[U-Boot] [PATCH 0/2] eMMC: support for Read Protected Memory Block (RPMB)
This serie of patches adds some functions and a sub-command of 'mmc' for programming the authentication key and for reading and writing the RPMB partition of an eMMC according to the JEDEC standard No. 64-A441
The sub-command rpmb is enabled by the flag CONFIG_SUPPORT_EMMC_RPMB defined in the board configuration file. It has been tested on a SabreSDP iMX6 board.
Pierre Aubert (2): eMMC: add support for operations in RPMB partition eMMC: cmd_mmc.c adds the 'rpmb' sub-command for the 'mmc' command
common/cmd_mmc.c | 128 ++++++++++++++++++++- drivers/mmc/Makefile | 1 + drivers/mmc/rpmb.c | 317 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/mmc.h | 10 ++- lib/Makefile | 3 + 5 files changed, 457 insertions(+), 2 deletions(-) create mode 100644 drivers/mmc/rpmb.c
This patch adds functions for read, write and authentication key programming for the Replay Protected Memory Block partition in the eMMC.
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Pantelis Antoniou panto@antoniou-consulting.com --- drivers/mmc/Makefile | 1 + drivers/mmc/rpmb.c | 317 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/mmc.h | 10 ++- lib/Makefile | 3 + 4 files changed, 330 insertions(+), 1 deletions(-) create mode 100644 drivers/mmc/rpmb.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 931922b..4c6ab9e 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -30,6 +30,7 @@ obj-$(CONFIG_DWMMC) += dw_mmc.o obj-$(CONFIG_EXYNOS_DWMMC) += exynos_dw_mmc.o obj-$(CONFIG_ZYNQ_SDHCI) += zynq_sdhci.o obj-$(CONFIG_SOCFPGA_DWMMC) += socfpga_dw_mmc.o +obj-$(CONFIG_SUPPORT_EMMC_RPMB) += rpmb.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o else diff --git a/drivers/mmc/rpmb.c b/drivers/mmc/rpmb.c new file mode 100644 index 0000000..7f9dffc --- /dev/null +++ b/drivers/mmc/rpmb.c @@ -0,0 +1,317 @@ +/* + * Copyright 2014, Staubli Faverges + * Pierre Aubert + * + * eMMC- Replay Protected Memory Block + * According to JEDEC Standard No. 84-A441 + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> +#include <mmc.h> +#include <sha256.h> +#include "mmc_private.h" + +/* Request codes */ +#define RPMB_REQ_KEY 1 +#define RPMB_REQ_WCOUNTER 2 +#define RPMB_REQ_WRITE_DATA 3 +#define RPMB_REQ_READ_DATA 4 +#define RPMB_REQ_STATUS 5 + +/* Response code */ +#define RPMB_RESP_KEY 0x0100 +#define RPMB_RESP_WCOUNTER 0x0200 +#define RPMB_RESP_WRITE_DATA 0x0300 +#define RPMB_RESP_READ_DATA 0x0400 + +/* Error codes */ +#define RPMB_OK 0 +#define RPMB_ERR_GENERAL 1 +#define RPMB_ERR_AUTH 2 +#define RPMB_ERR_COUNTER 3 +#define RPMB_ERR_ADDRESS 4 +#define RPMB_ERR_WRITE 5 +#define RPMB_ERR_READ 6 +#define RPMB_ERR_KEY 7 +#define RPMB_ERR_CNT_EXPIRED 0x80 +#define RPMB_ERR_MSK 0x7 + +/* Sizes of RPMB data frame */ +#define RPMB_SZ_STUFF 196 +#define RPMB_SZ_MAC 32 +#define RPMB_SZ_DATA 256 +#define RPMB_SZ_NONCE 16 + +#define SHA256_BLOCK_SIZE 64 + +/* Error messages */ +static const char * const rpmb_err_msg[] = { + "", + "General failure", + "Authentication failure", + "Counter failure", + "Address failure", + "Write failure", + "Read failure", + "Authentication key not yet programmed", +}; + + +/* Structure of RPMB data frame. */ +static struct s_rpmb { + unsigned char stuff[RPMB_SZ_STUFF]; + unsigned char mac[RPMB_SZ_MAC]; + unsigned char data[RPMB_SZ_DATA]; + unsigned char nonce[RPMB_SZ_NONCE]; + unsigned long write_counter; + unsigned short address; + unsigned short block_count; + unsigned short result; + unsigned short request; +} __aligned(32) rpmb_frame; + +static int mmc_set_blockcount(struct mmc *mmc, unsigned int blockcount, + bool is_rel_write) +{ + struct mmc_cmd cmd = {0}; + + cmd.cmdidx = MMC_CMD_SET_BLOCK_COUNT; + cmd.cmdarg = blockcount & 0x0000FFFF; + if (is_rel_write) + cmd.cmdarg |= 1 << 31; + cmd.resp_type = MMC_RSP_R1; + + return mmc_send_cmd(mmc, &cmd, NULL); +} +static int mmc_rpmb_request(struct mmc *mmc, const struct s_rpmb *s, + unsigned int count, bool is_rel_write) +{ + struct mmc_cmd cmd = {0}; + struct mmc_data data; + int ret; + + ret = mmc_set_blockcount(mmc, count, is_rel_write); + if (ret) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:mmc_set_blockcount-> %d\n", __func__, ret); +#endif + return 1; + } + + cmd.cmdidx = MMC_CMD_WRITE_MULTIPLE_BLOCK; + cmd.cmdarg = 0; + cmd.resp_type = MMC_RSP_R1b; + + data.src = (const char *)s; + data.blocks = 1; + data.blocksize = MMC_MAX_BLOCK_LEN; + data.flags = MMC_DATA_WRITE; + + ret = mmc_send_cmd(mmc, &cmd, &data); + if (ret) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:mmc_send_cmd-> %d\n", __func__, ret); +#endif + return 1; + } + return 0; +} +static int mmc_rpmb_response(struct mmc *mmc, struct s_rpmb *s, + unsigned short expected) +{ + struct mmc_cmd cmd = {0}; + struct mmc_data data; + int ret; + + ret = mmc_set_blockcount(mmc, 1, false); + if (ret) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:mmc_set_blockcount-> %d\n", __func__, ret); +#endif + return -1; + } + cmd.cmdidx = MMC_CMD_READ_MULTIPLE_BLOCK; + cmd.cmdarg = 0; + cmd.resp_type = MMC_RSP_R1; + + data.dest = (char *)s; + data.blocks = 1; + data.blocksize = MMC_MAX_BLOCK_LEN; + data.flags = MMC_DATA_READ; + + ret = mmc_send_cmd(mmc, &cmd, &data); + if (ret) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:mmc_send_cmd-> %d\n", __func__, ret); +#endif + return -1; + } + /* Check the response and the status */ + if (be16_to_cpu(rpmb_frame.request) != expected) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:response= %x\n", __func__, + be16_to_cpu(rpmb_frame.request)); +#endif + return -1; + } + ret = be16_to_cpu(rpmb_frame.result); + if (ret) { + printf("%s %s\n", rpmb_err_msg[ret & RPMB_ERR_MSK], + (ret & RPMB_ERR_CNT_EXPIRED) ? + "Write counter has expired" : ""); + } + + /* Return the status of the command */ + return ret; +} +static int mmc_rpmb_status(struct mmc *mmc, unsigned short expected) +{ + memset(&rpmb_frame, 0, sizeof(rpmb_frame)); + rpmb_frame.request = cpu_to_be16(RPMB_REQ_STATUS); + if (mmc_rpmb_request(mmc, &rpmb_frame, 1, false)) + return -1; + + /* Read the result */ + return mmc_rpmb_response(mmc, &rpmb_frame, expected); +} +static void rpmb_hmac(unsigned char *key, unsigned char *buff, int len, + unsigned char *output) +{ + sha256_context ctx; + int i; + unsigned char k_ipad[SHA256_BLOCK_SIZE]; + unsigned char k_opad[SHA256_BLOCK_SIZE]; + + sha256_starts(&ctx); + + /* According to RFC 4634, the HMAC transform looks like: + SHA(K XOR opad, SHA(K XOR ipad, text)) + + where K is an n byte key. + ipad is the byte 0x36 repeated blocksize times + opad is the byte 0x5c repeated blocksize times + and text is the data being protected. + */ + + for (i = 0; i < RPMB_SZ_MAC; i++) { + k_ipad[i] = key[i] ^ 0x36; + k_opad[i] = key[i] ^ 0x5c; + } + /* remaining pad bytes are '\0' XOR'd with ipad and opad values */ + for ( ; i < SHA256_BLOCK_SIZE; i++) { + k_ipad[i] = 0x36; + k_opad[i] = 0x5c; + } + sha256_update(&ctx, k_ipad, SHA256_BLOCK_SIZE); + sha256_update(&ctx, buff, len); + sha256_finish(&ctx, output); + + /* Init context for second pass */ + sha256_starts(&ctx); + + /* start with outer pad */ + sha256_update(&ctx, k_opad, SHA256_BLOCK_SIZE); + + /* then results of 1st hash */ + sha256_update(&ctx, output, RPMB_SZ_MAC); + + /* finish up 2nd pass */ + sha256_finish(&ctx, output); +} +int mmc_rpmb_get_counter(struct mmc *mmc, unsigned long *pcounter) +{ + int ret; + + /* Fill the request */ + memset(&rpmb_frame, 0, sizeof(rpmb_frame)); + rpmb_frame.request = cpu_to_be16(RPMB_REQ_WCOUNTER); + if (mmc_rpmb_request(mmc, &rpmb_frame, 1, false)) + return -1; + + /* Read the result */ + ret = mmc_rpmb_response(mmc, &rpmb_frame, RPMB_RESP_WCOUNTER); + if (ret) + return ret; + + *pcounter = be32_to_cpu(rpmb_frame.write_counter); + return 0; +} +int mmc_rpmb_set_key(struct mmc *mmc, void *key) +{ + /* Fill the request */ + memset(&rpmb_frame, 0, sizeof(rpmb_frame)); + rpmb_frame.request = cpu_to_be16(RPMB_REQ_KEY); + memcpy(&rpmb_frame.mac, key, sizeof(rpmb_frame.mac)); + + if (mmc_rpmb_request(mmc, &rpmb_frame, 1, true)) + return -1; + + /* read the operation status */ + return mmc_rpmb_status(mmc, RPMB_RESP_KEY); +} +int mmc_rpmb_read(struct mmc *mmc, void *addr, unsigned short blk, + unsigned short cnt, unsigned char *key) +{ + int i; + + for (i = 0; i < cnt; i++) { + /* Fill the request */ + memset(&rpmb_frame, 0, sizeof(rpmb_frame)); + rpmb_frame.address = cpu_to_be16(blk + i); + rpmb_frame.request = cpu_to_be16(RPMB_REQ_READ_DATA); + if (mmc_rpmb_request(mmc, &rpmb_frame, 1, false)) + break; + + /* Read the result */ + if (mmc_rpmb_response(mmc, &rpmb_frame, RPMB_RESP_READ_DATA)) + break; + + /* Check the HMAC if key is provided */ + if (key) { + unsigned char ret_hmac[RPMB_SZ_MAC]; + + rpmb_hmac(key, rpmb_frame.data, 284, ret_hmac); + if (memcmp(ret_hmac, rpmb_frame.mac, RPMB_SZ_MAC)) { + printf("MAC error on block #%d\n", i); + break; + } + } + /* Copy data */ + memcpy(addr + i * RPMB_SZ_DATA, rpmb_frame.data, RPMB_SZ_DATA); + } + return i; +} +int mmc_rpmb_write(struct mmc *mmc, void *addr, unsigned short blk, + unsigned short cnt, unsigned char *key) +{ + unsigned long wcount; + int i; + + for (i = 0; i < cnt; i++) { + if (mmc_rpmb_get_counter(mmc, &wcount)) { + printf("Cannot read RPMB write counter\n"); + break; + } + + /* Fill the request */ + memset(&rpmb_frame, 0, sizeof(rpmb_frame)); + memcpy(rpmb_frame.data, addr + i * RPMB_SZ_DATA, RPMB_SZ_DATA); + rpmb_frame.address = cpu_to_be16(blk + i); + rpmb_frame.block_count = cpu_to_be16(1); + rpmb_frame.write_counter = cpu_to_be32(wcount); + rpmb_frame.request = cpu_to_be16(RPMB_REQ_WRITE_DATA); + /* Computes HMAC */ + rpmb_hmac(key, rpmb_frame.data, 284, rpmb_frame.mac); + + if (mmc_rpmb_request(mmc, &rpmb_frame, 1, true)) + break; + + /* Get status */ + if (mmc_rpmb_status(mmc, RPMB_RESP_WRITE_DATA)) + break; + } + return i; +} diff --git a/include/mmc.h b/include/mmc.h index 42d0125..14d296c 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -69,6 +69,7 @@ #define MMC_CMD_SET_BLOCKLEN 16 #define MMC_CMD_READ_SINGLE_BLOCK 17 #define MMC_CMD_READ_MULTIPLE_BLOCK 18 +#define MMC_CMD_SET_BLOCK_COUNT 23 #define MMC_CMD_WRITE_SINGLE_BLOCK 24 #define MMC_CMD_WRITE_MULTIPLE_BLOCK 25 #define MMC_CMD_ERASE_GROUP_START 35 @@ -224,6 +225,7 @@ * boot partitions (2), general purpose partitions (4) in MMC v4.4. */ #define MMC_NUM_BOOT_PARTITION 2 +#define MMC_PART_RPMB 3 /* RPMB partition number */
struct mmc_cid { unsigned long psn; @@ -335,7 +337,13 @@ int mmc_set_part_conf(struct mmc *mmc, u8 ack, u8 part_num, u8 access); int mmc_set_boot_bus_width(struct mmc *mmc, u8 width, u8 reset, u8 mode); /* Function to modify the RST_n_FUNCTION field of EXT_CSD */ int mmc_set_rst_n_function(struct mmc *mmc, u8 enable); - +/* Functions to read / write the RPMB partition */ +int mmc_rpmb_set_key(struct mmc *mmc, void *key); +int mmc_rpmb_get_counter(struct mmc *mmc, unsigned long *counter); +int mmc_rpmb_read(struct mmc *mmc, void *addr, unsigned short blk, + unsigned short cnt, unsigned char *key); +int mmc_rpmb_write(struct mmc *mmc, void *addr, unsigned short blk, + unsigned short cnt, unsigned char *key); /** * Start device initialization and return immediately; it does not block on * polling OCR (operation condition register) status. Then you should call diff --git a/lib/Makefile b/lib/Makefile index 27e4f78..2bf90f3 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -35,6 +35,9 @@ obj-y += net_utils.o obj-$(CONFIG_PHYSMEM) += physmem.o obj-y += qsort.o obj-$(CONFIG_SHA1) += sha1.o +ifdef CONFIG_SUPPORT_EMMC_RPMB +CONFIG_SHA256 := y +endif obj-$(CONFIG_SHA256) += sha256.o obj-y += strmhz.o obj-$(CONFIG_TPM) += tpm.o
Hello, Pierre.
