[PATCH v3 0/3] tools/sunxi: Use mkimage for SPL generation
an update addressing Samuel's review comments and fixing the broken tools-only build. ==================
So far creating a bootable SPL image for Allwinner based boards uses the mksunxiboot tool. Most other platforms seemed to have integrated this kind of functionality into the common mkimage tool.
Since there is nothing special about the Allwinner image in this respect, just add support for the so-called "eGON" image type into mkimage. If there was a particular reason this hasn't been done before, please let me know.
This will eventually allow us to remove mksunxiboot, but I leave it around for now in case of regressions and since some people depend on it from external projects.
Patch 1/3 splits some existing sunxi specific header file, so we can share the eGON header definition between the tools and the SPL. Patch 2/3 adds the actual support to mkimage, patch 3/3 then switches the Makefile to use mkimage instead of mksunxiboot.
I tested all 152 Allwinner boards by building each u-boot-sunxi-with-spl.bin and comparing them against the version created using mksunxiboot (using SOURCE_DATE_EPOCH and .scmversion to create reproducible builds, and by reverting just patch 3/3). All files before and after were identical.
Cheers, Andre
Changelog v2 .. v3: - factor out eGON struct into separate header file - only print extended header information when applicable - remove redundant alignment - minor cosmetic fixes
Changelog v1 .. v2: - Drop already merged cleanup patch (v1 1/3) - replace relative include path - remove already defined ALIGN macro - rebase against current master
Andre Przywara (3): sunxi: Factor out eGON BROM header description tools: mkimage: Add Allwinner eGON support sunxi: Use mkimage for SPL boot image generation
arch/arm/include/asm/arch-sunxi/spl.h | 65 +----------- common/image.c | 1 + include/image.h | 1 + include/sunxi_image.h | 82 ++++++++++++++++ scripts/Makefile.spl | 8 +- tools/Makefile | 1 + tools/sunxi_egon.c | 136 ++++++++++++++++++++++++++ 7 files changed, 226 insertions(+), 68 deletions(-) create mode 100644 include/sunxi_image.h create mode 100644 tools/sunxi_egon.c
To be able to easily share the Allwinner eGON BROM header structure between the tools and the SPL code, move the struct definition into a separate header file.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/include/asm/arch-sunxi/spl.h | 65 +-------------------- include/sunxi_image.h | 81 +++++++++++++++++++++++++++ 2 files changed, 82 insertions(+), 64 deletions(-) create mode 100644 include/sunxi_image.h
diff --git a/arch/arm/include/asm/arch-sunxi/spl.h b/arch/arm/include/asm/arch-sunxi/spl.h index 8c916e8c752..7b99c1aa12d 100644 --- a/arch/arm/include/asm/arch-sunxi/spl.h +++ b/arch/arm/include/asm/arch-sunxi/spl.h @@ -7,19 +7,7 @@ #ifndef _ASM_ARCH_SPL_H_ #define _ASM_ARCH_SPL_H_
-#define BOOT0_MAGIC "eGON.BT0" -#define SPL_SIGNATURE "SPL" /* marks "sunxi" SPL header */ -#define SPL_MAJOR_BITS 3 -#define SPL_MINOR_BITS 5 -#define SPL_VERSION(maj, min) \ - ((((maj) & ((1U << SPL_MAJOR_BITS) - 1)) << SPL_MINOR_BITS) | \ - ((min) & ((1U << SPL_MINOR_BITS) - 1))) - -#define SPL_HEADER_VERSION SPL_VERSION(0, 2) - -#define SPL_ENV_HEADER_VERSION SPL_VERSION(0, 1) -#define SPL_DT_HEADER_VERSION SPL_VERSION(0, 2) -#define SPL_DRAM_HEADER_VERSION SPL_VERSION(0, 3) +#include <sunxi_image.h>
#define SPL_ADDR CONFIG_SUNXI_SRAM_ADDRESS
@@ -31,57 +19,6 @@ #define SUNXI_BOOTED_FROM_MMC0_HIGH 0x10 #define SUNXI_BOOTED_FROM_MMC2_HIGH 0x12
