070000) #define QCA956X_GMAC_SIZE 0x64
+#define QCA956X_SRIF_BASE \ + (AR71XX_APB_BASE + 0x00116000) +#define QCA956X_SRIF_SIZE 0x1000 + /* * DDR_CTRL block */ @@ -278,6 +285,18 @@ #define QCA953X_DDR_REG_CTL_CONF 0x108 #define QCA953X_DDR_REG_CONFIG3 0x15c
+#define QCA956X_DDR_REG_TAP_CTRL2 0x24 +#define QCA956X_DDR_REG_TAP_CTRL3 0x28 +#define QCA956X_DDR_REG_DDR2_CONFIG 0xb8 +#define QCA956X_DDR_REG_DDR2_EMR2 0xbc +#define QCA956X_DDR_REG_DDR2_EMR3 0xc0 +#define QCA956X_DDR_REG_BURST 0xc4 +#define QCA956X_DDR_REG_BURST2 0xc8 +#define QCA956X_DDR_REG_TIMEOUT_MAX 0xcc +#define QCA956X_DDR_REG_FSM_WAIT_CTRL 0xe4 +#define QCA956X_DDR_REG_CTL_CONF 0x108 +#define QCA956X_DDR_REG_DDR3_CONFIG 0x15c + /* * PLL block */ @@ -519,6 +538,13 @@ #define QCA956X_PLL_DDR_CONFIG_REG 0x08 #define QCA956X_PLL_DDR_CONFIG1_REG 0x0c #define QCA956X_PLL_CLK_CTRL_REG 0x10 +#define QCA956X_PLL_SWITCH_CLK_CTRL_REG 0x28 +#define QCA956X_PLL_ETH_XMII_CTRL_REG 0x30 +#define QCA956X_PLL_DDR_DIT_FRAC_REG 0x38 +#define QCA956X_PLL_DDR_DIT2_FRAC_REG 0x3c +#define QCA956X_PLL_CPU_DIT_FRAC_REG 0x40 +#define QCA956X_PLL_CPU_DIT2_FRAC_REG 0x44 +#define QCA956X_PLL_ETH_SGMII_SERDES_REG 0x4c
#define QCA956X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 #define QCA956X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f @@ -756,6 +782,17 @@ #define QCA955X_RESET_MBOX BIT(1) #define QCA955X_RESET_I2S BIT(0)
+#define QCA956X_RESET_EXTERNAL BIT(28) +#define QCA956X_RESET_FULL_CHIP BIT(24) +#define QCA956X_RESET_GE1_MDIO BIT(23) /* Reserved in datasheet */ +#define QCA956X_RESET_GE0_MDIO BIT(22) +#define QCA956X_RESET_GE1_MAC BIT(13) /* Reserved in datasheet */ +#define QCA956X_RESET_SGMII_ASSERT BIT(12) +#define QCA956X_RESET_GE0_MAC BIT(9) +#define QCA956X_RESET_SGMII BIT(8) +#define QCA956X_RESET_SGMII_ANALOG BIT(2) +#define QCA956X_RESET_SWITCH BIT(0) + #define AR933X_BOOTSTRAP_MDIO_GPIO_EN BIT(18) #define AR933X_BOOTSTRAP_DDR2 BIT(13) #define AR933X_BOOTSTRAP_EEPBUSY BIT(4) @@ -1099,8 +1136,12 @@ #define QCA953X_GPIO_IN_MUX_UART0_SIN 9 #define QCA953X_GPIO_IN_MUX_SPI_DATA_IN 8
+#define QCA956X_GPIO(x) BIT(x) +#define QCA956X_GPIO_MUX_MASK(x) (0xff << (x)) #define QCA956X_GPIO_OUT_MUX_GE0_MDO 32 #define QCA956X_GPIO_OUT_MUX_GE0_MDC 33 +#define QCA956X_GPIO_IN_MUX_UART0_SIN 0x12 +#define QCA956X_GPIO_OUT_MUX_UART0_SOUT 0x16
#define AR71XX_GPIO_COUNT 16 #define AR7240_GPIO_COUNT 18 @@ -1179,6 +1220,25 @@ #define QCA953X_SRIF_DPLL2_OUTDIV_SHIFT 13 #define QCA953X_SRIF_DPLL2_OUTDIV_MASK 0x7
+#define QCA956X_SRIF_BB_DPLL1_REG 0x180 +#define QCA956X_SRIF_BB_DPLL2_REG 0x184 +#define QCA956X_SRIF_BB_DPLL3_REG 0x188 + +#define QCA956X_SRIF_CPU_DPLL1_REG 0xf00 +#define QCA956X_SRIF_CPU_DPLL2_REG 0xf04 +#define QCA956X_SRIF_CPU_DPLL3_REG 0xf08 + +#define QCA956X_SRIF_DDR_DPLL1_REG 0xec0 +#define QCA956X_SRIF_DDR_DPLL2_REG 0xec4 +#define QCA956X_SRIF_DDR_DPLL3_REG 0xec8 + +#define QCA956X_SRIF_PCIE_DPLL1_REG 0xc80 +#define QCA956X_SRIF_PCIE_DPLL2_REG 0xc84 +#define QCA956X_SRIF_PCIE_DPLL3_REG 0xc88 + +#define QCA956X_SRIF_PMU1_REG 0xcc0 +#define QCA956X_SRIF_PMU2_REG 0xcc4 + /* * MII_CTRL block */ @@ -1261,4 +1321,17 @@ #define QCA955X_ETH_CFG_RGMII_EN BIT(0) #define QCA955X_ETH_CFG_GE0_SGMII BIT(6)
+/* + * QCA956X GMAC Interface + */ + +#define QCA956X_GMAC_REG_ETH_CFG 0x00 +#define QCA956X_GMAC_REG_SGMII_RESET 0x14 +#define QCA956X_GMAC_REG_SGMII_SERDES 0x18 +#define QCA956X_GMAC_REG_MR_AN_CTRL 0x1c +#define QCA956X_GMAC_REG_SGMII_CONFIG 0x34 +#define QCA956X_GMAC_REG_SGMII_DEBUG 0x58 + +#define QCA956X_ETH_CFG_GE0_SGMII BIT(6) + #endif /* __ASM_AR71XX_H */ diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h index 5de7a43f79..0fde5079b1 100644 --- a/arch/mips/mach-ath79/include/mach/ath79.h +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -2,6 +2,7 @@ /* * Atheros AR71XX/AR724X/AR913X common definitions * + * Copyright (C) 2018-2019 Rosy Song rosysong@rosinson.com * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com * Copyright (C) 2008-2011 Gabor Juhos juhosg@openwrt.org * Copyright (C) 2008 Imre Kaloz kaloz@openwrt.org @@ -146,4 +147,6 @@ int ath79_usb_reset(void); void ar934x_pll_init(const u16 cpu_mhz, const u16 ddr_mhz, const u16 ahb_mhz); void ar934x_ddr_init(const u16 cpu_mhz, const u16 ddr_mhz, const u16 ahb_mhz);
+void qca956x_pll_init(void); +void qca956x_ddr_init(void); #endif /* __ASM_MACH_ATH79_H */ diff --git a/arch/mips/mach-ath79/qca956x/Makefile b/arch/mips/mach-ath79/qca956x/Makefile new file mode 100644 index 0000000000..3f5fc0363f --- /dev/null +++ b/arch/mips/mach-ath79/qca956x/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += cpu.o +obj-y += clk.o +obj-y += ddr.o qca956x-ddr-tap.o diff --git a/arch/mips/mach-ath79/qca956x/clk.c b/arch/mips/mach-ath79/qca956x/clk.c new file mode 100644 index 0000000000..ca956d1291 --- /dev/null +++ b/arch/mips/mach-ath79/qca956x/clk.c @@ -0,0 +1,419 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Rosy Song rosysong@rosinson.com + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/ath79.h> +#include <wait_bit.h> + +#define PLL_SRIF_DPLL2_KI_LSB 29 +#define PLL_SRIF_DPLL2_KI_MASK 0x60000000 +#define PLL_SRIF_DPLL2_KI_SET(x) \ + (((x) << PLL_SRIF_DPLL2_KI_LSB) & PLL_SRIF_DPLL2_KI_MASK) +#define PLL_SRIF_DPLL2_KD_LSB 25 +#define PLL_SRIF_DPLL2_KD_MASK 0x1e000000 +#define PLL_SRIF_DPLL2_KD_SET(x) \ + (((x) << PLL_SRIF_DPLL2_KD_LSB) & PLL_SRIF_DPLL2_KD_MASK) +#define PLL_SRIF_DPLL2_PLL_PWD_LSB 22 +#define PLL_SRIF_DPLL2_PLL_PWD_MASK 0x00400000 +#define PLL_SRIF_DPLL2_PLL_PWD_SET(x) \ + (((x) << PLL_SRIF_DPLL2_PLL_PWD_LSB) & PLL_SRIF_DPLL2_PLL_PWD_MASK) +#define PLL_SRIF_DPLL2_OUTDIV_LSB 19 +#define PLL_SRIF_DPLL2_OUTDIV_MASK 0x00380000 +#define PLL_SRIF_DPLL2_OUTDIV_SET(x) \ + (((x) << PLL_SRIF_DPLL2_OUTDIV_LSB) & PLL_SRIF_DPLL2_OUTDIV_MASK) +#define PLL_SRIF_DPLL2_PHASE_SHIFT_LSB 12 +#define PLL_SRIF_DPLL2_PHASE_SHIFT_MASK 0x0007f000 +#define PLL_SRIF_DPLL2_PHASE_SHIFT_SET(x) \ + (((x) << PLL_SRIF_DPLL2_PHASE_SHIFT_LSB) & PLL_SRIF_DPLL2_PHASE_SHIFT_MASK) +#define CPU_PLL_CONFIG_PLLPWD_LSB 30 +#define CPU_PLL_CONFIG_PLLPWD_MASK 0x40000000 +#define CPU_PLL_CONFIG_PLLPWD_SET(x) \ + (((x) << CPU_PLL_CONFIG_PLLPWD_LSB) & CPU_PLL_CONFIG_PLLPWD_MASK) +#define CPU_PLL_CONFIG_OUTDIV_LSB 19 +#define CPU_PLL_CONFIG_OUTDIV_MASK 0x00380000 +#define CPU_PLL_CONFIG_OUTDIV_SET(x) \ + (((x) << CPU_PLL_CONFIG_OUTDIV_LSB) & CPU_PLL_CONFIG_OUTDIV_MASK) +#define CPU_PLL_CONFIG_RANGE_LSB 17 +#define CPU_PLL_CONFIG_RANGE_MASK 0x00060000 +#define CPU_PLL_CONFIG_RANGE_SET(x) \ + (((x) << CPU_PLL_CONFIG_RANGE_LSB) & CPU_PLL_CONFIG_RANGE_MASK) +#define CPU_PLL_CONFIG_REFDIV_LSB 12 +#define CPU_PLL_CONFIG_REFDIV_MASK 0x0001f000 +#define CPU_PLL_CONFIG_REFDIV_SET(x) \ + (((x) << CPU_PLL_CONFIG_REFDIV_LSB) & CPU_PLL_CONFIG_REFDIV_MASK) +#define CPU_PLL_CONFIG1_NINT_LSB 18 +#define CPU_PLL_CONFIG1_NINT_MASK 0x07fc0000 +#define CPU_PLL_CONFIG1_NINT_SET(x) \ + (((x) << CPU_PLL_CONFIG1_NINT_LSB) & CPU_PLL_CONFIG1_NINT_MASK) +#define CPU_PLL_DITHER1_DITHER_EN_LSB 31 +#define CPU_PLL_DITHER1_DITHER_EN_MASK 0x80000000 +#define CPU_PLL_DITHER1_DITHER_EN_SET(x) \ + (((x) << CPU_PLL_DITHER1_DITHER_EN_LSB) & CPU_PLL_DITHER1_DITHER_EN_MASK) +#define CPU_PLL_DITHER1_UPDATE_COUNT_LSB 24 +#define CPU_PLL_DITHER1_UPDATE_COUNT_MASK 0x3f000000 +#define CPU_PLL_DITHER1_UPDATE_COUNT_SET(x) \ + (((x) << CPU_PLL_DITHER1_UPDATE_COUNT_LSB) & CPU_PLL_DITHER1_UPDATE_COUNT_MASK) +#define CPU_PLL_DITHER1_NFRAC_STEP_LSB 18 +#define CPU_PLL_DITHER1_NFRAC_STEP_MASK 0x00fc0000 +#define CPU_PLL_DITHER1_NFRAC_STEP_SET(x) \ + (((x) << CPU_PLL_DITHER1_NFRAC_STEP_LSB) & CPU_PLL_DITHER1_NFRAC_STEP_MASK) +#define CPU_PLL_DITHER1_NFRAC_MIN_LSB 0 +#define CPU_PLL_DITHER1_NFRAC_MIN_MASK 0x0003ffff +#define CPU_PLL_DITHER1_NFRAC_MIN_SET(x) \ + (((x) << CPU_PLL_DITHER1_NFRAC_MIN_LSB) & CPU_PLL_DITHER1_NFRAC_MIN_MASK) +#define CPU_PLL_DITHER2_NFRAC_MAX_LSB 0 +#define CPU_PLL_DITHER2_NFRAC_MAX_MASK 0x0003ffff +#define CPU_PLL_DITHER2_NFRAC_MAX_SET(x) \ + (((x) << CPU_PLL_DITHER2_NFRAC_MAX_LSB) & CPU_PLL_DITHER2_NFRAC_MAX_MASK) +#define DDR_PLL_CONFIG_PLLPWD_LSB 30 +#define DDR_PLL_CONFIG_PLLPWD_MASK 0x40000000 +#define DDR_PLL_CONFIG_PLLPWD_SET(x) \ + (((x) << DDR_PLL_CONFIG_PLLPWD_LSB) & DDR_PLL_CONFIG_PLLPWD_MASK) +#define DDR_PLL_CONFIG_OUTDIV_LSB 23 +#define DDR_PLL_CONFIG_OUTDIV_MASK 0x03800000 +#define DDR_PLL_CONFIG_OUTDIV_SET(x) \ + (((x) << DDR_PLL_CONFIG_OUTDIV_LSB) & DDR_PLL_CONFIG_OUTDIV_MASK) +#define DDR_PLL_CONFIG_RANGE_LSB 21 +#define DDR_PLL_CONFIG_RANGE_MASK 0x00600000 +#define DDR_PLL_CONFIG_RANGE_SET(x) \ + (((x) << DDR_PLL_CONFIG_RANGE_LSB) & DDR_PLL_CONFIG_RANGE_MASK) +#define DDR_PLL_CONFIG_REFDIV_LSB 16 +#define DDR_PLL_CONFIG_REFDIV_MASK 0x001f0000 +#define DDR_PLL_CONFIG_REFDIV_SET(x) \ + (((x) << DDR_PLL_CONFIG_REFDIV_LSB) & DDR_PLL_CONFIG_REFDIV_MASK) +#define DDR_PLL_CONFIG1_NINT_LSB 18 +#define DDR_PLL_CONFIG1_NINT_MASK 0x07fc0000 +#define DDR_PLL_CONFIG1_NINT_SET(x) \ + (((x) << DDR_PLL_CONFIG1_NINT_LSB) & DDR_PLL_CONFIG1_NINT_MASK) +#define DDR_PLL_DITHER1_DITHER_EN_LSB 31 +#define DDR_PLL_DITHER1_DITHER_EN_MASK 0x80000000 +#define DDR_PLL_DITHER1_DITHER_EN_SET(x) \ + (((x) << DDR_PLL_DITHER1_DITHER_EN_LSB) & DDR_PLL_DITHER1_DITHER_EN_MASK) +#define DDR_PLL_DITHER1_UPDATE_COUNT_LSB 27 +#define DDR_PLL_DITHER1_UPDATE_COUNT_MASK 0x78000000 +#define DDR_PLL_DITHER1_UPDATE_COUNT_SET(x) \ + (((x) << DDR_PLL_DITHER1_UPDATE_COUNT_LSB) & DDR_PLL_DITHER1_UPDATE_COUNT_MASK) +#define DDR_PLL_DITHER1_NFRAC_STEP_LSB 20 +#define DDR_PLL_DITHER1_NFRAC_STEP_MASK 0x07f00000 +#define DDR_PLL_DITHER1_NFRAC_STEP_SET(x) \ + (((x) << DDR_PLL_DITHER1_NFRAC_STEP_LSB) & DDR_PLL_DITHER1_NFRAC_STEP_MASK) +#define DDR_PLL_DITHER1_NFRAC_MIN_LSB 0 +#define DDR_PLL_DITHER1_NFRAC_MIN_MASK 0x0003ffff +#define DDR_PLL_DITHER1_NFRAC_MIN_SET(x) \ + (((x) << DDR_PLL_DITHER1_NFRAC_MIN_LSB) & DDR_PLL_DITHER1_NFRAC_MIN_MASK) +#define DDR_PLL_DITHER2_NFRAC_MAX_LSB 0 +#define DDR_PLL_DITHER2_NFRAC_MAX_MASK 0x0003ffff +#define DDR_PLL_DITHER2_NFRAC_MAX_SET(x) \ + (((x) << DDR_PLL_DITHER2_NFRAC_MAX_LSB) & DDR_PLL_DITHER2_NFRAC_MAX_MASK) +#define CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_LSB 24 +#define CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_MASK 0x01000000 +#define CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_SET(x) \ + (((x) << CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_LSB) & CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_MASK) +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_LSB 21 +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_MASK 0x00200000 +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_SET(x) \ + (((x) << CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_LSB) & CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_MASK) +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_LSB 20 +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_MASK 0x00100000 +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_SET(x) \ + (((x) << CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_LSB) & CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_MASK) +#define CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_LSB 15 +#define CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_MASK 0x000f8000 +#define CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_SET(x) \ + (((x) << CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_LSB) & CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_MASK) +#define CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_LSB 10 +#define CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_MASK 0x00007c00 +#define CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_SET(x) \ + (((x) << CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_LSB) & CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_MASK) +#define CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_LSB 5 +#define CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_MASK 0x000003e0 +#define CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_SET(x) \ + (((x) << CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_LSB) & CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_MASK) +#define CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_LSB 4 +#define CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_MASK 0x00000010 +#define CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_SET(x) \ + (((x) << CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_LSB) & CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_MASK) +#define CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_LSB 3 +#define CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_MASK 0x00000008 +#define CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_SET(x) \ + (((x) << CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_LSB) & CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_MASK) +#define CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_LSB 2 +#define CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_MASK 0x00000004 +#define CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_SET(x) \ + (((x) << CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_LSB) & CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_MASK) + +#define CPU_PLL_CONFIG1_NINT_VAL CPU_PLL_CONFIG1_NINT_SET(0x1f) +#define CPU_PLL_CONFIG_REF_DIV_VAL CPU_PLL_CONFIG_REFDIV_SET(0x1) +#define CPU_PLL_CONFIG_RANGE_VAL CPU_PLL_CONFIG_RANGE_SET(0) +#define CPU_PLL_CONFIG_OUT_DIV_VAL1 CPU_PLL_CONFIG_OUTDIV_SET(0) +#define CPU_PLL_CONFIG_OUT_DIV_VAL2 CPU_PLL_CONFIG_OUTDIV_SET(0) +#define CPU_PLL_DITHER1_VAL CPU_PLL_DITHER1_DITHER_EN_SET(0) | \ + CPU_PLL_DITHER1_NFRAC_MIN_SET(0) | \ + CPU_PLL_DITHER1_NFRAC_STEP_SET(0) | \ + CPU_PLL_DITHER1_UPDATE_COUNT_SET(0x0) +#define CPU_PLL_DITHER2_VAL CPU_PLL_DITHER2_NFRAC_MAX_SET(0x0) +#define DDR_PLL_CONFIG1_NINT_VAL DDR_PLL_CONFIG1_NINT_SET(0x1a) +#define DDR_PLL_CONFIG_REF_DIV_VAL DDR_PLL_CONFIG_REFDIV_SET(0x1) +#define DDR_PLL_CONFIG_RANGE_VAL DDR_PLL_CONFIG_RANGE_SET(0) +#define DDR_PLL_CONFIG_OUT_DIV_VAL1 