[U-Boot] [PATCH v2 00/10] sunxi: Remove SYS_EXTRA_OPTIONS
Hello everyone,
This a V2 for my patchset that removes the SYS_EXTRA_OPTIONS from all sunxi defconfigs. The values in this variable are converted to Kconfig or simply removed.
Based on u-boot sunxi repository: git://git.denx.de/u-boot-sunxi.git next branch, from last commit: 002d907da51fdf10a03d389852645675529c78e6
* Changes since V1 *
- Patch 01: Rename the config optino to SUN7I_GMAC and move it in driver/net/Kconfig. Remove also the "default n" line in the KConfig. - Patch 02-03-04-05 : No modifications - Patch 06: Rename the config SUNXI_EMAC to SUN4I_EMAC - Patch 07: Move it to driver/net's Kconfig and remove "default n" line. - Patch 08-09: No modifications except the use of "help" instead of "---help---" option in Kconfig. - Patch 10: Remove the CONS_INDEX definition from sunxi-common header.
* Summary of patches *
Patch 1: Convert SUNXI_GMAC config to Kconfig and remove it from all defconfig. Patch 2: Remove AXP209_POWER configuration as this config is already converted in Kconfig (drivers/power). It is automatically chosen when the SoC is sun4i, sun5i or sun7i. Patch 3 and 4: Remove CMD_BMP and CMD_ZIP configs from SYS_EXTRA_OPTIONS. Patch 5: Remove SYS_EXTRA_OPTIONS from mk802_defconfig as it contains only USB_EHCI which is already converted to Kconfig. Patch 6, 7: Convert SUNXI_EMAC and CONFIG_RGMII to Kconfig and remove it from all SYS_EXTRA_OPTIONS entries. Patch 8 and 9: Convert CONFIG_SATAPWR and CONFIG_MACPWR to Kconfig. It becomes a string instead of the gpio number so the function sunxi_name_to_gpio is used to do the conversion from string to int. Patch 10: Convert console index (CONS_INDEX) to Kconfig. The default value is 1 except for sun5i which is 2 and sun8i which is 5.
Thank you in advance! Best regards, Mylène
Mylène Josserand (10): sunxi: Convert SUNXI_GMAC to Kconfig sunxi: icnova-a20-swac_defconfig: Remove AXP209_POWER sunxi: icnova-a20-swac_defconfig: Remove CMD_BMP from SYS_EXTRA_OPTIONS sunxi: icnova-a20-swac_defconfig: Remove CMD_UNZIP and SYS_EXTRA_OPTIONS sunxi: mk802_defconfig: Remove SYS_EXTRA_OPTIONS sunxi: Convert SUNXI_EMAC to Kconfig sunxi: Convert CONFIG_RGMII to Kconfig sunxi: Convert CONFIG_SATAPWR to Kconfig sunxi: Convert CONFIG_MACPWR to Kconfig sunxi: Convert CONS_INDEX to Kconfig
board/sunxi/Kconfig | 23 +++++++++++++++++++++++ board/sunxi/board.c | 12 +++++++----- configs/A10-OLinuXino-Lime_defconfig | 3 ++- configs/A10s-OLinuXino-M_defconfig | 2 +- configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 4 +++- configs/A20-OLinuXino-Lime_defconfig | 3 ++- configs/A20-OLinuXino_MICRO_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 4 +++- configs/Ampe_A76_defconfig | 1 - configs/Bananapi_defconfig | 4 +++- configs/Bananapro_defconfig | 4 +++- configs/CHIP_defconfig | 1 - configs/CSQ_CS908_defconfig | 2 +- configs/Colombus_defconfig | 3 ++- configs/Cubieboard2_defconfig | 3 ++- configs/Cubieboard_defconfig | 3 ++- configs/Cubietruck_defconfig | 4 +++- configs/Empire_electronix_d709_defconfig | 1 - configs/Empire_electronix_m712_defconfig | 1 - configs/Hummingbird_A31_defconfig | 3 ++- configs/Itead_Ibox_A20_defconfig | 3 ++- configs/Lamobo_R1_defconfig | 5 ++++- configs/Linksprite_pcDuino3_Nano_defconfig | 4 +++- configs/Linksprite_pcDuino3_defconfig | 3 ++- configs/Linksprite_pcDuino_defconfig | 2 +- configs/Marsboard_A10_defconfig | 2 +- configs/Mele_A1000G_quad_defconfig | 2 +- configs/Mele_A1000_defconfig | 3 ++- configs/Mele_I7_defconfig | 2 +- configs/Mele_M3_defconfig | 2 +- configs/Mele_M5_defconfig | 2 +- configs/Mele_M9_defconfig | 2 +- configs/Orangepi_defconfig | 4 +++- configs/Orangepi_mini_defconfig | 4 +++- configs/Sinlinx_SinA31s_defconfig | 2 +- configs/Sinovoip_BPI_M2_defconfig | 3 ++- configs/Sinovoip_BPI_M3_defconfig | 2 +- configs/Wits_Pro_A20_DKT_defconfig | 3 ++- configs/ba10_tv_box_defconfig | 2 +- configs/difrnce_dit4350_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/i12-tvbox_defconfig | 3 ++- configs/iNet_D978_rev2_defconfig | 1 - configs/icnova-a20-swac_defconfig | 2 +- configs/inet86dz_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/jesurun_q5_defconfig | 3 ++- configs/mixtile_loftq_defconfig | 4 +++- configs/mk802_defconfig | 1 - configs/orangepi_plus2e_defconfig | 2 +- configs/orangepi_plus_defconfig | 3 ++- configs/polaroid_mid2407pxe03_defconfig | 1 - configs/polaroid_mid2809pxe04_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - drivers/net/Kconfig | 17 +++++++++++++++++ include/configs/sunxi-common.h | 4 ---- 62 files changed, 122 insertions(+), 67 deletions(-)