-/* boot head definition from sun4i boot code */ -struct boot_file_head { - uint32_t b_instruction; /* one intruction jumping to real code */ - uint8_t magic[8]; /* ="eGON.BT0" or "eGON.BT1", not C-style str */ - uint32_t check_sum; /* generated by PC */ - uint32_t length; /* generated by PC */ - /* - * We use a simplified header, only filling in what is needed - * by the boot ROM. To be compatible with Allwinner tools we - * would need to implement the proper fields here instead of - * padding. - * - * Actually we want the ability to recognize our "sunxi" variant - * of the SPL. To do so, let's place a special signature into the - * "pub_head_size" field. We can reasonably expect Allwinner's - * boot0 to always have the upper 16 bits of this set to 0 (after - * all the value shouldn't be larger than the limit imposed by - * SRAM size). - * If the signature is present (at 0x14), then we know it's safe - * to use the remaining 8 bytes (at 0x18) for our own purposes. - * (E.g. sunxi-tools "fel" utility can pass information there.) - */ - union { - uint32_t pub_head_size; - uint8_t spl_signature[4]; - }; - uint32_t fel_script_address; /* since v0.1, set by sunxi-fel */ - /* - * If the fel_uEnv_length member below is set to a non-zero value, - * it specifies the size (byte count) of data at fel_script_address. - * At the same time this indicates that the data is in uEnv.txt - * compatible format, ready to be imported via "env import -t". - */ - uint32_t fel_uEnv_length; /* since v0.1, set by sunxi-fel */ - /* - * Offset of an ASCIIZ string (relative to the SPL header), which - * contains the default device tree name (CONFIG_DEFAULT_DEVICE_TREE). - * This is optional and may be set to NULL. Is intended to be used - * by flash programming tools for providing nice informative messages - * to the users. - */ - uint32_t dt_name_offset; /* since v0.2, set by mksunxiboot */ - uint32_t dram_size; /* in MiB, since v0.3, set by SPL */ - uint32_t boot_media; /* written here by the boot ROM */ - /* A padding area (may be used for storing text strings) */ - uint32_t string_pool[13]; /* since v0.2, filled by mksunxiboot */ - /* The header must be a multiple of 32 bytes (for VBAR alignment) */ -}; - -/* Compile time check to assure proper alignment of structure */ -typedef char boot_file_head_not_multiple_of_32[1 - 2*(sizeof(struct boot_file_head) % 32)];
#define is_boot0_magic(addr) (memcmp((void *)addr, BOOT0_MAGIC, 8) == 0)
diff --git a/include/sunxi_image.h b/include/sunxi_image.h new file mode 100644 index 00000000000..d0d1290eb72 --- /dev/null +++ b/include/sunxi_image.h @@ -0,0 +1,81 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2007-2011 + * Allwinner Technology Co., Ltd. <www.allwinnertech.com> + * Tom Cubie tangliang@allwinnertech.com + * + * Constants and data structures used in Allwinner "eGON" images, as + * parsed by the Boot-ROM. + * + * Shared between mkimage and the SPL. + */ +#ifndef SUNXI_IMAGE_H +#define SUNXI_IMAGE_H + +#define BOOT0_MAGIC "eGON.BT0" +#define SPL_SIGNATURE "SPL" /* marks "sunxi" SPL header */ +#define SPL_MAJOR_BITS 3 +#define SPL_MINOR_BITS 5 +#define SPL_VERSION(maj, min) \ + ((((maj) & ((1U << SPL_MAJOR_BITS) - 1)) << SPL_MINOR_BITS) | \ + ((min) & ((1U << SPL_MINOR_BITS) - 1))) + +#define SPL_HEADER_VERSION SPL_VERSION(0, 2) + +#define SPL_ENV_HEADER_VERSION SPL_VERSION(0, 1) +#define SPL_DT_HEADER_VERSION SPL_VERSION(0, 2) +#define SPL_DRAM_HEADER_VERSION SPL_VERSION(0, 3) + +/* boot head definition from sun4i boot code */ +struct boot_file_head { + uint32_t b_instruction; /* one intruction jumping to real code */ + uint8_t magic[8]; /* ="eGON.BT0" or "eGON.BT1", not C-style str */ + uint32_t check_sum; /* generated by PC */ + uint32_t length; /* generated by PC */ + /* + * We use a simplified header, only filling in what is needed + * by the boot ROM. To be compatible with Allwinner tools we + * would need to implement the proper fields here instead of + * padding. + * + * Actually we want the ability to recognize our "sunxi" variant + * of the SPL. To do so, let's place a special signature into the + * "pub_head_size" field. We can reasonably expect Allwinner's + * boot0 to always have the upper 16 bits of this set to 0 (after + * all the value shouldn't be larger than the limit imposed by + * SRAM size). + * If the signature is present (at 0x14), then we know it's safe + * to use the remaining 8 bytes (at 0x18) for our own purposes. + * (E.g. sunxi-tools "fel" utility can pass information there.) + */ + union { + uint32_t pub_head_size; + uint8_t spl_signature[4]; + }; + uint32_t fel_script_address; /* since v0.1, set by sunxi-fel */ + /* + * If the fel_uEnv_length member below is set to a non-zero value, + * it specifies the size (byte count) of data at fel_script_address. + * At the same time this indicates that the data is in uEnv.txt + * compatible format, ready to be imported via "env import -t". + */ + uint32_t fel_uEnv_length; /* since v0.1, set by sunxi-fel */ + /* + * Offset of an ASCIIZ string (relative to the SPL header), which + * contains the default device tree name (CONFIG_DEFAULT_DEVICE_TREE). + * This is optional and may be set to NULL. Is intended to be used + * by flash programming tools for providing nice informative messages + * to the users. + */ + uint32_t dt_name_offset; /* since v0.2, set by mksunxiboot */ + uint32_t dram_size; /* in MiB, since v0.3, set by SPL */ + uint32_t boot_media; /* written here by the boot ROM */ + /* A padding area (may be used for storing text strings) */ + uint32_t string_pool[13]; /* since v0.2, filled by mksunxiboot */ + /* The header must be a multiple of 32 bytes (for VBAR alignment) */ +}; + +/* Compile time check to assure proper alignment of structure */ +typedef char boot_file_head_not_multiple_of_32[1 - 2*(sizeof(struct boot_file_head) % 32)]; + +#endif
So far we used the separate mksunxiboot tool for generating a bootable image for Allwinner SPLs, probably just for historical reasons.
Use the mkimage framework to generate a so called eGON image the Allwinner BROM expects. The new image type is called "sunxi_egon", to differentiate it from the (still to be implemented) secure boot TOC0 image.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- common/image.c | 1 + include/image.h | 1 + include/sunxi_image.h | 1 + tools/Makefile | 1 + tools/sunxi_egon.c | 136 ++++++++++++++++++++++++++++++++++++++++++ 5 files changed, 140 insertions(+) create mode 100644 tools/sunxi_egon.c
diff --git a/common/image.c b/common/image.c index 451fc689a89..6923dac7c07 100644 --- a/common/image.c +++ b/common/image.c @@ -189,6 +189,7 @@ static const table_entry_t uimage_type[] = { { IH_TYPE_STM32IMAGE, "stm32image", "STMicroelectronics STM32 Image" }, { IH_TYPE_MTKIMAGE, "mtk_image", "MediaTek BootROM loadable Image" }, { IH_TYPE_COPRO, "copro", "Coprocessor Image"}, + { IH_TYPE_SUNXI_EGON, "sunxi_egon", "Allwinner eGON Boot Image" }, { -1, "", "", }, };
diff --git a/include/image.h b/include/image.h index 00bc03bebec..89bfca2155a 100644 --- a/include/image.h +++ b/include/image.h @@ -308,6 +308,7 @@ enum { IH_TYPE_IMX8MIMAGE, /* Freescale IMX8MBoot Image */ IH_TYPE_IMX8IMAGE, /* Freescale IMX8Boot Image */ IH_TYPE_COPRO, /* Coprocessor Image for remoteproc*/ + IH_TYPE_SUNXI_EGON, /* Allwinner eGON Boot Image */
IH_TYPE_COUNT, /* Number of image types */ }; diff --git a/include/sunxi_image.h b/include/sunxi_image.h index d0d1290eb72..5b2055c0af3 100644 --- a/include/sunxi_image.h +++ b/include/sunxi_image.h @@ -13,6 +13,7 @@ #define SUNXI_IMAGE_H
