[U-Boot] [PATCH v2] regulator: palmas: Fix smps6 - smps9 indices
The array indices used currently are dispalaced by 1 for SMPS6 through SMPS10 in the respective places of voltage and ctrl arrays hence fix the same as to assign the right voltage and ctrl registers.
Signed-off-by: Keerthy j-keerthy@ti.com ---
Changes in v2:
* Elaborated the commit log.
drivers/power/regulator/palmas_regulator.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/power/regulator/palmas_regulator.c b/drivers/power/regulator/palmas_regulator.c index cce7cd2..399f7a5 100644 --- a/drivers/power/regulator/palmas_regulator.c +++ b/drivers/power/regulator/palmas_regulator.c @@ -356,7 +356,7 @@ static int palmas_smps_probe(struct udevice *dev) case 8: case 9: case 10: - idx = dev->driver_data - 4; + idx = dev->driver_data - 3; uc_pdata->ctrl_reg = palmas_smps_ctrl[type][idx]; uc_pdata->volt_reg = palmas_smps_volt[type][idx]; break;
Keerthy