Could you please help me to understand why you used R1b with MMC_CMD_WRITE_MULTIPLE_BLOCK in mmc_rpmb_request:
Because according to the spec CMD25 has R1 response, also RPMB section does not explicitly point on the response type, maybe these words are the key:
"The busy signaling in the Dat0 line after the CRC status by the e•MMC is indicating request busy."
But I am not sure.
-- Roman
This sub-command adds support for the RPMB partition of an eMMC: * mmc rpmb key <address of the authentication key> Programs the authentication key in the eMMC This key can not be overwritten. * mmc rpmb read <address> <block> <#count> [address of key] Reads <#count> blocks of 256 bytes in the RPMB partition beginning at block number <block>. If the optionnal address of the authentication key is provided, the Message Authentication Code (MAC) is verified on each block. * mmc rpmb write <address> <block> <#count> <address of key> Writes <#count> blocks of 256 bytes in the RPMB partition beginning at block number <block>. The datas are signed with the key provided. * mmc rpmb counter Returns the 'Write counter' of the RPMB partition.
The sub-command is conditional on compilation flag CONFIG_SUPPORT_EMMC_RPMB
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Pantelis Antoniou panto@antoniou-consulting.com --- common/cmd_mmc.c | 128 +++++++++++++++++++++++++++++++++++++++++++++++++++++- 1 files changed, 127 insertions(+), 1 deletions(-)
diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index c1916c9..3cf11e7 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -130,7 +130,123 @@ U_BOOT_CMD( "display MMC info", "- display info of the current MMC device" ); +#ifdef CONFIG_SUPPORT_EMMC_RPMB +static int confirm_key_prog(void) +{ + puts("Warning: Programming authentication key can be done only once !\n" + " Use this command only if you are sure of what you are doing,\n" + "Really perform the key programming ? "); + if (getc() == 'y') { + int c; + + putc('y'); + c = getc(); + putc('\n'); + if (c == '\r') + return 1; + }
+ puts("Authentication key programming aborted\n"); + return 0; +} +static int do_mmcrpmb(int argc, char * const argv[]) +{ + enum rpmb_state { + RPMB_INVALID, + RPMB_READ, + RPMB_WRITE, + RPMB_KEY, + RPMB_COUNTER, + } state; + + state = RPMB_INVALID; + if (argc == 4 && strcmp(argv[2], "key") == 0) + state = RPMB_KEY; + if ((argc == 6 || argc == 7) && strcmp(argv[2], "read") == 0) + state = RPMB_READ; + else if (argc == 7 && strcmp(argv[2], "write") == 0) + state = RPMB_WRITE; + else if (argc == 3 && strcmp(argv[2], "counter") == 0) + state = RPMB_COUNTER; + + if (state != RPMB_INVALID) { + struct mmc *mmc = find_mmc_device(curr_device); + void *key_addr; + char original_part; + int ret; + + if (!mmc) { + printf("no mmc device at slot %x\n", curr_device); + return CMD_RET_FAILURE; + } + mmc_init(mmc); + if (IS_SD(mmc)) { + printf("It is not a EMMC device\n"); + return CMD_RET_FAILURE; + } + /* Switch to the RPMB partition */ + original_part = mmc->part_num; + if (mmc->part_num != MMC_PART_RPMB) { + if (mmc_switch_part(curr_device, MMC_PART_RPMB) != 0) + return CMD_RET_FAILURE; + mmc->part_num = MMC_PART_RPMB; + } + ret = CMD_RET_SUCCESS; + if (state == RPMB_KEY) { + key_addr = (void *)simple_strtoul(argv[3], NULL, 16); + if (confirm_key_prog()) { + if (mmc_rpmb_set_key(mmc, key_addr)) { + printf("ERROR - Key already programmed ?\n"); + ret = CMD_RET_FAILURE; + } + } else { + ret = CMD_RET_FAILURE; + } + } else if (state == RPMB_COUNTER) { + unsigned long counter; + if (mmc_rpmb_get_counter(mmc, &counter)) + ret = CMD_RET_FAILURE; + else + printf("Write counter= %lx\n", counter); + } else { + u16 blk, cnt; + void *addr; + int n; + + addr = (void *)simple_strtoul(argv[3], NULL, 16); + blk = simple_strtoul(argv[4], NULL, 16); + cnt = simple_strtoul(argv[5], NULL, 16); + + if (state == RPMB_READ) { + key_addr = (argc == 7) ? + (void *)simple_strtoul(argv[6], + NULL, 16) : + NULL; + n = mmc_rpmb_read(mmc, addr, blk, cnt, + key_addr); + } else { + key_addr = (void *)simple_strtoul(argv[6], + NULL, 16); + n = mmc_rpmb_write(mmc, addr, blk, cnt, + key_addr); + } + printf("%d RPMB blocks %s: %s\n", + n, argv[2], (n == cnt) ? "OK" : "ERROR"); + if (n != cnt) + ret = CMD_RET_FAILURE; + } + + /* Return to orginal partition */ + if (mmc->part_num != original_part) { + if (mmc_switch_part(curr_device, original_part) != 0) + return CMD_RET_FAILURE; + mmc->part_num = original_part; + } + return ret; + } else + return CMD_RET_USAGE; +} +#endif static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { enum mmc_state state; @@ -365,6 +481,10 @@ static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return mmc_set_rst_n_function(mmc, enable); #endif /* CONFIG_SUPPORT_EMMC_BOOT */ +#ifdef CONFIG_SUPPORT_EMMC_RPMB + } else if (strcmp(argv[1], "rpmb") == 0) { + return do_mmcrpmb(argc, argv); +#endif /* CONFIG_SUPPORT_EMMC_RPMB */ }
else if (argc == 3 && strcmp(argv[1], "setdsr") == 0) { @@ -454,7 +574,7 @@ static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
U_BOOT_CMD( - mmc, 6, 1, do_mmcops, + mmc, 7, 1, do_mmcops, "MMC sub system", "read addr blk# cnt\n" "mmc write addr blk# cnt\n" @@ -474,6 +594,12 @@ U_BOOT_CMD( " - Change the RST_n_FUNCTION field of the specified device\n" " WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.\n" #endif +#ifdef CONFIG_SUPPORT_EMMC_RPMB + "mmc rpmb read addr blk# cnt [address of auth-key] - block size is 256 bytes\n" + "mmc rpmb write addr blk# cnt <address of auth-key> - block size is 256 bytes\n" + "mmc rpmb key <address of auth-key> - program the RPMB authentication key.\n" + "mmc rpmb counter - read the value of the write counter\n" +#endif "mmc setdsr - set DSR register value\n" ); #endif /* !CONFIG_GENERIC_MMC */
Changes in V2: - use ALLOC_CACHE_ALIGN_BUFFER in rpmb.c instead of a static buffer for the RPMB frames.
