[PATCH] arm: k3: use correct weak function name spl_board_prepare_for_linux
Replace the function spl_board_prepare_for_boot_linux by the correct name of the weak function spl_board_prepare_for_linux defined in spl.h.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
arch/arm/mach-k3/common.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index 9695b2236e..63bf060616 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -440,7 +440,7 @@ void spl_board_prepare_for_boot(void) dcache_disable(); }
-void spl_board_prepare_for_boot_linux(void) +void spl_board_prepare_for_linux(void) { dcache_disable(); }
Applied to u-boot-ti.
Thanks and regards, Lokesh
Lokesh Vutla
Patrick Delaunay