Move the SUNXI_GMAC config option to Kconfig, remove it from SYS_EXTRA_OPTIONS and rename it into SUN7I_GMAC.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- configs/A20-OLinuXino-Lime2_defconfig | 3 ++- configs/A20-OLinuXino-Lime_defconfig | 3 ++- configs/A20-OLinuXino_MICRO_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 3 ++- configs/Bananapi_defconfig | 3 ++- configs/Bananapro_defconfig | 3 ++- configs/CSQ_CS908_defconfig | 2 +- configs/Colombus_defconfig | 3 ++- configs/Cubieboard2_defconfig | 3 ++- configs/Cubietruck_defconfig | 3 ++- configs/Hummingbird_A31_defconfig | 3 ++- configs/Itead_Ibox_A20_defconfig | 3 ++- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 3 ++- configs/Linksprite_pcDuino3_defconfig | 3 ++- configs/Mele_A1000G_quad_defconfig | 2 +- configs/Mele_I7_defconfig | 2 +- configs/Mele_M3_defconfig | 2 +- configs/Mele_M5_defconfig | 2 +- configs/Mele_M9_defconfig | 2 +- configs/Orangepi_defconfig | 3 ++- configs/Orangepi_mini_defconfig | 3 ++- configs/Sinlinx_SinA31s_defconfig | 2 +- configs/Sinovoip_BPI_M2_defconfig | 3 ++- configs/Wits_Pro_A20_DKT_defconfig | 3 ++- configs/i12-tvbox_defconfig | 3 ++- configs/icnova-a20-swac_defconfig | 3 ++- configs/mixtile_loftq_defconfig | 3 ++- drivers/net/Kconfig | 5 +++++ 29 files changed, 54 insertions(+), 28 deletions(-)
diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 8fd7c64e77..97df8596bc 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -6,10 +6,11 @@ CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 26e6ace103..9315efc884 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -4,10 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index d629eb1b36..a1787f9438 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -7,10 +7,11 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_VIDEO_VGA=y +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index b5d52dba24..14ec877e73 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -9,10 +9,11 @@ CONFIG_MMC3_PINS="PH" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 0f2ef1b7ed..eb47c4e848 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -4,11 +4,12 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index e3bb4b20d5..ba9ee61a00 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -6,11 +6,12 @@ CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="PH0" CONFIG_USB2_VBUS_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 448ce951a0..d78c5c482a 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -4,9 +4,9 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index d8272c5dcf..8a8c117719 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -14,9 +14,10 @@ CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_I2C_SDA="PA23" CONFIG_VIDEO_LCD_PANEL_I2C_SCL="PA24" CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index dfeb66c9fb..062d8e180e 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -4,10 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 10f3237cd5..f0c490c0f6 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -8,11 +8,12 @@ CONFIG_USB0_VBUS_PIN="PH17" CONFIG_USB0_VBUS_DET="PH22" CONFIG_USB0_ID_DET="PH19" CONFIG_VIDEO_VGA=y +CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPH(12)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index dc4133d081..599909c764 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -6,9 +6,10 @@ CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index baca3e84cc..d7043f638a 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -4,10 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 6fe79e2a6e..08314275e0 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -4,11 +4,12 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH10" +CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 622d35c70b..ba6c287d4e 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -5,11 +5,12 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=122 CONFIG_USB1_VBUS_PIN="PH11" +CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 9d2dfa5a7c..a7b95fea4b 