[PATCH 1/1] serial: move sbi_dbcn_available to .data section
U-Boot SPL loads the device-tree directly behind main U-Boot overlapping the .bss section. reserve_fdt() is called in board_init_f() to relocate the device-tree to a safe location.
Debug UARTs are enabled before board_init_f(). With sbi_dbcn_available in the .bss section the device-tree is corrupted when _debug_uart_init() is called in the SBI serial driver. Move the variable to the .data section.
Link: https://bugs.launchpad.net/ubuntu/+source/u-boot/+bug/2054091 Fixes: dfe08374943c ("risc-v: implement DBCN based debug console") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- drivers/serial/serial_sbi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/serial/serial_sbi.c b/drivers/serial/serial_sbi.c index a51a96c1ef0..f3ecfccab43 100644 --- a/drivers/serial/serial_sbi.c +++ b/drivers/serial/serial_sbi.c @@ -17,7 +17,7 @@ static inline void _debug_uart_putc(int c)
#else
-static int sbi_dbcn_available; +static int sbi_dbcn_available __section(".data");
static inline void _debug_uart_init(void) {
#else
Tested-by: Aurelien Jarno aurelien@aurel32.net
This also appears to fix the inconsistent boot issues that I've been seeing since I reported: https://lore.kernel.org/u-boot/20240122-finicky-ancient-797ba048f927@spud/
Tested-by: Conor Dooley conor.dooley@microchip.com
Thanks, Conor.
Aurelien Jarno
Conor Dooley
