[PATCH] ARM: renesas: Turn on PIE for Gen3
Turn on PIE, so that the U-Boot binary can be started from any arbitrary location in DRAM instead of a predefined fixed one. Note that this patch is not setting SYS_TEXT_BASE=0x0 yet, since that triggers relocation bugs in env code that are yet to be fixed.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Biju Das biju.das.jz@bp.renesas.com Cc: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com --- arch/arm/mach-rmobile/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-rmobile/Kconfig b/arch/arm/mach-rmobile/Kconfig index 41322b2c4c..69e40cf382 100644 --- a/arch/arm/mach-rmobile/Kconfig +++ b/arch/arm/mach-rmobile/Kconfig @@ -17,6 +17,7 @@ config RCAR_GEN3 select PINCTRL select PINCONF select PINCTRL_PFC + select POSITION_INDEPENDENT select SUPPORT_SPL imply CMD_FS_UUID imply CMD_GPT
