Re: [U-Boot] U-Boot Security
Hello everyone,
I have created the FIT to be loaded by the SPL and the keys for the signature.
Now, I am wondering how the signature is done by U-Boot? Is there an option in menuconfig that points to the key or is it me that has to do it manually? Also, I am wondering how to place the public key inside the U-Boot image?
Sincerely,
Pascal Linder
Student Telekommunikation Netzwerke und Sicherheit
Klasse T-3b
________________________________ Von: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Gesendet: Samstag, 27. April 2019 21:12:03 An: Linder Pascal Betreff: Re: AW: [U-Boot] U-Boot Security
Hello Pascal,
I can't help you much there, I can only tell you SPL -> U-Boot should be the same as U-Boot -> FIT(Linux). I once tested this and it works, but it's too long ago to remember. And your first mail suggested the latter case (U-Boot -> FIT/Linux) already works for you...
Besides, please keep the discussion public (on the mailing list). There are others who know this far better than me and might be able to help more.
On 27.04.19 17:50, Linder Pascal wrote:
Hello Simon, >
Thanks for your response! Now, I am just wondering how the signature is done by U-Boot. Or is it me that must sign the images manually with mkimage?
The key and certificate I have in a directory called keys inside U-Boot. Is there an option in KConfig to create the relation to this key?
Summarized, I would like to know how to put the public key into my U-Boot image?
Sincerely,
Pascal Linder
Klasse T-3b
Von: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Gesendet: Mittwoch, 24. April 2019 19:56:51 An: Linder Pascal; u-boot@lists.denx.de Betreff: Re: [U-Boot] U-Boot Security
Am 24.04.2019 um 15:55 schrieb Linder Pascal:
Hello everyone,
I want to add some supplementary security to my embedded system. The Flattened Image Tree (FIT) to secure the operating system and the device tree, I have already found. Now, I am wondering if I could also secure U-Boot itself before starting it by the Secondary Program Loader (SPL). Does anyone knows a method to do that?
Just as U-Boot can load Kernel + DTS as FIT, SPL can load U-Boot as FIT. See CONFIG_SPL_LOAD_FIT. This FIT containing U-Boot + its DTS can then be verified, too.
Linder Pascal