DDR_PLL_CONFIG_OUTDIV_SET(0) +#define DDR_PLL_CONFIG_OUT_DIV_VAL2 DDR_PLL_CONFIG_OUTDIV_SET(0) +#define DDR_PLL_DITHER1_VAL DDR_PLL_DITHER1_DITHER_EN_SET(0) | \ + DDR_PLL_DITHER1_NFRAC_MIN_SET(0) | \ + DDR_PLL_DITHER1_NFRAC_STEP_SET(0) | \ + DDR_PLL_DITHER1_UPDATE_COUNT_SET(0x0) +#define DDR_PLL_DITHER2_VAL DDR_PLL_DITHER2_NFRAC_MAX_SET(0x0) +#define AHB_CLK_FROM_DDR CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_SET(0) +#define CPU_AND_DDR_CLK_FROM_DDR \ + CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_SET(0) +#define CPU_AND_DDR_CLK_FROM_CPU \ + CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_SET(0) +#define CPU_DDR_CLOCK_CONTROL_AHB_DIV_VAL \ + CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_SET(0x2) +#define CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV \ + CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_SET(0) +#define CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV \ + CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_SET(0) + +static inline void set_val(u32 _reg, u32 _mask, u32 _val) +{ + void __iomem *pll_regs = map_physmem(AR71XX_PLL_BASE, + AR71XX_PLL_SIZE, MAP_NOCACHE); + writel((readl(pll_regs + _reg) & (~(_mask))) | _val, pll_regs + _reg); +} + +#define cpu_pll_set(_mask, _val) \ + set_val(QCA956X_PLL_CPU_CONFIG_REG, _mask, _val) + +#define ddr_pll_set(_mask, _val) \ + set_val(QCA956X_PLL_DDR_CONFIG_REG, _mask, _val) + +#define cpu_ddr_control_set(_mask, _val) \ + set_val(QCA956X_PLL_CLK_CTRL_REG, _mask, _val) + +DECLARE_GLOBAL_DATA_PTR; + +static u32 qca956x_get_xtal(void) +{ + u32 val; + + val = ath79_get_bootstrap(); + if (val & QCA956X_BOOTSTRAP_REF_CLK_40) + return 40000000; + else + return 25000000; +} + +int get_serial_clock(void) +{ + return qca956x_get_xtal(); +} + +void qca956x_pll_init(void) +{ + void __iomem *srif_regs = map_physmem(QCA956X_SRIF_BASE, + QCA956X_SRIF_SIZE, MAP_NOCACHE); + void __iomem *pll_regs = map_physmem(AR71XX_PLL_BASE, + AR71XX_PLL_SIZE, MAP_NOCACHE); + + /* 8.16.2 Baseband DPLL2 */ + writel(PLL_SRIF_DPLL2_KI_SET(2) | PLL_SRIF_DPLL2_KD_SET(0xa) | + PLL_SRIF_DPLL2_PLL_PWD_SET(1) | PLL_SRIF_DPLL2_OUTDIV_SET(1) | + PLL_SRIF_DPLL2_PHASE_SHIFT_SET(6), srif_regs + QCA956X_SRIF_BB_DPLL2_REG); + + /* 8.16.2 PCIE DPLL2 */ + writel(PLL_SRIF_DPLL2_KI_SET(2) | PLL_SRIF_DPLL2_KD_SET(0xa) | + PLL_SRIF_DPLL2_PLL_PWD_SET(1) | PLL_SRIF_DPLL2_OUTDIV_SET(3) | + PLL_SRIF_DPLL2_PHASE_SHIFT_SET(6), srif_regs + QCA956X_SRIF_PCIE_DPLL2_REG); + + /* 8.16.2 DDR DPLL2 */ + writel(PLL_SRIF_DPLL2_KI_SET(2) | PLL_SRIF_DPLL2_KD_SET(0xa) | + PLL_SRIF_DPLL2_PLL_PWD_SET(1) | PLL_SRIF_DPLL2_PHASE_SHIFT_SET(6), + srif_regs + QCA956X_SRIF_DDR_DPLL2_REG); + + /* 8.16.2 CPU DPLL2 */ + writel(PLL_SRIF_DPLL2_KI_SET(1) | PLL_SRIF_DPLL2_KD_SET(7) | + PLL_SRIF_DPLL2_PLL_PWD_SET(1) | PLL_SRIF_DPLL2_PHASE_SHIFT_SET(6), + srif_regs + QCA956X_SRIF_CPU_DPLL2_REG); + + /* pll_bypass_set */ + cpu_ddr_control_set(CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_MASK, + CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_SET(1)); + cpu_ddr_control_set(CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_MASK, + CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_SET(1)); + cpu_ddr_control_set(CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_MASK, + CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_SET(1)); + + /* init_cpu_pll */ + cpu_pll_set(CPU_PLL_CONFIG_PLLPWD_MASK, CPU_PLL_CONFIG_PLLPWD_SET(1)); + cpu_pll_set(CPU_PLL_CONFIG_REFDIV_MASK, CPU_PLL_CONFIG_REF_DIV_VAL); + cpu_pll_set(CPU_PLL_CONFIG_RANGE_MASK, CPU_PLL_CONFIG_RANGE_VAL); + cpu_pll_set(CPU_PLL_CONFIG_OUTDIV_MASK, CPU_PLL_CONFIG_OUT_DIV_VAL1); + set_val(QCA956X_PLL_CPU_CONFIG1_REG, CPU_PLL_CONFIG1_NINT_MASK, \ + CPU_PLL_CONFIG1_NINT_VAL); + + /* init_ddr_pll */ + ddr_pll_set(DDR_PLL_CONFIG_PLLPWD_MASK, DDR_PLL_CONFIG_PLLPWD_SET(1)); + ddr_pll_set(DDR_PLL_CONFIG_REFDIV_MASK, DDR_PLL_CONFIG_REF_DIV_VAL); + ddr_pll_set(DDR_PLL_CONFIG_RANGE_MASK, DDR_PLL_CONFIG_RANGE_VAL); + ddr_pll_set(DDR_PLL_CONFIG_OUTDIV_MASK, DDR_PLL_CONFIG_OUT_DIV_VAL1); + set_val(QCA956X_PLL_DDR_CONFIG1_REG, DDR_PLL_CONFIG1_NINT_MASK, + DDR_PLL_CONFIG1_NINT_VAL); + + /* init_ahb_pll */ + writel(CPU_DDR_CLOCK_CONTROL_AHB_DIV_VAL | AHB_CLK_FROM_DDR | + CPU_AND_DDR_CLK_FROM_DDR | CPU_AND_DDR_CLK_FROM_CPU | + CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV | CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV | + CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_SET(1) | + CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_SET(1) | + CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_SET(1), pll_regs + QCA956X_PLL_CLK_CTRL_REG); + + /* ddr_pll_dither_unset */ + writel(DDR_PLL_DITHER1_VAL, pll_regs + QCA956X_PLL_DDR_DIT_FRAC_REG); + writel(DDR_PLL_DITHER2_VAL, pll_regs + QCA956X_PLL_DDR_DIT2_FRAC_REG); + + /* cpu_pll_dither_unset */ + writel(CPU_PLL_DITHER1_VAL, pll_regs + QCA956X_PLL_CPU_DIT_FRAC_REG); + writel(CPU_PLL_DITHER2_VAL, pll_regs + QCA956X_PLL_CPU_DIT2_FRAC_REG); + + /* pll_pwd_unset */ + cpu_pll_set(CPU_PLL_CONFIG_PLLPWD_MASK, CPU_PLL_CONFIG_PLLPWD_SET(0)); + ddr_pll_set(DDR_PLL_CONFIG_PLLPWD_MASK, DDR_PLL_CONFIG_PLLPWD_SET(0)); + + /* outdiv_unset */ + cpu_pll_set(CPU_PLL_CONFIG_OUTDIV_MASK, CPU_PLL_CONFIG_OUT_DIV_VAL2); + ddr_pll_set(DDR_PLL_CONFIG_OUTDIV_MASK, DDR_PLL_CONFIG_OUT_DIV_VAL2); + + /* pll_bypass_unset */ + cpu_ddr_control_set(CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_MASK, + CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_SET(0)); + cpu_ddr_control_set(CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_MASK, + CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_SET(0)); + cpu_ddr_control_set(CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_MASK, + CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_SET(0)); + + while (readl(pll_regs + QCA956X_PLL_CPU_CONFIG_REG) & 0x8000000) + /* NOP */; + + while (readl(pll_regs + QCA956X_PLL_DDR_CONFIG_REG) & 0x8000000) + /* NOP */; +} + +int get_clocks(void) +{ + void __iomem *regs; + u32 ref_rate, cpu_rate, ddr_rate, ahb_rate; + u32 out_div, ref_div, postdiv, nint, hfrac, lfrac, clk_ctrl; + u32 pll, cpu_pll, ddr_pll, misc; + + /* + * QCA956x timer init workaround has to be applied right before setting + * up the clock. Else, there will be no jiffies + */ + regs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, + MAP_NOCACHE); + misc = readl(regs + AR71XX_RESET_REG_MISC_INT_ENABLE); + misc |= MISC_INT_MIPS_SI_TIMERINT_MASK; + writel(misc, regs + AR71XX_RESET_REG_MISC_INT_ENABLE); + + regs = map_physmem(AR71XX_PLL_BASE, AR71XX_PLL_SIZE, + MAP_NOCACHE); + pll = readl(regs + QCA956X_PLL_CPU_CONFIG_REG); + out_div = (pll >> QCA956X_PLL_CPU_CONFIG_OUTDIV_SHIFT) & + QCA956X_PLL_CPU_CONFIG_OUTDIV_MASK; + ref_div = (pll >> QCA956X_PLL_CPU_CONFIG_REFDIV_SHIFT) & + QCA956X_PLL_CPU_CONFIG_REFDIV_MASK; + + pll = readl(regs + QCA956X_PLL_CPU_CONFIG1_REG); + nint = (pll >> QCA956X_PLL_CPU_CONFIG1_NINT_SHIFT) & + QCA956X_PLL_CPU_CONFIG1_NINT_MASK; + hfrac = (pll >> QCA956X_PLL_CPU_CONFIG1_NFRAC_H_SHIFT) & + QCA956X_PLL_CPU_CONFIG1_NFRAC_H_MASK; + lfrac = (pll >> QCA956X_PLL_CPU_CONFIG1_NFRAC_L_SHIFT) & + QCA956X_PLL_CPU_CONFIG1_NFRAC_L_MASK; + + ref_rate = qca956x_get_xtal(); + + cpu_pll = nint * ref_rate / ref_div; + cpu_pll += (lfrac * ref_rate) / ((ref_div * 25) << 13); + cpu_pll += (hfrac >> 13) * ref_rate / ref_div; + cpu_pll /= (1 << out_div); + + pll = readl(regs + QCA956X_PLL_DDR_CONFIG_REG); + out_div = (pll >> QCA956X_PLL_DDR_CONFIG_OUTDIV_SHIFT) & + QCA956X_PLL_DDR_CONFIG_OUTDIV_MASK; + ref_div = (pll >> QCA956X_PLL_DDR_CONFIG_REFDIV_SHIFT) & + QCA956X_PLL_DDR_CONFIG_REFDIV_MASK; + pll = readl(regs + QCA956X_PLL_DDR_CONFIG1_REG); + nint = (pll >> QCA956X_PLL_DDR_CONFIG1_NINT_SHIFT) & + QCA956X_PLL_DDR_CONFIG1_NINT_MASK; + hfrac = (pll >> QCA956X_PLL_DDR_CONFIG1_NFRAC_H_SHIFT) & + QCA956X_PLL_DDR_CONFIG1_NFRAC_H_MASK; + lfrac = (pll >> QCA956X_PLL_DDR_CONFIG1_NFRAC_L_SHIFT) & + QCA956X_PLL_DDR_CONFIG1_NFRAC_L_MASK; + + ddr_pll = nint * ref_rate / ref_div; + ddr_pll += (lfrac * ref_rate) / ((ref_div * 25) << 13); + ddr_pll += (hfrac >> 13) * ref_rate / ref_div; + ddr_pll /= (1 << out_div); + + clk_ctrl = readl(regs + QCA956X_PLL_CLK_CTRL_REG); + + postdiv = (clk_ctrl >> QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT) & + QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_MASK; + + if (clk_ctrl & QCA956X_PLL_CLK_CTRL_CPU_PLL_BYPASS) + cpu_rate = ref_rate; + else if (clk_ctrl & QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_CPUPLL) + cpu_rate = ddr_pll / (postdiv + 1); + else + cpu_rate = cpu_pll / (postdiv + 1); + + postdiv = (clk_ctrl >> QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT) & + QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_MASK; + + if (clk_ctrl & QCA956X_PLL_CLK_CTRL_DDR_PLL_BYPASS) + ddr_rate = ref_rate; + else if (clk_ctrl & QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_DDRPLL) + ddr_rate = cpu_pll / (postdiv + 1); + else + ddr_rate = ddr_pll / (postdiv + 1); + + postdiv = (clk_ctrl >> QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT) & + QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_MASK; + + if (clk_ctrl & QCA956X_PLL_CLK_CTRL_AHB_PLL_BYPASS) + ahb_rate = ref_rate; + else if (clk_ctrl & QCA956X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL) + ahb_rate = ddr_pll / (postdiv + 1); + else + ahb_rate = cpu_pll / (postdiv + 1); + + gd->cpu_clk = cpu_rate; + gd->mem_clk = ddr_rate; + gd->bus_clk = ahb_rate; + + debug("cpu_clk=%u, ddr_clk=%u, bus_clk=%u\n", + cpu_rate, ddr_rate, ahb_rate); + + return 0; +} + +ulong get_bus_freq(ulong dummy) +{ + if (!gd->bus_clk) + get_clocks(); + return gd->bus_clk; +} + +ulong get_ddr_freq(ulong dummy) +{ + if (!gd->mem_clk) + get_clocks(); + return gd->mem_clk; +} diff --git a/arch/mips/mach-ath79/qca956x/cpu.c b/arch/mips/mach-ath79/qca956x/cpu.c new file mode 100644 index 0000000000..08a8c84e72 --- /dev/null +++ b/arch/mips/mach-ath79/qca956x/cpu.c @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Rosy Song rosysong@rosinson.com + */ + +#include <common.h> + +/* The lowlevel_init() is not needed on QCA956X */ +void lowlevel_init(void) {} diff --git a/arch/mips/mach-ath79/qca956x/ddr.c b/arch/mips/mach-ath79/qca956x/ddr.c new file mode 100644 index 0000000000..fb2230430c --- /dev/null +++ b/arch/mips/mach-ath79/qca956x/ddr.c @@ -0,0 +1,308 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Rosy Song rosysong@rosinson.com + * + * Based on QSDK + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/ath79.h> + +#define DDR_FSM_WAIT_CTRL_VAL 0xa12 +#define DDR_CTL_CONFIG_SRAM_TSEL_LSB 30 +#define DDR_CTL_CONFIG_SRAM_TSEL_MASK 0xc0000000 +#define DDR_CTL_CONFIG_SRAM_TSEL_SET(x) \ + (((x) << DDR_CTL_CONFIG_SRAM_TSEL_LSB) & DDR_CTL_CONFIG_SRAM_TSEL_MASK) +#define DDR_CTL_CONFIG_GE0_SRAM_SYNC_LSB 20 +#define DDR_CTL_CONFIG_GE0_SRAM_SYNC_MASK 0x00100000 +#define DDR_CTL_CONFIG_GE0_SRAM_SYNC_SET(x) \ + (((x) << DDR_CTL_CONFIG_GE0_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_GE0_SRAM_SYNC_MASK) +#define DDR_CTL_CONFIG_GE1_SRAM_SYNC_LSB 19 +#define DDR_CTL_CONFIG_GE1_SRAM_SYNC_MASK 0x00080000 +#define DDR_CTL_CONFIG_GE1_SRAM_SYNC_SET(x) \ + (((x) << DDR_CTL_CONFIG_GE1_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_GE1_SRAM_SYNC_MASK) +#define DDR_CTL_CONFIG_USB_SRAM_SYNC_LSB 18 +#define DDR_CTL_CONFIG_USB_SRAM_SYNC_MASK 0x00040000 +#define DDR_CTL_CONFIG_USB_SRAM_SYNC_SET(x) \ + (((x) << DDR_CTL_CONFIG_USB_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_USB_SRAM_SYNC_MASK) +#define DDR_CTL_CONFIG_PCIE_SRAM_SYNC_LSB 17 +#define DDR_CTL_CONFIG_PCIE_SRAM_SYNC_MASK 0x00020000 +#define DDR_CTL_CONFIG_PCIE_SRAM_SYNC_SET(x) \ + (((x) << DDR_CTL_CONFIG_PCIE_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_PCIE_SRAM_SYNC_MASK) +#define DDR_CTL_CONFIG_WMAC_SRAM_SYNC_LSB 16 +#define DDR_CTL_CONFIG_WMAC_SRAM_SYNC_MASK 0x00010000 +#define DDR_CTL_CONFIG_WMAC_SRAM_SYNC_SET(x) \ + (((x) << DDR_CTL_CONFIG_WMAC_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_WMAC_SRAM_SYNC_MASK) +#define DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_LSB 15 +#define DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_MASK 0x00008000 +#define DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_SET(x) \ + (((x) << DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_MASK) +#define DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_LSB 14 +#define DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_MASK 0x00004000 +#define DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_SET(x) \ + (((x) << DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_MASK) +#define DDR_CTL_CONFIG_PAD_DDR2_SEL_LSB 6 +#define DDR_CTL_CONFIG_PAD_DDR2_SEL_MASK 0x00000040 +#define DDR_CTL_CONFIG_PAD_DDR2_SEL_SET(x) \ + (((x) << DDR_CTL_CONFIG_PAD_DDR2_SEL_LSB) & DDR_CTL_CONFIG_PAD_DDR2_SEL_MASK) +#define DDR_CTL_CONFIG_CPU_DDR_SYNC_LSB 2 +#define DDR_CTL_CONFIG_CPU_DDR_SYNC_MASK 0x00000004 +#define DDR_CTL_CONFIG_CPU_DDR_SYNC_SET(x) \ + (((x) << DDR_CTL_CONFIG_CPU_DDR_SYNC_LSB) & DDR_CTL_CONFIG_CPU_DDR_SYNC_MASK) +#define DDR_CTL_CONFIG_HALF_WIDTH_LSB 1 +#define DDR_CTL_CONFIG_HALF_WIDTH_MASK 0x00000002 +#define DDR_CTL_CONFIG_HALF_WIDTH_SET(x) \ + (((x) << DDR_CTL_CONFIG_HALF_WIDTH_LSB) & DDR_CTL_CONFIG_HALF_WIDTH_MASK) +#define DDR_CONFIG_CAS_LATENCY_MSB_LSB 31 +#define DDR_CONFIG_CAS_LATENCY_MSB_MASK 0x80000000 +#define DDR_CONFIG_CAS_LATENCY_MSB_SET(x) \ + (((x) << DDR_CONFIG_CAS_LATENCY_MSB_LSB) & DDR_CONFIG_CAS_LATENCY_MSB_MASK) +#define DDR_CONFIG_OPEN_PAGE_LSB 30 +#define DDR_CONFIG_OPEN_PAGE_MASK 0x40000000 +#define DDR_CONFIG_OPEN_PAGE_SET(x) \ + (((x) << DDR_CONFIG_OPEN_PAGE_LSB) & DDR_CONFIG_OPEN_PAGE_MASK) +#define DDR_CONFIG_CAS_LATENCY_LSB 27 +#define DDR_CONFIG_CAS_LATENCY_MASK 0x38000000 +#define DDR_CONFIG_CAS_LATENCY_SET(x) \ + (((x) << DDR_CONFIG_CAS_LATENCY_LSB) & DDR_CONFIG_CAS_LATENCY_MASK) +#define DDR_CONFIG_TMRD_LSB 23 +#define DDR_CONFIG_TMRD_MASK 0x07800000 +#define DDR_CONFIG_TMRD_SET(x) \ + (((x) << DDR_CONFIG_TMRD_LSB) & DDR_CONFIG_TMRD_MASK) +#define