[U-Boot] [PATCH] net: ftmac110: cosmetics and cleanup
1. Update license statement
2. struct ftmac110_regs __iomem *regs -> struct ftmac110_regs *regs.
3. Reformat hardware tx/rx descriptor as an uniform one, and replace uint32_t[2] with uint64_t for descriptor control.
Signed-off-by: Kuo-Jung Su dantesu@faraday-tech.com CC: Joe Hershberger joe.hershberger@gmail.com CC: Tom Rini trini@ti.com --- drivers/net/ftmac110.c | 117 ++++++++++++++++++++++++++++-------------------- drivers/net/ftmac110.h | 87 +++++++++++++++++++---------------- 2 files changed, 117 insertions(+), 87 deletions(-)
diff --git a/drivers/net/ftmac110.c b/drivers/net/ftmac110.c index 579dcc7..d154cb9 100644 --- a/drivers/net/ftmac110.c +++ b/drivers/net/ftmac110.c @@ -1,11 +1,22 @@ /* * Faraday 10/100Mbps Ethernet Controller * - * (C) Copyright 2010 Faraday Technology + * (C) Copyright 2013 Faraday Technology * Dante Su dantesu@faraday-tech.com * - * This file is released under the terms of GPL v2 and any later version. - * See the file COPYING in the root directory of the source tree for details. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA */
#include <common.h> @@ -55,11 +66,11 @@ struct ftmac110_chip { uint32_t lnkup; uint32_t phy_addr;
- struct ftmac110_rxd *rxd; + struct ftmac110_desc *rxd; ulong rxd_dma; uint32_t rxd_idx;
- struct ftmac110_txd *txd; + struct ftmac110_desc *txd; ulong txd_dma; uint32_t txd_idx; }; @@ -70,7 +81,7 @@ static uint16_t mdio_read(struct eth_device *dev, uint8_t phyaddr, uint8_t phyreg) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; + struct ftmac110_regs *regs = chip->regs; uint32_t tmp, ts; uint16_t ret = 0xffff;
@@ -99,7 +110,7 @@ static void mdio_write(struct eth_device *dev, uint8_t phyaddr, uint8_t phyreg, uint16_t phydata) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; + struct ftmac110_regs *regs = chip->regs; uint32_t tmp, ts;
tmp = PHYCR_WRITE @@ -186,8 +197,8 @@ static uint32_t ftmac110_phyqry(struct eth_device *dev)
exit: printf("ftmac110: %d Mbps, %s\n", - (maccr & MACCR_100M) ? 100 : 10, - (maccr & MACCR_FD) ? "Full" : "half"); + (maccr & MACCR_100M) ? 100 : 10, + (maccr & MACCR_FD) ? "Full" : "half"); return maccr; }
@@ -196,7 +207,7 @@ static int ftmac110_reset(struct eth_device *dev) uint8_t *a; uint32_t i, maccr; struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; + struct ftmac110_regs *regs = chip->regs;
/* 1. MAC reset */ writel(MACCR_RESET, ®s->maccr); @@ -213,14 +224,15 @@ static int ftmac110_reset(struct eth_device *dev) /* 1-1. Init tx ring */ for (i = 0; i < CFG_TXDES_NUM; ++i) { /* owned by SW */ - chip->txd[i].ct[0] = 0; + chip->txd[i].ctrl &= cpu_to_le64(FTMAC110_TXD_CLRMASK); } chip->txd_idx = 0;
/* 1-2. Init rx ring */ for (i = 0; i < CFG_RXDES_NUM; ++i) { /* owned by HW */ - chip->rxd[i].ct[0] = cpu_to_le32(FTMAC110_RXCT0_OWNER); + chip->rxd[i].ctrl &= cpu_to_le64(FTMAC110_RXD_CLRMASK); + chip->rxd[i].ctrl |= cpu_to_le64(FTMAC110_RXD_OWNER); } chip->rxd_idx = 0;
