[PATCH v4 0/2] Calculate SDRAM size for Actions OWL SoCs
Mani pointed out that changes in previous version were not good enough for S900 and he provide snippet that seems to work on S900.
This series v4 fixes the S900 Support by taking in changes suggested by Mani.
Realized that sent the wrong version(v2) that has typos and didn't get compile for S900. Just fixed this in v3.
This small series allows us to calculate SDRAM size instead of guessing it.
Patch (1/2) is re-worked to support S900 SoC along with S700.
These changes have been tested on S700 based Cubieboard7-lite board, and it would be great if this can be tested on S900.
Amit Singh Tomar (2): Actions: OWL: Calculate SDRAM size arm: actions: remove "CONFIG_SYS_SDRAM_SIZE" for Actions Owl Semi SoCs
arch/arm/mach-owl/soc.c | 22 +++++++++++++++++++++- include/configs/owl-common.h | 1 - 2 files changed, 21 insertions(+), 2 deletions(-)
Calculate the SDRAM size from DDR capacity register registers instead of using hard-coded value. This is quite useful to get correct size on differnt boards based on Actions OWL family of SoCs (S700 and S900).
There is no documentation available that talks about DDR registers, and this is very much taken from vendor source.
This commit lets Linux boot on Cubieboard7-lite(based on S700).
Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- Changes since v3: * Fixed S900 support as suggested by Mani. * Changes the function name to owl_get_ddrcap. Changes since v2: * Fixed the variable name so that it can compile for S900. Changes since v1: * added support for S900 * updated the commit message to reflect common OWL support. --- arch/arm/mach-owl/soc.c | 22 +++++++++++++++++++++- 1 file changed, 21 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-owl/soc.c b/arch/arm/mach-owl/soc.c index 409cbd319f20..fcf61d39b63a 100644 --- a/arch/arm/mach-owl/soc.c +++ b/arch/arm/mach-owl/soc.c @@ -13,14 +13,34 @@ #include <asm/mach-types.h> #include <asm/psci.h>
+#define DMM_INTERLEAVE_PER_CH_CFG 0xe0290028 + DECLARE_GLOBAL_DATA_PTR;
+unsigned int owl_get_ddrcap(void) +{ + unsigned int val, cap; + + /* ddr capacity register initialized by ddr driver + * in early bootloader + */ +#if defined(CONFIG_MACH_S700) + val = (readl(DMM_INTERLEAVE_PER_CH_CFG) >> 8) & 0x7; + cap = (val + 1) * 256; +#elif defined(CONFIG_MACH_S900) + val = (readl(DMM_INTERLEAVE_PER_CH_CFG) >> 8) & 0xf; + cap = 64 * (1 << val); +#endif + + return cap; +} + /* * dram_init - sets uboots idea of sdram size */ int dram_init(void) { - gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + gd->ram_size = owl_get_ddrcap() * 1024 * 1024; return 0; }
Reviewed-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org
Thanks, Mani
Changes since v3:
- Fixed S900 support as suggested by Mani.
- Changes the function name to owl_get_ddrcap.
Changes since v2:
- Fixed the variable name so that it can compile for S900.
- unsigned int val, cap;
- /* ddr capacity register initialized by ddr driver
- val = (readl(DMM_INTERLEAVE_PER_CH_CFG) >> 8) & 0x7;
- cap = (val + 1) * 256;
- val = (readl(DMM_INTERLEAVE_PER_CH_CFG) >> 8) & 0xf;
- cap = 64 * (1 << val);
- return cap;
- dram_init - sets uboots idea of sdram size
- gd->ram_size = owl_get_ddrcap() * 1024 * 1024; return 0;
-- 2.7.4
Signed-off-by: Amit Singh Tomar amittomer25@gmail.com Reviewed-by: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org
Now that, we calculate SDRAM size by reading DDR registers, "CONFIG_SYS_SDRAM_SIZE" is no more needed.
This commit removes "CONFIG_SYS_SDRAM_SIZE" from common configuration file.
Signed-off-by: Amit Singh Tomar amittomer25@gmail.com --- * No change since previous version. --- include/configs/owl-common.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/owl-common.h b/include/configs/owl-common.h index f77a5fa4c114..7634578f856d 100644 --- a/include/configs/owl-common.h +++ b/include/configs/owl-common.h @@ -12,7 +12,6 @@
/* SDRAM Definitions */ #define CONFIG_SYS_SDRAM_BASE 0x0 -#define CONFIG_SYS_SDRAM_SIZE 0x80000000
/* Generic Timer Definitions */ #define COUNTER_FREQUENCY (24000000) /* 24MHz */
Thanks, Mani
- No change since previous version.
2.7.4
Hi Tom
-- 2.7.4
Do you have a plan to take these in ?
Thanks -Amit.
On Fri, Jun 12, 2020 at 11:56:47PM +0530, Amit Tomer wrote:
Hi Tom
-- 2.7.4
Of what I call from the thread, it's OK for this to go in for v2020.07 so it's on my TODO list for -next but only part of the queue of hopefully easy to grab and use things, which isn't where I start :)
Amit Singh Tomar
Amit Tomer