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -4,10 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=122 +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index 4097e5bbe0..bb45ca19f1 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -5,9 +5,9 @@ CONFIG_DRAM_ZQ=120 CONFIG_INITIAL_USB_SCAN_DELAY=2000 CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index eb3c74c55d..abe362af20 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -4,9 +4,9 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=120 CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index 037e768c64..fe4dcc4cbc 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -7,9 +7,9 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index e64e45257b..ac239da91d 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -6,10 +6,10 @@ CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=122 CONFIG_MMC0_CD_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index c4e599351f..5f2772bc6e 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -4,9 +4,9 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=120 CONFIG_USB1_VBUS_PIN="PC27" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index ccece01029..5b624e2883 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -7,11 +7,12 @@ CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index febdcd07ad..4506f8f74f 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -9,11 +9,12 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 9ac89121bc..e9ba316246 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -8,9 +8,9 @@ CONFIG_MMC3_PINS="PC" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 267aaf8ad1..46da7ed949 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -4,9 +4,10 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 0735055622..b703d36963 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -9,10 +9,11 @@ CONFIG_VIDEO_LCD_POWER="PH8" CONFIG_VIDEO_LCD_BL_EN="PH7" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 8012c078fb..098918d27e 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -4,9 +4,10 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_VIDEO_COMPOSITE=y +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,MACPWR=SUNXI_GPH(21)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 78cc3bb972..7ae4ccc01b 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -11,9 +11,10 @@ CONFIG_USB1_VBUS_PIN="PG10" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH22" CONFIG_VIDEO_LCD_PANEL_LVDS=y +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP,CMD_UNZIP" +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,CMD_BMP,CMD_UNZIP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 8ca8467a4e..3155673055 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -5,9 +5,10 @@ CONFIG_DRAM_ZQ=251 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" +CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPA(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 929b9e273e..a8fe3e4c89 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -175,6 +175,11 @@ config RTL8169 This driver supports Realtek 8169 series gigabit ethernet family of PCI/PCIe chipsets/adapters.
+config SUN7I_GMAC + bool "Enable GMAC Ethernet support" + help + Enable the support for Sun7i GMAC Ethernet controller + config SUN8I_EMAC bool "Allwinner Sun8i Ethernet MAC support" depends on DM_ETH
On Wed, Mar 29, 2017 at 09:26:28AM +0200, Mylène Josserand wrote:
+config SUN7I_GMAC
- bool "Enable GMAC Ethernet support"
GMAC itself is a quite common term when talking about a Gigabit Ethernet controller. How about something like "Enable Allwinner GMAC Ethernet Support"?
Once fixed, Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Maxime
Remove the AXP209_POWER option from SYS_EXTRA_OPTIONS. As this configuration already exists on Kconfig, we just need to remove it from defconfig.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/icnova-a20-swac_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 7ae4ccc01b..37ef55f760 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -14,7 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,CMD_BMP,CMD_UNZIP" +CONFIG_SYS_EXTRA_OPTIONS="CMD_BMP,CMD_UNZIP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
This configuration is not necessary in a defconfig file so it is removed from the SYS_EXTRA_OPTIONS.
diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 37ef55f760..b20fc80cda 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -14,7 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CMD_BMP,CMD_UNZIP" +CONFIG_SYS_EXTRA_OPTIONS="CMD_UNZIP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
Remove this command as it is not necessary in defconfig file. As there is no more command/option in SYS_EXTRA_OPTIONS, it can be removed from this defconfig file.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/icnova-a20-swac_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index b20fc80cda..d164b17eec 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -14,7 +14,6 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CMD_UNZIP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
The USB_EHCI configuration is already set in this defconfig using kconfig's config. This configuration in SYS_EXTRA_OPTIONS must be removed and so the SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- configs/mk802_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 47bbf62274..2f63320fb9 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -4,7 +4,6 @@ CONFIG_MACH_SUN4I=y CONFIG_USB2_VBUS_PIN="PH12" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set
Convert the SUNXI_EMAC config to Kconfig. Remove it from SYS_EXTRA_OPTIONS from many sunxi defconfig and renamed it into SUN4I_EMAC to not confuse it with SUN8I_EMAC.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- configs/A10-OLinuXino-Lime_defconfig | 3 ++- configs/A10s-OLinuXino-M_defconfig | 2 +- configs/Cubieboard_defconfig | 3 ++- configs/Linksprite_pcDuino_defconfig | 2 +- configs/Marsboard_A10_defconfig | 2 +- configs/Mele_A1000_defconfig | 3 ++- configs/ba10_tv_box_defconfig | 2 +- configs/jesurun_q5_defconfig | 3 ++- drivers/net/Kconfig | 6 ++++++ 9 files changed, 18 insertions(+), 8 deletions(-)
diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 50436a7a52..bc7220b78e 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -9,11 +9,12 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUN4I_EMAC=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index e2bebf827c..11009a1566 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -9,10 +9,10 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=1 CONFIG_USB1_VBUS_PIN="PB10" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUN4I_EMAC=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 64aebed2f1..d55d0232b2 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -7,9 +7,10 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,SATAPWR=SUNXI_GPB(8)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index ab094a6553..640a310159 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -6,9 +6,9 @@ CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 0d381ff1b8..bdf257a444 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -4,10 +4,10 @@ CONFIG_MACH_SUN4I=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUN4I_EMAC=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 820d5ed98e..bd10e535db 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -7,9 +7,10 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(15)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index c60766ce3c..02f4f4f085 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -9,10 +9,10 @@ CONFIG_USB2_VBUS_PIN="PH12" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-ba10-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 6e4e6ca235..fbd2a78502 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -7,10 +7,11 @@ CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(19)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(19)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SUN4I_EMAC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index a8fe3e4c89..6d97af0739 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -180,6 +180,12 @@ config SUN7I_GMAC help Enable the support for Sun7i GMAC Ethernet controller
+config SUN4I_EMAC + bool "Allwinner Sun4i Ethernet MAC support" + depends on DM_ETH + help + This driver supports the Allwinner based SUN4I Ethernet MAC. + config SUN8I_EMAC bool "Allwinner Sun8i Ethernet MAC support" depends on DM_ETH
Thanks! Maxime
Convert CONFIG_RGMII to Kconfig. Thanks to that, it is possible to update defconfig files of SYS_EXTRA_OPTIONS accordingly and remove it when it is possible.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- configs/A20-OLinuXino-Lime2_defconfig | 3 ++- configs/A20-Olimex-SOM-EVB_defconfig | 3 ++- configs/Bananapi_defconfig | 3 ++- configs/Bananapro_defconfig | 3 ++- configs/Colombus_defconfig | 2 +- configs/Cubietruck_defconfig | 3 ++- configs/Hummingbird_A31_defconfig | 2 +- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 3 ++- configs/Orangepi_defconfig | 3 ++- configs/Orangepi_mini_defconfig | 3 ++- configs/Sinovoip_BPI_M2_defconfig | 2 +- configs/Wits_Pro_A20_DKT_defconfig | 2 +- configs/mixtile_loftq_defconfig | 3 ++- drivers/net/Kconfig | 6 ++++++ 15 files changed, 30 insertions(+), 14 deletions(-)
diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 97df8596bc..e698fefb87 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -4,13 +4,14 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 14ec877e73..c361798623 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -7,13 +7,14 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH0" CONFIG_MMC3_PINS="PH" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPC(3)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index eb47c4e848..3b5678419a 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -3,13 +3,14 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_RGMII=y CONFIG_VIDEO_COMPOSITE=y CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index ba9ee61a00..cbdb980fc9 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH0" CONFIG_USB2_VBUS_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y @@ -11,7 +12,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 8a8c117719..4aaae91b6d 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=240 CONFIG_DRAM_ZQ=251 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="" CONFIG_I2C0_ENABLE=y CONFIG_AXP_GPIO=y @@ -17,7 +18,6 @@ CONFIG_VIDEO_LCD_PANEL_EDP_4_LANE_1620M_VIA_ANX9804=y CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index f0c490c0f6..c6f7ae64d5 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PH17" CONFIG_USB0_VBUS_DET="PH22" CONFIG_USB0_ID_DET="PH19" @@ -13,7 +14,7 @@ CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(12)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 599909c764..614ad12b06 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=251 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_VIDEO_VGA_VIA_LCD=y @@ -9,7 +10,6 @@ CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 08314275e0..1b1bdf3a60 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -4,12 +4,13 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH10" +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index ba6c287d4e..439eaf9759 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -5,12 +5,13 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=122 CONFIG_USB1_VBUS_PIN="PH11" +CONFIG_RGMII=y CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,SATAPWR=SUNXI_GPH(2)" +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 5b624e2883..b5e811ff9f 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_VGA=y @@ -12,7 +13,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index 4506f8f74f..b04de1701d 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH10" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_COMPOSITE=y @@ -14,7 +15,7 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPH(23)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 46da7ed949..c04ec58250 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="" CONFIG_USB2_VBUS_PIN="" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index b703d36963..26af2da5b6 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 +CONFIG_RGMII=y CONFIG_VIDEO_VGA=y CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:24,pclk_khz:65000,le:159,ri:160,up:22,lo:15,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH8" @@ -13,7 +14,6 @@ CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 3155673055..4a2eed8de1 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -3,12 +3,13 @@ CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=251 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH24" CONFIG_USB2_VBUS_PIN="" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPA(21)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPA(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6d97af0739..5e3e42682d 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -163,6 +163,12 @@ config PCH_GBE This MAC is present in Intel Platform Controller Hub EG20T. It supports 10/100/1000 Mbps operation.
+config RGMII + bool "Enable RGMII" + help + Enable the support of the Reduced Gigabit Media-Independent + Interface (RGMII). + config RTL8139 bool "Realtek 8139 series Ethernet controller driver" help
Thanks! Maxime
Convert the CONFIG_SATAPWR into kconfig. Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some defconfigs.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/Kconfig | 7 +++++++ board/sunxi/board.c | 7 ++++--- configs/A10-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino-Lime2_defconfig | 2 +- configs/A20-OLinuXino-Lime_defconfig | 2 +- configs/A20-OLinuXino_MICRO_defconfig | 2 +- configs/A20-Olimex-SOM-EVB_defconfig | 2 +- configs/Cubieboard2_defconfig | 2 +- configs/Cubieboard_defconfig | 2 +- configs/Cubietruck_defconfig | 2 +- configs/Itead_Ibox_A20_defconfig | 2 +- configs/Lamobo_R1_defconfig | 3 ++- configs/Linksprite_pcDuino3_Nano_defconfig | 2 +- configs/Linksprite_pcDuino3_defconfig | 2 +- configs/Sinovoip_BPI_M3_defconfig | 2 +- configs/orangepi_plus_defconfig | 3 ++- 16 files changed, 27 insertions(+), 17 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 00011331b9..6de59d36c7 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -683,6 +683,13 @@ config VIDEO_LCD_TL059WV5C0
endchoice
+config SATAPWR + string "SATA power pin" + default "" + help + Set the pins used to power the SATA. This takes a string in the + format understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of + port H.