common/cmd_mmc.c | 128 ++++++++++++++++++++- drivers/mmc/Makefile | 1 + drivers/mmc/rpmb.c | 323 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/mmc.h | 10 ++- lib/Makefile | 3 + 5 files changed, 463 insertions(+), 2 deletions(-) create mode 100644 drivers/mmc/rpmb.c
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Pantelis Antoniou panto@antoniou-consulting.com --- drivers/mmc/Makefile | 1 + drivers/mmc/rpmb.c | 323 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/mmc.h | 10 ++- lib/Makefile | 3 + 4 files changed, 336 insertions(+), 1 deletions(-) create mode 100644 drivers/mmc/rpmb.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 931922b..4c6ab9e 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -30,6 +30,7 @@ obj-$(CONFIG_DWMMC) += dw_mmc.o obj-$(CONFIG_EXYNOS_DWMMC) += exynos_dw_mmc.o obj-$(CONFIG_ZYNQ_SDHCI) += zynq_sdhci.o obj-$(CONFIG_SOCFPGA_DWMMC) += socfpga_dw_mmc.o +obj-$(CONFIG_SUPPORT_EMMC_RPMB) += rpmb.o ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o else diff --git a/drivers/mmc/rpmb.c b/drivers/mmc/rpmb.c new file mode 100644 index 0000000..05936f5 --- /dev/null +++ b/drivers/mmc/rpmb.c @@ -0,0 +1,323 @@ +/* + * Copyright 2014, Staubli Faverges + * Pierre Aubert + * + * eMMC- Replay Protected Memory Block + * According to JEDEC Standard No. 84-A441 + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <common.h> +#include <mmc.h> +#include <sha256.h> +#include "mmc_private.h" + +/* Request codes */ +#define RPMB_REQ_KEY 1 +#define RPMB_REQ_WCOUNTER 2 +#define RPMB_REQ_WRITE_DATA 3 +#define RPMB_REQ_READ_DATA 4 +#define RPMB_REQ_STATUS 5 + +/* Response code */ +#define RPMB_RESP_KEY 0x0100 +#define RPMB_RESP_WCOUNTER 0x0200 +#define RPMB_RESP_WRITE_DATA 0x0300 +#define RPMB_RESP_READ_DATA 0x0400 + +/* Error codes */ +#define RPMB_OK 0 +#define RPMB_ERR_GENERAL 1 +#define RPMB_ERR_AUTH 2 +#define RPMB_ERR_COUNTER 3 +#define RPMB_ERR_ADDRESS 4 +#define RPMB_ERR_WRITE 5 +#define RPMB_ERR_READ 6 +#define RPMB_ERR_KEY 7 +#define RPMB_ERR_CNT_EXPIRED 0x80 +#define RPMB_ERR_MSK 0x7 + +/* Sizes of RPMB data frame */ +#define RPMB_SZ_STUFF 196 +#define RPMB_SZ_MAC 32 +#define RPMB_SZ_DATA 256 +#define RPMB_SZ_NONCE 16 + +#define SHA256_BLOCK_SIZE 64 + +/* Error messages */ +static const char * const rpmb_err_msg[] = { + "", + "General failure", + "Authentication failure", + "Counter failure", + "Address failure", + "Write failure", + "Read failure", + "Authentication key not yet programmed", +}; + + +/* Structure of RPMB data frame. */ +struct s_rpmb { + unsigned char stuff[RPMB_SZ_STUFF]; + unsigned char mac[RPMB_SZ_MAC]; + unsigned char data[RPMB_SZ_DATA]; + unsigned char nonce[RPMB_SZ_NONCE]; + unsigned long write_counter; + unsigned short address; + unsigned short block_count; + unsigned short result; + unsigned short request; +}; + +static int mmc_set_blockcount(struct mmc *mmc, unsigned int blockcount, + bool is_rel_write) +{ + struct mmc_cmd cmd = {0}; + + cmd.cmdidx = MMC_CMD_SET_BLOCK_COUNT; + cmd.cmdarg = blockcount & 0x0000FFFF; + if (is_rel_write) + cmd.cmdarg |= 1 << 31; + cmd.resp_type = MMC_RSP_R1; + + return mmc_send_cmd(mmc, &cmd, NULL); +} +static int mmc_rpmb_request(struct mmc *mmc, const struct s_rpmb *s, + unsigned int count, bool is_rel_write) +{ + struct mmc_cmd cmd = {0}; + struct mmc_data data; + int ret; + + ret = mmc_set_blockcount(mmc, count, is_rel_write); + if (ret) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:mmc_set_blockcount-> %d\n", __func__, ret); +#endif + return 1; + } + + cmd.cmdidx = MMC_CMD_WRITE_MULTIPLE_BLOCK; + cmd.cmdarg = 0; + cmd.resp_type = MMC_RSP_R1b; + + data.src = (const char *)s; + data.blocks = 1; + data.blocksize = MMC_MAX_BLOCK_LEN; + data.flags = MMC_DATA_WRITE; + + ret = mmc_send_cmd(mmc, &cmd, &data); + if (ret) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:mmc_send_cmd-> %d\n", __func__, ret); +#endif + return 1; + } + return 0; +} +static int mmc_rpmb_response(struct mmc *mmc, struct s_rpmb *s, + unsigned short expected) +{ + struct mmc_cmd cmd = {0}; + struct mmc_data data; + int ret; + + ret = mmc_set_blockcount(mmc, 1, false); + if (ret) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:mmc_set_blockcount-> %d\n", __func__, ret); +#endif + return -1; + } + cmd.cmdidx = MMC_CMD_READ_MULTIPLE_BLOCK; + cmd.cmdarg = 0; + cmd.resp_type = MMC_RSP_R1; + + data.dest = (char *)s; + data.blocks = 1; + data.blocksize = MMC_MAX_BLOCK_LEN; + data.flags = MMC_DATA_READ; + + ret = mmc_send_cmd(mmc, &cmd, &data); + if (ret) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:mmc_send_cmd-> %d\n", __func__, ret); +#endif + return -1; + } + /* Check the response and the status */ + if (be16_to_cpu(s->request) != expected) { +#ifdef CONFIG_MMC_RPMB_TRACE + printf("%s:response= %x\n", __func__, + be16_to_cpu(s->request)); +#endif + return -1; + } + ret = be16_to_cpu(s->result); + if (ret) { + printf("%s %s\n", rpmb_err_msg[ret & RPMB_ERR_MSK], + (ret & RPMB_ERR_CNT_EXPIRED) ? + "Write counter has expired" : ""); + } + + /* Return the status of the command */ + return ret; +} +static int mmc_rpmb_status(struct mmc *mmc, unsigned short expected) +{ + ALLOC_CACHE_ALIGN_BUFFER(struct s_rpmb, rpmb_frame, 1); + + memset(rpmb_frame, 0, sizeof(struct s_rpmb)); + rpmb_frame->request = cpu_to_be16(RPMB_REQ_STATUS); + if (mmc_rpmb_request(mmc, rpmb_frame, 1, false)) + return -1; + + /* Read the result */ + return mmc_rpmb_response(mmc, rpmb_frame, expected); +} +static void rpmb_hmac(unsigned char *key, unsigned char *buff, int len, + unsigned char *output) +{ + sha256_context ctx; + int i; + unsigned char k_ipad[SHA256_BLOCK_SIZE]; + unsigned char k_opad[SHA256_BLOCK_SIZE]; + + sha256_starts(&ctx); + + /* According to RFC 4634, the HMAC transform looks like: + SHA(K XOR opad, SHA(K XOR ipad, text)) + + where K is an n byte key. + ipad is the byte 0x36 repeated blocksize times + opad is the byte 0x5c repeated blocksize times + and text is the data being protected. + */ + + for (i = 0; i < RPMB_SZ_MAC; i++) { + k_ipad[i] = key[i] ^ 0x36; + k_opad[i] = key[i] ^ 0x5c; + } + /* remaining pad bytes are '\0' XOR'd with ipad and opad values */ + for ( ; i < SHA256_BLOCK_SIZE; i++) { + k_ipad[i] = 0x36; + k_opad[i] = 0x5c; + } + sha256_update(&ctx, k_ipad, SHA256_BLOCK_SIZE); + sha256_update(&ctx, buff, len); + sha256_finish(&ctx, output); + + /* Init context for second pass */ + sha256_starts(&ctx); + + /* start with outer pad */ + sha256_update(&ctx, k_opad, SHA256_BLOCK_SIZE); + + /* then results of 1st hash */ + sha256_update(&ctx, output, RPMB_SZ_MAC); + + /* finish up 2nd pass */ + sha256_finish(&ctx, output); +} +int mmc_rpmb_get_counter(struct mmc *mmc, unsigned long *pcounter) +{ + int ret; + ALLOC_CACHE_ALIGN_BUFFER(struct s_rpmb, rpmb_frame, 1); + + /* Fill the request */ + memset(rpmb_frame, 0, sizeof(struct s_rpmb)); + rpmb_frame->request = cpu_to_be16(RPMB_REQ_WCOUNTER); + if (mmc_rpmb_request(mmc, rpmb_frame, 1, false)) + return -1; + + /* Read the result */ + ret = mmc_rpmb_response(mmc, rpmb_frame, RPMB_RESP_WCOUNTER); + if (ret) + return ret; + + *pcounter = be32_to_cpu(rpmb_frame->write_counter); + return 0; +} +int mmc_rpmb_set_key(struct mmc *mmc, void *key) +{ + ALLOC_CACHE_ALIGN_BUFFER(struct s_rpmb, rpmb_frame, 1); + /* Fill the request */ + memset(rpmb_frame, 0, sizeof(struct s_rpmb)); + rpmb_frame->request = cpu_to_be16(RPMB_REQ_KEY); + memcpy(rpmb_frame->mac, key, RPMB_SZ_MAC); + + if (mmc_rpmb_request(mmc, rpmb_frame, 1, true)) + return -1; + + /* read the operation status */ + return mmc_rpmb_status(mmc, RPMB_RESP_KEY); +} +int mmc_rpmb_read(struct mmc *mmc, void *addr, unsigned short blk, + unsigned short cnt, unsigned char *key) +{ + ALLOC_CACHE_ALIGN_BUFFER(struct s_rpmb, rpmb_frame, 1); + int i; + + for (i = 0; i < cnt; i++) { + /* Fill the request */ + memset(rpmb_frame, 0, sizeof(struct s_rpmb)); + rpmb_frame->address = cpu_to_be16(blk + i); + rpmb_frame->request = cpu_to_be16(RPMB_REQ_READ_DATA); + if (mmc_rpmb_request(mmc, rpmb_frame, 1, false)) + break; + + /* Read the result */ + if (mmc_rpmb_response(mmc, rpmb_frame, RPMB_RESP_READ_DATA)) + break; + + /* Check the HMAC if key is provided */ + if (key) { + unsigned char ret_hmac[RPMB_SZ_MAC]; + + rpmb_hmac(key, rpmb_frame->data, 284, ret_hmac); + if (memcmp(ret_hmac, rpmb_frame->mac, RPMB_SZ_MAC)) { + printf("MAC error on block #%d\n", i); + break; + } + } + /* Copy data */ + memcpy(addr + i * RPMB_SZ_DATA, rpmb_frame->data, RPMB_SZ_DATA); + } + return i; +} +int mmc_rpmb_write(struct mmc *mmc, void *addr, unsigned short blk, + unsigned short cnt, unsigned char *key) +{ + ALLOC_CACHE_ALIGN_BUFFER(struct s_rpmb, rpmb_frame, 1); + unsigned long wcount; + int i; + + for (i = 0; i < cnt; i++) { + if (mmc_rpmb_get_counter(mmc, &wcount)) { + printf("Cannot read RPMB write counter\n"); + break; + } + + /* Fill the request */ + memset(rpmb_frame, 0, sizeof(struct s_rpmb)); + memcpy(rpmb_frame->data, addr + i * RPMB_SZ_DATA, RPMB_SZ_DATA); + rpmb_frame->address = cpu_to_be16(blk + i); + rpmb_frame->block_count = cpu_to_be16(1); + rpmb_frame->write_counter = cpu_to_be32(wcount); + rpmb_frame->request = cpu_to_be16(RPMB_REQ_WRITE_DATA); + /* Computes HMAC */ + rpmb_hmac(key, rpmb_frame->data, 284, rpmb_frame->mac); + + if (mmc_rpmb_request(mmc, rpmb_frame, 1, true)) + break; + + /* Get status */ + if (mmc_rpmb_status(mmc, RPMB_RESP_WRITE_DATA)) + break; + } + return i; +} diff --git a/include/mmc.h b/include/mmc.h index 42d0125..14d296c 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -69,6 +69,7 @@ #define MMC_CMD_SET_BLOCKLEN 16 #define MMC_CMD_READ_SINGLE_BLOCK 17 #define MMC_CMD_READ_MULTIPLE_BLOCK 18 +#define MMC_CMD_SET_BLOCK_COUNT 23 #define MMC_CMD_WRITE_SINGLE_BLOCK 24 #define MMC_CMD_WRITE_MULTIPLE_BLOCK 25 #define MMC_CMD_ERASE_GROUP_START 35 @@ -224,6 +225,7 @@ * boot partitions (2), general purpose partitions (4) in MMC v4.4. */ #define MMC_NUM_BOOT_PARTITION 2 +#define MMC_PART_RPMB 3 /* RPMB partition number */
Dear Pierre Aubert,
- mmc rpmb key <address of the authentication key> Programs the authentication key in the eMMC This key can not be overwritten.
