[RESEND PATCH v6 2/2] mmc: openpiton: add piton_mmc driver
This commit adds support to piton_mmc driver for OpenPiton-riscv64 In particular, this driver
- V6 . change type of address . move declarations ahead . loop style update
Signed-off-by: Tianrui Wei tianrui-wei@outlook.com Signed-off-by: Jonathan Balkind jbalkind@ucsb.edu --- drivers/mmc/Kconfig | 9 +++ drivers/mmc/Makefile | 1 + drivers/mmc/piton_mmc.c | 169 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 179 insertions(+) create mode 100644 drivers/mmc/piton_mmc.c
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 8901456967..096d6a930c 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -727,6 +727,15 @@ config MMC_SUNXI_HAS_MODE_SWITCH bool depends on MMC_SUNXI
+config MMC_PITON + bool "MMC support for OpenPiton SoC" + depends on DM_MMC && BLK + help + This selects support for the SD host controller on + OpenPiton SoC. Note that this SD controller directly + exposes the contents of the SD card as memory mapped, + so there is no manual configuration required + config GENERIC_ATMEL_MCI bool "Atmel Multimedia Card Interface support" depends on DM_MMC && BLK && ARCH_AT91 diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 89d6af3db3..cc08b41d0d 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -72,6 +72,7 @@ obj-$(CONFIG_MMC_SDHCI_XENON) += xenon_sdhci.o obj-$(CONFIG_MMC_SDHCI_ZYNQ) += zynq_sdhci.o
obj-$(CONFIG_MMC_SUNXI) += sunxi_mmc.o +obj-$(CONFIG_MMC_PITON) += piton_mmc.o obj-$(CONFIG_MMC_UNIPHIER) += tmio-common.o uniphier-sd.o obj-$(CONFIG_RENESAS_SDHI) += tmio-common.o renesas-sdhi.o obj-$(CONFIG_MMC_BCM2835) += bcm2835_sdhost.o diff --git a/drivers/mmc/piton_mmc.c b/drivers/mmc/piton_mmc.c new file mode 100644 index 0000000000..32671d1a89 --- /dev/null +++ b/drivers/mmc/piton_mmc.c @@ -0,0 +1,169 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2009 SAMSUNG Electronics + * Minkyu Kang mk7.kang@samsung.com + * Jaehoon Chung jh80.chung@samsung.com + * Portions Copyright 2011-2019 NVIDIA Corporation + * Portions Copyright 2021 Tianrui Wei + * This file is adapted from tegra_mmc.c + * Tianrui Wei tianrui-wei@outlook.com + */ + +#include <asm/gpio.h> +#include <asm/io.h> +#include <common.h> +#include <div64.h> +#include <dm.h> +#include <errno.h> +#include <linux/bitops.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <linux/types.h> +#include <log.h> +#include <mmc.h> + +struct piton_mmc_plat { + struct mmc_config cfg; + struct mmc mmc; +}; + +struct piton_mmc_priv { + void __iomem *piton_mmc_base_addr; /* peripheral id */ +}; + +/* + * see mmc_read_blocks to see how it is used. + * start block is hidden at cmd->arg + * also, initialize the block size at init + */ +static int piton_mmc_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + /* check first if this is a pure command */ + if (!data) + return 0; + + struct piton_mmc_priv *priv = dev_get_priv(dev); + u32 *buff, *start_addr; + size_t byte_cnt, start_block; + + buff = (u32 *)data->dest; + start_block = cmd->cmdarg; + start_addr = priv->piton_mmc_base_addr + start_block; + + /* if there is a read */ + if (data->flags & MMC_DATA_READ) { + for (byte_cnt = data->blocks * data->blocksize; byte_cnt; + byte_cnt -= sizeof(u32)) { + *buff++ = readl(start_addr++); + } + } else { + return -ENOSYS; + } + + return 0; +} + +static int piton_mmc_ofdata_to_platdata(struct udevice *dev) +{ + struct piton_mmc_priv *priv = dev_get_priv(dev); + struct piton_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_config *cfg; + struct mmc *mmc; + /* fill in device description */ + struct blk_desc *bdesc; + + priv->piton_mmc_base_addr = (void *)dev_read_addr(dev); + cfg = &plat->cfg; + cfg->name = "PITON MMC"; + cfg->host_caps = MMC_MODE_8BIT; + cfg->f_max = 100000; + cfg->f_min = 400000; + cfg->voltages = MMC_VDD_21_22; + + mmc = &plat->mmc; + mmc->read_bl_len = MMC_MAX_BLOCK_LEN; + mmc->capacity_user = 0x100000000; + mmc->capacity_user *= mmc->read_bl_len; + mmc->capacity_boot = 0; + mmc->capacity_rpmb = 0; + for (int i = 0; i < 4; i++) + mmc->capacity_gp[i] = 0; + mmc->capacity = 0x2000000000ULL; + mmc->has_init = 1; + + bdesc = mmc_get_blk_desc(mmc); + bdesc->lun = 0; + bdesc->hwpart = 0; + bdesc->type = 0; + bdesc->blksz = mmc->read_bl_len; + bdesc->log2blksz = LOG2(bdesc->blksz); + bdesc->lba = lldiv(mmc->capacity, mmc->read_bl_len); + + return 0; +} + +/* test if the micro sd card is present + * always return 1, which means present + */ +static int piton_mmc_getcd(struct udevice *dev) +{ + /* + * always return 1 + */ + return 1; +} + +/* dummy function, piton_mmc don't need initialization + * in hw + */ +static const struct dm_mmc_ops piton_mmc_ops = { + .send_cmd = piton_mmc_send_cmd, + .get_cd = piton_mmc_getcd, +}; + +static int piton_mmc_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct piton_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_config *cfg = &plat->cfg; + + cfg->name = dev->name; + upriv->mmc = &plat->mmc; + upriv->mmc->has_init = 1; + upriv->mmc->capacity = 0x2000000000ULL; + upriv->mmc->read_bl_len = MMC_MAX_BLOCK_LEN; + return 0; +} + +static int piton_mmc_bind(struct udevice *dev) +{ + struct piton_mmc_plat *plat = dev_get_platdata(dev); + struct mmc_config *cfg = &plat->cfg; + + cfg->name = dev->name; + cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_8BIT; + cfg->voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34; + cfg->f_min = 1000000; + cfg->f_max = 52000000; + cfg->b_max = U32_MAX; + + return mmc_bind(dev, &plat->mmc, cfg); +} + +static const struct udevice_id piton_mmc_ids[] = { + {.compatible = "openpiton,piton-mmc"}, + {/* sentinel */} +}; + +U_BOOT_DRIVER(piton_mmc_drv) = { + .name = "piton_mmc", + .id = UCLASS_MMC, + .of_match = piton_mmc_ids, + .ofdata_to_platdata = piton_mmc_ofdata_to_platdata, + .bind = piton_mmc_bind, + .probe = piton_mmc_probe, + .ops = &piton_mmc_ops, + .platdata_auto_alloc_size = sizeof(struct piton_mmc_plat), + .priv_auto_alloc_size = sizeof(struct piton_mmc_priv), +};
Dear Tianrui,
+config MMC_PITON
- bool "MMC support for OpenPiton SoC"
- depends on DM_MMC && BLK
- help
Fix indentation.
Ditto.
- (C) Copyright 2009 SAMSUNG Electronics
- Minkyu Kang mk7.kang@samsung.com
- Jaehoon Chung jh80.chung@samsung.com
- Portions Copyright 2011-2019 NVIDIA Corporation
- Portions Copyright 2021 Tianrui Wei
- This file is adapted from tegra_mmc.c
- Tianrui Wei tianrui-wei@outlook.com
- struct mmc_config cfg;
- struct mmc mmc;
- void __iomem *piton_mmc_base_addr; /* peripheral id */
- see mmc_read_blocks to see how it is used.