@@ -269,7 +281,7 @@ static int ftmac110_probe(struct eth_device *dev, bd_t *bis) static void ftmac110_halt(struct eth_device *dev) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; + struct ftmac110_regs *regs = chip->regs;
writel(0, ®s->imr); writel(0, ®s->maccr); @@ -280,8 +292,9 @@ static void ftmac110_halt(struct eth_device *dev) static int ftmac110_send(struct eth_device *dev, void *pkt, int len) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; - struct ftmac110_txd *des; + struct ftmac110_regs *regs = chip->regs; + struct ftmac110_desc *txd; + uint64_t ctrl;
if (!chip->lnkup) return 0; @@ -293,24 +306,26 @@ static int ftmac110_send(struct eth_device *dev, void *pkt, int len)
len = max(60, len);
- des = &chip->txd[chip->txd_idx]; - if (le32_to_cpu(des->ct[0]) & FTMAC110_TXCT0_OWNER) { + txd = &chip->txd[chip->txd_idx]; + ctrl = le64_to_cpu(txd->ctrl); + if (ctrl & FTMAC110_TXD_OWNER) { /* kick-off Tx DMA */ writel(0xffffffff, ®s->txpd); printf("ftmac110: out of txd\n"); return 0; }
- memcpy(des->vbuf, (void *)pkt, len); - dma_map_single(des->vbuf, len, DMA_TO_DEVICE); - - /* update len, fts and lts */ - des->ct[1] &= cpu_to_le32(FTMAC110_TXCT1_END); - des->ct[1] |= cpu_to_le32(FTMAC110_TXCT1_LEN(len) - | FTMAC110_TXCT1_FTS | FTMAC110_TXCT1_LTS); + memcpy(txd->vbuf, (void *)pkt, len); + dma_map_single(txd->vbuf, len, DMA_TO_DEVICE);
- /* set owner bit and clear others */ - des->ct[0] = cpu_to_le32(FTMAC110_TXCT0_OWNER); + /* clear control bits */ + ctrl &= FTMAC110_TXD_CLRMASK; + /* set len, fts and lts */ + ctrl |= FTMAC110_TXD_LEN(len) | FTMAC110_TXD_FTS | FTMAC110_TXD_LTS; + /* set owner bit */ + ctrl |= FTMAC110_TXD_OWNER; + /* write back to descriptor */ + txd->ctrl = cpu_to_le64(ctrl);
/* kick-off Tx DMA */ writel(0xffffffff, ®s->txpd); @@ -323,23 +338,24 @@ static int ftmac110_send(struct eth_device *dev, void *pkt, int len) static int ftmac110_recv(struct eth_device *dev) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_rxd *des; - uint32_t ct0, len, rlen = 0; + struct ftmac110_desc *rxd; + uint32_t len, rlen = 0; + uint64_t ctrl; uint8_t *buf;
do { - des = &chip->rxd[chip->rxd_idx]; - ct0 = le32_to_cpu(des->ct[0]); - if (ct0 & FTMAC110_RXCT0_OWNER) + rxd = &chip->rxd[chip->rxd_idx]; + ctrl = le64_to_cpu(rxd->ctrl); + if (ctrl & FTMAC110_RXD_OWNER) break;
- len = FTMAC110_RXCT0_LEN(ct0); - buf = des->vbuf; + len = (uint32_t)FTMAC110_RXD_LEN(ctrl); + buf = rxd->vbuf;
- if (ct0 & FTMAC110_RXCT0_ERRMASK) { + if (ctrl & FTMAC110_RXD_ERRMASK) { printf("ftmac110: rx error\n"); } else { dma_map_single(buf, len, DMA_FROM_DEVICE); @@ -348,7 +364,9 @@ static int ftmac110_recv(struct eth_device *dev) }
/* owned by hardware */ - des->ct[0] = cpu_to_le32(FTMAC110_RXCT0_OWNER); + ctrl &= FTMAC110_RXD_CLRMASK; + ctrl |= FTMAC110_RXD_OWNER; + rxd->ctrl |= cpu_to_le64(ctrl);
chip->rxd_idx = (chip->rxd_idx + 1) % CFG_RXDES_NUM; } while (0); @@ -423,42 +441,43 @@ int ftmac110_initialize(bd_t *bis)