DDR_CONFIG_TRFC_LSB 17 +#define DDR_CONFIG_TRFC_MASK 0x007e0000 +#define DDR_CONFIG_TRFC_SET(x) \ + (((x) << DDR_CONFIG_TRFC_LSB) & DDR_CONFIG_TRFC_MASK) +#define DDR_CONFIG_TRRD_LSB 13 +#define DDR_CONFIG_TRRD_MASK 0x0001e000 +#define DDR_CONFIG_TRRD_SET(x) \ + (((x) << DDR_CONFIG_TRRD_LSB) & DDR_CONFIG_TRRD_MASK) +#define DDR_CONFIG_TRP_LSB 9 +#define DDR_CONFIG_TRP_MASK 0x00001e00 +#define DDR_CONFIG_TRP_SET(x) \ + (((x) << DDR_CONFIG_TRP_LSB) & DDR_CONFIG_TRP_MASK) +#define DDR_CONFIG_TRCD_LSB 5 +#define DDR_CONFIG_TRCD_MASK 0x000001e0 +#define DDR_CONFIG_TRCD_SET(x) \ + (((x) << DDR_CONFIG_TRCD_LSB) & DDR_CONFIG_TRCD_MASK) +#define DDR_CONFIG_TRAS_LSB 0 +#define DDR_CONFIG_TRAS_MASK 0x0000001f +#define DDR_CONFIG_TRAS_SET(x) \ + (((x) << DDR_CONFIG_TRAS_LSB) & DDR_CONFIG_TRAS_MASK) +#define DDR_CONFIG2_HALF_WIDTH_LOW_LSB 31 +#define DDR_CONFIG2_HALF_WIDTH_LOW_MASK 0x80000000 +#define DDR_CONFIG2_HALF_WIDTH_LOW_SET(x) \ + (((x) << DDR_CONFIG2_HALF_WIDTH_LOW_LSB) & DDR_CONFIG2_HALF_WIDTH_LOW_MASK) +#define DDR_CONFIG2_SWAP_A26_A27_LSB 30 +#define DDR_CONFIG2_SWAP_A26_A27_MASK 0x40000000 +#define DDR_CONFIG2_SWAP_A26_A27_SET(x) \ + (((x) << DDR_CONFIG2_SWAP_A26_A27_LSB) & DDR_CONFIG2_SWAP_A26_A27_MASK) +#define DDR_CONFIG2_GATE_OPEN_LATENCY_LSB 26 +#define DDR_CONFIG2_GATE_OPEN_LATENCY_MASK 0x3c000000 +#define DDR_CONFIG2_GATE_OPEN_LATENCY_SET(x) \ + (((x) << DDR_CONFIG2_GATE_OPEN_LATENCY_LSB) & DDR_CONFIG2_GATE_OPEN_LATENCY_MASK) +#define DDR_CONFIG2_TWTR_LSB 21 +#define DDR_CONFIG2_TWTR_MASK 0x03e00000 +#define DDR_CONFIG2_TWTR_SET(x) \ + (((x) << DDR_CONFIG2_TWTR_LSB) & DDR_CONFIG2_TWTR_MASK) +#define DDR_CONFIG2_TRTP_LSB 17 +#define DDR_CONFIG2_TRTP_MASK 0x001e0000 +#define DDR_CONFIG2_TRTP_SET(x) \ + (((x) << DDR_CONFIG2_TRTP_LSB) & DDR_CONFIG2_TRTP_MASK) +#define DDR_CONFIG2_TRTW_LSB 12 +#define DDR_CONFIG2_TRTW_MASK 0x0001f000 +#define DDR_CONFIG2_TRTW_SET(x) \ + (((x) << DDR_CONFIG2_TRTW_LSB) & DDR_CONFIG2_TRTW_MASK) +#define DDR_CONFIG2_TWR_LSB 8 +#define DDR_CONFIG2_TWR_MASK 0x00000f00 +#define DDR_CONFIG2_TWR_SET(x) \ + (((x) << DDR_CONFIG2_TWR_LSB) & DDR_CONFIG2_TWR_MASK) +#define DDR_CONFIG2_CKE_LSB 7 +#define DDR_CONFIG2_CKE_MASK 0x00000080 +#define DDR_CONFIG2_CKE_SET(x) \ + (((x) << DDR_CONFIG2_CKE_LSB) & DDR_CONFIG2_CKE_MASK) +#define DDR_CONFIG2_CNTL_OE_EN_LSB 5 +#define DDR_CONFIG2_CNTL_OE_EN_MASK 0x00000020 +#define DDR_CONFIG2_CNTL_OE_EN_SET(x) \ + (((x) << DDR_CONFIG2_CNTL_OE_EN_LSB) & DDR_CONFIG2_CNTL_OE_EN_MASK) +#define DDR_CONFIG2_BURST_LENGTH_LSB 0 +#define DDR_CONFIG2_BURST_LENGTH_MASK 0x0000000f +#define DDR_CONFIG2_BURST_LENGTH_SET(x) \ + (((x) << DDR_CONFIG2_BURST_LENGTH_LSB) & DDR_CONFIG2_BURST_LENGTH_MASK) +#define RST_BOOTSTRAP_ADDRESS 0x180600b0 +#define PMU2_SWREGMSB_LSB 22 +#define PMU2_SWREGMSB_MASK 0xffc00000 +#define PMU2_SWREGMSB_SET(x) \ + (((x) << PMU2_SWREGMSB_LSB) & PMU2_SWREGMSB_MASK) +#define PMU2_PGM_LSB 21 +#define PMU2_PGM_MASK 0x00200000 +#define PMU2_PGM_SET(x) \ + (((x) << PMU2_PGM_LSB) & PMU2_PGM_MASK) + +#define CPU_DDR_SYNC_MODE DDR_CTL_CONFIG_CPU_DDR_SYNC_SET(0) + +/* +* DDR2 DDR1 +* 0x40c3 25MHz 0x4186 25Mhz +* 0x4138 40MHz 0x4270 40Mhz +*/ +#define CFG_DDR2_REFRESH_VAL 0x40c3 +#define CFG_DDR2_CONFIG_VAL DDR_CONFIG_CAS_LATENCY_MSB_SET(0x1) | \ + DDR_CONFIG_OPEN_PAGE_SET(0x1) | DDR_CONFIG_CAS_LATENCY_SET(0x4) | \ + DDR_CONFIG_TMRD_SET(0x6) | DDR_CONFIG_TRFC_SET(0x16) | \ + DDR_CONFIG_TRRD_SET(0x7) | DDR_CONFIG_TRP_SET(0xb) | \ + DDR_CONFIG_TRCD_SET(0xb) | DDR_CONFIG_TRAS_SET(0) +#define CFG_DDR2_CONFIG2_VAL DDR_CONFIG2_HALF_WIDTH_LOW_SET(0x1) | \ + DDR_CONFIG2_SWAP_A26_A27_SET(0x0) | DDR_CONFIG2_GATE_OPEN_LATENCY_SET(0xa) | \ + DDR_CONFIG2_TWTR_SET(0x16) | DDR_CONFIG2_TRTP_SET(0xa) | \ + DDR_CONFIG2_TRTW_SET(0xe) | DDR_CONFIG2_TWR_SET(0x2) | \ + DDR_CONFIG2_CKE_SET(0x1) | DDR_CONFIG2_CNTL_OE_EN_SET(0x1) | \ + DDR_CONFIG2_BURST_LENGTH_SET(0x8) + +#define CFG_DDR2_CONFIG3_VAL 0x0000000e +#define CFG_DDR2_EXT_MODE_VAL1 0x782 +#define CFG_DDR2_EXT_MODE_VAL2 0x402 +#define CFG_DDR2_MODE_VAL_INIT 0xb53 +#define CFG_DDR2_MODE_VAL 0xa53 +#define CFG_DDR2_TAP_VAL 0x10 +#define CFG_DDR2_EN_TWL_VAL 0x00001e91 +#define CFG_DDR2_RD_DATA_THIS_CYCLE_VAL_16 0xffff + +#define CFG_DDR_CTL_CONFIG DDR_CTL_CONFIG_SRAM_TSEL_SET(0x1) | \ + DDR_CTL_CONFIG_GE0_SRAM_SYNC_SET(0x1) | \ + DDR_CTL_CONFIG_GE1_SRAM_SYNC_SET(0x1) | \ + DDR_CTL_CONFIG_USB_SRAM_SYNC_SET(0x1) | \ + DDR_CTL_CONFIG_PCIE_SRAM_SYNC_SET(0x1) | \ + DDR_CTL_CONFIG_WMAC_SRAM_SYNC_SET(0x1) | \ + DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_SET(0x1) | \ + DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_SET(0x1) + +DECLARE_GLOBAL_DATA_PTR; + +void qca956x_ddr_init(void) +{ + u32 ddr_config, ddr_config2, ddr_config3, mod_val, \ + mod_val_init, cycle_val, tap_val, ctl_config; + void __iomem *ddr_regs = map_physmem(AR71XX_DDR_CTRL_BASE, AR71XX_DDR_CTRL_SIZE, + MAP_NOCACHE); + void __iomem *srif_regs = map_physmem(QCA956X_SRIF_BASE, QCA956X_SRIF_SIZE, + MAP_NOCACHE); + + ddr_config = CFG_DDR2_CONFIG_VAL; + ddr_config2 = CFG_DDR2_CONFIG2_VAL; + ddr_config3 = CFG_DDR2_CONFIG3_VAL; + mod_val_init = CFG_DDR2_MODE_VAL_INIT; + mod_val = CFG_DDR2_MODE_VAL; + tap_val = CFG_DDR2_TAP_VAL; + cycle_val = CFG_DDR2_RD_DATA_THIS_CYCLE_VAL_16; + ctl_config = CFG_DDR_CTL_CONFIG | DDR_CTL_CONFIG_PAD_DDR2_SEL_SET(0x1) | + DDR_CTL_CONFIG_HALF_WIDTH_SET(0x1) | CPU_DDR_SYNC_MODE; + + writel(0x10, ddr_regs + AR71XX_DDR_REG_CONTROL); + udelay(10); + + writel(0x20, ddr_regs + AR71XX_DDR_REG_CONTROL); + udelay(10); + + writel(ctl_config, ddr_regs + QCA956X_DDR_REG_CTL_CONF); + udelay(10); + + writel(cycle_val, ddr_regs + AR71XX_DDR_REG_RD_CYCLE); + udelay(100); + + writel(0x74444444, ddr_regs + QCA956X_DDR_REG_BURST); + udelay(100); + + writel(0x44444444, ddr_regs + QCA956X_DDR_REG_BURST2); + udelay(100); + + writel(DDR_FSM_WAIT_CTRL_VAL, ddr_regs + QCA956X_DDR_REG_FSM_WAIT_CTRL); + udelay(100); + + writel(0xfffff, ddr_regs + QCA956X_DDR_REG_TIMEOUT_MAX); + udelay(100); + + writel(ddr_config, ddr_regs + AR71XX_DDR_REG_CONFIG); + udelay(100); + + writel(ddr_config2, ddr_regs + AR71XX_DDR_REG_CONFIG2); + udelay(100); + + writel(ddr_config3, ddr_regs + QCA956X_DDR_REG_DDR3_CONFIG); + udelay(100); + + writel(CFG_DDR2_EN_TWL_VAL, ddr_regs + QCA956X_DDR_REG_DDR2_CONFIG); + udelay(100); + + writel(ddr_config2 | 0x80, ddr_regs + AR71XX_DDR_REG_CONFIG2); /* CKE Enable */ + udelay(100); + + writel(0x8, ddr_regs + AR71XX_DDR_REG_CONTROL); /* Precharge */ + udelay(10); + + writel(0, ddr_regs + QCA956X_DDR_REG_DDR2_EMR2); + writel(0x10, ddr_regs + AR71XX_DDR_REG_CONTROL); /* EMR2 */ + udelay(10); + + writel(0, ddr_regs + QCA956X_DDR_REG_DDR2_EMR3); + writel(0x20, ddr_regs + AR71XX_DDR_REG_CONTROL); /* EMR3 */ + udelay(10); + + /* EMR DLL enable, Reduced Driver Impedance control, Differential DQS disabled */ + writel(CFG_DDR2_EXT_MODE_VAL2, ddr_regs + AR71XX_DDR_REG_EMR); + udelay(100); + + writel(0x2, ddr_regs + AR71XX_DDR_REG_CONTROL); /* EMR write */ + udelay(10); + + writel(mod_val_init, ddr_regs + AR71XX_DDR_REG_MODE); + udelay(1000); + + writel(0x1, ddr_regs + AR71XX_DDR_REG_CONTROL); /* MR Write */ + udelay(10); + + writel(0x8, ddr_regs + AR71XX_DDR_REG_CONTROL); /* Precharge */ + udelay(10); + + writel(0x4, ddr_regs + AR71XX_DDR_REG_CONTROL); /* Auto Refresh */ + udelay(10); + + writel(0x4, ddr_regs + AR71XX_DDR_REG_CONTROL); /* Auto Refresh */ + udelay(10); + + /* Issue MRS to remove DLL out-of-reset */ + writel(mod_val, ddr_regs + AR71XX_DDR_REG_MODE); + udelay(100); + + writel(0x1, ddr_regs + AR71XX_DDR_REG_CONTROL); /* MR write */ + udelay(100); + + writel(CFG_DDR2_EXT_MODE_VAL1, ddr_regs + AR71XX_DDR_REG_EMR); + udelay(100); + + writel(0x2, ddr_regs + AR71XX_DDR_REG_CONTROL); /* EMR write */ + udelay(100); + + writel(CFG_DDR2_EXT_MODE_VAL2, ddr_regs + AR71XX_DDR_REG_EMR); + udelay(100); + + writel(0x2, ddr_regs + AR71XX_DDR_REG_CONTROL); /* EMR write */ + udelay(100); + + writel(CFG_DDR2_REFRESH_VAL, ddr_regs + AR71XX_DDR_REG_REFRESH); + udelay(100); + + writel(tap_val, ddr_regs + AR71XX_DDR_REG_TAP_CTRL0); + writel(tap_val, ddr_regs + AR71XX_DDR_REG_TAP_CTRL1); + writel(tap_val, ddr_regs + QCA956X_DDR_REG_TAP_CTRL2); + writel(tap_val, ddr_regs + QCA956X_DDR_REG_TAP_CTRL3); + + writel(0x633c8176, srif_regs + QCA956X_SRIF_PMU1_REG); + /* Set DDR2 Voltage to 1.8 volts */ + writel(PMU2_SWREGMSB_SET(0x40) | PMU2_PGM_SET(0x1), + srif_regs + QCA956X_SRIF_PMU2_REG); +} diff --git a/arch/mips/mach-ath79/qca956x/qca956x-ddr-tap.S b/arch/mips/mach-ath79/qca956x/qca956x-ddr-tap.S new file mode 100644 index 0000000000..315ce6b395 --- /dev/null +++ b/arch/mips/mach-ath79/qca956x/qca956x-ddr-tap.S @@ -0,0 +1,193 @@ +/* SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Rosy Song rosysong@rosinson.com + * + * Based on QSDK + */ + +#include <config.h> +#include <asm/asm.h> +#include <asm/regdef.h> +#include <asm/mipsregs.h> +#include <asm/addrspace.h> +#include <mach/ar71xx_regs.h> + + .set noreorder + +LEAF(ddr_tap_tuning) + li a0, 0xbd001f00 + sw zero, 0x0(a0) /* Place where the tap values are saved and used for SWEEP */ + sw zero, 0x4(a0) /* Place where the number of passing taps are saved. */ + sw zero, 0x14(a0) /* Place where the last pass tap value is stored */ + li a1, 0xaa55aa55 /* Indicates that the First pass tap value is not found */ + sw a1, 0x10(a0) /* Place where the First pass tap value is stored */ + nop + + li a0, CKSEG1ADDR(AR71XX_RESET_BASE) /* RESET_BASE_ADDRESS */ + lw a1, 0x1c(a0) /* Reading the RST_RESET_ADDRESS */ + li a2, 0x08000000 /* Setting the RST_RESET_RTC_RESET */ + or a1, a1, a2 + sw a1, 0x1c(a0) + + li a3, 0xffffffff + xor a2, a2, a3 + and a1, a1, a2 + sw a1, 0x1c(a0) /* Taking the RTC out of RESET */ + nop + + li a0, CKSEG1ADDR(QCA956X_RTC_BASE) /* RTC_BASE_ADDRESS */ + li a1, 0x1 + sw a1, 0x0040(a0) /* RTC_SYNC_RESET_ADDRESS */ + + li a2, 0x2 + +_poll_for_RTC_ON: + lw a1, 0x0044(a0) /* RTC_SYNC_STATUS_ADDRESS */ + and a1, a2, a1 + bne a1, a2, _poll_for_RTC_ON + nop + +_CHANGE_TAPS: + li t0, 0xbd001f00 /* Read the current value of the TAP for programming */ + lw t1, 0x0(t0) + li t2, 0x00000000 + or t3, t1, t2 + + li t0, 0xb8000000 /* DDR_BASE_ADDRESS */ + sw t3, 0x1c(t0) /* TAP_CONTROL_0_ADDRESS */ + sw t3, 0x20(t0) /* TAP_CONTROL_1_ADDRESS */ + sw t3, 0x24(t0) /* TAP_CONTROL_2_ADDRESS */ + sw t3, 0x28(t0) /* TAP_CONTROL_3_ADDRESS */ + + li t1, 0x00000010 /* Running the test 8 times */ + sw t1, 0x0068(t0) /* PERF_COMP_ADDR_1_ADDRESS */ + + li t1, 0xfa5de83f /* 4 Row Address Bits, 4 Column Address Bits, 2 BA bits */ + sw t1, 0x002c(t0) /* PERF_MASK_ADDR_0_ADDRESS */ + + li t1, 0x0000ffff + sw t1, 0x0070(t0) /* PERF_COMP_AHB_GE0_1_ADDRESS */ + + li t1, 0x0000ffff + sw t1, 0x0040(t0) /* PERF_COMP_AHB_GE1_0_ADDRESS */ + + li t1, 0x0000ffff + sw t1, 0x0078(t0) /* PERF_COMP_AHB_GE1_1_ADDRESS */ + + li t1, 0x0000ffff + sw t1, 0x0034(t0) /* PERF_MASK_AHB_GE0_0_ADDRESS */ + + li t1, 0x0000ffff + sw t1, 0x006c(t0) /* PERF_MASK_AHB_GE0_1_ADDRESS */ + + li t1, 0x0000ffff + sw t1, 0x003c(t0) /* PERF_MASK_AHB_GE1_0_ADDRESS */ + + li t1, 0x0000ffff + sw t1, 0x0074(t0) /* PERF_MASK_AHB_GE1_1_ADDRESS */ + + li t1, 0x0000ffff + sw t1, 0x0038(t0) /* PERF_COMP_AHB_GE0_0_ADDRESS */ + + li t1, 0x00000001 + sw t1, 0x011c(t0) /* DDR_BIST_ADDRESS */ + + li t2, 0x1 + +_bist_done_poll: + lw t1, 0x0120(t0) /* DDR_BIST_STATUS_ADDRESS */ + and t1, t1, t2 + bne t1, t2, _bist_done_poll + nop + + lw t1, 0x0120(t0) /* DDR_BIST_STATUS_ADDRESS */ + li t4, 0x000001fe + and t2, t1, t4 + srl t2, t2, 0x1 /* no. of Pass Runs */ + + li t5, 0x00000000 + sw t5, 0x011c(t0) /* DDR_BIST_ADDRESS - Stop the DDR BIST test */ + + li t5, 0x0001fe00 + and t5, t5, t1 + bnez t5, _iterate_tap /* This is a redundant compare but nevertheless - Comparing the FAILS */ + nop + + lw t1, 0x0068(t0) /* PERF_COMP_ADDR_1_ADDRESS */ + li t3, 0x000001fe + and t3, t3, t1 + srl t3, t3, 0x1 /* No. of runs in the config register. */ + bne t3, t2, _iterate_tap + nop + +pass_tap: + li t0, 0xbd001f00 + lw t1, 0x4(t0) + addiu t1, t1, 0x1 + sw t1, 0x4(t0) + + li t0, 0xbd001f10 + lw t1, 0x0(t0) + li t2, 0xaa55aa55 + beq t1, t2, _first_pass + nop + + li t0, 0xbd001f00 + lw t1, 0x0(t0) + li t0, 0xbd001f10 + sw t1, 0x4(t0) + nop + b _iterate_tap + nop + +_first_pass: + li t0, 0xbd001f00 + lw t1, 0x0(t0) + li t0, 0xbd001f10 + sw t1, 0x0(t0) + sw t1, 0x4(t0) + nop + +_iterate_tap: + li t0, 0xbd001f00 + lw t1, 0x0(t0) + li t2, 0x3f + beq t1, t2, _STOP_TEST + nop + + addiu t1, t1, 0x1 + sw t1, 0x0(t0) + nop + b _CHANGE_TAPS + nop + +_STOP_TEST: + li t0, 0xbd001f00 + lw t1, 0x4(t0) + bnez t1, _load_center_tap + nop + + li t3, 0x8 /* Default Tap to be used */ + b _load_tap_into_reg + nop + +_load_center_tap: + li t0, 0xbd001f10 + lw t1, 0x0(t0) + lw t2, 0x4(t0) + add t3, t1, t2 + srl t3, t3, 0x1 + li t4, 0x3f + and t3, t3, t4 + +_load_tap_into_reg: + li t0, 0xb8000000 + sw t3, 0x1c(t0) /* TAP_CONTROL_0_ADDRESS */ + sw t3, 0x20(t0) /* TAP_CONTROL_1_ADDRESS */ + sw t3, 0x24(t0) /* TAP_CONTROL_2_ADDRESS */ + sw t3, 0x28(t0) /* TAP_CONTROL_3_ADDRESS */ + + nop + jr ra + nop + END(ddr_tap_tuning) diff --git a/arch/mips/mach-ath79/reset.c b/arch/mips/mach-ath79/reset.c index 6a94d886f9..0ab3ab6383 100644 --- a/arch/mips/mach-ath79/reset.c +++ b/arch/mips/mach-ath79/reset.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2015-2016 Wills Wang wills.wang@live.com + * Copyright (C) 2018-2019 Rosy Song rosysong@rosinson.com */
#include <common.h> @@ -11,6 +12,44 @@ #include <mach/ath79.h> #include <mach/ar71xx_regs.h>