- mmc rpmb read <address> <block> <#count> [address of key] Reads <#count> blocks of 256 bytes in the RPMB partition beginning at block number <block>. If the optionnal address of the authentication key is provided, the Message Authentication Code (MAC) is verified on each block.
- mmc rpmb write <address> <block> <#count> <address of key> Writes <#count> blocks of 256 bytes in the RPMB partition beginning at block number <block>. The datas are signed with the key provided.
- mmc rpmb counter Returns the 'Write counter' of the RPMB partition.
Such new options must be documented in the README.
- puts("Warning: Programming authentication key can be done only once !\n"
- if (getc() == 'y') {
Would it not makes sense to flush the input before reading the char, so that you don;t react on any type-ahead that might already be buffered?
int c;
putc('y');
c = getc();
putc('\n');
if (c == '\r')
return 1;
Should we allow for 'Y"? And for "yes" / "Yes"?
We have getenv_yesno() - maybe we should provide a similar function that can be used in other places where such interactive confirmation is needed?
- if (state != RPMB_INVALID) {
Change this into
if (state == RPMB_INVALID) return CMD_RET_USAGE;
and avoid one level of indentation; this will make the code much easier to read.
if (IS_SD(mmc)) {
Is IS_SD() a reliable test for eMMC devics, or would that also return true in other cases?
} else {
You should really avoid deep nesting and take early exits. You can write this as:
if (!confirm_key_prog()) return CMD_RET_FAILURE;
if (mmc_rpmb_set_key(mmc, key_addr)) { printf("ERROR - Key already programmed ?\n"); ret = CMD_RET_FAILURE; }
Please fix globally.
Please insert a blank line between declarations and code.
As the input is in hex, it is usually also a good idea to (also) print the count in hex.
- } else if (strcmp(argv[1], "rpmb") == 0) {
I think that now, with more subcommands being added, we should convert the mmc code to proper subcommand handling. [It might even make sense to do so for "mmc rpmb", too.]
Hello Wolfgang,
Le 17/04/2014 21:56, Wolfgang Denk a écrit :
Dear Pierre Aubert,
I will add it in a V3
int c;
putc('y');
c = getc();
putc('\n');
if (c == '\r')
return 1;
I have found such a confirmation in cmd_fuse, cmd_otp and cmd_mmc. It makes sense to provide a global function. I will try to submit a patch for that.
Change this into
if (IS_SD(mmc)) {
You're right, the test must be more restrictive. The RPMB partition is available only since the release 4.41 of the Jedec standard. I will fix it in a V3.
} else {
if (!confirm_key_prog()) return CMD_RET_FAILURE; if (mmc_rpmb_set_key(mmc, key_addr)) { printf("ERROR - Key already programmed ?\n"); ret = CMD_RET_FAILURE; }
No problem, it will be fixed globally in V3
Ok
For coherency with the mmc read and mmc write, I kept the same output. But it can be changed, of course.
Do you think about the use of the macro U_BOOT_CMD_MKENT ?
Best regards Pierre Aubert
Dear Pierre,
Yes - see for example how the "env" sub-commands are implemented.
Changes in V3: - add entries in README for configuration options related to eMMC. - new patch for adding the 'confirm_yesno' function as suggested by W.Denk - improved test for existence of RPMB partition. - fix of coding issues.
Pierre Aubert (3): eMMC: add support for operations in RPMB partition Add the function 'confirm_yesno' for interactive confirmation. eMMC: cmd_mmc.c adds the 'rpmb' sub-command for the 'mmc' command
README | 10 ++ common/cmd_fuse.c | 11 +-- common/cmd_mmc.c | 123 +++++++++++++++++++- common/cmd_nand.c | 16 +-- common/cmd_otp.c | 18 +--- common/console.c | 28 ++++- drivers/mmc/Makefile | 1 + drivers/mmc/rpmb.c | 323 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/common.h | 2 +- include/mmc.h | 10 ++- lib/Makefile | 3 + 11 files changed, 506 insertions(+), 39 deletions(-) create mode 100644 drivers/mmc/rpmb.c
User's confirmation is asked in different commands. This commit adds a function for such confirmation.
Signed-off-by: Pierre Aubert p.aubert@staubli.com --- common/cmd_fuse.c | 11 ++--------- common/cmd_nand.c | 16 +++++----------- common/cmd_otp.c | 18 +++--------------- common/console.c | 28 +++++++++++++++++++++++++++- include/common.h | 2 +- 5 files changed, 38 insertions(+), 37 deletions(-)
diff --git a/common/cmd_fuse.c b/common/cmd_fuse.c index 0df57db..abab978 100644 --- a/common/cmd_fuse.c +++ b/common/cmd_fuse.c @@ -33,15 +33,8 @@ static int confirm_prog(void) "what you are doing!\n" "\nReally perform this fuse programming? <y/N>\n");
- if (getc() == 'y') { - int c; - - putc('y'); - c = getc(); - putc('\n'); - if (c == '\r') - return 1; - } + if (confirm_yesno()) + return 1;
puts("Fuse programming aborted\n"); return 0; diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 04ab0f1..a84f7dc 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -605,22 +605,16 @@ static int do_nand(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) opts.spread = spread;
if (scrub) { - if (!scrub_yes) - puts(scrub_warn); - - if (scrub_yes) + if (scrub_yes) { opts.scrub = 1; - else if (getc() == 'y') { - puts("y"); - if (getc() == '\r') + } else { + puts(scrub_warn); + if (confirm_yesno()) { opts.scrub = 1; - else { + } else { puts("scrub aborted\n"); return 1; } - } else { - puts("scrub aborted\n"); - return 1; } } ret = nand_erase_opts(nand, &opts); diff --git a/common/cmd_otp.c b/common/cmd_otp.c index 67808aa..593bb8c 100644 --- a/common/cmd_otp.c +++ b/common/cmd_otp.c @@ -158,21 +158,9 @@ int do_otp(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) lowup(half + count - 1), page + (half + count - 1) / 2, half + count ); - - i = 0; - while (1) { - if (tstc()) { - const char exp_ans[] = "YES\r"; - char c; - putc(c = getc()); - if (exp_ans[i++] != c) { - printf(" Aborting\n"); - return 1; - } else if (!exp_ans[i]) { - puts("\n"); - break; - } - } + if (!confirm_yesno()) { + printf(" Aborting\n"); + return 1; } }
diff --git a/common/console.c b/common/console.c index 2dfb788..5453726 100644 --- a/common/console.c +++ b/common/console.c @@ -537,7 +537,33 @@ int ctrlc(void) } return 0; } - +/* Reads user's confirmation. + Returns 1 if user's input is "y", "Y", "yes" or "YES" +*/ +int confirm_yesno(void) +{ + int i; + char str_input[5]; + + /* Flush input */ + while (tstc()) + getc(); + i = 0; + while (i < sizeof(str_input)) { + str_input[i] = getc(); + putc(str_input[i]); + if (str_input[i] == '\r') + break; + i++; + } + putc('\n'); + if (strncmp(str_input, "y\r", 2) == 0 || + strncmp(str_input, "Y\r", 2) == 0 || + strncmp(str_input, "yes\r", 4) == 0 || + strncmp(str_input, "YES\r", 4) == 0) + return 1; + return 0; +} /* pass 1 to disable ctrlc() checking, 0 to enable. * returns previous state */ diff --git a/include/common.h b/include/common.h index baf361b..1d922b9 100644 --- a/include/common.h +++ b/include/common.h @@ -838,7 +838,7 @@ int ctrlc (void); int had_ctrlc (void); /* have we had a Control-C since last clear? */ void clear_ctrlc (void); /* clear the Control-C condition */ int disable_ctrlc (int); /* 1 to disable, 0 to enable Control-C detect */ - +int confirm_yesno(void); /* 1 if input is "y", "Y", "yes" or "YES" */ /* * STDIO based functions (can always be used) */
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Pantelis Antoniou panto@antoniou-consulting.com --- README | 10 ++++ common/cmd_mmc.c | 123 +++++++++++++++++++++++++++++++++++++++++++++++++++++- 2 files changed, 132 insertions(+), 1 deletions(-)
diff --git a/README b/README index 52a92e7..518e209 100644 --- a/README +++ b/README @@ -1493,6 +1493,16 @@ The following options need to be configured: CONFIG_SH_MMCIF_CLK Define the clock frequency for MMCIF
+ CONFIG_GENERIC_MMC + Enable the generic MMC driver + + CONFIG_SUPPORT_EMMC_BOOT + Enable some additional features of the eMMC boot partitions. + + CONFIG_SUPPORT_EMMC_RPMB + Enable the commands for reading, writing and programming the + key for the Replay Protection Memory Block partition in eMMC. + - USB Device Firmware Update (DFU) class support: CONFIG_DFU_FUNCTION This enables the USB portion of the DFU USB class diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index c1916c9..da8a243 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -130,7 +130,118 @@ U_BOOT_CMD( "display MMC info", "- display info of the current MMC device" ); +#ifdef CONFIG_SUPPORT_EMMC_RPMB +static int confirm_key_prog(void) +{ + puts("Warning: Programming authentication key can be done only once !\n" + " Use this command only if you are sure of what you are doing,\n" + "Really perform the key programming? <y/N> "); + if (confirm_yesno()) + return 1; + + puts("Authentication key programming aborted\n"); + return 0; +} +static int do_mmcrpmb(int argc, char * const argv[]) +{ + enum rpmb_state { + RPMB_INVALID, + RPMB_READ, + RPMB_WRITE, + RPMB_KEY, + RPMB_COUNTER, + } state; + struct mmc *mmc = find_mmc_device(curr_device); + void *key_addr; + char original_part; + int ret; + + state = RPMB_INVALID; + if (argc == 4 && strcmp(argv[2], "key") == 0) + state = RPMB_KEY; + if ((argc == 6 || argc == 7) && strcmp(argv[2], "read") == 0) + state = RPMB_READ; + else if (argc == 7 && strcmp(argv[2], "write") == 0) + state = RPMB_WRITE; + else if (argc == 3 && strcmp(argv[2], "counter") == 0) + state = RPMB_COUNTER; + + if (state == RPMB_INVALID) + return CMD_RET_USAGE;
+ if (!mmc) { + printf("no mmc device at slot %x\n", curr_device); + return CMD_RET_FAILURE; + } + mmc_init(mmc); + if (!(mmc->version & MMC_VERSION_MMC)) { + printf("It is not a EMMC device\n"); + return CMD_RET_FAILURE; + } + if (mmc->version < MMC_VERSION_4_41) { + printf("RPMB not supported before version 4.41\n"); + return CMD_RET_FAILURE; + } + /* Switch to the RPMB partition */ + original_part = mmc->part_num; + if (mmc->part_num != MMC_PART_RPMB) { + if (mmc_switch_part(curr_device, MMC_PART_RPMB) != 0) + return CMD_RET_FAILURE; + mmc->part_num = MMC_PART_RPMB; + } + ret = CMD_RET_SUCCESS; + if (state == RPMB_KEY) { + key_addr = (void *)simple_strtoul(argv[3], NULL, 16); + if (!confirm_key_prog()) + return CMD_RET_FAILURE; + if (mmc_rpmb_set_key(mmc, key_addr)) { + printf("ERROR - Key already programmed ?\n"); + ret = CMD_RET_FAILURE; + } + } else if (state == RPMB_COUNTER) { + unsigned long counter; + + if (mmc_rpmb_get_counter(mmc, &counter)) + ret = CMD_RET_FAILURE; + else + printf("Write counter= %lx\n", counter); + } else { + u16 blk, cnt; + void *addr; + int n; + + addr = (void *)simple_strtoul(argv[3], NULL, 16); + blk = simple_strtoul(argv[4], NULL, 16); + cnt = simple_strtoul(argv[5], NULL, 16); + + if (state == RPMB_READ) { + key_addr = (argc == 7) ? + (void *)simple_strtoul(argv[6], + NULL, 16) : + NULL; + n = mmc_rpmb_read(mmc, addr, blk, cnt, + key_addr); + } else { + key_addr = (void *)simple_strtoul(argv[6], + NULL, 16); + n = mmc_rpmb_write(mmc, addr, blk, cnt, + key_addr); + } + printf("%d RPMB blocks %s: %s\n", + n, argv[2], (n == cnt) ? "OK" : "ERROR"); + if (n != cnt) + ret = CMD_RET_FAILURE; + } + + /* Return to orginal partition */ + if (mmc->part_num != original_part) { + if (mmc_switch_part(curr_device, original_part) != 0) + return CMD_RET_FAILURE; + mmc->part_num = original_part; + } + return ret; +} +#endif static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { enum mmc_state state; @@ -365,6 +476,10 @@ static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
else if (argc == 3 && strcmp(argv[1], "setdsr") == 0) { @@ -454,7 +569,7 @@ static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
U_BOOT_CMD( - mmc, 6, 1, do_mmcops, + mmc, 7, 1, do_mmcops, "MMC sub system", "read addr blk# cnt\n" "mmc write addr blk# cnt\n" @@ -474,6 +589,12 @@ U_BOOT_CMD( " - Change the RST_n_FUNCTION field of the specified device\n" " WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.\n" #endif +#ifdef CONFIG_SUPPORT_EMMC_RPMB + "mmc rpmb read addr blk# cnt [address of auth-key] - block size is 256 bytes\n" + "mmc rpmb write addr blk# cnt <address of auth-key> - block size is 256 bytes\n" + "mmc rpmb key <address of auth-key> - program the RPMB authentication key.\n" + "mmc rpmb counter - read the value of the write counter\n" +#endif "mmc setdsr - set DSR register value\n" ); #endif /* !CONFIG_GENERIC_MMC */
Dear Pierre Aubert,
Unfortunatley there is no changelog here. Please note that this is mandatory for updated patch versions, see [1]
[1] http://www.denx.de/wiki/view/U-Boot/Patches#Sending_updated_patch_versions
A changelog in the cover letter is useless, as this does not get recorded in patchwork. The changelog must always be in the patch itself.