/* allocate tx descriptors (it must be 16 bytes aligned) */ chip->txd = dma_alloc_coherent( - sizeof(struct ftmac110_txd) * CFG_TXDES_NUM, &chip->txd_dma); + sizeof(struct ftmac110_desc) * CFG_TXDES_NUM, &chip->txd_dma); if (!chip->txd) panic("ftmac110: out of memory 3\n"); memset(chip->txd, 0, - sizeof(struct ftmac110_txd) * CFG_TXDES_NUM); + sizeof(struct ftmac110_desc) * CFG_TXDES_NUM); for (i = 0; i < CFG_TXDES_NUM; ++i) { void *va = memalign(ARCH_DMA_MINALIGN, CFG_XBUF_SIZE); + if (!va) panic("ftmac110: out of memory 4\n"); - chip->txd[i].vbuf = va; - chip->txd[i].buf = cpu_to_le32(virt_to_phys(va)); - chip->txd[i].ct[1] = 0; - chip->txd[i].ct[0] = 0; /* owned by SW */ + chip->txd[i].vbuf = va; + chip->txd[i].pbuf = cpu_to_le32(virt_to_phys(va)); + chip->txd[i].ctrl = 0; /* owned by SW */ } - chip->txd[i - 1].ct[1] |= cpu_to_le32(FTMAC110_TXCT1_END); + chip->txd[i - 1].ctrl |= cpu_to_le64(FTMAC110_TXD_END); chip->txd_idx = 0;
/* allocate rx descriptors (it must be 16 bytes aligned) */ chip->rxd = dma_alloc_coherent( - sizeof(struct ftmac110_rxd) * CFG_RXDES_NUM, &chip->rxd_dma); + sizeof(struct ftmac110_desc) * CFG_RXDES_NUM, &chip->rxd_dma); if (!chip->rxd) panic("ftmac110: out of memory 4\n"); memset((void *)chip->rxd, 0, - sizeof(struct ftmac110_rxd) * CFG_RXDES_NUM); + sizeof(struct ftmac110_desc) * CFG_RXDES_NUM); for (i = 0; i < CFG_RXDES_NUM; ++i) { void *va = memalign(ARCH_DMA_MINALIGN, CFG_XBUF_SIZE + 2); + if (!va) panic("ftmac110: out of memory 5\n"); /* it needs to be exactly 2 bytes aligned */ va = ((uint8_t *)va + 2); - chip->rxd[i].vbuf = va; - chip->rxd[i].buf = cpu_to_le32(virt_to_phys(va)); - chip->rxd[i].ct[1] = cpu_to_le32(CFG_XBUF_SIZE); - chip->rxd[i].ct[0] = cpu_to_le32(FTMAC110_RXCT0_OWNER); + chip->rxd[i].vbuf = va; + chip->rxd[i].pbuf = cpu_to_le32(virt_to_phys(va)); + chip->rxd[i].ctrl = cpu_to_le64(FTMAC110_RXD_OWNER + | FTMAC110_RXD_BUFSZ(CFG_XBUF_SIZE)); } - chip->rxd[i - 1].ct[1] |= cpu_to_le32(FTMAC110_RXCT1_END); + chip->rxd[i - 1].ctrl |= cpu_to_le64(FTMAC110_RXD_END); chip->rxd_idx = 0;
eth_register(dev); diff --git a/drivers/net/ftmac110.h b/drivers/net/ftmac110.h index 5b2d23b..def5f86 100644 --- a/drivers/net/ftmac110.h +++ b/drivers/net/ftmac110.h @@ -1,11 +1,22 @@ /* * Faraday 10/100Mbps Ethernet Controller * - * (C) Copyright 2010 Faraday Technology + * (C) Copyright 2013 Faraday Technology * Dante Su dantesu@faraday-tech.com * - * This file is released under the terms of GPL v2 and any later version. - * See the file COPYING in the root directory of the source tree for details. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA */
#ifndef _FTMAC110_H @@ -136,42 +147,42 @@ struct ftmac110_regs { /* * descriptor structure */ -struct ftmac110_rxd { - uint32_t ct[2]; - uint32_t buf; - void *vbuf; /* reserved */ +struct ftmac110_desc { + uint64_t ctrl; + uint32_t pbuf; + void *vbuf; };