config GMAC_TX_DELAY int "GMAC Transmit Clock Delay Chain" diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 53656383d5..131986bd17 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -80,7 +80,7 @@ DECLARE_GLOBAL_DATA_PTR; /* add board specific code here */ int board_init(void) { - __maybe_unused int id_pfr1, ret; + __maybe_unused int id_pfr1, ret, satapwr_pin;
gd->bd->bi_boot_params = (PHYS_SDRAM_0 + 0x100);
@@ -118,8 +118,9 @@ int board_init(void) return ret;
#ifdef CONFIG_SATAPWR - gpio_request(CONFIG_SATAPWR, "satapwr"); - gpio_direction_output(CONFIG_SATAPWR, 1); + satapwr_pin = sunxi_name_to_gpio(CONFIG_SATAPWR); + gpio_request(satapwr_pin, "satapwr"); + gpio_direction_output(satapwr_pin, 1); #endif #ifdef CONFIG_MACPWR gpio_request(CONFIG_MACPWR, "macpwr"); diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index bc7220b78e..1e7f34b89c 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -6,10 +6,10 @@ CONFIG_DRAM_CLK=480 CONFIG_DRAM_EMR1=4 CONFIG_SYS_CLK_FREQ=912000000 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PC3" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index e698fefb87..e171dd6194 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -7,11 +7,11 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SATAPWR="PC3" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 9315efc884..6b675fd196 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -4,11 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PC3" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index a1787f9438..e1d7b53bcb 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -7,11 +7,11 @@ CONFIG_MMC0_CD_PIN="PH1" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_VIDEO_VGA=y +CONFIG_SATAPWR="PB8" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index c361798623..4a0c55a4a2 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -10,11 +10,11 @@ CONFIG_MMC_SUNXI_SLOT_EXTRA=3 CONFIG_RGMII=y CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" +CONFIG_SATAPWR="PC3" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index 062d8e180e..fa84acc737 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -4,11 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PB8" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index d55d0232b2..e73d9c384b 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -4,10 +4,10 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PB8" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index c6f7ae64d5..0848a32bf9 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -9,12 +9,12 @@ CONFIG_USB0_VBUS_PIN="PH17" CONFIG_USB0_VBUS_DET="PH22" CONFIG_USB0_ID_DET="PH19" CONFIG_VIDEO_VGA=y +CONFIG_SATAPWR="PH12" CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=1 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(12)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index d7043f638a..e73fade645 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -4,11 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_MMC0_CD_PIN="PH1" +CONFIG_SATAPWR="PB8" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPB(8)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 1b1bdf3a60..6f3f08cb43 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -5,12 +5,13 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC0_CD_PIN="PH10" CONFIG_RGMII=y +CONFIG_SATAPWR="PB3" CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23),SATAPWR=SUNXI_GPB(3)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 439eaf9759..91a96f05a3 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -6,12 +6,12 @@ CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=122 CONFIG_USB1_VBUS_PIN="PH11" CONFIG_RGMII=y +CONFIG_SATAPWR="PH2" CONFIG_SUN7I_GMAC=y CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index a7b95fea4b..4307b8dcef 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -4,11 +4,11 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=122 +CONFIG_SATAPWR="PH2" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPH(2)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index d15ac2000b..80b5a7a647 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -11,9 +11,9 @@ CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_USB0_ID_DET="PH11" CONFIG_USB1_VBUS_PIN="PD24" CONFIG_AXP_GPIO=y +CONFIG_SATAPWR="PD25" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinovoip-bpi-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPD(25)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index bf88fef3b8..9729580c96 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -7,9 +7,10 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PG13" +CONFIG_SATAPWR="PG11" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPG(11),MACPWR=SUNXI_GPD(6)" +CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set
Convert the CONFIG_MACPWR to Kconfig and update all the sunxi defconfigs that used it in SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com Acked-by: Maxime Ripard maxime.ripard@free-electrons.com --- board/sunxi/Kconfig | 7 +++++++ board/sunxi/board.c | 7 ++++--- configs/Bananapi_defconfig | 2 +- configs/Bananapro_defconfig | 2 +- configs/Lamobo_R1_defconfig | 2 +- configs/Mele_A1000_defconfig | 2 +- configs/Orangepi_defconfig | 2 +- configs/Orangepi_mini_defconfig | 2 +- configs/i12-tvbox_defconfig | 2 +- configs/jesurun_q5_defconfig | 2 +- configs/mixtile_loftq_defconfig | 2 +- configs/orangepi_plus2e_defconfig | 2 +- configs/orangepi_plus_defconfig | 2 +- 13 files changed, 22 insertions(+), 14 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 6de59d36c7..9963b6b5d8 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -318,6 +318,13 @@ config OLD_SUNXI_KERNEL_COMPAT Set this to enable various workarounds for old kernels, this results in sub-optimal settings for newer kernels, only enable if needed.