- if (argc == 4 && strcmp(argv[2], "key") == 0)
state = RPMB_KEY;
- if ((argc == 6 || argc == 7) && strcmp(argv[2], "read") == 0)
state = RPMB_READ;
- else if (argc == 7 && strcmp(argv[2], "write") == 0)
state = RPMB_WRITE;
- else if (argc == 3 && strcmp(argv[2], "counter") == 0)
As mentiuoned before, these repeated strcmp() should probably be replaced by a subcommand table.
- ret = CMD_RET_SUCCESS;
- if (state == RPMB_KEY) {
Do a return here, or use some "goto errout" and place the label errout before the needed cleanup acrtions.
- } else if (state == RPMB_COUNTER) {
You can then get rid of this "else" level.
else
Ditto.
Should this be a debug() ?
Again, it would be better to switch the code to regular subcommand processing.
Changes in V4: - use subcommand tables for 'mmc' command and 'mmc rpmb' subcommand. - add 'mmc info' subcommand, which is the same as mmcinfo. mmcinfo is kept for compatibility. - add changelog in commit comments.
Pierre Aubert (3): eMMC: add support for operations in RPMB partition Add the function 'confirm_yesno' for interactive eMMC: cmd_mmc.c adds the 'rpmb' sub-command for the 'mmc' command
README | 10 + common/cmd_fuse.c | 11 +- common/cmd_mmc.c | 806 +++++++++++++++++++++++++++++++------------------ common/cmd_nand.c | 16 +- common/cmd_otp.c | 18 +- common/console.c | 28 ++- drivers/mmc/Makefile | 1 + drivers/mmc/rpmb.c | 323 ++++++++++++++++++++ include/common.h | 2 +- include/mmc.h | 10 +- lib/Makefile | 3 + 11 files changed, 894 insertions(+), 334 deletions(-) create mode 100644 drivers/mmc/rpmb.c
Dear Pierre Aubert,
Changes in V2:
The changelog goes into the comment section (i. e. below the "---" line), not into the commit message. Also, this being V4 of the patch, I wonder what was changed in V3 and V4?
Add changelog here!
Hello Wolfgang,
Le 24/04/2014 08:55, Wolfgang Denk a écrit :
Dear Pierre Aubert,
Changes in V2:
I will fix it in V5. I made the same mistake for the patch 3/3.
There's no change for this patch in V3 and V4. I have resubmitted all the patchset.
Add changelog here!
Ok
Dear Pierre,
Thanks.
Actually I cannot see a V4 of patch 3/3 ?
Then the changelog should say so (like: "V3, V4: no changes").
Hello Wolfgang,
Le 24/04/2014 09:33, Wolfgang Denk a écrit :
Dear Pierre,
Thanks.
It's strange. On my side, I can see it in the mailing list and in patchwork.
Ok, I will fix it.
Best regards Pierre
Dear Pierre.
This is a pretty ugly way to tweak the configuration. Why do we need this?
I gess all you really want is
obj-$(CONFIG_SUPPORT_EMMC_RPMB) += sha256.o
Hello Wolfgang,
Le 24/04/2014 08:59, Wolfgang Denk a écrit :
Dear Pierre.
In message 1398321641-7113-2-git-send-email-p.aubert@staubli.com you wrote: ...
Yes. I will fix it.
Changes in V4: - use subcommand table for 'mmc' command and 'mmc rpmb' subcommand. - add 'mmc info' subcommand, which is the same as mmcinfo. mmcinfo is kept for compatibility. - add changelog in commit comments.
Changes in V3: - add entries in README for configuration options related to eMMC. - improved test for existence of RPMB partition. - fix of coding issues.
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Pantelis Antoniou panto@antoniou-consulting.com CC: Wolfgang Denk wd@denx.de --- README | 10 + common/cmd_mmc.c | 806 ++++++++++++++++++++++++++++++++++-------------------- 2 files changed, 520 insertions(+), 296 deletions(-)
+ CONFIG_GENERIC_MMC + Enable the generic MMC driver + + CONFIG_SUPPORT_EMMC_BOOT + Enable some additional features of the eMMC boot partitions. + + CONFIG_SUPPORT_EMMC_RPMB + Enable the commands for reading, writing and programming the + key for the Replay Protection Memory Block partition in eMMC. + - USB Device Firmware Update (DFU) class support: CONFIG_DFU_FUNCTION This enables the USB portion of the DFU USB class diff --git a/common/cmd_mmc.c b/common/cmd_mmc.c index c1916c9..55af295 100644 --- a/common/cmd_mmc.c +++ b/common/cmd_mmc.c @@ -71,12 +71,6 @@ U_BOOT_CMD( ); #else /* !CONFIG_GENERIC_MMC */
-enum mmc_state { - MMC_INVALID, - MMC_READ, - MMC_WRITE, - MMC_ERASE, -}; static void print_mmcinfo(struct mmc *mmc) { printf("Device: %s\n", mmc->cfg->name); @@ -98,7 +92,18 @@ static void print_mmcinfo(struct mmc *mmc)
printf("Bus Width: %d-bit\n", mmc->bus_width); } - +static struct mmc *init_mmc_device(int dev) +{ + struct mmc *mmc; + mmc = find_mmc_device(dev); + if (!mmc) { + printf("no mmc device at slot %x\n", dev); + return NULL; + } + if (mmc_init(mmc)) + return NULL; + return mmc; +} static int do_mmcinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { struct mmc *mmc; @@ -112,351 +117,546 @@ static int do_mmcinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } }
- mmc = find_mmc_device(curr_device); + mmc = init_mmc_device(curr_device); + if (!mmc) + return CMD_RET_FAILURE;
- if (mmc) { - mmc_init(mmc); + print_mmcinfo(mmc); + return CMD_RET_SUCCESS; +}
- print_mmcinfo(mmc); - return 0; - } else { - printf("no mmc device at slot %x\n", curr_device); +#ifdef CONFIG_SUPPORT_EMMC_RPMB +static int confirm_key_prog(void) +{ + puts("Warning: Programming authentication key can be done only once !\n" + " Use this command only if you are sure of what you are doing,\n" + "Really perform the key programming? <y/N> "); + if (confirm_yesno()) return 1; + + puts("Authentication key programming aborted\n"); + return 0; +} +static int do_mmcrpmb_key(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + void *key_addr; + struct mmc *mmc = find_mmc_device(curr_device); + + if (argc != 2) + return CMD_RET_USAGE; + + key_addr = (void *)simple_strtoul(argv[1], NULL, 16); + if (!confirm_key_prog()) + return CMD_RET_FAILURE; + if (mmc_rpmb_set_key(mmc, key_addr)) { + printf("ERROR - Key already programmed ?\n"); + return CMD_RET_FAILURE; } + return CMD_RET_SUCCESS; } +static int do_mmcrpmb_read(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + u16 blk, cnt; + void *addr; + int n; + void *key_addr = NULL; + struct mmc *mmc = find_mmc_device(curr_device);
-U_BOOT_CMD( - mmcinfo, 1, 0, do_mmcinfo, - "display MMC info", - "- display info of the current MMC device" -); + if (argc < 4) + return CMD_RET_USAGE;
-static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) + addr = (void *)simple_strtoul(argv[1], NULL, 16); + blk = simple_strtoul(argv[2], NULL, 16); + cnt = simple_strtoul(argv[3], NULL, 16); + + if (argc == 5) + key_addr = (void *)simple_strtoul(argv[4], NULL, 16); + + printf("\nMMC RPMB read: dev # %d, block # %d, count %d ... ", + curr_device, blk, cnt); + n = mmc_rpmb_read(mmc, addr, blk, cnt, key_addr); + + printf("%d RPMB blocks read: %s\n", n, (n == cnt) ? "OK" : "ERROR"); + if (n != cnt) + return CMD_RET_FAILURE; + return CMD_RET_SUCCESS; +} +static int do_mmcrpmb_write(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) { - enum mmc_state state; + u16 blk, cnt; + void *addr; + int n; + void *key_addr; + struct mmc *mmc = find_mmc_device(curr_device);
- if (argc < 2) + if (argc != 5) return CMD_RET_USAGE;
- if (curr_device < 0) { - if (get_mmc_num() > 0) - curr_device = 0; - else { - puts("No MMC device available\n"); - return 1; - } + addr = (void *)simple_strtoul(argv[1], NULL, 16); + blk = simple_strtoul(argv[2], NULL, 16); + cnt = simple_strtoul(argv[3], NULL, 16); + key_addr = (void *)simple_strtoul(argv[4], NULL, 16); + + printf("\nMMC RPMB write: dev # %d, block # %d, count %d ... ", + curr_device, blk, cnt); + n = mmc_rpmb_write(mmc, addr, blk, cnt, key_addr); + + printf("%d RPMB blocks written: %s\n", n, (n == cnt) ? "OK" : "ERROR"); + if (n != cnt) + return CMD_RET_FAILURE; + return CMD_RET_SUCCESS; +} +static int do_mmcrpmb_counter(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + unsigned long counter; + struct mmc *mmc = find_mmc_device(curr_device); + + if (mmc_rpmb_get_counter(mmc, &counter)) + return CMD_RET_FAILURE; + printf("RPMB Write counter= %lx\n", counter); + return CMD_RET_SUCCESS; +} + +static cmd_tbl_t cmd_rpmb[] = { + U_BOOT_CMD_MKENT(key, 2, 0, do_mmcrpmb_key, "", ""), + U_BOOT_CMD_MKENT(read, 5, 1, do_mmcrpmb_read, "", ""), + U_BOOT_CMD_MKENT(write, 5, 0, do_mmcrpmb_write, "", ""), + U_BOOT_CMD_MKENT(counter, 1, 1, do_mmcrpmb_counter, "", ""), +}; + +static int do_mmcrpmb(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + cmd_tbl_t *cp; + struct mmc *mmc; + char original_part; + int ret; + + cp = find_cmd_tbl(argv[1], cmd_rpmb, ARRAY_SIZE(cmd_rpmb)); + + /* Drop the rpmb subcommand */ + argc--; + argv++; + + if (cp == NULL || argc > cp->maxargs) + return CMD_RET_USAGE; + if (flag == CMD_FLAG_REPEAT && !cp->repeatable) + return CMD_RET_SUCCESS; + + mmc = init_mmc_device(curr_device); + if (!mmc) + return CMD_RET_FAILURE; + + if (!(mmc->version & MMC_VERSION_MMC)) { + printf("It is not a EMMC device\n"); + return CMD_RET_FAILURE; + } + if (mmc->version < MMC_VERSION_4_41) { + printf("RPMB not supported before version 4.41\n"); + return CMD_RET_FAILURE; } + /* Switch to the RPMB partition */ + original_part = mmc->part_num; + if (mmc->part_num != MMC_PART_RPMB) { + if (mmc_switch_part(curr_device, MMC_PART_RPMB) != 0) + return CMD_RET_FAILURE; + mmc->part_num = MMC_PART_RPMB; + } + ret = cp->cmd(cmdtp, flag, argc, argv);