-#define FTMAC110_RXCT0_OWNER BIT_MASK(31) /* owner: 1=HW, 0=SW */ -#define FTMAC110_RXCT0_FRS BIT_MASK(29) /* first pkt desc */ -#define FTMAC110_RXCT0_LRS BIT_MASK(28) /* last pkt desc */ -#define FTMAC110_RXCT0_ODDNB BIT_MASK(22) /* odd nibble */ -#define FTMAC110_RXCT0_RUNT BIT_MASK(21) /* runt pkt */ -#define FTMAC110_RXCT0_FTL BIT_MASK(20) /* frame too long */ -#define FTMAC110_RXCT0_CRC BIT_MASK(19) /* pkt crc error */ -#define FTMAC110_RXCT0_ERR BIT_MASK(18) /* bus error */ -#define FTMAC110_RXCT0_ERRMASK (0x1f << 18) /* all errors */ -#define FTMAC110_RXCT0_BCST BIT_MASK(17) /* Bcst pkt */ -#define FTMAC110_RXCT0_MCST BIT_MASK(16) /* Mcst pkt */ -#define FTMAC110_RXCT0_LEN(x) ((x) & 0x7ff) - -#define FTMAC110_RXCT1_END BIT_MASK(31) -#define FTMAC110_RXCT1_BUFSZ(x) ((x) & 0x7ff) - -struct ftmac110_txd { - uint32_t ct[2]; - uint32_t buf; - void *vbuf; /* reserved */ -}; - -#define FTMAC110_TXCT0_OWNER BIT_MASK(31) /* owner: 1=HW, 0=SW */ -#define FTMAC110_TXCT0_COL 0x00000003 /* collision */ - -#define FTMAC110_TXCT1_END BIT_MASK(31) /* end of ring */ -#define FTMAC110_TXCT1_TXIC BIT_MASK(30) /* tx done interrupt */ -#define FTMAC110_TXCT1_TX2FIC BIT_MASK(29) /* tx fifo interrupt */ -#define FTMAC110_TXCT1_FTS BIT_MASK(28) /* first pkt desc */ -#define FTMAC110_TXCT1_LTS BIT_MASK(27) /* last pkt desc */ -#define FTMAC110_TXCT1_LEN(x) ((x) & 0x7ff) +#define FTMAC110_RXD_END ((uint64_t)1 << 63) +#define FTMAC110_RXD_BUFSZ(x) (((uint64_t)(x) & 0x7ff) << 32) + +#define FTMAC110_RXD_OWNER ((uint64_t)1 << 31) /* owner: 1=HW, 0=SW */ +#define FTMAC110_RXD_FRS ((uint64_t)1 << 29) /* first pkt desc */ +#define FTMAC110_RXD_LRS ((uint64_t)1 << 28) /* last pkt desc */ +#define FTMAC110_RXD_ODDNB ((uint64_t)1 << 22) /* odd nibble */ +#define FTMAC110_RXD_RUNT ((uint64_t)1 << 21) /* runt pkt */ +#define FTMAC110_RXD_FTL ((uint64_t)1 << 20) /* frame too long */ +#define FTMAC110_RXD_CRC ((uint64_t)1 << 19) /* pkt crc error */ +#define FTMAC110_RXD_ERR ((uint64_t)1 << 18) /* bus error */ +#define FTMAC110_RXD_ERRMASK ((uint64_t)0x1f << 18) +#define FTMAC110_RXD_BCST ((uint64_t)1 << 17) /* Bcst pkt */ +#define FTMAC110_RXD_MCST ((uint64_t)1 << 16) /* Mcst pkt */ +#define FTMAC110_RXD_LEN(x) ((uint64_t)((x) & 0x7ff)) + +#define FTMAC110_RXD_CLRMASK \ + (FTMAC110_RXD_END | FTMAC110_RXD_BUFSZ(0x7ff)) + +#define FTMAC110_TXD_END ((uint64_t)1 << 63) /* end of ring */ +#define FTMAC110_TXD_TXIC ((uint64_t)1 << 62) /* tx done interrupt */ +#define FTMAC110_TXD_TX2FIC ((uint64_t)1 << 61) /* tx fifo interrupt */ +#define FTMAC110_TXD_FTS ((uint64_t)1 << 60) /* first pkt desc */ +#define FTMAC110_TXD_LTS ((uint64_t)1 << 59) /* last pkt desc */ +#define FTMAC110_TXD_LEN(x) ((uint64_t)((x) & 0x7ff) << 32) + +#define FTMAC110_TXD_OWNER ((uint64_t)1 << 31) /* owner: 1=HW, 0=SW */ +#define FTMAC110_TXD_COL ((uint64_t)3) /* collision */ + +#define FTMAC110_TXD_CLRMASK \ + (FTMAC110_TXD_END)
#endif /* FTMAC110_H */ -- 1.7.9.5
Hi Kuo-Jung Su,
Please send these as separate patches that each have a single, complete purpose.
2013/7/9 Joe Hershberger joe.hershberger@gmail.com:
Hi Kuo-Jung Su,
Got it, thanks
-- Best wishes, Kuo-Jung Su
Changes for v2: - Re-send these as separate patches that each have a single, complete purpose.
