[PATCH] ARM: MediaTek: amend IC description for MediaTek MT8512
The description for MT8512 has some mistake, so correct it.
Signed-off-by: Mingming Lee Mingming.Lee@mediatek.com --- arch/arm/mach-mediatek/Kconfig | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-mediatek/Kconfig b/arch/arm/mach-mediatek/Kconfig index 0042e57017..7f40ba9319 100644 --- a/arch/arm/mach-mediatek/Kconfig +++ b/arch/arm/mach-mediatek/Kconfig @@ -47,10 +47,10 @@ config TARGET_MT8512 select ARM64 select MT8512 help - The MediaTek MT8512 is a ARM64-based SoC with a quad-core Cortex-A53. + The MediaTek MT8512 is a ARM64-based SoC with a dual-core Cortex-A53. including UART, SPI, USB2.0 and OTG, SD and MMC cards, NAND, PWM, - Ethernet, IR TX/RX, I2C, I2S, S/PDIF, and built-in Wi-Fi / Bluetooth combo - chip and several DDR3 and DDR4 options. + IR RX, I2C, I2S, S/PDIF, and built-in Wi-Fi / Bluetooth digital + and several LPDDR3 and LPDDR4 options.
config TARGET_MT8516 bool "MediaTek MT8516 SoC"
mingming lee