+config MACPWR + string "MAC power pin" + default "" + help + Set the pin used to power the MAC. This takes a string in the format + understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of port H. + config MMC depends on !UART0_PORT_F default y if ARCH_SUNXI diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 131986bd17..906a06d0d9 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -80,7 +80,7 @@ DECLARE_GLOBAL_DATA_PTR; /* add board specific code here */ int board_init(void) { - __maybe_unused int id_pfr1, ret, satapwr_pin; + __maybe_unused int id_pfr1, ret, satapwr_pin, macpwr_pin;
@@ -123,8 +123,9 @@ int board_init(void) gpio_direction_output(satapwr_pin, 1); #endif #ifdef CONFIG_MACPWR - gpio_request(CONFIG_MACPWR, "macpwr"); - gpio_direction_output(CONFIG_MACPWR, 1); + macpwr_pin = sunxi_name_to_gpio(CONFIG_MACPWR); + gpio_request(macpwr_pin, "macpwr"); + gpio_direction_output(macpwr_pin, 1); #endif
/* Uses dm gpio code so do this here and not in i2c_init_board() */ diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 3b5678419a..4b7c7e4d20 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_RGMII=y CONFIG_VIDEO_COMPOSITE=y CONFIG_SUN7I_GMAC=y @@ -10,7 +11,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index cbdb980fc9..7736de9216 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH0" CONFIG_USB2_VBUS_PIN="PH1" @@ -12,7 +13,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 6f3f08cb43..c3f4bdd85c 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_MMC0_CD_PIN="PH10" CONFIG_RGMII=y CONFIG_SATAPWR="PB3" @@ -11,7 +12,6 @@ CONFIG_GMAC_TX_DELAY=4 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index bd10e535db..9532d75710 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -2,12 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y +CONFIG_MACPWR="PH15" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(15)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index b5e811ff9f..5dc3b5c4bc 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH26" CONFIG_USB2_VBUS_PIN="PH22" @@ -13,7 +14,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index b04de1701d..eaf92d402a 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 +CONFIG_MACPWR="PH23" CONFIG_MMC0_CD_PIN="PH10" CONFIG_MMC3_CD_PIN="PH11" CONFIG_MMC_SUNXI_SLOT_EXTRA=3 @@ -15,7 +16,6 @@ CONFIG_GMAC_TX_DELAY=3 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(23)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 098918d27e..cbdc64f958 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -3,11 +3,11 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 +CONFIG_MACPWR="PH21" CONFIG_VIDEO_COMPOSITE=y CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index fbd2a78502..b9f48aaa0e 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -3,11 +3,11 @@ CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=312 +CONFIG_MACPWR="PH19" CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPH(19)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 4a2eed8de1..f1e3984c29 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=251 +CONFIG_MACPWR="PA21" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_RGMII=y CONFIG_USB1_VBUS_PIN="PH24" @@ -9,7 +10,6 @@ CONFIG_USB2_VBUS_PIN="" CONFIG_SUN7I_GMAC=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPA(21)" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_plus2e_defconfig b/configs/orangepi_plus2e_defconfig index df05d370e4..4f1336d211 100644 --- a/configs/orangepi_plus2e_defconfig +++ b/configs/orangepi_plus2e_defconfig @@ -5,10 +5,10 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus2e" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index 9729580c96..b765459d07 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -5,12 +5,12 @@ CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y +CONFIG_MACPWR="PD6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB1_VBUS_PIN="PG13" CONFIG_SATAPWR="PG11" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="MACPWR=SUNXI_GPD(6)" CONFIG_CONSOLE_MUX=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set
Convert the CONS_INDEX configuration to Kconfig. Update sunxi's defconfigs to remove SYS_EXTRA_OPTIONS variable not needed anymore. Default value is 1 except for sun5i (equals 2) and sun8i (equals 5).