Kuo-Jung Su (3): net: ftmac110: Update license statement net: ftmac110: struct ftmac110_regs __iomem * -> struct ftmac110_regs * net: ftmac110: Update tx/rx descriptor format
drivers/net/ftmac110.c | 113 ++++++++++++++++++++++++++++-------------------- drivers/net/ftmac110.h | 87 +++++++++++++++++++++---------------- 2 files changed, 115 insertions(+), 85 deletions(-)
-- 1.7.9.5
Signed-off-by: Kuo-Jung Su dantesu@faraday-tech.com CC: Joe Hershberger joe.hershberger@gmail.com --- drivers/net/ftmac110.c | 17 ++++++++++++++--- drivers/net/ftmac110.h | 17 ++++++++++++++--- 2 files changed, 28 insertions(+), 6 deletions(-)
diff --git a/drivers/net/ftmac110.c b/drivers/net/ftmac110.c index 35f8633..c7d45e1 100644 --- a/drivers/net/ftmac110.c +++ b/drivers/net/ftmac110.c @@ -1,11 +1,22 @@ /* * Faraday 10/100Mbps Ethernet Controller * - * (C) Copyright 2010 Faraday Technology + * (C) Copyright 2013 Faraday Technology * Dante Su dantesu@faraday-tech.com * - * This file is released under the terms of GPL v2 and any later version. - * See the file COPYING in the root directory of the source tree for details. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA */
#include <common.h> diff --git a/drivers/net/ftmac110.h b/drivers/net/ftmac110.h index 5b2d23b..4bb8b76 100644 --- a/drivers/net/ftmac110.h +++ b/drivers/net/ftmac110.h @@ -1,11 +1,22 @@ /* * Faraday 10/100Mbps Ethernet Controller * - * (C) Copyright 2010 Faraday Technology + * (C) Copyright 2013 Faraday Technology * Dante Su dantesu@faraday-tech.com * - * This file is released under the terms of GPL v2 and any later version. - * See the file COPYING in the root directory of the source tree for details. + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA */
#ifndef _FTMAC110_H -- 1.7.9.5
Applied, Thanks! -Joe
Signed-off-by: Kuo-Jung Su dantesu@faraday-tech.com CC: Joe Hershberger joe.hershberger@gmail.com --- drivers/net/ftmac110.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/net/ftmac110.c b/drivers/net/ftmac110.c index c7d45e1..1afd95a 100644 --- a/drivers/net/ftmac110.c +++ b/drivers/net/ftmac110.c @@ -81,7 +81,7 @@ static uint16_t mdio_read(struct eth_device *dev, uint8_t phyaddr, uint8_t phyreg) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; + struct ftmac110_regs *regs = chip->regs; uint32_t tmp, ts; uint16_t ret = 0xffff;
@@ -110,7 +110,7 @@ static void mdio_write(struct eth_device *dev, uint8_t phyaddr, uint8_t phyreg, uint16_t phydata) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; + struct ftmac110_regs *regs = chip->regs; uint32_t tmp, ts;
tmp = PHYCR_WRITE @@ -207,7 +207,7 @@ static int ftmac110_reset(struct eth_device *dev) uint8_t *a; uint32_t i, maccr; struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; + struct ftmac110_regs *regs = chip->regs;
/* 1. MAC reset */ writel(MACCR_RESET, ®s->maccr); @@ -280,7 +280,7 @@ static int ftmac110_probe(struct eth_device *dev, bd_t *bis) static void ftmac110_halt(struct eth_device *dev) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; + struct ftmac110_regs *regs = chip->regs;
writel(0, ®s->imr); writel(0, ®s->maccr); @@ -291,7 +291,7 @@ static void ftmac110_halt(struct eth_device *dev) static int ftmac110_send(struct eth_device *dev, void *pkt, int len) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_regs __iomem *regs = chip->regs; + struct ftmac110_regs *regs = chip->regs; struct ftmac110_txd *des;