#define BOOT0_MAGIC "eGON.BT0" +#define BROM_STAMP_VALUE 0x5f0a6c39 #define SPL_SIGNATURE "SPL" /* marks "sunxi" SPL header */ #define SPL_MAJOR_BITS 3 #define SPL_MINOR_BITS 5 diff --git a/tools/Makefile b/tools/Makefile index 51123fd9298..2c9a0c4c4e7 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -104,6 +104,7 @@ dumpimage-mkimage-objs := aisimage.o \ stm32image.o \ $(ROCKCHIP_OBS) \ socfpgaimage.o \ + sunxi_egon.o \ lib/crc16.o \ lib/sha1.o \ lib/sha256.o \ diff --git a/tools/sunxi_egon.c b/tools/sunxi_egon.c new file mode 100644 index 00000000000..8987794518a --- /dev/null +++ b/tools/sunxi_egon.c @@ -0,0 +1,136 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018 Arm Ltd. + */ + +#include "imagetool.h" +#include <image.h> + +#include <sunxi_image.h> + +/* + * NAND requires 8K padding. SD/eMMC gets away with 512 bytes, + * but let's use the larger padding to cover both. + */ +#define PAD_SIZE 8192 + +static int egon_check_params(struct image_tool_params *params) +{ + /* We just need a binary image file. */ + return !params->dflag; +} + +static int egon_verify_header(unsigned char *ptr, int image_size, + struct image_tool_params *params) +{ + const struct boot_file_head *header = (void *)ptr; + uint32_t length; + + /* First 4 bytes must be an ARM branch instruction. */ + if ((le32_to_cpu(header->b_instruction) & 0xff000000) != 0xea000000) + return EXIT_FAILURE; + + if (memcmp(header->magic, BOOT0_MAGIC, sizeof(header->magic))) + return EXIT_FAILURE; + + length = le32_to_cpu(header->length); + /* Must be at least 512 byte aligned. */ + if (length & 511) + return EXIT_FAILURE; + + /* + * Image could also contain U-Boot proper, so could be bigger. + * But it must not be shorter. + */ + if (image_size < length) + return EXIT_FAILURE; + + return EXIT_SUCCESS; +} + +static void egon_print_header(const void *buf) +{ + const struct boot_file_head *header = buf; + + printf("Allwinner eGON image, size: %d bytes\n", + le32_to_cpu(header->length)); + + if (memcmp(header->spl_signature, SPL_SIGNATURE, 3)) + return; + + printf("\tSPL header version %d.%d\n", + header->spl_signature[3] >> SPL_MINOR_BITS, + header->spl_signature[3] & ((1U << SPL_MINOR_BITS) - 1)); + if (header->spl_signature[3] >= SPL_DT_HEADER_VERSION) { + uint32_t dt_name_offs = le32_to_cpu(header->dt_name_offset); + + if (dt_name_offs > 0) + printf("\tDT name: %s\n", (char *)buf + dt_name_offs); + } +} + +static void egon_set_header(void *buf, struct stat *sbuf, int infd, + struct image_tool_params *params) +{ + struct boot_file_head *header = buf; + uint32_t *buf32 = buf; + uint32_t checksum = 0, value; + int i; + + /* Generate an ARM branch instruction to jump over the header. */ + value = 0xea000000 | (sizeof(struct boot_file_head) / 4 - 2); + header->b_instruction = cpu_to_le32(value); + + memcpy(header->magic, BOOT0_MAGIC, sizeof(header->magic)); + header->check_sum = cpu_to_le32(BROM_STAMP_VALUE); + header->length = cpu_to_le32(params->file_size); + + memcpy(header->spl_signature, SPL_SIGNATURE, 3); + + /* If an image name has been provided, use it as the DT name. */ + if (params->imagename && params->imagename[0]) { + header->spl_signature[3] = SPL_DT_HEADER_VERSION; + + value = offsetof(struct boot_file_head, string_pool); + header->dt_name_offset = cpu_to_le32(value); + + strncpy((char *)header->string_pool, params->imagename, 52); + /* Make sure we have a terminating zero byte. */ + ((char *)header->string_pool)[51] = 0; + } else + header->spl_signature[3] = SPL_ENV_HEADER_VERSION; + + /* Calculate the checksum. Yes, it's that simple. */ + for (i = 0; i < sbuf->st_size / 4; i++) + checksum += le32_to_cpu(buf32[i]); + header->check_sum = cpu_to_le32(checksum); +} + +static int egon_check_image_type(uint8_t type) +{ + return type == IH_TYPE_SUNXI_EGON ? 0 : 1; +} + +static int egon_vrec_header(struct image_tool_params *params, + struct image_type_params *tparams) +{ + tparams->hdr = calloc(sizeof(struct boot_file_head), 1); + + /* Return padding to 8K blocks. */ + return ALIGN(params->file_size, PAD_SIZE) - params->file_size; +} + +U_BOOT_IMAGE_TYPE( + sunxi_egon, + "Allwinner eGON Boot Image support", + sizeof(struct boot_file_head), + NULL, + egon_check_params, + egon_verify_header, + egon_print_header, + egon_set_header, + NULL, + egon_check_image_type, + NULL, + egon_vrec_header +);
- { IH_TYPE_SUNXI_EGON, "sunxi_egon", "Allwinner eGON Boot Image" }, { -1, "", "", },
- (C) Copyright 2018 Arm Ltd.
