[PATCH v1] doc: Update path to source_file_format.rst
Previously, the file extension was .txt, and it referenced the uImage.FIT directory, which no longer exists. This commit updates the path accordingly.
Signed-off-by: Joao Marcos Costa jmcosta944@gmail.com --- doc/usage/fit/howto.rst | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/doc/usage/fit/howto.rst b/doc/usage/fit/howto.rst index c933703d1d..8b38cd534d 100644 --- a/doc/usage/fit/howto.rst +++ b/doc/usage/fit/howto.rst @@ -22,7 +22,7 @@ for its latest version. mkimage (together with dtc) takes as input an image source file, which describes the contents of the image and defines its various properties used during booting. By convention, image source file has the ".its" extension, also, the details of its format are given in -doc/uImage.FIT/source_file_format.txt. The actual data that is to be included in +doc/usage/fit/source_file_format.rst. The actual data that is to be included in the uImage (kernel, ramdisk, etc.) is specified in the image source file in the form of paths to appropriate data files. The outcome of the image creation process is a binary file (by convention with the ".itb" extension) that
Thank you for updating the reference.
In the HTML documentation we want to generate a link here using:
:doc:`source_file_format`
Best regards
Heinrich
Best regards
Heinrich
Joao Marcos Costa