- if (strcmp(argv[1], "rescan") == 0) { - struct mmc *mmc; + /* Return to original partition */ + if (mmc->part_num != original_part) { + if (mmc_switch_part(curr_device, original_part) != 0) + return CMD_RET_FAILURE; + mmc->part_num = original_part; + } + return ret; +} +#endif
- if (argc != 2) - return CMD_RET_USAGE; +static int do_mmc_read(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + struct mmc *mmc; + u32 blk, cnt, n; + void *addr;
- mmc = find_mmc_device(curr_device); - if (!mmc) { - printf("no mmc device at slot %x\n", curr_device); - return 1; - } + if (argc != 4) + return CMD_RET_USAGE;
- mmc->has_init = 0; + addr = (void *)simple_strtoul(argv[1], NULL, 16); + blk = simple_strtoul(argv[2], NULL, 16); + cnt = simple_strtoul(argv[3], NULL, 16);
- if (mmc_init(mmc)) - return 1; - else - return 0; - } else if (strcmp(argv[1], "part") == 0) { - block_dev_desc_t *mmc_dev; - struct mmc *mmc; + mmc = init_mmc_device(curr_device); + if (!mmc) + return CMD_RET_FAILURE;
- if (argc != 2) - return CMD_RET_USAGE; + printf("\nMMC read: dev # %d, block # %d, count %d ... ", + curr_device, blk, cnt);
- mmc = find_mmc_device(curr_device); - if (!mmc) { - printf("no mmc device at slot %x\n", curr_device); - return 1; - } - mmc_init(mmc); - mmc_dev = mmc_get_dev(curr_device); - if (mmc_dev != NULL && - mmc_dev->type != DEV_TYPE_UNKNOWN) { - print_part(mmc_dev); - return 0; - } + n = mmc->block_dev.block_read(curr_device, blk, cnt, addr); + /* flush cache after read */ + flush_cache((ulong)addr, cnt * 512); /* FIXME */ + printf("%d blocks read: %s\n", n, (n == cnt) ? "OK" : "ERROR");
- puts("get mmc type error!\n"); - return 1; - } else if (strcmp(argv[1], "list") == 0) { - if (argc != 2) - return CMD_RET_USAGE; - print_mmc_devices('\n'); - return 0; - } else if (strcmp(argv[1], "dev") == 0) { - int dev, part = -1; - struct mmc *mmc; - - if (argc == 2) - dev = curr_device; - else if (argc == 3) - dev = simple_strtoul(argv[2], NULL, 10); - else if (argc == 4) { - dev = (int)simple_strtoul(argv[2], NULL, 10); - part = (int)simple_strtoul(argv[3], NULL, 10); - if (part > PART_ACCESS_MASK) { - printf("#part_num shouldn't be larger" - " than %d\n", PART_ACCESS_MASK); - return 1; - } - } else - return CMD_RET_USAGE; + return (n == cnt) ? CMD_RET_SUCCESS : CMD_RET_FAILURE; +} +static int do_mmc_write(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + struct mmc *mmc; + u32 blk, cnt, n; + void *addr;
- mmc = find_mmc_device(dev); - if (!mmc) { - printf("no mmc device at slot %x\n", dev); - return 1; - } + if (argc != 4) + return CMD_RET_USAGE;
- mmc_init(mmc); - if (part != -1) { - int ret; - if (mmc->part_config == MMCPART_NOAVAILABLE) { - printf("Card doesn't support part_switch\n"); - return 1; - } + addr = (void *)simple_strtoul(argv[1], NULL, 16); + blk = simple_strtoul(argv[2], NULL, 16); + cnt = simple_strtoul(argv[3], NULL, 16);
- if (part != mmc->part_num) { - ret = mmc_switch_part(dev, part); - if (!ret) - mmc->part_num = part; + mmc = init_mmc_device(curr_device); + if (!mmc) + return CMD_RET_FAILURE;
- printf("switch to partitions #%d, %s\n", - part, (!ret) ? "OK" : "ERROR"); - } - } - curr_device = dev; - if (mmc->part_config == MMCPART_NOAVAILABLE) - printf("mmc%d is current device\n", curr_device); - else - printf("mmc%d(part %d) is current device\n", - curr_device, mmc->part_num); + printf("\nMMC write: dev # %d, block # %d, count %d ... ", + curr_device, blk, cnt);
- return 0; -#ifdef CONFIG_SUPPORT_EMMC_BOOT - } else if (strcmp(argv[1], "partconf") == 0) { - int dev; - struct mmc *mmc; - u8 ack, part_num, access; - - if (argc == 6) { - dev = simple_strtoul(argv[2], NULL, 10); - ack = simple_strtoul(argv[3], NULL, 10); - part_num = simple_strtoul(argv[4], NULL, 10); - access = simple_strtoul(argv[5], NULL, 10); - } else { - return CMD_RET_USAGE; - } + if (mmc_getwp(mmc) == 1) { + printf("Error: card is write protected!\n"); + return CMD_RET_FAILURE; + } + n = mmc->block_dev.block_write(curr_device, blk, cnt, addr); + printf("%d blocks written: %s\n", n, (n == cnt) ? "OK" : "ERROR");
- mmc = find_mmc_device(dev); - if (!mmc) { - printf("no mmc device at slot %x\n", dev); - return 1; - } + return (n == cnt) ? CMD_RET_SUCCESS : CMD_RET_FAILURE; +} +static int do_mmc_erase(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + struct mmc *mmc; + u32 blk, cnt, n;
- if (IS_SD(mmc)) { - puts("PARTITION_CONFIG only exists on eMMC\n"); - return 1; - } + if (argc != 3) + return CMD_RET_USAGE;
- /* acknowledge to be sent during boot operation */ - return mmc_set_part_conf(mmc, ack, part_num, access); - } else if (strcmp(argv[1], "bootbus") == 0) { - int dev; - struct mmc *mmc; - u8 width, reset, mode; - - if (argc == 6) { - dev = simple_strtoul(argv[2], NULL, 10); - width = simple_strtoul(argv[3], NULL, 10); - reset = simple_strtoul(argv[4], NULL, 10); - mode = simple_strtoul(argv[5], NULL, 10); - } else { - return CMD_RET_USAGE; - } + blk = simple_strtoul(argv[1], NULL, 16); + cnt = simple_strtoul(argv[2], NULL, 16);
- mmc = find_mmc_device(dev); - if (!mmc) { - printf("no mmc device at slot %x\n", dev); - return 1; - } + mmc = init_mmc_device(curr_device); + if (!mmc) + return CMD_RET_FAILURE;
- if (IS_SD(mmc)) { - puts("BOOT_BUS_WIDTH only exists on eMMC\n"); - return 1; - } + printf("\nMMC erase: dev # %d, block # %d, count %d ... ", + curr_device, blk, cnt);
- /* acknowledge to be sent during boot operation */ - return mmc_set_boot_bus_width(mmc, width, reset, mode); - } else if (strcmp(argv[1], "bootpart-resize") == 0) { - int dev; - struct mmc *mmc; - u32 bootsize, rpmbsize; - - if (argc == 5) { - dev = simple_strtoul(argv[2], NULL, 10); - bootsize = simple_strtoul(argv[3], NULL, 10); - rpmbsize = simple_strtoul(argv[4], NULL, 10); - } else { - return CMD_RET_USAGE; - } + if (mmc_getwp(mmc) == 1) { + printf("Error: card is write protected!\n"); + return CMD_RET_FAILURE; + } + n = mmc->block_dev.block_erase(curr_device, blk, cnt); + printf("%d blocks erased: %s\n", n, (n == cnt) ? "OK" : "ERROR");
- mmc = find_mmc_device(dev); - if (!mmc) { - printf("no mmc device at slot %x\n", dev); - return 1; - } + return (n == cnt) ? CMD_RET_SUCCESS : CMD_RET_FAILURE; +} +static int do_mmc_rescan(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + struct mmc *mmc;
- if (IS_SD(mmc)) { - printf("It is not a EMMC device\n"); - return 1; - } + mmc = find_mmc_device(curr_device); + if (!mmc) { + printf("no mmc device at slot %x\n", curr_device); + return CMD_RET_FAILURE; + }
- if (0 == mmc_boot_partition_size_change(mmc, - bootsize, rpmbsize)) { - printf("EMMC boot partition Size %d MB\n", bootsize); - printf("EMMC RPMB partition Size %d MB\n", rpmbsize); - return 0; - } else { - printf("EMMC boot partition Size change Failed.\n"); - return 1; - } - } else if (strcmp(argv[1], "rst-function") == 0) { - /* - * Set the RST_n_ENABLE bit of RST_n_FUNCTION - * The only valid values are 0x0, 0x1 and 0x2 and writing - * a value of 0x1 or 0x2 sets the value permanently. - */ - int dev; - struct mmc *mmc; - u8 enable; - - if (argc == 4) { - dev = simple_strtoul(argv[2], NULL, 10); - enable = simple_strtoul(argv[3], NULL, 10); - } else { - return CMD_RET_USAGE; - } + mmc->has_init = 0;
- if (enable > 2 || enable < 0) { - puts("Invalid RST_n_ENABLE value\n"); - return CMD_RET_USAGE; + if (mmc_init(mmc)) + return CMD_RET_FAILURE; + return CMD_RET_SUCCESS; +} +static int do_mmc_part(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + block_dev_desc_t *mmc_dev; + struct mmc *mmc; + + mmc = init_mmc_device(curr_device); + if (!mmc) + return CMD_RET_FAILURE; + + mmc_dev = mmc_get_dev(curr_device); + if (mmc_dev != NULL && mmc_dev->type != DEV_TYPE_UNKNOWN) { + print_part(mmc_dev); + return CMD_RET_SUCCESS; + } + + puts("get mmc type error!\n"); + return CMD_RET_FAILURE; +} +static int do_mmc_dev(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + int dev, part = -1; + struct mmc *mmc; + + if (argc == 1) { + dev = curr_device; + } else if (argc == 2) { + dev = simple_strtoul(argv[1], NULL, 10); + } else if (argc == 3) { + dev = (int)simple_strtoul(argv[1], NULL, 10); + part = (int)simple_strtoul(argv[2], NULL, 10); + if (part > PART_ACCESS_MASK) { + printf("#part_num shouldn't be larger than %d\n", + PART_ACCESS_MASK); + return CMD_RET_FAILURE; } + } else { + return CMD_RET_USAGE; + }
- mmc = find_mmc_device(dev); - if (!mmc) { - printf("no mmc device at slot %x\n", dev); - return 1; + mmc = init_mmc_device(dev); + if (!mmc) + return CMD_RET_FAILURE; + + if (part != -1) { + int ret; + if (mmc->part_config == MMCPART_NOAVAILABLE) { + printf("Card doesn't support part_switch\n"); + return CMD_RET_FAILURE; }