- start block is hidden at cmd->arg
- also, initialize the block size at init
Ditto.
- /* check first if this is a pure command */
- if (!data)
- struct piton_mmc_priv *priv = dev_get_priv(dev);
- u32 *buff, *start_addr;
- size_t byte_cnt, start_block;
- buff = (u32 *)data->dest;
- start_block = cmd->cmdarg;
- start_addr = priv->piton_mmc_base_addr + start_block;
- /* if there is a read */
- if (data->flags & MMC_DATA_READ) {
- } else {
return -ENOSYS;
Is is right to return -ENOSYS? MMC_DATA_WRITE doesn't support?
- struct piton_mmc_plat *plat = dev_get_platdata(dev);
- struct mmc_config *cfg;
- struct mmc *mmc;
- /* fill in device description */
- struct blk_desc *bdesc;
- priv->piton_mmc_base_addr = (void *)dev_read_addr(dev);
- cfg = &plat->cfg;
- cfg->name = "PITON MMC";
- cfg->host_caps = MMC_MODE_8BIT;
- cfg->f_max = 100000;
f_max is 100K? I don't think so.
- cfg->f_min = 400000;
- cfg->voltages = MMC_VDD_21_22;
- mmc = &plat->mmc;
- mmc->read_bl_len = MMC_MAX_BLOCK_LEN;
- mmc->capacity_user = 0x100000000;
- mmc->capacity_user *= mmc->read_bl_len;
- mmc->capacity_boot = 0;
- mmc->capacity_rpmb = 0;
- for (int i = 0; i < 4; i++)
- mmc->capacity = 0x2000000000ULL;
Use macro. It's not readable. What's 0x2000000000ULL?
- mmc->has_init = 1;
Right? has_init will be set in mmc.c. Why it's set to 1 in driver?
- bdesc = mmc_get_blk_desc(mmc);
- bdesc->lun = 0;
- bdesc->hwpart = 0;
- bdesc->type = 0;
- bdesc->blksz = mmc->read_bl_len;
- bdesc->log2blksz = LOG2(bdesc->blksz);
- bdesc->lba = lldiv(mmc->capacity, mmc->read_bl_len);
- always return 1, which means present
* always return 1
- return 1;
- in hw
- .send_cmd = piton_mmc_send_cmd,
- .get_cd = piton_mmc_getcd,
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct mmc_config *cfg = &plat->cfg;
- cfg->name = dev->name;
- upriv->mmc = &plat->mmc;
- upriv->mmc->has_init = 1;
Ditto.
- upriv->mmc->capacity = 0x2000000000ULL;
Ditto.
- upriv->mmc->read_bl_len = MMC_MAX_BLOCK_LEN;
readl_blk_len will be set in mmc.c. Your driver doesn't use mmc.c? Why do you set to some values in your driver?
- cfg->host_caps = MMC_MODE_HS_52MHz | MMC_MODE_HS | MMC_MODE_8BIT;
- cfg->voltages = MMC_VDD_165_195 | MMC_VDD_32_33 | MMC_VDD_33_34;
- cfg->f_min = 1000000;
- cfg->f_max = 52000000;
- cfg->b_max = U32_MAX;
Use a readable value instead of U32_MAX. CONFIG_SYS_MMC_MAX_BLK_COUNT or other.
Best Regards, Jaehoon Chung
- return mmc_bind(dev, &plat->mmc, cfg);
- {.compatible = "openpiton,piton-mmc"},
- {/* sentinel */}
- .name = "piton_mmc",
- .id = UCLASS_MMC,
- .of_match = piton_mmc_ids,
- .ofdata_to_platdata = piton_mmc_ofdata_to_platdata,
- .bind = piton_mmc_bind,
- .probe = piton_mmc_probe,
- .ops = &piton_mmc_ops,
- .platdata_auto_alloc_size = sizeof(struct piton_mmc_plat),
- .priv_auto_alloc_size = sizeof(struct piton_mmc_priv),
Hi Jaehoon,
Many thanks for taking the time to review our patches :P
On 6/14/2021 6:09 AM, Jaehoon Chung wrote:
Dear Tianrui,
+config MMC_PITON
- help
Fix indentation.