+/* QCA956X ETH_SGMII_SERDES Registers */ +#define SGMII_SERDES_RES_CALIBRATION_LSB 23 +#define SGMII_SERDES_RES_CALIBRATION_MASK 0x07800000 +#define SGMII_SERDES_RES_CALIBRATION_SET(x) \ + (((x) << SGMII_SERDES_RES_CALIBRATION_LSB) & SGMII_SERDES_RES_CALIBRATION_MASK) +#define SGMII_SERDES_CDR_BW_LSB 1 +#define SGMII_SERDES_CDR_BW_MASK 0x00000006 +#define SGMII_SERDES_CDR_BW_SET(x) \ + (((x) << SGMII_SERDES_CDR_BW_LSB) & SGMII_SERDES_CDR_BW_MASK) +#define SGMII_SERDES_TX_DR_CTRL_LSB 4 +#define SGMII_SERDES_TX_DR_CTRL_MASK 0x00000070 +#define SGMII_SERDES_TX_DR_CTRL_SET(x) \ + (((x) << SGMII_SERDES_TX_DR_CTRL_LSB) & SGMII_SERDES_TX_DR_CTRL_MASK) +#define SGMII_SERDES_PLL_BW_LSB 8 +#define SGMII_SERDES_PLL_BW_MASK 0x00000100 +#define SGMII_SERDES_PLL_BW_SET(x) \ + (((x) << SGMII_SERDES_PLL_BW_LSB) & SGMII_SERDES_PLL_BW_MASK) +#define SGMII_SERDES_EN_SIGNAL_DETECT_LSB 16 +#define SGMII_SERDES_EN_SIGNAL_DETECT_MASK 0x00010000 +#define SGMII_SERDES_EN_SIGNAL_DETECT_SET(x) \ + (((x) << SGMII_SERDES_EN_SIGNAL_DETECT_LSB) & SGMII_SERDES_EN_SIGNAL_DETECT_MASK) +#define SGMII_SERDES_FIBER_SDO_LSB 17 +#define SGMII_SERDES_FIBER_SDO_MASK 0x00020000 +#define SGMII_SERDES_FIBER_SDO_SET(x) \ + (((x) << SGMII_SERDES_FIBER_SDO_LSB) & SGMII_SERDES_FIBER_SDO_MASK) +#define SGMII_SERDES_VCO_REG_LSB 27 +#define SGMII_SERDES_VCO_REG_MASK 0x78000000 +#define SGMII_SERDES_VCO_REG_SET(x) \ + (((x) << SGMII_SERDES_VCO_REG_LSB) & SGMII_SERDES_VCO_REG_MASK) +#define SGMII_SERDES_VCO_FAST_LSB 9 +#define SGMII_SERDES_VCO_FAST_MASK 0x00000200 +#define SGMII_SERDES_VCO_FAST_GET(x) \ + (((x) & SGMII_SERDES_VCO_FAST_MASK) >> SGMII_SERDES_VCO_FAST_LSB) +#define SGMII_SERDES_VCO_SLOW_LSB 10 +#define SGMII_SERDES_VCO_SLOW_MASK 0x00000400 +#define SGMII_SERDES_VCO_SLOW_GET(x) \ + (((x) & SGMII_SERDES_VCO_SLOW_MASK) >> SGMII_SERDES_VCO_SLOW_LSB) + void _machine_restart(void) { void __iomem *base; @@ -152,6 +191,236 @@ static int eth_init_qca953x(void) return 0; }
+static int qca956x_sgmii_cal(void) +{ + int i; + u32 reg, rev_sgmii_val; + u32 vco_fast, vco_slow; + u32 start_val = 0, end_val = 0; + void __iomem *gregs = map_physmem(AR71XX_MII_BASE, AR71XX_MII_SIZE, + MAP_NOCACHE); + void __iomem *pregs = map_physmem(AR71XX_PLL_BASE, AR71XX_PLL_SIZE, + MAP_NOCACHE); + void __iomem *rregs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, + MAP_NOCACHE); + const u32 mask = QCA956X_RESET_SGMII_ASSERT | QCA956X_RESET_SGMII; + + writel(BIT(2) | BIT(0), pregs + QCA956X_PLL_ETH_SGMII_SERDES_REG); + + reg = readl(gregs + QCA956X_GMAC_REG_SGMII_SERDES); + vco_fast = SGMII_SERDES_VCO_FAST_GET(reg); + vco_slow = SGMII_SERDES_VCO_SLOW_GET(reg); + + /* Set resistor calibration from 0000 to 1111 */ + for (i = 0; i < 0x10; i++) { + reg = (readl(gregs + QCA956X_GMAC_REG_SGMII_SERDES) & + ~SGMII_SERDES_RES_CALIBRATION_MASK) | + SGMII_SERDES_RES_CALIBRATION_SET(i); + writel(reg, gregs + QCA956X_GMAC_REG_SGMII_SERDES); + + udelay(50); + + reg = readl(gregs + QCA956X_GMAC_REG_SGMII_SERDES); + if (vco_fast != SGMII_SERDES_VCO_FAST_GET(reg) || + vco_slow != SGMII_SERDES_VCO_SLOW_GET(reg)) { + if (start_val == 0) { + start_val = i; + end_val = i; + } else { + end_val = i; + } + } + vco_fast = SGMII_SERDES_VCO_FAST_GET(reg); + vco_slow = SGMII_SERDES_VCO_SLOW_GET(reg); + } + + if (start_val == 0) + rev_sgmii_val = 0x7; + else + rev_sgmii_val = (start_val + end_val) >> 1; + + writel((readl(gregs + QCA956X_GMAC_REG_SGMII_SERDES) & + ~SGMII_SERDES_RES_CALIBRATION_MASK) | + SGMII_SERDES_RES_CALIBRATION_SET(rev_sgmii_val), + gregs + QCA956X_GMAC_REG_SGMII_SERDES); + + writel(BIT(2) | BIT(0), pregs + QCA956X_PLL_ETH_SGMII_SERDES_REG); + + reg = readl(gregs + QCA956X_GMAC_REG_SGMII_SERDES); + writel(SGMII_SERDES_CDR_BW_SET(3) | SGMII_SERDES_TX_DR_CTRL_SET(1) | + SGMII_SERDES_PLL_BW_SET(1) | SGMII_SERDES_EN_SIGNAL_DETECT_SET(1) | + SGMII_SERDES_FIBER_SDO_SET(1) | SGMII_SERDES_VCO_REG_SET(3) | reg, + gregs + QCA956X_GMAC_REG_SGMII_SERDES); + + setbits_be32(rregs + QCA956X_RESET_REG_RESET_MODULE, mask); + mdelay(1); + clrbits_be32(rregs + QCA956X_RESET_REG_RESET_MODULE, mask); + mdelay(1); + + while (!(readl(gregs + QCA956X_GMAC_REG_SGMII_SERDES) & BIT(15))) + /* NOP */; + + return 0; +} + +static int qca956x_sgmii_setup(void) +{ + int i; + u32 s = 0, reg = 0; + u32 _regs[] = { + BIT(4), /* HW_RX_125M_N */ + BIT(2), /* RX_125M_N */ + BIT(3), /* TX_125M_N */ + BIT(0), /* RX_CLK_N */ + BIT(1), /* TX_CLK_N */ + }; + void __iomem *gregs = map_physmem(AR71XX_MII_BASE, AR71XX_MII_SIZE, + MAP_NOCACHE); + + /* Force sgmii mode */ + writel(BIT(6) | BIT(15) | BIT(8), gregs + QCA956X_GMAC_REG_MR_AN_CTRL); + udelay(10); + writel(0x2 | BIT(5) | (0x2 << 6), gregs + QCA956X_GMAC_REG_SGMII_CONFIG); + + /* SGMII reset sequence sugguest by qca systems team. */ + writel(0, gregs + QCA956X_GMAC_REG_SGMII_RESET); + for (i = 0; i < ARRAY_SIZE(_regs); i++) { + reg |= _regs[i]; + writel(reg, gregs + QCA956X_GMAC_REG_SGMII_RESET); + } + + writel(readl(gregs + QCA956X_GMAC_REG_MR_AN_CTRL) & ~BIT(15), + gregs + QCA956X_GMAC_REG_MR_AN_CTRL); + + /* + * WARNING: Across resets SGMII link status goes to weird state. + * if 0xb8070058 (SGMII_DEBUG Register) reads other than 0xf or 0x10 + * for sure we are in bad state. + * Issue a PHY RESET in MR_AN_CONTROL_ADDRESS to keep going. + */ + i = 0; + s = (readl(gregs + QCA956X_GMAC_REG_SGMII_DEBUG) & 0xff); + while (!(s == 0xf || s == 0x10)) { + writel(readl(gregs + QCA956X_GMAC_REG_MR_AN_CTRL) | BIT(15), + gregs + QCA956X_GMAC_REG_MR_AN_CTRL); + udelay(100); + writel(readl(gregs + QCA956X_GMAC_REG_MR_AN_CTRL) & ~BIT(15), + gregs + QCA956X_GMAC_REG_MR_AN_CTRL); + if (i++ == 10) + break; + s = (readl(gregs + QCA956X_GMAC_REG_SGMII_DEBUG) & 0xff); + } + + return 0; +} + +static int qca956x_s17_reset(void) +{ + void __iomem *regs = map_physmem(AR71XX_GPIO_BASE, AR71XX_GPIO_SIZE, + MAP_NOCACHE); + void __iomem *rregs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, + MAP_NOCACHE); + const u32 mask = QCA956X_RESET_SGMII_ASSERT | QCA956X_RESET_SGMII | + QCA956X_RESET_EXTERNAL | QCA956X_RESET_SGMII_ANALOG | + QCA956X_RESET_SWITCH; + /* Bits(Reserved in datasheet) should be set to 1 */ + const u32 mask_r = QCA956X_RESET_SGMII_ASSERT | QCA956X_RESET_SGMII | + QCA956X_RESET_EXTERNAL; + + setbits_be32(rregs + QCA956X_RESET_REG_RESET_MODULE, mask); + mdelay(1); + clrbits_be32(rregs + QCA956X_RESET_REG_RESET_MODULE, mask_r); + mdelay(1); + + /* Reset s17 switch(GPIO11) SYS_RST_L */ + writel(readl(regs + AR71XX_GPIO_REG_OE) & ~BIT(11), + regs + AR71XX_GPIO_REG_OE); + udelay(100); + + writel(readl(regs + AR71XX_GPIO_REG_OUT) & ~BIT(11), + regs + AR71XX_GPIO_REG_OUT); + udelay(100); + writel(readl(regs + AR71XX_GPIO_REG_OUT) | BIT(11), + regs + AR71XX_GPIO_REG_OUT); + + return 0; +} + +static int qca956x_init_mdio(void) +{ + u32 reg; + void __iomem *regs = map_physmem(AR71XX_GPIO_BASE, AR71XX_GPIO_SIZE, + MAP_NOCACHE); + void __iomem *rregs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE, + MAP_NOCACHE); + const u32 mask = QCA956X_RESET_GE0_MDIO | QCA956X_RESET_GE0_MAC | + QCA956X_RESET_GE1_MDIO | QCA956X_RESET_GE1_MAC; + + setbits_be32(rregs + QCA956X_RESET_REG_RESET_MODULE, mask); + mdelay(1); + clrbits_be32(rregs + QCA956X_RESET_REG_RESET_MODULE, mask); + mdelay(1); + + /* GPIO4 as MDI */ + reg = readl(regs + QCA956X_GPIO_REG_IN_ENABLE3); + reg &= ~(0xff << 16); + reg |= (0x4 << 16); + writel(reg, regs + QCA956X_GPIO_REG_IN_ENABLE3); + + /* GPIO4 as MDO */ + reg = readl(regs + QCA956X_GPIO_REG_OUT_FUNC1); + reg &= ~0xff; + reg |= 0x20; + writel(reg, regs + QCA956X_GPIO_REG_OUT_FUNC1); + + /* Init MDC(GPIO3) / MDIO(GPIO4) */ + reg = readl(regs + AR71XX_GPIO_REG_OE); + reg &= ~BIT(4); + writel(reg, regs + AR71XX_GPIO_REG_OE); + udelay(100); + + reg = readl(regs + AR71XX_GPIO_REG_OE); + reg &= ~BIT(3); + writel(reg, regs + AR71XX_GPIO_REG_OE); + udelay(100); + + /* GPIO3 as MDI */ + reg = readl(regs + QCA956X_GPIO_REG_OUT_FUNC0); + reg &= ~(0xff << 24); + reg |= (0x21 << 24); + writel(reg, regs + QCA956X_GPIO_REG_OUT_FUNC0); + + return 0; +} + +static int eth_init_qca956x(void) +{ + void __iomem *pregs = map_physmem(AR71XX_PLL_BASE, AR71XX_PLL_SIZE, + MAP_NOCACHE); + void __iomem *gregs = map_physmem(AR71XX_MII_BASE, AR71XX_MII_SIZE, + MAP_NOCACHE); + + qca956x_sgmii_cal(); + qca956x_s17_reset(); + qca956x_init_mdio(); + + if (ath79_get_bootstrap() & QCA956X_BOOTSTRAP_REF_CLK_40) + writel(0x45500, pregs + QCA956X_PLL_SWITCH_CLK_CTRL_REG); + else + writel(0xc5200, pregs + QCA956X_PLL_SWITCH_CLK_CTRL_REG); + + qca956x_sgmii_setup(); + + writel((3 << 16) | (3 << 14) | (1 << 0) | (1 << 6), + gregs + QCA956X_GMAC_REG_ETH_CFG); + + writel((1 << 31) | (2 << 28) | (2 << 26) | (1 << 25), + pregs + QCA956X_PLL_ETH_XMII_CTRL_REG); + mdelay(1); + + return 0; +} + int ath79_eth_reset(void) { /* @@ -164,6 +433,8 @@ int ath79_eth_reset(void) return eth_init_ar934x(); if (soc_is_qca953x()) return eth_init_qca953x(); + if (soc_is_qca956x()) + return eth_init_qca956x();
return -EINVAL; } diff --git a/board/qca/ap152/Kconfig b/board/qca/ap152/Kconfig new file mode 100644 index 0000000000..f6ad498e85 --- /dev/null +++ b/board/qca/ap152/Kconfig @@ -0,0 +1,15 @@ +if TARGET_AP152 + +config SYS_VENDOR + default "qca" + +config SYS_BOARD + default "ap152" + +config SYS_CONFIG_NAME + default "ap152" + +config SYS_TEXT_BASE + default 0x9f000000 + +endif diff --git a/board/qca/ap152/MAINTAINERS b/board/qca/ap152/MAINTAINERS new file mode 100644 index 0000000000..785ec2766d --- /dev/null +++ b/board/qca/ap152/MAINTAINERS @@ -0,0 +1,6 @@ +AP152 BOARD +M: Rosy Song rosysong@rosinson.com +S: Maintained +F: board/qca/ap152/ +F: include/configs/ap152.h +F: configs/ap152_defconfig diff --git a/board/qca/ap152/Makefile b/board/qca/ap152/Makefile new file mode 100644 index 0000000000..4270afa129 --- /dev/null +++ b/board/qca/ap152/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y = ap152.o diff --git a/board/qca/ap152/ap152.c b/board/qca/ap152/ap152.c new file mode 100644 index 0000000000..30cd56563b --- /dev/null +++ b/board/qca/ap152/ap152.c @@ -0,0 +1,81 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Rosy Song rosysong@rosinson.com + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/ddr.h> +#include <mach/ath79.h> +#include <debug_uart.h> + +#define RST_RESET_RTC_RESET_LSB 27 +#define RST_RESET_RTC_RESET_MASK 0x08000000 +#define RST_RESET_RTC_RESET_SET(x) \ + (((x) << RST_RESET_RTC_RESET_LSB) & RST_RESET_RTC_RESET_MASK) + +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) +{ + void __iomem *regs; + u32 val; + + regs = map_physmem(AR71XX_GPIO_BASE, AR71XX_GPIO_SIZE, + MAP_NOCACHE); + + /* UART : RX18, TX22 done + * GPIO18 as input, GPIO22 as output + */ + val = readl(regs + AR71XX_GPIO_REG_OE); + val |= QCA956X_GPIO(18); + val &= ~QCA956X_GPIO(22); + writel(val, regs + AR71XX_GPIO_REG_OE); + + /* + * Enable GPIO22 as UART0_SOUT + */ + val = readl(regs + QCA956X_GPIO_REG_OUT_FUNC5); + val &= ~QCA956X_GPIO_MUX_MASK(16); + val |= QCA956X_GPIO_OUT_MUX_UART0_SOUT << 16; + writel(val, regs + QCA956X_GPIO_REG_OUT_FUNC5); + + /* + * Enable GPIO18 as UART0_SIN + */ + val = readl(regs + QCA956X_GPIO_REG_IN_ENABLE0); + val &= ~QCA956X_GPIO_MUX_MASK(8); + val |= QCA956X_GPIO_IN_MUX_UART0_SIN << 8; + writel(val, regs + QCA956X_GPIO_REG_IN_ENABLE0); + + /* + * Enable GPIO22 output + */ + val = readl(regs + AR71XX_GPIO_REG_OUT); + val |= QCA956X_GPIO(22); + writel(val, regs + AR71XX_GPIO_REG_OUT); +} +#endif + +int board_early_init_f(void) +{ + u32 reg; + void __iomem *rst_regs = map_physmem(AR71XX_RESET_BASE, + AR71XX_RESET_SIZE, MAP_NOCACHE); + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + /* CPU:775, DDR:650, AHB:258 */ + qca956x_pll_init(); + qca956x_ddr_init(); +#endif + + /* Take WMAC out of reset */ + reg = readl(rst_regs + QCA956X_RESET_REG_RESET_MODULE); + reg &= (~RST_RESET_RTC_RESET_SET(1)); + writel(reg, rst_regs + QCA956X_RESET_REG_RESET_MODULE); + + ath79_eth_reset(); + return 0; +} diff --git a/configs/ap152_defconfig b/configs/ap152_defconfig new file mode 100644 index 0000000000..21cb6eb742 --- /dev/null +++ b/configs/ap152_defconfig @@ -0,0 +1,49 @@ +CONFIG_MIPS=y +CONFIG_SYS_TEXT_BASE=0x9F000000 +CONFIG_SYS_MALLOC_F_LEN=0x800 +CONFIG_SYS_CACHE_SIZE_AUTO=y +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_BASE=0xb8020000 +CONFIG_DEBUG_UART_CLOCK=25000000 +CONFIG_ARCH_ATH79=y +CONFIG_TARGET_AP152=y +CONFIG_DEBUG_UART=y +CONFIG_BOOTDELAY=3 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/mtdblock2 rootfstype=squashfs" +CONFIG_DISPLAY_CPUINFO=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_PROMPT="ap152 # " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi-flash.0" +CONFIG_MTDPARTS_DEFAULT="mtdparts=spi-flash.0:256k(u-boot),64k(u-boot-env),6336k(rootfs),1472k(uImage),64k(ART)" +# CONFIG_ISO_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="ap152" +CONFIG_ENV_IS_IN_SPI_FLASH=y +# CONFIG_NET is not set +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_PINCTRL=y +CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_ATH79_SPI=y +CONFIG_LZMA=y diff --git a/include/configs/ap152.h b/include/configs/ap152.h new file mode 100644 index 0000000000..bc88506dff --- /dev/null +++ b/include/configs/ap152.h @@ -0,0 +1,54 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Rosy Song rosysong@rosinson.com + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_MHZ 375 +#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_MALLOC_LEN 0x40000 +#define CONFIG_SYS_BOOTPARAMS_LEN 0x20000 + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_LOAD_ADDR 0x81000000 + +#define CONFIG_SYS_INIT_RAM_ADDR 0xbd000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x2000 +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE - 1) + +/* + * Serial Port + */ +#define CONFIG_SYS_NS16550_CLK 25000000 +#define CONFIG_SYS_BAUDRATE_TABLE \ + {9600, 19200, 38400, 57600, 115200} + +#define CONFIG_BOOTCOMMAND "sf probe;" \ + "mtdparts default;" \ + "bootm 0x9f060000" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "ipaddr=192.168.1.1\0" \ + "serverip=192.168.1.10\0" \ + +#define CONFIG_ENV_SPI_MAX_HZ 25000000 +#define CONFIG_ENV_OFFSET 0x40000 +#define CONFIG_ENV_SECT_SIZE 0x10000 +#define CONFIG_ENV_SIZE 0x10000 + +/* Miscellaneous configurable options */ + +/* + * Diagnostics + */ +#define CONFIG_SYS_MEMTEST_START 0x80100000 +#define CONFIG_SYS_MEMTEST_END 0x83f00000 + +#endif /* __CONFIG_H */
Am 05.03.19 um 08:04 schrieb rosysong@rosinson.com:
Signed-off-by: Rosy Song rosysong@rosinson.com
as requested in the last review, please provide a proper commit message. You also need to provide a changelog if you submit an updated series.