- NAND requires 8K padding. SD/eMMC gets away with 512 bytes,
- but let's use the larger padding to cover both.
- /* We just need a binary image file. */
- return !params->dflag;
- const struct boot_file_head *header = (void *)ptr;
- uint32_t length;
- /* First 4 bytes must be an ARM branch instruction. */
- if ((le32_to_cpu(header->b_instruction) & 0xff000000) != 0xea000000)
- if (memcmp(header->magic, BOOT0_MAGIC, sizeof(header->magic)))
- length = le32_to_cpu(header->length);
- /* Must be at least 512 byte aligned. */
- if (length & 511)
- if (image_size < length)
- return EXIT_SUCCESS;
- const struct boot_file_head *header = buf;
- printf("Allwinner eGON image, size: %d bytes\n",
- if (memcmp(header->spl_signature, SPL_SIGNATURE, 3))
return;
- printf("\tSPL header version %d.%d\n",
- if (header->spl_signature[3] >= SPL_DT_HEADER_VERSION) {
- struct boot_file_head *header = buf;
- uint32_t *buf32 = buf;
- uint32_t checksum = 0, value;
- int i;
- /* Generate an ARM branch instruction to jump over the header. */
- value = 0xea000000 | (sizeof(struct boot_file_head) / 4 - 2);
- header->b_instruction = cpu_to_le32(value);
- memcpy(header->magic, BOOT0_MAGIC, sizeof(header->magic));
- header->check_sum = cpu_to_le32(BROM_STAMP_VALUE);
- header->length = cpu_to_le32(params->file_size);
- memcpy(header->spl_signature, SPL_SIGNATURE, 3);
- /* If an image name has been provided, use it as the DT name. */
- if (params->imagename && params->imagename[0]) {
I get:
tools/sunxi_egon.c: In function 'egon_set_header': tools/sunxi_egon.c:97:3: warning: 'strncpy' specified bound 52 equals destination size [-Wstringop-truncation] 97 | strncpy((char *)header->string_pool, params->imagename, 52); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
- } else
- /* Calculate the checksum. Yes, it's that simple. */
- for (i = 0; i < sbuf->st_size / 4; i++)
- header->check_sum = cpu_to_le32(checksum);
- return type == IH_TYPE_SUNXI_EGON ? 0 : 1;
- tparams->hdr = calloc(sizeof(struct boot_file_head), 1);
- /* Return padding to 8K blocks. */
- return ALIGN(params->file_size, PAD_SIZE) - params->file_size;
+U_BOOT_IMAGE_TYPE(
- sunxi_egon,
- "Allwinner eGON Boot Image support",
- sizeof(struct boot_file_head),
- NULL,
- egon_check_params,
- egon_verify_header,
- egon_print_header,
- egon_set_header,
- NULL,
- egon_check_image_type,
- NULL,
- egon_vrec_header
Switch the SPL boot image generation from using mksunxiboot to the new sunxi_egon format of mkimage.
Verified to create identical results for all 152 Allwinner boards.
Signed-off-by: Andre Przywara andre.przywara@arm.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jagan Teki jagan@amarulasolutions.com --- scripts/Makefile.spl | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 9f1f7445d71..db95bd998a8 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -382,11 +382,11 @@ endif $(obj)/$(SPL_BIN).sfp: $(obj)/$(SPL_BIN).bin FORCE $(call if_changed,mkimage)
-quiet_cmd_mksunxiboot = MKSUNXI $@ -cmd_mksunxiboot = $(objtree)/tools/mksunxiboot \ - --default-dt $(CONFIG_DEFAULT_DEVICE_TREE) $< $@ +MKIMAGEFLAGS_sunxi-spl.bin = -T sunxi_egon \ + -n $(CONFIG_DEFAULT_DEVICE_TREE) + $(obj)/sunxi-spl.bin: $(obj)/$(SPL_BIN).bin FORCE - $(call if_changed,mksunxiboot) + $(call if_changed,mkimage)
quiet_cmd_sunxi_spl_image_builder = SUNXI_SPL_IMAGE_BUILDER $@ cmd_sunxi_spl_image_builder = $(objtree)/tools/sunxi-spl-image-builder \
For the series:
Reviewed-by: Samuel Holland samuel@sholland.org Tested-by: Samuel Holland samuel@sholland.org
Andre Przywara
Samuel Holland