Signed-off-by: Mylène Josserand mylene.josserand@free-electrons.com --- board/sunxi/Kconfig | 9 +++++++++ configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/CHIP_defconfig | 1 - configs/Empire_electronix_d709_defconfig | 1 - configs/Empire_electronix_m712_defconfig | 1 - configs/difrnce_dit4350_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/iNet_D978_rev2_defconfig | 1 - configs/inet86dz_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/polaroid_mid2407pxe03_defconfig | 1 - configs/polaroid_mid2809pxe04_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - include/configs/sunxi-common.h | 4 ---- 20 files changed, 9 insertions(+), 22 deletions(-)
diff --git a/board/sunxi/Kconfig b/board/sunxi/Kconfig index 9963b6b5d8..706c62d233 100644 --- a/board/sunxi/Kconfig +++ b/board/sunxi/Kconfig @@ -157,6 +157,15 @@ config ARM_BOOT_HOOK_RMR This allows both the SPL and the U-Boot proper to be entered in either mode and switch to AArch64 if needed.
+config CONS_INDEX + int "UART used for console" + default 2 if MACH_SUN5I + default 5 if MACH_SUN8I + default 1 + help + Configures the console index for Allwinner SoC. 2 for SUN5I, 5 for SUN8I + and 1 otherwise. + config DRAM_TYPE int "sunxi dram type" depends on MACH_SUN8I_A83T diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index 361d90a701..1dbd671d01 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -12,7 +12,6 @@ CONFIG_VIDEO_LCD_POWER="PB10" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 3191098bf1..6aec11d594 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_POWER="AXP0-0" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 5020724aa8..59a66c1b9d 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 65d0c9847a..080f4718b2 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -8,7 +8,6 @@ CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y CONFIG_USB0_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_DFU=y diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 831949a08b..756636d41e 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-d709" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index 4b51380fc0..22d43785be 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-m712" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index 6149c94ff4..a04b876266 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-difrnce-dit4350" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 02a8a78db5..ded42cd6c5 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index 913a7638f8..930a4e6011 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-gt90h-v4" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index d5e63095ab..8437c7b8c2 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -16,7 +16,6 @@ CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-inet-d978-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index 4ed94dc1e3..28a8a4edf5 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-inet86dz" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index 7c306f8b59..b6502f1bc6 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 2ac6f4ccac..f88a0bedd0 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2407pxe03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index d9bcd4f554..c98d66235a 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2809pxe04" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 6b516db4b8..6d4889f9d9 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="AXP0-1" CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 971dcea1c8..c3eae9dd74 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index f99e347e43..8140d4fa1a 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index 182bd9acf3..7ba8fbb196 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -15,7 +15,6 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index ab2d33f3aa..8d31847a4a 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -252,10 +252,6 @@ extern int soft_i2c_gpio_scl; defined CONFIG_SY8106A_POWER #endif
-#ifndef CONFIG_CONS_INDEX -#define CONFIG_CONS_INDEX 1 /* UART0 */ -#endif - #ifdef CONFIG_REQUIRE_SERIAL_CONSOLE #if CONFIG_CONS_INDEX == 1 #ifdef CONFIG_MACH_SUN9I
Did you rebase on the current sunxi tree recently? There's at least two boards (CHIP Pro and A23 EVB) that are unfortunately missing from that least, and whose compilation now will cause a warning :/
The CHIP Pro also has a bunch of other (new) options in SYS_EXTRA_OPTIONS, but you don't have to convert them if you don't want to.
+config CONS_INDEX
- int "UART used for console"
- default 2 if MACH_SUN5I
- default 5 if MACH_SUN8I
- default 1
- help
and 1 otherwise.
This is a generic option that is used across a number of platforms, perhaps this would be better suited to be in drivers/serial (or some place else?)
Thanks! Maxime
Hi Maxime,
Thank you for all your reviews!
I based my series against "next" and these new defconfigs are not available. Should I rebase my patches against "master" branch?
I will have a look :)
+config CONS_INDEX
- default 1
- help
and 1 otherwise.
Sure, it makes sense.
Thanks!
Maxime Ripard
Mylene Josserand
Mylène Josserand