- if (IS_SD(mmc)) { - puts("RST_n_FUNCTION only exists on eMMC\n"); - return 1; + if (part != mmc->part_num) { + ret = mmc_switch_part(dev, part); + if (!ret) + mmc->part_num = part; + + printf("switch to partitions #%d, %s\n", + part, (!ret) ? "OK" : "ERROR"); } + } + curr_device = dev; + if (mmc->part_config == MMCPART_NOAVAILABLE) + printf("mmc%d is current device\n", curr_device); + else + printf("mmc%d(part %d) is current device\n", + curr_device, mmc->part_num);
- return mmc_set_rst_n_function(mmc, enable); -#endif /* CONFIG_SUPPORT_EMMC_BOOT */ + return CMD_RET_SUCCESS; +} +static int do_mmc_list(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + print_mmc_devices('\n'); + return CMD_RET_SUCCESS; +} +#ifdef CONFIG_SUPPORT_EMMC_BOOT +static int do_mmc_bootbus(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + int dev; + struct mmc *mmc; + u8 width, reset, mode; + + if (argc != 5) + return CMD_RET_USAGE; + dev = simple_strtoul(argv[1], NULL, 10); + width = simple_strtoul(argv[2], NULL, 10); + reset = simple_strtoul(argv[3], NULL, 10); + mode = simple_strtoul(argv[4], NULL, 10); + + mmc = init_mmc_device(dev); + if (!mmc) + return CMD_RET_FAILURE; + + if (IS_SD(mmc)) { + puts("BOOT_BUS_WIDTH only exists on eMMC\n"); + return CMD_RET_FAILURE; }
- else if (argc == 3 && strcmp(argv[1], "setdsr") == 0) { - struct mmc *mmc = find_mmc_device(curr_device); - u32 val = simple_strtoul(argv[2], NULL, 16); - int ret; + /* acknowledge to be sent during boot operation */ + return mmc_set_boot_bus_width(mmc, width, reset, mode); +} +static int do_mmc_boot_resize(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + int dev; + struct mmc *mmc; + u32 bootsize, rpmbsize;
- if (!mmc) { - printf("no mmc device at slot %x\n", curr_device); - return 1; - } - ret = mmc_set_dsr(mmc, val); - printf("set dsr %s\n", (!ret) ? "OK, force rescan" : "ERROR"); - if (!ret) { - mmc->has_init = 0; - if (mmc_init(mmc)) - return 1; - else - return 0; - } - return ret; + if (argc != 4) + return CMD_RET_USAGE; + dev = simple_strtoul(argv[1], NULL, 10); + bootsize = simple_strtoul(argv[2], NULL, 10); + rpmbsize = simple_strtoul(argv[3], NULL, 10); + + mmc = init_mmc_device(dev); + if (!mmc) + return CMD_RET_FAILURE; + + if (IS_SD(mmc)) { + printf("It is not a EMMC device\n"); + return CMD_RET_FAILURE; }
- state = MMC_INVALID; - if (argc == 5 && strcmp(argv[1], "read") == 0) - state = MMC_READ; - else if (argc == 5 && strcmp(argv[1], "write") == 0) - state = MMC_WRITE; - else if (argc == 4 && strcmp(argv[1], "erase") == 0) - state = MMC_ERASE; - - if (state != MMC_INVALID) { - struct mmc *mmc = find_mmc_device(curr_device); - int idx = 2; - u32 blk, cnt, n; - void *addr; - - if (state != MMC_ERASE) { - addr = (void *)simple_strtoul(argv[idx], NULL, 16); - ++idx; - } else - addr = NULL; - blk = simple_strtoul(argv[idx], NULL, 16); - cnt = simple_strtoul(argv[idx + 1], NULL, 16); - - if (!mmc) { - printf("no mmc device at slot %x\n", curr_device); - return 1; - } + if (mmc_boot_partition_size_change(mmc, bootsize, rpmbsize)) { + printf("EMMC boot partition Size change Failed.\n"); + return CMD_RET_FAILURE; + }
- printf("\nMMC %s: dev # %d, block # %d, count %d ... ", - argv[1], curr_device, blk, cnt); + printf("EMMC boot partition Size %d MB\n", bootsize); + printf("EMMC RPMB partition Size %d MB\n", rpmbsize); + return CMD_RET_SUCCESS; +} +static int do_mmc_partconf(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + int dev; + struct mmc *mmc; + u8 ack, part_num, access;
- mmc_init(mmc); + if (argc != 5) + return CMD_RET_USAGE;
- if ((state == MMC_WRITE || state == MMC_ERASE)) { - if (mmc_getwp(mmc) == 1) { - printf("Error: card is write protected!\n"); - return 1; - } - } + dev = simple_strtoul(argv[1], NULL, 10); + ack = simple_strtoul(argv[2], NULL, 10); + part_num = simple_strtoul(argv[3], NULL, 10); + access = simple_strtoul(argv[4], NULL, 10);
- switch (state) { - case MMC_READ: - n = mmc->block_dev.block_read(curr_device, blk, - cnt, addr); - /* flush cache after read */ - flush_cache((ulong)addr, cnt * 512); /* FIXME */ - break; - case MMC_WRITE: - n = mmc->block_dev.block_write(curr_device, blk, - cnt, addr); - break; - case MMC_ERASE: - n = mmc->block_dev.block_erase(curr_device, blk, cnt); - break; - default: - BUG(); - } + mmc = init_mmc_device(dev); + if (!mmc) + return CMD_RET_FAILURE; + + if (IS_SD(mmc)) { + puts("PARTITION_CONFIG only exists on eMMC\n"); + return CMD_RET_FAILURE; + } + + /* acknowledge to be sent during boot operation */ + return mmc_set_part_conf(mmc, ack, part_num, access); +} +static int do_mmc_rst_func(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + int dev; + struct mmc *mmc; + u8 enable; + + /* + * Set the RST_n_ENABLE bit of RST_n_FUNCTION + * The only valid values are 0x0, 0x1 and 0x2 and writing + * a value of 0x1 or 0x2 sets the value permanently. + */ + if (argc != 3) + return CMD_RET_USAGE; + + dev = simple_strtoul(argv[1], NULL, 10); + enable = simple_strtoul(argv[2], NULL, 10); + + if (enable > 2 || enable < 0) { + puts("Invalid RST_n_ENABLE value\n"); + return CMD_RET_USAGE; + } + + mmc = init_mmc_device(dev); + if (!mmc) + return CMD_RET_FAILURE; + + if (IS_SD(mmc)) { + puts("RST_n_FUNCTION only exists on eMMC\n"); + return CMD_RET_FAILURE; + }
- printf("%d blocks %s: %s\n", - n, argv[1], (n == cnt) ? "OK" : "ERROR"); - return (n == cnt) ? 0 : 1; + return mmc_set_rst_n_function(mmc, enable); +} +#endif +static int do_mmc_setdsr(cmd_tbl_t *cmdtp, int flag, + int argc, char * const argv[]) +{ + struct mmc *mmc; + u32 val; + int ret; + + if (argc != 2) + return CMD_RET_USAGE; + val = simple_strtoul(argv[2], NULL, 16); + + mmc = find_mmc_device(curr_device); + if (!mmc) { + printf("no mmc device at slot %x\n", curr_device); + return CMD_RET_FAILURE; + } + ret = mmc_set_dsr(mmc, val); + printf("set dsr %s\n", (!ret) ? "OK, force rescan" : "ERROR"); + if (!ret) { + mmc->has_init = 0; + if (mmc_init(mmc)) + return CMD_RET_FAILURE; + else + return CMD_RET_SUCCESS; } + return ret; +} + +static cmd_tbl_t cmd_mmc[] = { + U_BOOT_CMD_MKENT(info, 1, 0, do_mmcinfo, "", ""), + U_BOOT_CMD_MKENT(read, 4, 1, do_mmc_read, "", ""), + U_BOOT_CMD_MKENT(write, 4, 0, do_mmc_write, "", ""), + U_BOOT_CMD_MKENT(erase, 3, 0, do_mmc_erase, "", ""), + U_BOOT_CMD_MKENT(rescan, 1, 1, do_mmc_rescan, "", ""), + U_BOOT_CMD_MKENT(part, 1, 1, do_mmc_part, "", ""), + U_BOOT_CMD_MKENT(dev, 3, 0, do_mmc_dev, "", ""), + U_BOOT_CMD_MKENT(list, 1, 1, do_mmc_list, "", ""), +#ifdef CONFIG_SUPPORT_EMMC_BOOT + U_BOOT_CMD_MKENT(bootbus, 5, 0, do_mmc_bootbus, "", ""), + U_BOOT_CMD_MKENT(bootpart-resize, 3, 0, do_mmc_boot_resize, "", ""), + U_BOOT_CMD_MKENT(partconf, 5, 0, do_mmc_partconf, "", ""), + U_BOOT_CMD_MKENT(rst-function, 3, 0, do_mmc_rst_func, "", ""), +#endif +#ifdef CONFIG_SUPPORT_EMMC_RPMB + U_BOOT_CMD_MKENT(rpmb, CONFIG_SYS_MAXARGS, 1, do_mmcrpmb, "", ""), +#endif + U_BOOT_CMD_MKENT(setdsr, 2, 0, do_mmc_setdsr, "", ""), +}; + +static int do_mmcops(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + cmd_tbl_t *cp; + + cp = find_cmd_tbl(argv[1], cmd_mmc, ARRAY_SIZE(cmd_mmc)); + + /* Drop the mmc command */ + argc--; + argv++; + + if (cp == NULL || argc > cp->maxargs) + return CMD_RET_USAGE; + if (flag == CMD_FLAG_REPEAT && !cp->repeatable) + return CMD_RET_SUCCESS;
- return CMD_RET_USAGE; + if (curr_device < 0) { + if (get_mmc_num() > 0) { + curr_device = 0; + } else { + puts("No MMC device available\n"); + return CMD_RET_FAILURE; + } + } + return cp->cmd(cmdtp, flag, argc, argv); }
U_BOOT_CMD( - mmc, 6, 1, do_mmcops, + mmc, 7, 1, do_mmcops, "MMC sub system", - "read addr blk# cnt\n" + "info - display info of the current MMC device\n" + "mmc read addr blk# cnt\n" "mmc write addr blk# cnt\n" "mmc erase blk# cnt\n" "mmc rescan\n" @@ -474,6 +674,20 @@ U_BOOT_CMD( " - Change the RST_n_FUNCTION field of the specified device\n" " WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.\n" #endif - "mmc setdsr - set DSR register value\n" +#ifdef CONFIG_SUPPORT_EMMC_RPMB + "mmc rpmb read addr blk# cnt [address of auth-key] - block size is 256 bytes\n" + "mmc rpmb write addr blk# cnt <address of auth-key> - block size is 256 bytes\n" + "mmc rpmb key <address of auth-key> - program the RPMB authentication key.\n" + "mmc rpmb counter - read the value of the write counter\n" +#endif + "mmc setdsr <value> - set DSR register value\n" ); + +/* Old command kept for compatibility. Same as 'mmc info' */ +U_BOOT_CMD( + mmcinfo, 1, 0, do_mmcinfo, + "display MMC info", + "- display info of the current MMC device" +); + #endif /* !CONFIG_GENERIC_MMC */
This serie of patches adds some functions and a sub-command of 'mmc' for programming the authentication key and for reading and writing the RPMB partition of an eMMC according to the JEDEC standard No. 64-A441
The sub-command rpmb is enabled by the flag CONFIG_SUPPORT_EMMC_RPMB defined in the board configuration file. It has been tested on a SabreSDP iMX6 board.