if (!chip->lnkup) -- 1.7.9.5
1. Reformat tx/rx descriptor as an uniform struct. 2. Replace uint32_t[2] with uint64_t for descriptor control.
Signed-off-by: Kuo-Jung Su dantesu@faraday-tech.com CC: Joe Hershberger joe.hershberger@gmail.com --- drivers/net/ftmac110.c | 86 ++++++++++++++++++++++++++---------------------- drivers/net/ftmac110.h | 70 +++++++++++++++++++-------------------- 2 files changed, 82 insertions(+), 74 deletions(-)
diff --git a/drivers/net/ftmac110.c b/drivers/net/ftmac110.c index 1afd95a..d154cb9 100644 --- a/drivers/net/ftmac110.c +++ b/drivers/net/ftmac110.c @@ -66,11 +66,11 @@ struct ftmac110_chip { uint32_t lnkup; uint32_t phy_addr;
- struct ftmac110_txd *txd; + struct ftmac110_desc *txd; ulong txd_dma; uint32_t txd_idx; }; @@ -224,14 +224,15 @@ static int ftmac110_reset(struct eth_device *dev) /* 1-1. Init tx ring */ for (i = 0; i < CFG_TXDES_NUM; ++i) { /* owned by SW */ - chip->txd[i].ct[0] = 0; + chip->txd[i].ctrl &= cpu_to_le64(FTMAC110_TXD_CLRMASK); } chip->txd_idx = 0;
@@ -292,7 +293,8 @@ static int ftmac110_send(struct eth_device *dev, void *pkt, int len) { struct ftmac110_chip *chip = dev->priv; struct ftmac110_regs *regs = chip->regs; - struct ftmac110_txd *des; + struct ftmac110_desc *txd; + uint64_t ctrl;
if (!chip->lnkup) return 0; @@ -304,24 +306,26 @@ static int ftmac110_send(struct eth_device *dev, void *pkt, int len)
len = max(60, len);
- memcpy(des->vbuf, (void *)pkt, len); - dma_map_single(des->vbuf, len, DMA_TO_DEVICE); + memcpy(txd->vbuf, (void *)pkt, len); + dma_map_single(txd->vbuf, len, DMA_TO_DEVICE);
- /* update len, fts and lts */ - des->ct[1] &= cpu_to_le32(FTMAC110_TXCT1_END); - des->ct[1] |= cpu_to_le32(FTMAC110_TXCT1_LEN(len) - | FTMAC110_TXCT1_FTS | FTMAC110_TXCT1_LTS); - - /* set owner bit and clear others */ - des->ct[0] = cpu_to_le32(FTMAC110_TXCT0_OWNER); + /* clear control bits */ + ctrl &= FTMAC110_TXD_CLRMASK; + /* set len, fts and lts */ + ctrl |= FTMAC110_TXD_LEN(len) | FTMAC110_TXD_FTS | FTMAC110_TXD_LTS; + /* set owner bit */ + ctrl |= FTMAC110_TXD_OWNER; + /* write back to descriptor */ + txd->ctrl = cpu_to_le64(ctrl);
/* kick-off Tx DMA */ writel(0xffffffff, ®s->txpd); @@ -334,23 +338,24 @@ static int ftmac110_send(struct eth_device *dev, void *pkt, int len) static int ftmac110_recv(struct eth_device *dev) { struct ftmac110_chip *chip = dev->priv; - struct ftmac110_rxd *des; - uint32_t ct0, len, rlen = 0; + struct ftmac110_desc *rxd; + uint32_t len, rlen = 0; + uint64_t ctrl; uint8_t *buf;
- if (ct0 & FTMAC110_RXCT0_ERRMASK) { + if (ctrl & FTMAC110_RXD_ERRMASK) { printf("ftmac110: rx error\n"); } else { dma_map_single(buf, len, DMA_FROM_DEVICE); @@ -359,7 +364,9 @@ static int ftmac110_recv(struct eth_device *dev) }
chip->rxd_idx = (chip->rxd_idx + 1) % CFG_RXDES_NUM; } while (0); @@ -434,42 +441,43 @@ int ftmac110_initialize(bd_t *bis)
eth_register(dev); diff --git a/drivers/net/ftmac110.h b/drivers/net/ftmac110.h index 4bb8b76..def5f86 100644 --- a/drivers/net/ftmac110.h +++ b/drivers/net/ftmac110.h @@ -147,42 +147,42 @@ struct ftmac110_regs { /* * descriptor structure */ -struct ftmac110_rxd { - uint32_t ct[2]; - uint32_t buf; - void *vbuf; /* reserved */ +struct ftmac110_desc { + uint64_t ctrl; + uint32_t pbuf; + void *vbuf; };
- Reformat tx/rx descriptor as an uniform struct.
- Replace uint32_t[2] with uint64_t for descriptor control.
Joe Hershberger
Kuo-Jung Su