Maybe you should read this: https://www.denx.de/wiki/U-Boot/Patches
arch/mips/dts/Makefile | 1 + arch/mips/dts/ap152.dts | 48 ++ arch/mips/dts/qca956x.dtsi | 87 ++++ arch/mips/mach-ath79/Kconfig | 14 + arch/mips/mach-ath79/Makefile | 1 + .../mach-ath79/include/mach/ar71xx_regs.h | 73 +++ arch/mips/mach-ath79/include/mach/ath79.h | 3 + arch/mips/mach-ath79/qca956x/Makefile | 5 + arch/mips/mach-ath79/qca956x/clk.c | 419 ++++++++++++++++++ arch/mips/mach-ath79/qca956x/cpu.c | 9 + arch/mips/mach-ath79/qca956x/ddr.c | 308 +++++++++++++ .../mips/mach-ath79/qca956x/qca956x-ddr-tap.S | 193 ++++++++ arch/mips/mach-ath79/reset.c | 271 +++++++++++ board/qca/ap152/Kconfig | 15 + board/qca/ap152/MAINTAINERS | 6 + board/qca/ap152/Makefile | 3 + board/qca/ap152/ap152.c | 81 ++++ configs/ap152_defconfig | 49 ++ include/configs/ap152.h | 54 +++ 19 files changed, 1640 insertions(+) create mode 100644 arch/mips/dts/ap152.dts create mode 100644 arch/mips/dts/qca956x.dtsi create mode 100644 arch/mips/mach-ath79/qca956x/Makefile create mode 100644 arch/mips/mach-ath79/qca956x/clk.c create mode 100644 arch/mips/mach-ath79/qca956x/cpu.c create mode 100644 arch/mips/mach-ath79/qca956x/ddr.c create mode 100644 arch/mips/mach-ath79/qca956x/qca956x-ddr-tap.S create mode 100644 board/qca/ap152/Kconfig create mode 100644 board/qca/ap152/MAINTAINERS create mode 100644 board/qca/ap152/Makefile create mode 100644 board/qca/ap152/ap152.c create mode 100644 configs/ap152_defconfig create mode 100644 include/configs/ap152.h
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index b94b582837..621c35f0ef 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -2,6 +2,7 @@
dtb-$(CONFIG_TARGET_AP121) += ap121.dtb dtb-$(CONFIG_TARGET_AP143) += ap143.dtb +dtb-$(CONFIG_TARGET_AP152) += ap152.dtb dtb-$(CONFIG_TARGET_BOSTON) += img,boston.dtb dtb-$(CONFIG_TARGET_MALTA) += mti,malta.dtb dtb-$(CONFIG_TARGET_PIC32MZDASK) += pic32mzda_sk.dtb diff --git a/arch/mips/dts/ap152.dts b/arch/mips/dts/ap152.dts new file mode 100644 index 0000000000..1722290c73 --- /dev/null +++ b/arch/mips/dts/ap152.dts @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2018 Rosy Song rosysong@rosinson.com
+/dts-v1/; +#include "qca956x.dtsi"
- model = "AP152 Reference Board";
- compatible = "qca,ap152", "qca,qca956x";
- aliases {
spi0 = &spi0;
serial0 = &uart0;
- chosen {
stdout-path = "serial0:115200n8";
+&gmac0 {
- phy-mode = "sgmii";
- status = "okay";
+&xtal {
- clock-frequency = <25000000>;
+&uart0 {
- status = "okay";
+&spi0 {
- spi-max-frequency = <25000000>;
- status = "okay";
- spi-flash@0 {
#address-cells = <1>;
#size-cells = <1>;
compatible = "spi-flash";
memory-map = <0x9f000000 0x01000000>;
reg = <0>;
+}; diff --git a/arch/mips/dts/qca956x.dtsi b/arch/mips/dts/qca956x.dtsi new file mode 100644 index 0000000000..6cb360b3f8 --- /dev/null +++ b/arch/mips/dts/qca956x.dtsi @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+#include "skeleton.dtsi"
- compatible = "qca,qca956x";
- #address-cells = <1>;
- #size-cells = <1>;
- cpus {
#size-cells = <0>;
cpu@0 {
device_type = "cpu";
compatible = "mips,mips74Kc";
reg = <0>;
- clocks {
#size-cells = <1>;
ranges;
xtal: xtal {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-output-names = "xtal";
- ahb {
compatible = "simple-bus";
ranges;
#size-cells = <1>;
apb {
ranges;
#size-cells = <1>;
uart0: uart@18020000 {
compatible = "ns16550";
reg = <0x18020000 0x20>;
reg-shift = <2>;
status = "disabled";
gmac0: eth@0x19000000 {
compatible = "qca,ag956x-mac";
reg = <0x19000000 0x200>;
phy = <&phy0>;
phy-mode = "sgmii";
mdio {
#size-cells = <0>;
phy0: ethernet-phy@0 {
reg = <0>;
spi0: spi@1f000000 {
compatible = "qca,ar7100-spi";
reg = <0x1f000000 0x10>;
#size-cells = <0>;
+}; diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig index bc86f591df..bdb23b5765 100644 --- a/arch/mips/mach-ath79/Kconfig +++ b/arch/mips/mach-ath79/Kconfig @@ -33,6 +33,15 @@ config SOC_QCA953X help This supports QCA/Atheros qca953x family SOCs.
+config SOC_QCA956X
- bool
- select MIPS_TUNE_74KC
- select SUPPORTS_BIG_ENDIAN
- select SUPPORTS_CPU_MIPS32_R1
- select SUPPORTS_CPU_MIPS32_R2
- help
This supports QCA/Atheros qca956x family SOCs.
choice prompt "Board select"
@@ -44,6 +53,10 @@ config TARGET_AP143 bool "AP143 Reference Board" select SOC_QCA953X
+config TARGET_AP152
- bool "AP152 Reference Board"
- select SOC_QCA956X
config BOARD_TPLINK_WDR4300 bool "TP-Link WDR4300 Board" select SOC_AR934X @@ -52,6 +65,7 @@ endchoice
source "board/qca/ap121/Kconfig" source "board/qca/ap143/Kconfig" +source "board/qca/ap152/Kconfig" source "board/tplink/wdr4300/Kconfig"
endmenu diff --git a/arch/mips/mach-ath79/Makefile b/arch/mips/mach-ath79/Makefile index 7aa40c65d3..fbd40c02be 100644 --- a/arch/mips/mach-ath79/Makefile +++ b/arch/mips/mach-ath79/Makefile @@ -7,3 +7,4 @@ obj-y += dram.o obj-$(CONFIG_SOC_AR933X) += ar933x/ obj-$(CONFIG_SOC_AR934X) += ar934x/ obj-$(CONFIG_SOC_QCA953X) += qca953x/ +obj-$(CONFIG_SOC_QCA956X) += qca956x/ diff --git a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h index 5d371bb582..7cd16b8d81 100644 --- a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h +++ b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h @@ -194,6 +194,9 @@ #define QCA956X_WMAC_BASE \ (AR71XX_APB_BASE + 0x00100000) #define QCA956X_WMAC_SIZE 0x20000 +#define QCA956X_RTC_BASE \
- (AR71XX_APB_BASE + 0x00107000)
+#define QCA956X_RTC_SIZE 0x1000 #define QCA956X_EHCI0_BASE 0x1b000000 #define QCA956X_EHCI1_BASE 0x1b400000 #define QCA956X_EHCI_SIZE 0x200 @@ -201,6 +204,10 @@ (AR71XX_APB_BASE + 0x00070000) #define QCA956X_GMAC_SIZE 0x64
+#define QCA956X_SRIF_BASE \
- (AR71XX_APB_BASE + 0x00116000)
+#define QCA956X_SRIF_SIZE 0x1000
- DDR_CTRL block
*/ @@ -278,6 +285,18 @@ #define QCA953X_DDR_REG_CTL_CONF 0x108 #define QCA953X_DDR_REG_CONFIG3 0x15c
+#define QCA956X_DDR_REG_TAP_CTRL2 0x24 +#define QCA956X_DDR_REG_TAP_CTRL3 0x28 +#define QCA956X_DDR_REG_DDR2_CONFIG 0xb8 +#define QCA956X_DDR_REG_DDR2_EMR2 0xbc +#define QCA956X_DDR_REG_DDR2_EMR3 0xc0 +#define QCA956X_DDR_REG_BURST 0xc4 +#define QCA956X_DDR_REG_BURST2 0xc8 +#define QCA956X_DDR_REG_TIMEOUT_MAX 0xcc +#define QCA956X_DDR_REG_FSM_WAIT_CTRL 0xe4 +#define QCA956X_DDR_REG_CTL_CONF 0x108 +#define QCA956X_DDR_REG_DDR3_CONFIG 0x15c
- PLL block
*/ @@ -519,6 +538,13 @@ #define QCA956X_PLL_DDR_CONFIG_REG 0x08 #define QCA956X_PLL_DDR_CONFIG1_REG 0x0c #define QCA956X_PLL_CLK_CTRL_REG 0x10 +#define QCA956X_PLL_SWITCH_CLK_CTRL_REG 0x28 +#define QCA956X_PLL_ETH_XMII_CTRL_REG 0x30 +#define QCA956X_PLL_DDR_DIT_FRAC_REG 0x38 +#define QCA956X_PLL_DDR_DIT2_FRAC_REG 0x3c +#define QCA956X_PLL_CPU_DIT_FRAC_REG 0x40 +#define QCA956X_PLL_CPU_DIT2_FRAC_REG 0x44 +#define QCA956X_PLL_ETH_SGMII_SERDES_REG 0x4c
#define QCA956X_PLL_CPU_CONFIG_REFDIV_SHIFT 12 #define QCA956X_PLL_CPU_CONFIG_REFDIV_MASK 0x1f @@ -756,6 +782,17 @@ #define QCA955X_RESET_MBOX BIT(1) #define QCA955X_RESET_I2S BIT(0)
+#define QCA956X_RESET_EXTERNAL BIT(28) +#define QCA956X_RESET_FULL_CHIP BIT(24) +#define QCA956X_RESET_GE1_MDIO BIT(23) /* Reserved in datasheet */ +#define QCA956X_RESET_GE0_MDIO BIT(22) +#define QCA956X_RESET_GE1_MAC BIT(13) /* Reserved in datasheet */ +#define QCA956X_RESET_SGMII_ASSERT BIT(12) +#define QCA956X_RESET_GE0_MAC BIT(9) +#define QCA956X_RESET_SGMII BIT(8) +#define QCA956X_RESET_SGMII_ANALOG BIT(2) +#define QCA956X_RESET_SWITCH BIT(0)
#define AR933X_BOOTSTRAP_MDIO_GPIO_EN BIT(18) #define AR933X_BOOTSTRAP_DDR2 BIT(13) #define AR933X_BOOTSTRAP_EEPBUSY BIT(4) @@ -1099,8 +1136,12 @@ #define QCA953X_GPIO_IN_MUX_UART0_SIN 9 #define QCA953X_GPIO_IN_MUX_SPI_DATA_IN 8
+#define QCA956X_GPIO(x) BIT(x) +#define QCA956X_GPIO_MUX_MASK(x) (0xff << (x)) #define QCA956X_GPIO_OUT_MUX_GE0_MDO 32 #define QCA956X_GPIO_OUT_MUX_GE0_MDC 33 +#define QCA956X_GPIO_IN_MUX_UART0_SIN 0x12 +#define QCA956X_GPIO_OUT_MUX_UART0_SOUT 0x16
#define AR71XX_GPIO_COUNT 16 #define AR7240_GPIO_COUNT 18 @@ -1179,6 +1220,25 @@ #define QCA953X_SRIF_DPLL2_OUTDIV_SHIFT 13 #define QCA953X_SRIF_DPLL2_OUTDIV_MASK 0x7
+#define QCA956X_SRIF_BB_DPLL1_REG 0x180 +#define QCA956X_SRIF_BB_DPLL2_REG 0x184 +#define QCA956X_SRIF_BB_DPLL3_REG 0x188
+#define QCA956X_SRIF_CPU_DPLL1_REG 0xf00 +#define QCA956X_SRIF_CPU_DPLL2_REG 0xf04 +#define QCA956X_SRIF_CPU_DPLL3_REG 0xf08
+#define QCA956X_SRIF_DDR_DPLL1_REG 0xec0 +#define QCA956X_SRIF_DDR_DPLL2_REG 0xec4 +#define QCA956X_SRIF_DDR_DPLL3_REG 0xec8
+#define QCA956X_SRIF_PCIE_DPLL1_REG 0xc80 +#define QCA956X_SRIF_PCIE_DPLL2_REG 0xc84 +#define QCA956X_SRIF_PCIE_DPLL3_REG 0xc88
+#define QCA956X_SRIF_PMU1_REG 0xcc0 +#define QCA956X_SRIF_PMU2_REG 0xcc4
- MII_CTRL block
*/ @@ -1261,4 +1321,17 @@ #define QCA955X_ETH_CFG_RGMII_EN BIT(0) #define QCA955X_ETH_CFG_GE0_SGMII BIT(6)
- QCA956X GMAC Interface
+#define QCA956X_GMAC_REG_ETH_CFG 0x00 +#define QCA956X_GMAC_REG_SGMII_RESET 0x14 +#define QCA956X_GMAC_REG_SGMII_SERDES 0x18 +#define QCA956X_GMAC_REG_MR_AN_CTRL 0x1c +#define QCA956X_GMAC_REG_SGMII_CONFIG 0x34 +#define QCA956X_GMAC_REG_SGMII_DEBUG 0x58
+#define QCA956X_ETH_CFG_GE0_SGMII BIT(6)
#endif /* __ASM_AR71XX_H */ diff --git a/arch/mips/mach-ath79/include/mach/ath79.h b/arch/mips/mach-ath79/include/mach/ath79.h index 5de7a43f79..0fde5079b1 100644 --- a/arch/mips/mach-ath79/include/mach/ath79.h +++ b/arch/mips/mach-ath79/include/mach/ath79.h @@ -2,6 +2,7 @@ /*
- Atheros AR71XX/AR724X/AR913X common definitions
- Copyright (C) 2018-2019 Rosy Song rosysong@rosinson.com
- Copyright (C) 2015-2016 Wills Wang wills.wang@live.com
- Copyright (C) 2008-2011 Gabor Juhos juhosg@openwrt.org
- Copyright (C) 2008 Imre Kaloz kaloz@openwrt.org
@@ -146,4 +147,6 @@ int ath79_usb_reset(void); void ar934x_pll_init(const u16 cpu_mhz, const u16 ddr_mhz, const u16 ahb_mhz); void ar934x_ddr_init(const u16 cpu_mhz, const u16 ddr_mhz, const u16 ahb_mhz);
+void qca956x_pll_init(void); +void qca956x_ddr_init(void); #endif /* __ASM_MACH_ATH79_H */ diff --git a/arch/mips/mach-ath79/qca956x/Makefile b/arch/mips/mach-ath79/qca956x/Makefile new file mode 100644 index 0000000000..3f5fc0363f --- /dev/null +++ b/arch/mips/mach-ath79/qca956x/Makefile @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+
+obj-y += cpu.o +obj-y += clk.o +obj-y += ddr.o qca956x-ddr-tap.o diff --git a/arch/mips/mach-ath79/qca956x/clk.c b/arch/mips/mach-ath79/qca956x/clk.c new file mode 100644 index 0000000000..ca956d1291 --- /dev/null +++ b/arch/mips/mach-ath79/qca956x/clk.c @@ -0,0 +1,419 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Copyright (C) 2019 Rosy Song rosysong@rosinson.com
+#include <common.h> +#include <asm/io.h> +#include <asm/addrspace.h> +#include <asm/types.h> +#include <mach/ar71xx_regs.h> +#include <mach/ath79.h> +#include <wait_bit.h>
+#define PLL_SRIF_DPLL2_KI_LSB 29 +#define PLL_SRIF_DPLL2_KI_MASK 0x60000000 +#define PLL_SRIF_DPLL2_KI_SET(x) \
- (((x) << PLL_SRIF_DPLL2_KI_LSB) & PLL_SRIF_DPLL2_KI_MASK)
+#define PLL_SRIF_DPLL2_KD_LSB 25 +#define PLL_SRIF_DPLL2_KD_MASK 0x1e000000 +#define PLL_SRIF_DPLL2_KD_SET(x) \
- (((x) << PLL_SRIF_DPLL2_KD_LSB) & PLL_SRIF_DPLL2_KD_MASK)
+#define PLL_SRIF_DPLL2_PLL_PWD_LSB 22 +#define PLL_SRIF_DPLL2_PLL_PWD_MASK 0x00400000 +#define PLL_SRIF_DPLL2_PLL_PWD_SET(x) \
- (((x) << PLL_SRIF_DPLL2_PLL_PWD_LSB) & PLL_SRIF_DPLL2_PLL_PWD_MASK)
+#define PLL_SRIF_DPLL2_OUTDIV_LSB 19 +#define PLL_SRIF_DPLL2_OUTDIV_MASK 0x00380000 +#define PLL_SRIF_DPLL2_OUTDIV_SET(x) \
- (((x) << PLL_SRIF_DPLL2_OUTDIV_LSB) & PLL_SRIF_DPLL2_OUTDIV_MASK)
+#define PLL_SRIF_DPLL2_PHASE_SHIFT_LSB 12 +#define PLL_SRIF_DPLL2_PHASE_SHIFT_MASK 0x0007f000 +#define PLL_SRIF_DPLL2_PHASE_SHIFT_SET(x) \
- (((x) << PLL_SRIF_DPLL2_PHASE_SHIFT_LSB) & PLL_SRIF_DPLL2_PHASE_SHIFT_MASK)
+#define CPU_PLL_CONFIG_PLLPWD_LSB 30 +#define CPU_PLL_CONFIG_PLLPWD_MASK 0x40000000 +#define CPU_PLL_CONFIG_PLLPWD_SET(x) \
- (((x) << CPU_PLL_CONFIG_PLLPWD_LSB) & CPU_PLL_CONFIG_PLLPWD_MASK)
+#define CPU_PLL_CONFIG_OUTDIV_LSB 19 +#define CPU_PLL_CONFIG_OUTDIV_MASK 0x00380000 +#define CPU_PLL_CONFIG_OUTDIV_SET(x) \
- (((x) << CPU_PLL_CONFIG_OUTDIV_LSB) & CPU_PLL_CONFIG_OUTDIV_MASK)
+#define CPU_PLL_CONFIG_RANGE_LSB 17 +#define CPU_PLL_CONFIG_RANGE_MASK 0x00060000 +#define CPU_PLL_CONFIG_RANGE_SET(x) \
- (((x) << CPU_PLL_CONFIG_RANGE_LSB) & CPU_PLL_CONFIG_RANGE_MASK)
+#define CPU_PLL_CONFIG_REFDIV_LSB 12 +#define CPU_PLL_CONFIG_REFDIV_MASK 0x0001f000 +#define CPU_PLL_CONFIG_REFDIV_SET(x) \
- (((x) << CPU_PLL_CONFIG_REFDIV_LSB) & CPU_PLL_CONFIG_REFDIV_MASK)
+#define CPU_PLL_CONFIG1_NINT_LSB 18 +#define CPU_PLL_CONFIG1_NINT_MASK 0x07fc0000 +#define CPU_PLL_CONFIG1_NINT_SET(x) \