Will do
- config GENERIC_ATMEL_MCI bool "Atmel Multimedia Card Interface support" depends on DM_MMC && BLK && ARCH_AT91
Ditto.
- struct mmc mmc;
Ditto.
Will do
- if (!data)
- } else {
return -ENOSYS;
Will change to support it
- struct mmc *mmc;
- cfg = &plat->cfg;
We don't use f_max anywhere, so we're setting dummy values :P
- mmc = &plat->mmc;
Will do
Our mmc controller directly maps the contents of the SD card into a
memory region, so there're no configuration registers avaiable. We're
setting these values to avoid problems with mmc.c
- bdesc->lun = 0;
- bdesc->type = 0;
* always return 1
- return 1;
- in hw
Ditto.
Ditto
Ditto.
Ditto
Ditto
Will do.
Thanks for your review and helpful comments. We're very keen to get this upstream so I
will address your issues ASAP and get a new version submitted. Regarding readl_blk_len,
our MMC is a bit of a special case in that it's directly memory mapped under the hood.
Can we go ahead with this version or might you have another suggestion?
Tianrui
- {/* sentinel */}
- .id = UCLASS_MMC,
Hi Tianrui,
On 6/14/21 9:28 AM, Tianrui Wei wrote:
Hi Jaehoon,
Dear Tianrui,
- V6
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 8901456967..096d6a930c 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -727,6 +727,15 @@ config MMC_SUNXI_HAS_MODE_SWITCH bool depends on MMC_SUNXI +config MMC_PITON + bool "MMC support for OpenPiton SoC" + depends on DM_MMC && BLK + help + This selects support for the SD host controller on + OpenPiton SoC. Note that this SD controller directly + exposes the contents of the SD card as memory mapped, + so there is no manual configuration required
Fix indentation.
Will do
config GENERIC_ATMEL_MCI bool "Atmel Multimedia Card Interface support" depends on DM_MMC && BLK && ARCH_AT91 diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 89d6af3db3..cc08b41d0d 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -72,6 +72,7 @@ obj-$(CONFIG_MMC_SDHCI_XENON) += xenon_sdhci.o obj-$(CONFIG_MMC_SDHCI_ZYNQ) += zynq_sdhci.o obj-$(CONFIG_MMC_SUNXI) += sunxi_mmc.o +obj-$(CONFIG_MMC_PITON) += piton_mmc.o
Ditto.
Ditto.
Will do
+ return 0; +}
Will do
+ return 0; +}
- in hw
Ditto.
Ditto
Ditto.
Ditto
Ditto
+ return 0; +}
Will do.
I think that it can be applied after fixing some indentation. It seems that other things can be updated after applied your patches.
BTW, which board can this driver be used? Is there open board that can i use?
Tianrui
Dear Jaehoon,
On 6/14/2021 1:58 PM, Jaehoon Chung wrote:
Hi Tianrui,
Hi Jaehoon,
Dear Tianrui,
- V6
Fix indentation.
Will do
Ditto.
Ditto.
Will do
+ return 0; +}
Will do
+ return 0; +}
- in hw
Ditto.
Ditto
Ditto.
Ditto
Ditto
+ return 0; +}
Will do.
Many thanks for taking the time and energy to review our code!
If you want to test this driver, you can try Xilinx vc707, digilent nexys video and genesys 2.
As our SoC is fpga based, these development boards are the easiest to work with.
If you'd like to try it out, you could try the design as documented in the other patch's
board documentation :P
Best Regards,
Tianrui
Tianrui
Jaehoon Chung
Tianrui Wei
