[U-Boot] [PATCH] mpc8xxx: USB: fix: access of ehci struct elements
This patch fixes the access to the 'ehci' struct elements which should have been taken care off in 4ef01010aa4799c759d75e67007fdd3a38c88c8a Sorry about that.
Signed-off-by: Vivek Mahajan vivek.mahajan@freescale.com --- drivers/usb/host/ehci-fsl.c | 18 +++++++++--------- 1 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/usb/host/ehci-fsl.c b/drivers/usb/host/ehci-fsl.c index bf148c4..c674929 100644 --- a/drivers/usb/host/ehci-fsl.c +++ b/drivers/usb/host/ehci-fsl.c @@ -41,15 +41,15 @@ int ehci_hcd_init(void) struct usb_ehci *ehci;
ehci = (struct usb_ehci *)CONFIG_SYS_MPC8xxx_USB_ADDR; - hccr = (struct ehci_hccr *)((uint32_t)ehci->caplength); + hccr = (struct ehci_hccr *)((uint32_t)&ehci->caplength); hcor = (struct ehci_hcor *)((uint32_t) hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
/* Set to Host mode */ - setbits_le32((void *)ehci->usbmode, CM_HOST); + setbits_le32(&ehci->usbmode, CM_HOST);
- out_be32((void *)ehci->snoop1, SNOOP_SIZE_2GB); - out_be32((void *)ehci->snoop2, 0x80000000 | SNOOP_SIZE_2GB); + out_be32(&ehci->snoop1, SNOOP_SIZE_2GB); + out_be32(&ehci->snoop2, 0x80000000 | SNOOP_SIZE_2GB);
/* Init phy */ if (!strcmp(getenv("usb_phy_type"), "utmi")) @@ -58,13 +58,13 @@ int ehci_hcd_init(void) out_le32(&(hcor->or_portsc[0]), PORT_PTS_ULPI);
/* Enable interface. */ - setbits_be32((void *)ehci->control, USB_EN); + setbits_be32(&ehci->control, USB_EN);
- out_be32((void *)ehci->prictrl, 0x0000000c); - out_be32((void *)ehci->age_cnt_limit, 0x00000040); - out_be32((void *)ehci->sictrl, 0x00000001); + out_be32(&ehci->prictrl, 0x0000000c); + out_be32(&ehci->age_cnt_limit, 0x00000040); + out_be32(&ehci->sictrl, 0x00000001);
- in_le32((void *)ehci->usbmode); + in_le32(&ehci->usbmode);
return 0; }
2009/6/19 Vivek Mahajan vivek.mahajan@freescale.com:
Applied to u-boot-usb. Thanks,
Remy
Remy Bohmer
Vivek Mahajan