- (((x) << CPU_PLL_CONFIG1_NINT_LSB) & CPU_PLL_CONFIG1_NINT_MASK)
+#define CPU_PLL_DITHER1_DITHER_EN_LSB 31 +#define CPU_PLL_DITHER1_DITHER_EN_MASK 0x80000000 +#define CPU_PLL_DITHER1_DITHER_EN_SET(x) \
- (((x) << CPU_PLL_DITHER1_DITHER_EN_LSB) & CPU_PLL_DITHER1_DITHER_EN_MASK)
+#define CPU_PLL_DITHER1_UPDATE_COUNT_LSB 24 +#define CPU_PLL_DITHER1_UPDATE_COUNT_MASK 0x3f000000 +#define CPU_PLL_DITHER1_UPDATE_COUNT_SET(x) \
- (((x) << CPU_PLL_DITHER1_UPDATE_COUNT_LSB) & CPU_PLL_DITHER1_UPDATE_COUNT_MASK)
+#define CPU_PLL_DITHER1_NFRAC_STEP_LSB 18 +#define CPU_PLL_DITHER1_NFRAC_STEP_MASK 0x00fc0000 +#define CPU_PLL_DITHER1_NFRAC_STEP_SET(x) \
- (((x) << CPU_PLL_DITHER1_NFRAC_STEP_LSB) & CPU_PLL_DITHER1_NFRAC_STEP_MASK)
+#define CPU_PLL_DITHER1_NFRAC_MIN_LSB 0 +#define CPU_PLL_DITHER1_NFRAC_MIN_MASK 0x0003ffff +#define CPU_PLL_DITHER1_NFRAC_MIN_SET(x) \
- (((x) << CPU_PLL_DITHER1_NFRAC_MIN_LSB) & CPU_PLL_DITHER1_NFRAC_MIN_MASK)
+#define CPU_PLL_DITHER2_NFRAC_MAX_LSB 0 +#define CPU_PLL_DITHER2_NFRAC_MAX_MASK 0x0003ffff +#define CPU_PLL_DITHER2_NFRAC_MAX_SET(x) \
- (((x) << CPU_PLL_DITHER2_NFRAC_MAX_LSB) & CPU_PLL_DITHER2_NFRAC_MAX_MASK)
+#define DDR_PLL_CONFIG_PLLPWD_LSB 30 +#define DDR_PLL_CONFIG_PLLPWD_MASK 0x40000000 +#define DDR_PLL_CONFIG_PLLPWD_SET(x) \
- (((x) << DDR_PLL_CONFIG_PLLPWD_LSB) & DDR_PLL_CONFIG_PLLPWD_MASK)
+#define DDR_PLL_CONFIG_OUTDIV_LSB 23 +#define DDR_PLL_CONFIG_OUTDIV_MASK 0x03800000 +#define DDR_PLL_CONFIG_OUTDIV_SET(x) \
- (((x) << DDR_PLL_CONFIG_OUTDIV_LSB) & DDR_PLL_CONFIG_OUTDIV_MASK)
+#define DDR_PLL_CONFIG_RANGE_LSB 21 +#define DDR_PLL_CONFIG_RANGE_MASK 0x00600000 +#define DDR_PLL_CONFIG_RANGE_SET(x) \
- (((x) << DDR_PLL_CONFIG_RANGE_LSB) & DDR_PLL_CONFIG_RANGE_MASK)
+#define DDR_PLL_CONFIG_REFDIV_LSB 16 +#define DDR_PLL_CONFIG_REFDIV_MASK 0x001f0000 +#define DDR_PLL_CONFIG_REFDIV_SET(x) \
- (((x) << DDR_PLL_CONFIG_REFDIV_LSB) & DDR_PLL_CONFIG_REFDIV_MASK)
+#define DDR_PLL_CONFIG1_NINT_LSB 18 +#define DDR_PLL_CONFIG1_NINT_MASK 0x07fc0000 +#define DDR_PLL_CONFIG1_NINT_SET(x) \
- (((x) << DDR_PLL_CONFIG1_NINT_LSB) & DDR_PLL_CONFIG1_NINT_MASK)
+#define DDR_PLL_DITHER1_DITHER_EN_LSB 31 +#define DDR_PLL_DITHER1_DITHER_EN_MASK 0x80000000 +#define DDR_PLL_DITHER1_DITHER_EN_SET(x) \
- (((x) << DDR_PLL_DITHER1_DITHER_EN_LSB) & DDR_PLL_DITHER1_DITHER_EN_MASK)
+#define DDR_PLL_DITHER1_UPDATE_COUNT_LSB 27 +#define DDR_PLL_DITHER1_UPDATE_COUNT_MASK 0x78000000 +#define DDR_PLL_DITHER1_UPDATE_COUNT_SET(x) \
- (((x) << DDR_PLL_DITHER1_UPDATE_COUNT_LSB) & DDR_PLL_DITHER1_UPDATE_COUNT_MASK)
+#define DDR_PLL_DITHER1_NFRAC_STEP_LSB 20 +#define DDR_PLL_DITHER1_NFRAC_STEP_MASK 0x07f00000 +#define DDR_PLL_DITHER1_NFRAC_STEP_SET(x) \
- (((x) << DDR_PLL_DITHER1_NFRAC_STEP_LSB) & DDR_PLL_DITHER1_NFRAC_STEP_MASK)
+#define DDR_PLL_DITHER1_NFRAC_MIN_LSB 0 +#define DDR_PLL_DITHER1_NFRAC_MIN_MASK 0x0003ffff +#define DDR_PLL_DITHER1_NFRAC_MIN_SET(x) \
- (((x) << DDR_PLL_DITHER1_NFRAC_MIN_LSB) & DDR_PLL_DITHER1_NFRAC_MIN_MASK)
+#define DDR_PLL_DITHER2_NFRAC_MAX_LSB 0 +#define DDR_PLL_DITHER2_NFRAC_MAX_MASK 0x0003ffff +#define DDR_PLL_DITHER2_NFRAC_MAX_SET(x) \
- (((x) << DDR_PLL_DITHER2_NFRAC_MAX_LSB) & DDR_PLL_DITHER2_NFRAC_MAX_MASK)
+#define CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_LSB 24 +#define CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_MASK 0x01000000 +#define CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_SET(x) \
- (((x) << CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_LSB) & CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_MASK)
+#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_LSB 21 +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_MASK 0x00200000 +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_SET(x) \
- (((x) << CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_LSB) & CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_MASK)
+#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_LSB 20 +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_MASK 0x00100000 +#define CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_SET(x) \
- (((x) << CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_LSB) & CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_MASK)
+#define CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_LSB 15 +#define CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_MASK 0x000f8000 +#define CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_SET(x) \
- (((x) << CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_LSB) & CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_MASK)
+#define CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_LSB 10 +#define CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_MASK 0x00007c00 +#define CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_SET(x) \
- (((x) << CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_LSB) & CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_MASK)
+#define CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_LSB 5 +#define CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_MASK 0x000003e0 +#define CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_SET(x) \
- (((x) << CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_LSB) & CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_MASK)
+#define CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_LSB 4 +#define CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_MASK 0x00000010 +#define CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_SET(x) \
- (((x) << CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_LSB) & CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_MASK)
+#define CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_LSB 3 +#define CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_MASK 0x00000008 +#define CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_SET(x) \
- (((x) << CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_LSB) & CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_MASK)
+#define CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_LSB 2 +#define CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_MASK 0x00000004 +#define CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_SET(x) \
- (((x) << CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_LSB) & CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_MASK)
+#define CPU_PLL_CONFIG1_NINT_VAL CPU_PLL_CONFIG1_NINT_SET(0x1f) +#define CPU_PLL_CONFIG_REF_DIV_VAL CPU_PLL_CONFIG_REFDIV_SET(0x1) +#define CPU_PLL_CONFIG_RANGE_VAL CPU_PLL_CONFIG_RANGE_SET(0) +#define CPU_PLL_CONFIG_OUT_DIV_VAL1 CPU_PLL_CONFIG_OUTDIV_SET(0) +#define CPU_PLL_CONFIG_OUT_DIV_VAL2 CPU_PLL_CONFIG_OUTDIV_SET(0) +#define CPU_PLL_DITHER1_VAL CPU_PLL_DITHER1_DITHER_EN_SET(0) | \
- CPU_PLL_DITHER1_NFRAC_MIN_SET(0) | \
- CPU_PLL_DITHER1_NFRAC_STEP_SET(0) | \
- CPU_PLL_DITHER1_UPDATE_COUNT_SET(0x0)
+#define CPU_PLL_DITHER2_VAL CPU_PLL_DITHER2_NFRAC_MAX_SET(0x0) +#define DDR_PLL_CONFIG1_NINT_VAL DDR_PLL_CONFIG1_NINT_SET(0x1a) +#define DDR_PLL_CONFIG_REF_DIV_VAL DDR_PLL_CONFIG_REFDIV_SET(0x1) +#define DDR_PLL_CONFIG_RANGE_VAL DDR_PLL_CONFIG_RANGE_SET(0) +#define DDR_PLL_CONFIG_OUT_DIV_VAL1 DDR_PLL_CONFIG_OUTDIV_SET(0) +#define DDR_PLL_CONFIG_OUT_DIV_VAL2 DDR_PLL_CONFIG_OUTDIV_SET(0) +#define DDR_PLL_DITHER1_VAL DDR_PLL_DITHER1_DITHER_EN_SET(0) | \
- DDR_PLL_DITHER1_NFRAC_MIN_SET(0) | \
- DDR_PLL_DITHER1_NFRAC_STEP_SET(0) | \
- DDR_PLL_DITHER1_UPDATE_COUNT_SET(0x0)
+#define DDR_PLL_DITHER2_VAL DDR_PLL_DITHER2_NFRAC_MAX_SET(0x0) +#define AHB_CLK_FROM_DDR CPU_DDR_CLOCK_CONTROL_AHBCLK_FROM_DDRPLL_SET(0) +#define CPU_AND_DDR_CLK_FROM_DDR \
- CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_DDRPLL_SET(0)
+#define CPU_AND_DDR_CLK_FROM_CPU \
- CPU_DDR_CLOCK_CONTROL_CPU_DDR_CLK_FROM_CPUPLL_SET(0)
+#define CPU_DDR_CLOCK_CONTROL_AHB_DIV_VAL \
- CPU_DDR_CLOCK_CONTROL_AHB_POST_DIV_SET(0x2)
+#define CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV \
- CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV_SET(0)
+#define CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV \
- CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV_SET(0)
+static inline void set_val(u32 _reg, u32 _mask, u32 _val) +{
- void __iomem *pll_regs = map_physmem(AR71XX_PLL_BASE,
AR71XX_PLL_SIZE, MAP_NOCACHE);
- writel((readl(pll_regs + _reg) & (~(_mask))) | _val, pll_regs + _reg);
+#define cpu_pll_set(_mask, _val) \
- set_val(QCA956X_PLL_CPU_CONFIG_REG, _mask, _val)
+#define ddr_pll_set(_mask, _val) \
- set_val(QCA956X_PLL_DDR_CONFIG_REG, _mask, _val)
+#define cpu_ddr_control_set(_mask, _val) \
- set_val(QCA956X_PLL_CLK_CTRL_REG, _mask, _val)
+static u32 qca956x_get_xtal(void) +{
- u32 val;
- val = ath79_get_bootstrap();
- if (val & QCA956X_BOOTSTRAP_REF_CLK_40)
return 40000000;
- else
return 25000000;
+int get_serial_clock(void) +{
- return qca956x_get_xtal();
+void qca956x_pll_init(void) +{
- void __iomem *srif_regs = map_physmem(QCA956X_SRIF_BASE,
QCA956X_SRIF_SIZE, MAP_NOCACHE);
- /* 8.16.2 Baseband DPLL2 */
- writel(PLL_SRIF_DPLL2_KI_SET(2) | PLL_SRIF_DPLL2_KD_SET(0xa) |
PLL_SRIF_DPLL2_PLL_PWD_SET(1) | PLL_SRIF_DPLL2_OUTDIV_SET(1) |
PLL_SRIF_DPLL2_PHASE_SHIFT_SET(6), srif_regs + QCA956X_SRIF_BB_DPLL2_REG);
- /* 8.16.2 PCIE DPLL2 */
PLL_SRIF_DPLL2_PLL_PWD_SET(1) | PLL_SRIF_DPLL2_OUTDIV_SET(3) |
PLL_SRIF_DPLL2_PHASE_SHIFT_SET(6), srif_regs + QCA956X_SRIF_PCIE_DPLL2_REG);
- /* 8.16.2 DDR DPLL2 */
PLL_SRIF_DPLL2_PLL_PWD_SET(1) | PLL_SRIF_DPLL2_PHASE_SHIFT_SET(6),
srif_regs + QCA956X_SRIF_DDR_DPLL2_REG);
- /* 8.16.2 CPU DPLL2 */
- writel(PLL_SRIF_DPLL2_KI_SET(1) | PLL_SRIF_DPLL2_KD_SET(7) |
srif_regs + QCA956X_SRIF_CPU_DPLL2_REG);
- /* pll_bypass_set */
- cpu_ddr_control_set(CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_MASK,
CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_SET(1));
- cpu_ddr_control_set(CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_MASK,
CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_SET(1));
- cpu_ddr_control_set(CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_MASK,
CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_SET(1));
- /* init_cpu_pll */
- cpu_pll_set(CPU_PLL_CONFIG_PLLPWD_MASK, CPU_PLL_CONFIG_PLLPWD_SET(1));
- cpu_pll_set(CPU_PLL_CONFIG_REFDIV_MASK, CPU_PLL_CONFIG_REF_DIV_VAL);
- cpu_pll_set(CPU_PLL_CONFIG_RANGE_MASK, CPU_PLL_CONFIG_RANGE_VAL);
- cpu_pll_set(CPU_PLL_CONFIG_OUTDIV_MASK, CPU_PLL_CONFIG_OUT_DIV_VAL1);
- set_val(QCA956X_PLL_CPU_CONFIG1_REG, CPU_PLL_CONFIG1_NINT_MASK, \
CPU_PLL_CONFIG1_NINT_VAL);
- /* init_ddr_pll */
- ddr_pll_set(DDR_PLL_CONFIG_PLLPWD_MASK, DDR_PLL_CONFIG_PLLPWD_SET(1));
- ddr_pll_set(DDR_PLL_CONFIG_REFDIV_MASK, DDR_PLL_CONFIG_REF_DIV_VAL);
- ddr_pll_set(DDR_PLL_CONFIG_RANGE_MASK, DDR_PLL_CONFIG_RANGE_VAL);
- ddr_pll_set(DDR_PLL_CONFIG_OUTDIV_MASK, DDR_PLL_CONFIG_OUT_DIV_VAL1);
- set_val(QCA956X_PLL_DDR_CONFIG1_REG, DDR_PLL_CONFIG1_NINT_MASK,
DDR_PLL_CONFIG1_NINT_VAL);
- /* init_ahb_pll */
- writel(CPU_DDR_CLOCK_CONTROL_AHB_DIV_VAL | AHB_CLK_FROM_DDR |
CPU_AND_DDR_CLK_FROM_DDR | CPU_AND_DDR_CLK_FROM_CPU |
CPU_DDR_CLOCK_CONTROL_DDR_POST_DIV | CPU_DDR_CLOCK_CONTROL_CPU_POST_DIV |
CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_SET(1) |
CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_SET(1) |
CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_SET(1), pll_regs + QCA956X_PLL_CLK_CTRL_REG);
- /* ddr_pll_dither_unset */
- writel(DDR_PLL_DITHER1_VAL, pll_regs + QCA956X_PLL_DDR_DIT_FRAC_REG);
- writel(DDR_PLL_DITHER2_VAL, pll_regs + QCA956X_PLL_DDR_DIT2_FRAC_REG);
- /* cpu_pll_dither_unset */
- writel(CPU_PLL_DITHER1_VAL, pll_regs + QCA956X_PLL_CPU_DIT_FRAC_REG);
- writel(CPU_PLL_DITHER2_VAL, pll_regs + QCA956X_PLL_CPU_DIT2_FRAC_REG);
- /* pll_pwd_unset */
- cpu_pll_set(CPU_PLL_CONFIG_PLLPWD_MASK, CPU_PLL_CONFIG_PLLPWD_SET(0));
- ddr_pll_set(DDR_PLL_CONFIG_PLLPWD_MASK, DDR_PLL_CONFIG_PLLPWD_SET(0));
- /* outdiv_unset */
- cpu_pll_set(CPU_PLL_CONFIG_OUTDIV_MASK, CPU_PLL_CONFIG_OUT_DIV_VAL2);
- ddr_pll_set(DDR_PLL_CONFIG_OUTDIV_MASK, DDR_PLL_CONFIG_OUT_DIV_VAL2);
- /* pll_bypass_unset */
CPU_DDR_CLOCK_CONTROL_CPU_PLL_BYPASS_SET(0));
CPU_DDR_CLOCK_CONTROL_DDR_PLL_BYPASS_SET(0));
CPU_DDR_CLOCK_CONTROL_AHB_PLL_BYPASS_SET(0));
- while (readl(pll_regs + QCA956X_PLL_CPU_CONFIG_REG) & 0x8000000)
/* NOP */;
- while (readl(pll_regs + QCA956X_PLL_DDR_CONFIG_REG) & 0x8000000)
/* NOP */;
+int get_clocks(void) +{
- void __iomem *regs;
- u32 ref_rate, cpu_rate, ddr_rate, ahb_rate;
- u32 out_div, ref_div, postdiv, nint, hfrac, lfrac, clk_ctrl;
