[U-Boot] [PATCH] test/py: support 'memstart =' in u_boot_utils.find_ram_base()
Some archs like MIPS or PPC have a different 'bdinfo' output than ARM regarding the memory configuration. Also support 'memstart = 0x*' in u_boot_utils.find_ram_base() to make all tests requiring the RAM base working on those archs.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
test/py/u_boot_utils.py | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/test/py/u_boot_utils.py b/test/py/u_boot_utils.py index 6a6b2ec..e4765e3 100644 --- a/test/py/u_boot_utils.py +++ b/test/py/u_boot_utils.py @@ -201,7 +201,7 @@ def find_ram_base(u_boot_console): with u_boot_console.log.section('find_ram_base'): response = u_boot_console.run_command('bdinfo') for l in response.split('\n'): - if '-> start' in l: + if '-> start' in l or 'memstart =' in l: ram_base = int(l.split('=')[1].strip(), 16) break if ram_base is None:
Acked-by: Stephen Warren swarren@nvidia.com
... although wouldn't it be better to fix the bdinfo command so that it printed the same thing on all architectures?
Am 06.07.2016 um 16:37 schrieb Stephen Warren:
yes, but bdinfo isn't the only one affected. Currently we have two variants in "struct bd_info" of how to store the memory configuration:
- bi_memstart and bi_memsize - struct bi_dram[CONFIG_NR_DRAM_BANKS] if a board or arch defines CONFIG_NR_DRAM_BANKS
Maybe we could unify this one day. But this requires changes to other commands and generic board init. Until then test/py should support both variants.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Acked-by: Stephen Warren swarren@nvidia.com
Daniel Schwierzeck
Stephen Warren