Changes in V5: - move changelog to the right place for each patches - add empty changelog for patches with no change - change lib/Makefile for adding sha256 when CONFIG_SUPPORT_EMMC_RPMB is defined
README | 10 + common/cmd_fuse.c | 11 +- common/cmd_mmc.c | 806 +++++++++++++++++++++++++++++++------------------ common/cmd_nand.c | 16 +- common/cmd_otp.c | 18 +- common/console.c | 28 ++- drivers/mmc/Makefile | 1 + drivers/mmc/rpmb.c | 323 ++++++++++++++++++++ include/common.h | 2 +- include/mmc.h | 10 +- lib/Makefile | 1 + 11 files changed, 892 insertions(+), 334 deletions(-) create mode 100644 drivers/mmc/rpmb.c
This patch adds functions for read, write and authentication key programming for the Replay Protected Memory Block partition in the eMMC.
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Pantelis Antoniou panto@antoniou-consulting.com --- Changes in V5: - move changelog to the right place - change lib/Makefile for adding sha256 when CONFIG_SUPPORT_EMMC_RPMB is defined
V3, V4: no changes
drivers/mmc/Makefile | 1 + drivers/mmc/rpmb.c | 323 ++++++++++++++++++++++++++++++++++++++++++++++++++ include/mmc.h | 10 ++- lib/Makefile | 1 + 4 files changed, 334 insertions(+), 1 deletions(-) create mode 100644 drivers/mmc/rpmb.c
struct mmc_cid { unsigned long psn; @@ -335,7 +337,13 @@ int mmc_set_part_conf(struct mmc *mmc, u8 ack, u8 part_num, u8 access); int mmc_set_boot_bus_width(struct mmc *mmc, u8 width, u8 reset, u8 mode); /* Function to modify the RST_n_FUNCTION field of EXT_CSD */ int mmc_set_rst_n_function(struct mmc *mmc, u8 enable); - +/* Functions to read / write the RPMB partition */ +int mmc_rpmb_set_key(struct mmc *mmc, void *key); +int mmc_rpmb_get_counter(struct mmc *mmc, unsigned long *counter); +int mmc_rpmb_read(struct mmc *mmc, void *addr, unsigned short blk, + unsigned short cnt, unsigned char *key); +int mmc_rpmb_write(struct mmc *mmc, void *addr, unsigned short blk, + unsigned short cnt, unsigned char *key); /** * Start device initialization and return immediately; it does not block on * polling OCR (operation condition register) status. Then you should call diff --git a/lib/Makefile b/lib/Makefile index 27e4f78..377ab13 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -35,6 +35,7 @@ obj-y += net_utils.o obj-$(CONFIG_PHYSMEM) += physmem.o obj-y += qsort.o obj-$(CONFIG_SHA1) += sha1.o +obj-$(CONFIG_SUPPORT_EMMC_RPMB) += sha256.o obj-$(CONFIG_SHA256) += sha256.o obj-y += strmhz.o obj-$(CONFIG_TPM) += tpm.o
Hi Pierre,
Changes in V5:
defined
V3, V4: no changes
Changes in V2:
RPMB frames.
- Copyright 2014, Staubli Faverges
- Pierre Aubert
- eMMC- Replay Protected Memory Block
- According to JEDEC Standard No. 84-A441
- "General failure",
- "Authentication failure",
- "Counter failure",
- "Address failure",
- "Write failure",
- "Read failure",
- "Authentication key not yet programmed",
- unsigned char stuff[RPMB_SZ_STUFF];
- unsigned char mac[RPMB_SZ_MAC];
- unsigned char data[RPMB_SZ_DATA];
- unsigned char nonce[RPMB_SZ_NONCE];
- unsigned long write_counter;
- unsigned short address;
- unsigned short block_count;
- unsigned short result;
- unsigned short request;
bool is_rel_write)
- struct mmc_cmd cmd = {0};
- cmd.cmdidx = MMC_CMD_SET_BLOCK_COUNT;
- cmd.cmdarg = blockcount & 0x0000FFFF;
- if (is_rel_write)
- cmd.resp_type = MMC_RSP_R1;
- return mmc_send_cmd(mmc, &cmd, NULL);
- struct mmc_data data;
- int ret;
- ret = mmc_set_blockcount(mmc, count, is_rel_write);
- if (ret) {
return 1;
- cmd.cmdidx = MMC_CMD_WRITE_MULTIPLE_BLOCK;
- cmd.cmdarg = 0;
- cmd.resp_type = MMC_RSP_R1b;
- data.src = (const char *)s;
- data.blocks = 1;
- data.blocksize = MMC_MAX_BLOCK_LEN;
- data.flags = MMC_DATA_WRITE;
- ret = mmc_send_cmd(mmc, &cmd, &data);
- if (ret) {
return 1;
- int ret;
- ret = mmc_set_blockcount(mmc, 1, false);
- if (ret) {
return -1;
- cmd.cmdidx = MMC_CMD_READ_MULTIPLE_BLOCK;
- cmd.cmdarg = 0;
- data.dest = (char *)s;
- data.blocks = 1;
- data.flags = MMC_DATA_READ;
- if (ret) {
return -1;
- /* Check the response and the status */
- if (be16_to_cpu(s->request) != expected) {
return -1;
- ret = be16_to_cpu(s->result);
- if (ret) {
- /* Return the status of the command */
- return ret;
- ALLOC_CACHE_ALIGN_BUFFER(struct s_rpmb, rpmb_frame, 1);
- memset(rpmb_frame, 0, sizeof(struct s_rpmb));
- rpmb_frame->request = cpu_to_be16(RPMB_REQ_STATUS);
- if (mmc_rpmb_request(mmc, rpmb_frame, 1, false))
return -1;
- /* Read the result */
- return mmc_rpmb_response(mmc, rpmb_frame, expected);
- sha256_context ctx;
- int i;
- unsigned char k_ipad[SHA256_BLOCK_SIZE];
- unsigned char k_opad[SHA256_BLOCK_SIZE];
- sha256_starts(&ctx);
- /* According to RFC 4634, the HMAC transform looks like:
- for (i = 0; i < RPMB_SZ_MAC; i++) {
- /* remaining pad bytes are '\0' XOR'd with ipad and opad values */
- for ( ; i < SHA256_BLOCK_SIZE; i++) {
k_ipad[i] = 0x36;
k_opad[i] = 0x5c;
- sha256_update(&ctx, k_ipad, SHA256_BLOCK_SIZE);
- sha256_update(&ctx, buff, len);
- sha256_finish(&ctx, output);
- /* Init context for second pass */
- /* start with outer pad */
- sha256_update(&ctx, k_opad, SHA256_BLOCK_SIZE);
- /* then results of 1st hash */
- sha256_update(&ctx, output, RPMB_SZ_MAC);
- /* finish up 2nd pass */
- int ret;
- /* Fill the request */
- rpmb_frame->request = cpu_to_be16(RPMB_REQ_WCOUNTER);
return -1;
- ret = mmc_rpmb_response(mmc, rpmb_frame, RPMB_RESP_WCOUNTER);
- if (ret)
return ret;
- *pcounter = be32_to_cpu(rpmb_frame->write_counter);
- rpmb_frame->request = cpu_to_be16(RPMB_REQ_KEY);
- memcpy(rpmb_frame->mac, key, RPMB_SZ_MAC);
- if (mmc_rpmb_request(mmc, rpmb_frame, 1, true))
return -1;
- /* read the operation status */
- return mmc_rpmb_status(mmc, RPMB_RESP_KEY);
- int i;
- for (i = 0; i < cnt; i++) {
break;
break;
if (key) {
break;
/* Copy data */
- return i;
- unsigned long wcount;
- int i;
break;
/* Computes HMAC */
break;
/* Get status */
break;
- return i;
- boot partitions (2), general purpose partitions (4) in MMC v4.4.
- Start device initialization and return immediately; it does not block on
- polling OCR (operation condition register) status. Then you should call
diff --git a/lib/Makefile b/lib/Makefile index 27e4f78..377ab13 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -35,6 +35,7 @@ obj-y += net_utils.o obj-$(CONFIG_PHYSMEM) += physmem.o obj-y += qsort.o obj-$(CONFIG_SHA1) += sha1.o +obj-$(CONFIG_SUPPORT_EMMC_RPMB) += sha256.o obj-$(CONFIG_SHA256) += sha256.o obj-y += strmhz.o obj-$(CONFIG_TPM) += tpm.o -- 1.7.6.5
Looks good.
Applied
Thanks
-- Pantelis
Acked-by: Pantelis Antoniou panto@antoniou-consulting.com
V3, V4, V5: no changes
Patch added in V2
Hi Pierre,
Patch added in V2
int c;
putc('y');
c = getc();
putc('\n');
if (c == '\r')
return 1;
return 1;
if (scrub) {
if (!scrub_yes)
puts(scrub_warn);
if (scrub_yes)
puts("y");
if (getc() == '\r')
} else {
puts(scrub_warn);
else {
} else {
} ret = nand_erase_opts(nand, &opts);return 1; }
i = 0;
while (1) {
if (tstc()) {
char c;
putc(c = getc());
return 1;
puts("\n");
break;
} }return 1;
- Returns 1 if user's input is "y", "Y", "yes" or "YES"
- int i;
- char str_input[5];
- /* Flush input */
- while (tstc())
getc();
- i = 0;
- while (i < sizeof(str_input)) {
putc(str_input[i]);
break;
i++;
- putc('\n');
- if (strncmp(str_input, "y\r", 2) == 0 ||
return 1;
I guess you could convert to upper/lower case and reduce the comparisons but I'd let it pass.
Maybe follow up later with a patch just for that.
- returns previous state
- STDIO based functions (can always be used)
1.7.6.5
This is reasonable, and I've applied it to my mmc tree,
Applied,
Thanks
-- Pantelis
This sub-command adds support for the RPMB partition of an eMMC: * mmc rpmb key <address of the authentication key> Programs the authentication key in the eMMC This key can not be overwritten. * mmc rpmb read <address> <block> <#count> [address of key] Reads <#count> blocks of 256 bytes in the RPMB partition beginning at block number <block>. If the optionnal address of the authentication key is provided, the Message Authentication Code (MAC) is verified on each block. * mmc rpmb write <address> <block> <#count> <address of key> Writes <#count> blocks of 256 bytes in the RPMB partition beginning at block number <block>. The datas are signed with the key provided. * mmc rpmb counter Returns the 'Write counter' of the RPMB partition.
The sub-command is conditional on compilation flag CONFIG_SUPPORT_EMMC_RPMB
Signed-off-by: Pierre Aubert p.aubert@staubli.com CC: Pantelis Antoniou panto@antoniou-consulting.com CC: Wolfgang Denk wd@denx.de --- Changes in V5: - move changelog to the right place
V2: no changes
participants (6)
Pantelis Antoniou
Pantelis Antoniou
Pierre AUBERT
Pierre Aubert
Roman Peniaev