- u32 pll, cpu_pll, ddr_pll, misc;
* QCA956x timer init workaround has to be applied right before setting
* up the clock. Else, there will be no jiffies
- regs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE,
MAP_NOCACHE);
- misc = readl(regs + AR71XX_RESET_REG_MISC_INT_ENABLE);
- misc |= MISC_INT_MIPS_SI_TIMERINT_MASK;
- writel(misc, regs + AR71XX_RESET_REG_MISC_INT_ENABLE);
- regs = map_physmem(AR71XX_PLL_BASE, AR71XX_PLL_SIZE,
MAP_NOCACHE);
- pll = readl(regs + QCA956X_PLL_CPU_CONFIG_REG);
- out_div = (pll >> QCA956X_PLL_CPU_CONFIG_OUTDIV_SHIFT) &
QCA956X_PLL_CPU_CONFIG_OUTDIV_MASK;
- ref_div = (pll >> QCA956X_PLL_CPU_CONFIG_REFDIV_SHIFT) &
QCA956X_PLL_CPU_CONFIG_REFDIV_MASK;
- pll = readl(regs + QCA956X_PLL_CPU_CONFIG1_REG);
- nint = (pll >> QCA956X_PLL_CPU_CONFIG1_NINT_SHIFT) &
QCA956X_PLL_CPU_CONFIG1_NINT_MASK;
- hfrac = (pll >> QCA956X_PLL_CPU_CONFIG1_NFRAC_H_SHIFT) &
QCA956X_PLL_CPU_CONFIG1_NFRAC_H_MASK;
- lfrac = (pll >> QCA956X_PLL_CPU_CONFIG1_NFRAC_L_SHIFT) &
QCA956X_PLL_CPU_CONFIG1_NFRAC_L_MASK;
- ref_rate = qca956x_get_xtal();
- cpu_pll = nint * ref_rate / ref_div;
- cpu_pll += (lfrac * ref_rate) / ((ref_div * 25) << 13);
- cpu_pll += (hfrac >> 13) * ref_rate / ref_div;
- cpu_pll /= (1 << out_div);
- pll = readl(regs + QCA956X_PLL_DDR_CONFIG_REG);
- out_div = (pll >> QCA956X_PLL_DDR_CONFIG_OUTDIV_SHIFT) &
QCA956X_PLL_DDR_CONFIG_OUTDIV_MASK;
- ref_div = (pll >> QCA956X_PLL_DDR_CONFIG_REFDIV_SHIFT) &
QCA956X_PLL_DDR_CONFIG_REFDIV_MASK;
- pll = readl(regs + QCA956X_PLL_DDR_CONFIG1_REG);
- nint = (pll >> QCA956X_PLL_DDR_CONFIG1_NINT_SHIFT) &
QCA956X_PLL_DDR_CONFIG1_NINT_MASK;
- hfrac = (pll >> QCA956X_PLL_DDR_CONFIG1_NFRAC_H_SHIFT) &
QCA956X_PLL_DDR_CONFIG1_NFRAC_H_MASK;
- lfrac = (pll >> QCA956X_PLL_DDR_CONFIG1_NFRAC_L_SHIFT) &
QCA956X_PLL_DDR_CONFIG1_NFRAC_L_MASK;
- ddr_pll = nint * ref_rate / ref_div;
- ddr_pll += (lfrac * ref_rate) / ((ref_div * 25) << 13);
- ddr_pll += (hfrac >> 13) * ref_rate / ref_div;
- ddr_pll /= (1 << out_div);
- clk_ctrl = readl(regs + QCA956X_PLL_CLK_CTRL_REG);
- postdiv = (clk_ctrl >> QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_SHIFT) &
QCA956X_PLL_CLK_CTRL_CPU_POST_DIV_MASK;
- if (clk_ctrl & QCA956X_PLL_CLK_CTRL_CPU_PLL_BYPASS)
cpu_rate = ref_rate;
- else if (clk_ctrl & QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_CPUPLL)
cpu_rate = ddr_pll / (postdiv + 1);
- else
cpu_rate = cpu_pll / (postdiv + 1);
- postdiv = (clk_ctrl >> QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_SHIFT) &
QCA956X_PLL_CLK_CTRL_DDR_POST_DIV_MASK;
- if (clk_ctrl & QCA956X_PLL_CLK_CTRL_DDR_PLL_BYPASS)
ddr_rate = ref_rate;
- else if (clk_ctrl & QCA956X_PLL_CLK_CTRL_CPU_DDRCLK_FROM_DDRPLL)
ddr_rate = cpu_pll / (postdiv + 1);
- else
ddr_rate = ddr_pll / (postdiv + 1);
- postdiv = (clk_ctrl >> QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_SHIFT) &
QCA956X_PLL_CLK_CTRL_AHB_POST_DIV_MASK;
- if (clk_ctrl & QCA956X_PLL_CLK_CTRL_AHB_PLL_BYPASS)
ahb_rate = ref_rate;
- else if (clk_ctrl & QCA956X_PLL_CLK_CTRL_AHBCLK_FROM_DDRPLL)
ahb_rate = ddr_pll / (postdiv + 1);
- else
ahb_rate = cpu_pll / (postdiv + 1);
- gd->cpu_clk = cpu_rate;
- gd->mem_clk = ddr_rate;
- gd->bus_clk = ahb_rate;
- debug("cpu_clk=%u, ddr_clk=%u, bus_clk=%u\n",
cpu_rate, ddr_rate, ahb_rate);
+ulong get_bus_freq(ulong dummy) +{
- if (!gd->bus_clk)
get_clocks();
- return gd->bus_clk;
+ulong get_ddr_freq(ulong dummy) +{
- if (!gd->mem_clk)
get_clocks();
- return gd->mem_clk;
+} diff --git a/arch/mips/mach-ath79/qca956x/cpu.c b/arch/mips/mach-ath79/qca956x/cpu.c new file mode 100644 index 0000000000..08a8c84e72 --- /dev/null +++ b/arch/mips/mach-ath79/qca956x/cpu.c @@ -0,0 +1,9 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
+/* The lowlevel_init() is not needed on QCA956X */ +void lowlevel_init(void) {} diff --git a/arch/mips/mach-ath79/qca956x/ddr.c b/arch/mips/mach-ath79/qca956x/ddr.c new file mode 100644 index 0000000000..fb2230430c --- /dev/null +++ b/arch/mips/mach-ath79/qca956x/ddr.c @@ -0,0 +1,308 @@ +// SPDX-License-Identifier: GPL-2.0+ +/*
- Based on QSDK
+#define DDR_FSM_WAIT_CTRL_VAL 0xa12 +#define DDR_CTL_CONFIG_SRAM_TSEL_LSB 30 +#define DDR_CTL_CONFIG_SRAM_TSEL_MASK 0xc0000000 +#define DDR_CTL_CONFIG_SRAM_TSEL_SET(x) \
- (((x) << DDR_CTL_CONFIG_SRAM_TSEL_LSB) & DDR_CTL_CONFIG_SRAM_TSEL_MASK)
+#define DDR_CTL_CONFIG_GE0_SRAM_SYNC_LSB 20 +#define DDR_CTL_CONFIG_GE0_SRAM_SYNC_MASK 0x00100000 +#define DDR_CTL_CONFIG_GE0_SRAM_SYNC_SET(x) \
- (((x) << DDR_CTL_CONFIG_GE0_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_GE0_SRAM_SYNC_MASK)
+#define DDR_CTL_CONFIG_GE1_SRAM_SYNC_LSB 19 +#define DDR_CTL_CONFIG_GE1_SRAM_SYNC_MASK 0x00080000 +#define DDR_CTL_CONFIG_GE1_SRAM_SYNC_SET(x) \
- (((x) << DDR_CTL_CONFIG_GE1_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_GE1_SRAM_SYNC_MASK)
+#define DDR_CTL_CONFIG_USB_SRAM_SYNC_LSB 18 +#define DDR_CTL_CONFIG_USB_SRAM_SYNC_MASK 0x00040000 +#define DDR_CTL_CONFIG_USB_SRAM_SYNC_SET(x) \
- (((x) << DDR_CTL_CONFIG_USB_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_USB_SRAM_SYNC_MASK)
+#define DDR_CTL_CONFIG_PCIE_SRAM_SYNC_LSB 17 +#define DDR_CTL_CONFIG_PCIE_SRAM_SYNC_MASK 0x00020000 +#define DDR_CTL_CONFIG_PCIE_SRAM_SYNC_SET(x) \
- (((x) << DDR_CTL_CONFIG_PCIE_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_PCIE_SRAM_SYNC_MASK)
+#define DDR_CTL_CONFIG_WMAC_SRAM_SYNC_LSB 16 +#define DDR_CTL_CONFIG_WMAC_SRAM_SYNC_MASK 0x00010000 +#define DDR_CTL_CONFIG_WMAC_SRAM_SYNC_SET(x) \
- (((x) << DDR_CTL_CONFIG_WMAC_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_WMAC_SRAM_SYNC_MASK)
+#define DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_LSB 15 +#define DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_MASK 0x00008000 +#define DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_SET(x) \
- (((x) << DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_MASK)
+#define DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_LSB 14 +#define DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_MASK 0x00004000 +#define DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_SET(x) \
- (((x) << DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_LSB) & DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_MASK)
+#define DDR_CTL_CONFIG_PAD_DDR2_SEL_LSB 6 +#define DDR_CTL_CONFIG_PAD_DDR2_SEL_MASK 0x00000040 +#define DDR_CTL_CONFIG_PAD_DDR2_SEL_SET(x) \
- (((x) << DDR_CTL_CONFIG_PAD_DDR2_SEL_LSB) & DDR_CTL_CONFIG_PAD_DDR2_SEL_MASK)
+#define DDR_CTL_CONFIG_CPU_DDR_SYNC_LSB 2 +#define DDR_CTL_CONFIG_CPU_DDR_SYNC_MASK 0x00000004 +#define DDR_CTL_CONFIG_CPU_DDR_SYNC_SET(x) \
- (((x) << DDR_CTL_CONFIG_CPU_DDR_SYNC_LSB) & DDR_CTL_CONFIG_CPU_DDR_SYNC_MASK)
+#define DDR_CTL_CONFIG_HALF_WIDTH_LSB 1 +#define DDR_CTL_CONFIG_HALF_WIDTH_MASK 0x00000002 +#define DDR_CTL_CONFIG_HALF_WIDTH_SET(x) \
- (((x) << DDR_CTL_CONFIG_HALF_WIDTH_LSB) & DDR_CTL_CONFIG_HALF_WIDTH_MASK)
+#define DDR_CONFIG_CAS_LATENCY_MSB_LSB 31 +#define DDR_CONFIG_CAS_LATENCY_MSB_MASK 0x80000000 +#define DDR_CONFIG_CAS_LATENCY_MSB_SET(x) \
- (((x) << DDR_CONFIG_CAS_LATENCY_MSB_LSB) & DDR_CONFIG_CAS_LATENCY_MSB_MASK)
+#define DDR_CONFIG_OPEN_PAGE_LSB 30 +#define DDR_CONFIG_OPEN_PAGE_MASK 0x40000000 +#define DDR_CONFIG_OPEN_PAGE_SET(x) \
- (((x) << DDR_CONFIG_OPEN_PAGE_LSB) & DDR_CONFIG_OPEN_PAGE_MASK)
+#define DDR_CONFIG_CAS_LATENCY_LSB 27 +#define DDR_CONFIG_CAS_LATENCY_MASK 0x38000000 +#define DDR_CONFIG_CAS_LATENCY_SET(x) \
- (((x) << DDR_CONFIG_CAS_LATENCY_LSB) & DDR_CONFIG_CAS_LATENCY_MASK)
+#define DDR_CONFIG_TMRD_LSB 23 +#define DDR_CONFIG_TMRD_MASK 0x07800000 +#define DDR_CONFIG_TMRD_SET(x) \
- (((x) << DDR_CONFIG_TMRD_LSB) & DDR_CONFIG_TMRD_MASK)
+#define DDR_CONFIG_TRFC_LSB 17 +#define DDR_CONFIG_TRFC_MASK 0x007e0000 +#define DDR_CONFIG_TRFC_SET(x) \
- (((x) << DDR_CONFIG_TRFC_LSB) & DDR_CONFIG_TRFC_MASK)
+#define DDR_CONFIG_TRRD_LSB 13 +#define DDR_CONFIG_TRRD_MASK 0x0001e000 +#define DDR_CONFIG_TRRD_SET(x) \
- (((x) << DDR_CONFIG_TRRD_LSB) & DDR_CONFIG_TRRD_MASK)
+#define DDR_CONFIG_TRP_LSB 9 +#define DDR_CONFIG_TRP_MASK 0x00001e00 +#define DDR_CONFIG_TRP_SET(x) \
- (((x) << DDR_CONFIG_TRP_LSB) & DDR_CONFIG_TRP_MASK)
+#define DDR_CONFIG_TRCD_LSB 5 +#define DDR_CONFIG_TRCD_MASK 0x000001e0 +#define DDR_CONFIG_TRCD_SET(x) \
- (((x) << DDR_CONFIG_TRCD_LSB) & DDR_CONFIG_TRCD_MASK)
+#define DDR_CONFIG_TRAS_LSB 0 +#define DDR_CONFIG_TRAS_MASK 0x0000001f +#define DDR_CONFIG_TRAS_SET(x) \
- (((x) << DDR_CONFIG_TRAS_LSB) & DDR_CONFIG_TRAS_MASK)
+#define DDR_CONFIG2_HALF_WIDTH_LOW_LSB 31 +#define DDR_CONFIG2_HALF_WIDTH_LOW_MASK 0x80000000 +#define DDR_CONFIG2_HALF_WIDTH_LOW_SET(x) \
- (((x) << DDR_CONFIG2_HALF_WIDTH_LOW_LSB) & DDR_CONFIG2_HALF_WIDTH_LOW_MASK)
+#define DDR_CONFIG2_SWAP_A26_A27_LSB 30 +#define DDR_CONFIG2_SWAP_A26_A27_MASK 0x40000000 +#define DDR_CONFIG2_SWAP_A26_A27_SET(x) \
- (((x) << DDR_CONFIG2_SWAP_A26_A27_LSB) & DDR_CONFIG2_SWAP_A26_A27_MASK)
+#define DDR_CONFIG2_GATE_OPEN_LATENCY_LSB 26 +#define DDR_CONFIG2_GATE_OPEN_LATENCY_MASK 0x3c000000 +#define DDR_CONFIG2_GATE_OPEN_LATENCY_SET(x) \
- (((x) << DDR_CONFIG2_GATE_OPEN_LATENCY_LSB) & DDR_CONFIG2_GATE_OPEN_LATENCY_MASK)
+#define DDR_CONFIG2_TWTR_LSB 21 +#define DDR_CONFIG2_TWTR_MASK 0x03e00000 +#define DDR_CONFIG2_TWTR_SET(x) \
- (((x) << DDR_CONFIG2_TWTR_LSB) & DDR_CONFIG2_TWTR_MASK)
+#define DDR_CONFIG2_TRTP_LSB 17 +#define DDR_CONFIG2_TRTP_MASK 0x001e0000 +#define DDR_CONFIG2_TRTP_SET(x) \
- (((x) << DDR_CONFIG2_TRTP_LSB) & DDR_CONFIG2_TRTP_MASK)
+#define DDR_CONFIG2_TRTW_LSB 12 +#define DDR_CONFIG2_TRTW_MASK 0x0001f000 +#define DDR_CONFIG2_TRTW_SET(x) \
- (((x) << DDR_CONFIG2_TRTW_LSB) & DDR_CONFIG2_TRTW_MASK)
+#define DDR_CONFIG2_TWR_LSB 8 +#define DDR_CONFIG2_TWR_MASK 0x00000f00 +#define DDR_CONFIG2_TWR_SET(x) \
- (((x) << DDR_CONFIG2_TWR_LSB) & DDR_CONFIG2_TWR_MASK)
+#define DDR_CONFIG2_CKE_LSB 7 +#define DDR_CONFIG2_CKE_MASK 0x00000080 +#define DDR_CONFIG2_CKE_SET(x) \
- (((x) << DDR_CONFIG2_CKE_LSB) & DDR_CONFIG2_CKE_MASK)
+#define DDR_CONFIG2_CNTL_OE_EN_LSB 5 +#define DDR_CONFIG2_CNTL_OE_EN_MASK 0x00000020 +#define DDR_CONFIG2_CNTL_OE_EN_SET(x) \
- (((x) << DDR_CONFIG2_CNTL_OE_EN_LSB) & DDR_CONFIG2_CNTL_OE_EN_MASK)
+#define DDR_CONFIG2_BURST_LENGTH_LSB 0 +#define DDR_CONFIG2_BURST_LENGTH_MASK 0x0000000f +#define DDR_CONFIG2_BURST_LENGTH_SET(x) \
- (((x) << DDR_CONFIG2_BURST_LENGTH_LSB) & DDR_CONFIG2_BURST_LENGTH_MASK)
+#define RST_BOOTSTRAP_ADDRESS 0x180600b0 +#define PMU2_SWREGMSB_LSB 22 +#define PMU2_SWREGMSB_MASK 0xffc00000 +#define PMU2_SWREGMSB_SET(x) \
- (((x) << PMU2_SWREGMSB_LSB) & PMU2_SWREGMSB_MASK)
+#define PMU2_PGM_LSB 21 +#define PMU2_PGM_MASK 0x00200000 +#define PMU2_PGM_SET(x) \
- (((x) << PMU2_PGM_LSB) & PMU2_PGM_MASK)
+#define CPU_DDR_SYNC_MODE DDR_CTL_CONFIG_CPU_DDR_SYNC_SET(0)
+/* +* DDR2 DDR1 +* 0x40c3 25MHz 0x4186 25Mhz +* 0x4138 40MHz 0x4270 40Mhz +*/ +#define CFG_DDR2_REFRESH_VAL 0x40c3 +#define CFG_DDR2_CONFIG_VAL DDR_CONFIG_CAS_LATENCY_MSB_SET(0x1) | \
- DDR_CONFIG_OPEN_PAGE_SET(0x1) | DDR_CONFIG_CAS_LATENCY_SET(0x4) | \
- DDR_CONFIG_TMRD_SET(0x6) | DDR_CONFIG_TRFC_SET(0x16) | \
- DDR_CONFIG_TRRD_SET(0x7) | DDR_CONFIG_TRP_SET(0xb) | \
- DDR_CONFIG_TRCD_SET(0xb) | DDR_CONFIG_TRAS_SET(0)
+#define CFG_DDR2_CONFIG2_VAL DDR_CONFIG2_HALF_WIDTH_LOW_SET(0x1) | \
- DDR_CONFIG2_SWAP_A26_A27_SET(0x0) | DDR_CONFIG2_GATE_OPEN_LATENCY_SET(0xa) | \
- DDR_CONFIG2_TWTR_SET(0x16) | DDR_CONFIG2_TRTP_SET(0xa) | \
- DDR_CONFIG2_TRTW_SET(0xe) | DDR_CONFIG2_TWR_SET(0x2) | \
- DDR_CONFIG2_CKE_SET(0x1) | DDR_CONFIG2_CNTL_OE_EN_SET(0x1) | \
- DDR_CONFIG2_BURST_LENGTH_SET(0x8)
+#define CFG_DDR2_CONFIG3_VAL 0x0000000e +#define CFG_DDR2_EXT_MODE_VAL1 0x782 +#define CFG_DDR2_EXT_MODE_VAL2 0x402 +#define CFG_DDR2_MODE_VAL_INIT 0xb53 +#define CFG_DDR2_MODE_VAL 0xa53 +#define CFG_DDR2_TAP_VAL 0x10 +#define CFG_DDR2_EN_TWL_VAL 0x00001e91 +#define CFG_DDR2_RD_DATA_THIS_CYCLE_VAL_16 0xffff
+#define CFG_DDR_CTL_CONFIG DDR_CTL_CONFIG_SRAM_TSEL_SET(0x1) | \
- DDR_CTL_CONFIG_GE0_SRAM_SYNC_SET(0x1) | \
- DDR_CTL_CONFIG_GE1_SRAM_SYNC_SET(0x1) | \
- DDR_CTL_CONFIG_USB_SRAM_SYNC_SET(0x1) | \
- DDR_CTL_CONFIG_PCIE_SRAM_SYNC_SET(0x1) | \
- DDR_CTL_CONFIG_WMAC_SRAM_SYNC_SET(0x1) | \
- DDR_CTL_CONFIG_MISC_SRC1_SRAM_SYNC_SET(0x1) | \
- DDR_CTL_CONFIG_MISC_SRC2_SRAM_SYNC_SET(0x1)
+DECLARE_GLOBAL_DATA_PTR;
+void qca956x_ddr_init(void) +{
- u32 ddr_config, ddr_config2, ddr_config3, mod_val, \
mod_val_init, cycle_val, tap_val, ctl_config;
- void __iomem *ddr_regs = map_physmem(AR71XX_DDR_CTRL_BASE, AR71XX_DDR_CTRL_SIZE,
MAP_NOCACHE);
- void __iomem *srif_regs = map_physmem(QCA956X_SRIF_BASE, QCA956X_SRIF_SIZE,
MAP_NOCACHE);
- ddr_config = CFG_DDR2_CONFIG_VAL;
- ddr_config2 = CFG_DDR2_CONFIG2_VAL;
- ddr_config3 = CFG_DDR2_CONFIG3_VAL;
- mod_val_init = CFG_DDR2_MODE_VAL_INIT;
- mod_val = CFG_DDR2_MODE_VAL;
- tap_val = CFG_DDR2_TAP_VAL;
- cycle_val = CFG_DDR2_RD_DATA_THIS_CYCLE_VAL_16;
- ctl_config = CFG_DDR_CTL_CONFIG | DDR_CTL_CONFIG_PAD_DDR2_SEL_SET(0x1) |
DDR_CTL_CONFIG_HALF_WIDTH_SET(0x1) | CPU_DDR_SYNC_MODE;
- writel(0x10, ddr_regs + AR71XX_DDR_REG_CONTROL);
- udelay(10);
- writel(0x20, ddr_regs + AR71XX_DDR_REG_CONTROL);
- udelay(10);
- writel(ctl_config, ddr_regs + QCA956X_DDR_REG_CTL_CONF);
- udelay(10);
- writel(cycle_val, ddr_regs + AR71XX_DDR_REG_RD_CYCLE);
- udelay(100);
- writel(0x74444444, ddr_regs + QCA956X_DDR_REG_BURST);
- udelay(100);
- writel(0x44444444, ddr_regs + QCA956X_DDR_REG_BURST2);
- udelay(100);
- writel(DDR_FSM_WAIT_CTRL_VAL, ddr_regs + QCA956X_DDR_REG_FSM_WAIT_CTRL);
- udelay(100);
- writel(0xfffff, ddr_regs + QCA956X_DDR_REG_TIMEOUT_MAX);
- udelay(100);
- writel(ddr_config, ddr_regs + AR71XX_DDR_REG_CONFIG);
- udelay(100);
- writel(ddr_config2, ddr_regs + AR71XX_DDR_REG_CONFIG2);
- udelay(100);
- writel(ddr_config3, ddr_regs + QCA956X_DDR_REG_DDR3_CONFIG);
- udelay(100);
- writel(CFG_DDR2_EN_TWL_VAL, ddr_regs + QCA956X_DDR_REG_DDR2_CONFIG);
- udelay(100);
- writel(ddr_config2 | 0x80, ddr_regs + AR71XX_DDR_REG_CONFIG2); /* CKE Enable */
- udelay(100);
- writel(0x8, ddr_regs + AR71XX_DDR_REG_CONTROL); /* Precharge */
- udelay(10);
- writel(0, ddr_regs + QCA956X_DDR_REG_DDR2_EMR2);
- writel(0x10, ddr_regs + AR71XX_DDR_REG_CONTROL); /* EMR2 */
- udelay(10);
- writel(0, ddr_regs + QCA956X_DDR_REG_DDR2_EMR3);
- writel(0x20, ddr_regs + AR71XX_DDR_REG_CONTROL); /* EMR3 */
- udelay(10);
- /* EMR DLL enable, Reduced Driver Impedance control, Differential DQS disabled */
- writel(CFG_DDR2_EXT_MODE_VAL2, ddr_regs + AR71XX_DDR_REG_EMR);
- udelay(100);
- writel(0x2, ddr_regs + AR71XX_DDR_REG_CONTROL); /* EMR write */
- udelay(10);
- writel(mod_val_init, ddr_regs + AR71XX_DDR_REG_MODE);
- udelay(1000);
- writel(0x1, ddr_regs + AR71XX_DDR_REG_CONTROL); /* MR Write */
- udelay(10);
- udelay(10);
- writel(0x4, ddr_regs + AR71XX_DDR_REG_CONTROL); /* Auto Refresh */
- udelay(10);
- udelay(10);
- /* Issue MRS to remove DLL out-of-reset */
- writel(mod_val, ddr_regs + AR71XX_DDR_REG_MODE);
- udelay(100);
- writel(0x1, ddr_regs + AR71XX_DDR_REG_CONTROL); /* MR write */
- udelay(100);
- writel(CFG_DDR2_EXT_MODE_VAL1, ddr_regs + AR71XX_DDR_REG_EMR);
- udelay(100);
- udelay(100);
- udelay(100);
- udelay(100);
- writel(CFG_DDR2_REFRESH_VAL, ddr_regs + AR71XX_DDR_REG_REFRESH);
- udelay(100);
- writel(tap_val, ddr_regs + AR71XX_DDR_REG_TAP_CTRL0);
- writel(tap_val, ddr_regs + AR71XX_DDR_REG_TAP_CTRL1);
- writel(tap_val, ddr_regs + QCA956X_DDR_REG_TAP_CTRL2);
- writel(tap_val, ddr_regs + QCA956X_DDR_REG_TAP_CTRL3);
- writel(0x633c8176, srif_regs + QCA956X_SRIF_PMU1_REG);
- /* Set DDR2 Voltage to 1.8 volts */
- writel(PMU2_SWREGMSB_SET(0x40) | PMU2_PGM_SET(0x1),
- Based on QSDK
- .set noreorder
- li a0, 0xbd001f00
- sw zero, 0x0(a0) /* Place where the tap values are saved and used for SWEEP */
- sw zero, 0x4(a0) /* Place where the number of passing taps are saved. */
- sw zero, 0x14(a0) /* Place where the last pass tap value is stored */
- li a1, 0xaa55aa55 /* Indicates that the First pass tap value is not found */
- sw a1, 0x10(a0) /* Place where the First pass tap value is stored */
nop
- li a0, CKSEG1ADDR(AR71XX_RESET_BASE) /* RESET_BASE_ADDRESS */
- lw a1, 0x1c(a0) /* Reading the RST_RESET_ADDRESS */
- li a2, 0x08000000 /* Setting the RST_RESET_RTC_RESET */
- or a1, a1, a2
- sw a1, 0x1c(a0)
- li a3, 0xffffffff
- xor a2, a2, a3
- and a1, a1, a2
- sw a1, 0x1c(a0) /* Taking the RTC out of RESET */
nop
- li a0, CKSEG1ADDR(QCA956X_RTC_BASE) /* RTC_BASE_ADDRESS */
- li a1, 0x1
- sw a1, 0x0040(a0) /* RTC_SYNC_RESET_ADDRESS */
- li a2, 0x2
+_poll_for_RTC_ON:
- lw a1, 0x0044(a0) /* RTC_SYNC_STATUS_ADDRESS */
- and a1, a2, a1
- bne a1, a2, _poll_for_RTC_ON
nop
+_CHANGE_TAPS:
- li t0, 0xbd001f00 /* Read the current value of the TAP for programming */
- lw t1, 0x0(t0)
- li t2, 0x00000000
- or t3, t1, t2
- li t0, 0xb8000000 /* DDR_BASE_ADDRESS */
- sw t3, 0x1c(t0) /* TAP_CONTROL_0_ADDRESS */
- sw t3, 0x20(t0) /* TAP_CONTROL_1_ADDRESS */
- sw t3, 0x24(t0) /* TAP_CONTROL_2_ADDRESS */
- sw t3, 0x28(t0) /* TAP_CONTROL_3_ADDRESS */
- li t1, 0x00000010 /* Running the test 8 times */
- sw t1, 0x0068(t0) /* PERF_COMP_ADDR_1_ADDRESS */
- li t1, 0xfa5de83f /* 4 Row Address Bits, 4 Column Address Bits, 2 BA bits */
- sw t1, 0x002c(t0) /* PERF_MASK_ADDR_0_ADDRESS */
- li t1, 0x0000ffff
- sw t1, 0x0070(t0) /* PERF_COMP_AHB_GE0_1_ADDRESS */
- li t1, 0x0000ffff
- sw t1, 0x0040(t0) /* PERF_COMP_AHB_GE1_0_ADDRESS */
- li t1, 0x0000ffff
- sw t1, 0x0078(t0) /* PERF_COMP_AHB_GE1_1_ADDRESS */
- li t1, 0x0000ffff
- sw t1, 0x0034(t0) /* PERF_MASK_AHB_GE0_0_ADDRESS */
- li t1, 0x0000ffff
- sw t1, 0x006c(t0) /* PERF_MASK_AHB_GE0_1_ADDRESS */
- li t1, 0x0000ffff
- sw t1, 0x003c(t0) /* PERF_MASK_AHB_GE1_0_ADDRESS */
- li t1, 0x0000ffff
- sw t1, 0x0074(t0) /* PERF_MASK_AHB_GE1_1_ADDRESS */
- li t1, 0x0000ffff
- sw t1, 0x0038(t0) /* PERF_COMP_AHB_GE0_0_ADDRESS */
- li t1, 0x00000001
- sw t1, 0x011c(t0) /* DDR_BIST_ADDRESS */
- li t2, 0x1
+_bist_done_poll:
- lw t1, 0x0120(t0) /* DDR_BIST_STATUS_ADDRESS */
- and t1, t1, t2
- bne t1, t2, _bist_done_poll
nop
- li t4, 0x000001fe
- and t2, t1, t4
- srl t2, t2, 0x1 /* no. of Pass Runs */
- li t5, 0x00000000
- sw t5, 0x011c(t0) /* DDR_BIST_ADDRESS - Stop the DDR BIST test */
- li t5, 0x0001fe00
- and t5, t5, t1
- bnez t5, _iterate_tap /* This is a redundant compare but nevertheless - Comparing the FAILS */
nop
- lw t1, 0x0068(t0) /* PERF_COMP_ADDR_1_ADDRESS */
- li t3, 0x000001fe
- and t3, t3, t1
- srl t3, t3, 0x1 /* No. of runs in the config register. */
- bne t3, t2, _iterate_tap
nop
+pass_tap:
- li t0, 0xbd001f00
- lw t1, 0x4(t0)
- addiu t1, t1, 0x1
- sw t1, 0x4(t0)
- li t0, 0xbd001f10
- lw t1, 0x0(t0)
- li t2, 0xaa55aa55
- beq t1, t2, _first_pass
nop
- li t0, 0xbd001f00
- lw t1, 0x0(t0)
- li t0, 0xbd001f10
- sw t1, 0x4(t0)
nop
- b _iterate_tap
nop
+_first_pass:
- li t0, 0xbd001f00
- lw t1, 0x0(t0)
- li t0, 0xbd001f10
- sw t1, 0x0(t0)
- sw t1, 0x4(t0)
nop
+_iterate_tap:
- li t0, 0xbd001f00
- lw t1, 0x0(t0)
- li t2, 0x3f
- beq t1, t2, _STOP_TEST
nop
- addiu t1, t1, 0x1
- sw t1, 0x0(t0)
nop
- b _CHANGE_TAPS
nop
+_STOP_TEST:
- li t0, 0xbd001f00
- lw t1, 0x4(t0)
- bnez t1, _load_center_tap
nop
- li t3, 0x8 /* Default Tap to be used */
- b _load_tap_into_reg
nop
+_load_center_tap:
- li t0, 0xbd001f10
- lw t1, 0x0(t0)
- lw t2, 0x4(t0)
- add t3, t1, t2
- srl t3, t3, 0x1
- li t4, 0x3f
- and t3, t3, t4
- li t0, 0xb8000000
nop
- jr ra
nop
- END(ddr_tap_tuning)
- (((x) << SGMII_SERDES_RES_CALIBRATION_LSB) & SGMII_SERDES_RES_CALIBRATION_MASK)
- (((x) << SGMII_SERDES_CDR_BW_LSB) & SGMII_SERDES_CDR_BW_MASK)
- (((x) << SGMII_SERDES_TX_DR_CTRL_LSB) & SGMII_SERDES_TX_DR_CTRL_MASK)
- (((x) << SGMII_SERDES_PLL_BW_LSB) & SGMII_SERDES_PLL_BW_MASK)
- (((x) << SGMII_SERDES_EN_SIGNAL_DETECT_LSB) & SGMII_SERDES_EN_SIGNAL_DETECT_MASK)
- (((x) << SGMII_SERDES_FIBER_SDO_LSB) & SGMII_SERDES_FIBER_SDO_MASK)
- (((x) << SGMII_SERDES_VCO_REG_LSB) & SGMII_SERDES_VCO_REG_MASK)
- (((x) & SGMII_SERDES_VCO_FAST_MASK) >> SGMII_SERDES_VCO_FAST_LSB)
- (((x) & SGMII_SERDES_VCO_SLOW_MASK) >> SGMII_SERDES_VCO_SLOW_LSB)
- int i;
- u32 reg, rev_sgmii_val;
- u32 vco_fast, vco_slow;
- u32 start_val = 0, end_val = 0;
- void __iomem *gregs = map_physmem(AR71XX_MII_BASE, AR71XX_MII_SIZE,
MAP_NOCACHE);
- void __iomem *pregs = map_physmem(AR71XX_PLL_BASE, AR71XX_PLL_SIZE,
MAP_NOCACHE);
- void __iomem *rregs = map_physmem(AR71XX_RESET_BASE, AR71XX_RESET_SIZE,
MAP_NOCACHE);
- const u32 mask = QCA956X_RESET_SGMII_ASSERT | QCA956X_RESET_SGMII;
- writel(BIT(2) | BIT(0), pregs + QCA956X_PLL_ETH_SGMII_SERDES_REG);
- reg = readl(gregs + QCA956X_GMAC_REG_SGMII_SERDES);
- vco_fast = SGMII_SERDES_VCO_FAST_GET(reg);
- vco_slow = SGMII_SERDES_VCO_SLOW_GET(reg);
- /* Set resistor calibration from 0000 to 1111 */
- for (i = 0; i < 0x10; i++) {
udelay(50);
start_val = i;
end_val = i;
} else {
end_val = i;
- if (start_val == 0)
- else
- writel((readl(gregs + QCA956X_GMAC_REG_SGMII_SERDES) &
- writel(SGMII_SERDES_CDR_BW_SET(3) | SGMII_SERDES_TX_DR_CTRL_SET(1) |
- setbits_be32(rregs + QCA956X_RESET_REG_RESET_MODULE, mask);
- mdelay(1);
- clrbits_be32(rregs + QCA956X_RESET_REG_RESET_MODULE, mask);
- mdelay(1);
- while (!(readl(gregs + QCA956X_GMAC_REG_SGMII_SERDES) & BIT(15)))
/* NOP */;
- int i;
- u32 s = 0, reg = 0;
- u32 _regs[] = {
MAP_NOCACHE);
- /* Force sgmii mode */
- writel(BIT(6) | BIT(15) | BIT(8), gregs + QCA956X_GMAC_REG_MR_AN_CTRL);
- udelay(10);
- writel(0x2 | BIT(5) | (0x2 << 6), gregs + QCA956X_GMAC_REG_SGMII_CONFIG);
- /* SGMII reset sequence sugguest by qca systems team. */
- writel(0, gregs + QCA956X_GMAC_REG_SGMII_RESET);
- for (i = 0; i < ARRAY_SIZE(_regs); i++) {
reg |= _regs[i];
- writel(readl(gregs + QCA956X_GMAC_REG_MR_AN_CTRL) & ~BIT(15),
- i = 0;
- s = (readl(gregs + QCA956X_GMAC_REG_SGMII_DEBUG) & 0xff);
- while (!(s == 0xf || s == 0x10)) {
udelay(100);
if (i++ == 10)
break;
- void __iomem *regs = map_physmem(AR71XX_GPIO_BASE, AR71XX_GPIO_SIZE,
MAP_NOCACHE);
MAP_NOCACHE);
- const u32 mask = QCA956X_RESET_SGMII_ASSERT | QCA956X_RESET_SGMII |
- /* Bits(Reserved in datasheet) should be set to 1 */
- const u32 mask_r = QCA956X_RESET_SGMII_ASSERT | QCA956X_RESET_SGMII |
- mdelay(1);
- clrbits_be32(rregs + QCA956X_RESET_REG_RESET_MODULE, mask_r);
- mdelay(1);
- /* Reset s17 switch(GPIO11) SYS_RST_L */
- writel(readl(regs + AR71XX_GPIO_REG_OE) & ~BIT(11),
- udelay(100);
- writel(readl(regs + AR71XX_GPIO_REG_OUT) & ~BIT(11),
- udelay(100);
- writel(readl(regs + AR71XX_GPIO_REG_OUT) | BIT(11),
- u32 reg;
MAP_NOCACHE);
MAP_NOCACHE);
- const u32 mask = QCA956X_RESET_GE0_MDIO | QCA956X_RESET_GE0_MAC |
- mdelay(1);
- mdelay(1);
- /* GPIO4 as MDI */
- reg = readl(regs + QCA956X_GPIO_REG_IN_ENABLE3);
- reg &= ~(0xff << 16);
- reg |= (0x4 << 16);
- writel(reg, regs + QCA956X_GPIO_REG_IN_ENABLE3);
- /* GPIO4 as MDO */
- reg = readl(regs + QCA956X_GPIO_REG_OUT_FUNC1);
- reg &= ~0xff;
- reg |= 0x20;
- writel(reg, regs + QCA956X_GPIO_REG_OUT_FUNC1);
- /* Init MDC(GPIO3) / MDIO(GPIO4) */
- reg = readl(regs + AR71XX_GPIO_REG_OE);
- reg &= ~BIT(4);
- writel(reg, regs + AR71XX_GPIO_REG_OE);
- udelay(100);
- reg &= ~BIT(3);
- udelay(100);
- /* GPIO3 as MDI */
- reg = readl(regs + QCA956X_GPIO_REG_OUT_FUNC0);
- reg &= ~(0xff << 24);
- reg |= (0x21 << 24);
- writel(reg, regs + QCA956X_GPIO_REG_OUT_FUNC0);
MAP_NOCACHE);
MAP_NOCACHE);
- qca956x_sgmii_cal();
- qca956x_s17_reset();
- qca956x_init_mdio();
- if (ath79_get_bootstrap() & QCA956X_BOOTSTRAP_REF_CLK_40)
- else
- qca956x_sgmii_setup();
- writel((3 << 16) | (3 << 14) | (1 << 0) | (1 << 6),
- writel((1 << 31) | (2 << 28) | (2 << 26) | (1 << 25),
- mdelay(1);
return -EINVAL;
+config SYS_VENDOR
- default "qca"
+config SYS_BOARD
- default "ap152"
- default "ap152"
- default 0x9f000000
- (((x) << RST_RESET_RTC_RESET_LSB) & RST_RESET_RTC_RESET_MASK)
- u32 val;
- regs = map_physmem(AR71XX_GPIO_BASE, AR71XX_GPIO_SIZE,
MAP_NOCACHE);
- /* UART : RX18, TX22 done
- val = readl(regs + AR71XX_GPIO_REG_OE);
- val |= QCA956X_GPIO(18);
- val &= ~QCA956X_GPIO(22);
- writel(val, regs + AR71XX_GPIO_REG_OE);
- val = readl(regs + QCA956X_GPIO_REG_OUT_FUNC5);
- val &= ~QCA956X_GPIO_MUX_MASK(16);
- val |= QCA956X_GPIO_OUT_MUX_UART0_SOUT << 16;
- writel(val, regs + QCA956X_GPIO_REG_OUT_FUNC5);
- val = readl(regs + QCA956X_GPIO_REG_IN_ENABLE0);
- val &= ~QCA956X_GPIO_MUX_MASK(8);
- val |= QCA956X_GPIO_IN_MUX_UART0_SIN << 8;
- writel(val, regs + QCA956X_GPIO_REG_IN_ENABLE0);
- val = readl(regs + AR71XX_GPIO_REG_OUT);
- val |= QCA956X_GPIO(22);
- writel(val, regs + AR71XX_GPIO_REG_OUT);
+} +#endif
- u32 reg;
- void __iomem *rst_regs = map_physmem(AR71XX_RESET_BASE,
- /* CPU:775, DDR:650, AHB:258 */
- qca956x_pll_init();
- qca956x_ddr_init();
- /* Take WMAC out of reset */
- reg = readl(rst_regs + QCA956X_RESET_REG_RESET_MODULE);
- reg &= (~RST_RESET_RTC_RESET_SET(1));
- writel(reg, rst_regs + QCA956X_RESET_REG_RESET_MODULE);
- ath79_eth_reset();
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE - 1)
- Serial Port
- {9600, 19200, 38400, 57600, 115200}
"bootm 0x9f060000"
- "ipaddr=192.168.1.1\0" \
- "serverip=192.168.1.10\0" \
- Diagnostics
Daniel Schwierzeck
